2009-07-18at91cap9adk: fix #ifdef/#endif pairingWolfgang Denk
The #ifdef/#endif pairing in this file was obviously messed up. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18pcm030: fix out-of-tree buildingWolfgang Denk
Commit c9969947, which added support for the pcm030 board (aka phyCORE-MPC5200B-tiny), broke out-of-tree building. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18MPC837XERDB: fix warning: "CONFIG_SYS_MONITOR_LEN" redefinedWolfgang Denk
2009-07-188xxx: fix warning: implicit declaration of function 'uec_standard_init'Wolfgang Denk
Commit 8e55258f created function uec_standard_init() to initialize all UEC interfaces for 83xx and 85xx but failed to provide a prototype for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18MIP405T: fix compile problemWolfgang Denk
The "stdio/device: rework function naming convention" patch (commit 52cb4d4f) broke the MIP405T board; this patch fixes it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18NAND: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18CPCI750: fix compile problemWolfgang Denk
Commit bc0d3296 removed ppc_error_no.h from Marvell boards but forgot to update board/esd/cpci750/mv_eth.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-18Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2009-07-18Merge branch 'master' of git://git.denx.de/u-boot-i2cWolfgang Denk
2009-07-18cmd_i2c: bugfix: add missing braceAlessandro Rubini
The sub-command parser missed a brace, so "return 0;" is always taken and no error message is diplayed if you say "i2c scan" instead of "i2c probe", for example. Proper brace is added. Also, a misleading and unneeded else is removed. Signed-off-by: Alessandro Rubini <rubini@gnudd.com.it>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-17ppc: Fix compile error for boards with CONFIG_DDR_ECCPeter Tyser
A bug was introduced by commit e94e460c6e8741f42dab6d8dd4b596ba5d9d79ae which affected non-MPC83xx/85xx/86xx ppc boards which had CONFIG_DDR_ECC defined and resulted in errors such as: Configuring for canyonlands board... fsl_dma.c:50:2: error: #error "Freescale DMA engine not supported on your processor" make[1]: *** No rule to make target `.depend', needed by `libdma.a'. Stop. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-17include/config_cmd_default.h cleanupPrafulla Wadaskar
arranged configurations in alphabetical order CONFIG_CMD_FLASH moved under ifndef CONFIG_SYS_NO_FLASH Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2009-07-17Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2009-07-17Merge branch 'master' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-07-17sata: namespace curr_device variableMike Frysinger
The curr_device variable really should be namespaced with a "sata_" prefix since it is only used by the sata code. It also avoids random conflicts with other pieces of code (like cmd_mmc): common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17cmd_mmc: make curr_device staticMike Frysinger
The curr_device variable isn't used outside of cmd_mmc, so mark it static to avoid conflicts with other pieces of code (like sata which also exports a curr_device). Otherwise we end up with stuff like: common/libcommon.a(cmd_sata.o):(.data.curr_device+0x0): multiple definition of `curr_device' common/libcommon.a(cmd_mmc.o):(.data.curr_device+0x0): first defined here Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17envcrc: add missing dependencies on env storageMike Frysinger
When the envcrc building was made conditional, it missed a bunch of env storage types, so add all currently supported types. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17config.mk: Remove $(PCI_CLOCK) referenceShinya Kuribayashi
The following commit introduced $(PCI_CLOCK) reference so that we could tweak `PCI_66M' definition via an environment variable. > commit f046ccd15c8bc9613bfd72916b761a127d36e5c6 > Author: Eran Liberty <liberty@freescale.com> > Date: Thu Jul 28 10:08:46 2005 -0500 > > * Patch by Eran Liberty > Add support for the Freescale MPC8349ADS board. But I suggest a removal of it for the following reasons: * In 2006, MPC8349ADS was merged into MPC8349EMDS port, and it seems that MPC8349EMDS port is PCI_66M free. * OTOH, PCI_66M is used by MPC832XEMDS an MPC8360EMDS ports, but they don't need $(PCI_CLOCK) environment variable at all. PCI_66M is automatically configured via $(BOARD)_config names with the help of $(findstring _66_,$@). * Unfortunately $(PCI_CLOCK) has been undocumented anywhere, so only a few people know the existence of it these days. * Keep config.mk independent from $(BOARD) as much as possible. Signed-off-by: Shinya Kuribayashi <skuribay@pobox.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-17fix: missing autoconfig.mk from general MakefileJean-Christophe PLAGNIOL-VILLARD
At the first run of make we generate the autoconf.mk and autoconf.mk.dep if not already the case and we currently include only to .dep In order to use these autogenerated values we need to include it also even if it's included in config.mk but it's done before their generation Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-17Added support for splash screen positioningMatthias Weisser
This patch adds support splash image positioning by adding an additional variable "splashpos" to the environment. Please see README for details. Signed-off-by: Matthias Weisser <matthias.weisser@graf-syteco.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2009-07-17video: mb862xx: replace printf with putsAnatolij Gustschin
2009-07-17video: mb862xx: use macros instead of magic numbersAnatolij Gustschin
2009-07-17video: mb862xx: fix coding style and remove dead codeAnatolij Gustschin
2009-07-17microblaze: Remove ignored return type for __arch__swab16 functionMichal Simek
This change remove compilation warnings. Signed-off-by: Michal Simek <monstr@monstr.eu>
2009-07-17microblaze: Removed unused variablesMichal Simek
2009-07-16mpc83xx: MPC837xEMDS: Use hwconfig instead of pci_external_arbiter variableAnton Vorontsov
Since we have simple hwconfig interface now, we don't need pci_external_arbiter variable any longer. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC8315ERDB: Use hwconfig for board type selectionAnton Vorontsov
This patch simply converts the board to the hwconfig infrastructure. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC837XEMDS: Fixup eSDHC nodes in device treeAnton Vorontsov
fdt_fixup_esdhc() will either disable or enable eSDHC nodes, and also will fixup clock-frequency property. Plus, since DR USB and eSDHC are mutually exclusive, we should only configure the eSDHC if asked through hwconfig. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16mpc83xx: MPC837XERDB: Add support for FSL eSDHCAnton Vorontsov
This patch adds support for eSDHC on MPC837XERDB boards. The WP switch doesn't seem to work on RDB boards though, the WP pin is always asserted (can see the pin state when it's in GPIO mode). FSL DR USB and FSL eSDHC are mutually exclusive because of pins multiplexing, so user should specify 'esdhc' or 'dr_usb' options in the hwconfig environment variable to choose between the devices. p.s. Now we're very close to a monitor len limit (196 bytes left using gcc-4.2.0), so also increase the monitor len by one sector (64 KB). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16fsl_esdhc: Add device tree fixupsAnton Vorontsov
This patch implements fdt_fixup_esdhc() function that is used to fixup the device tree. The function adds status = "disabled" propery if esdhc pins muxed away, otherwise it fixups clock-frequency for esdhc nodes. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16Add simple hwconfig infrastructureAnton Vorontsov
This patch implements simple hwconfig infrastructure: an interface for software knobs to control a hardware. This is very simple implementation, i.e. it is implemented via `hwconfig' environment variable. Later we could write some "hwconfig <enable|disable|list>" commands, ncurses interface for Award BIOS-like interface, and frame-buffer interface for AMI GUI[1] BIOS-like interface with mouse support[2]. Current implementation details/limitations: 1. Doesn't support options dependencies and mutual exclusion. We can implement this by integrating apt-get[3] into the u-boot. But I didn't bother yet. 2. Since we don't implement hwconfig command, i.e. we're working with the environement directly, there is no way to tell that toggling a particular option will need a reboot to take an effect. So, for now it's advised to always reboot the target after modifying hwconfig variable. 3. We support hwconfig options with arguments. For example, set hwconfig dr_usb:mode=peripheral,phy_type=ulpi That means: - dr_usb - enable Dual-Role USB controller; - dr_usb:mode=peripheral - USB in Function mode; - dr_usb:phy_type=ulpi - USB should work with ULPI PHYs; The purpose of this simple implementation is to define some internal API and then we can continue improving user experience by adding more mature interface, like hwconfig command with bells and whistles. Or not adding, if we feel that current interface fits its needs. [1] http://en.wikipedia.org/wiki/American_Megatrends [2] Regarding ncurses and GUI with mouse support -- I'm just kidding. [3] The comment regarding apt-get is also a joke, meaning that dependency tracking could be non-trivial. For example, for enabling HW feature X we may need to disable Y, and turn Z into reduced mode (like RMII-only interface for ethernet, no MII). It's quite trivial to implement simple cases though. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-16Merge branch 'master' of git://git.denx.de/u-boot-cfi-flashWolfgang Denk
2009-07-16Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-07-16Merge branch 'asm-generic' of git://git.denx.de/u-boot-microblazeWolfgang Denk
2009-07-16Improve U-Boot Porting Guide in the READMEJerry Van Baren
Update for... * BDI2000 -> BDI3000 (BDI2000 is obsolete). * Add a line to read the doc/README.* files * Fix coding standard violations Signed-off-by: Gerald Van Baren <vanbaren@cideas.com>
2009-07-16mtd: cfi - if defined, use MAX_FLASH_BANKS_DETECT for static declarationsKim Phillips
a.k.a cfi_mtd.c does as cfi_flash.c does. This also prevents the TQM834x build from doing a: cfi_mtd.c:36: error: variably modified 'cfi_mtd_info' at file scope cfi_mtd.c:37: error: variably modified 'cfi_mtd_names' at file scope using gcc 4.4. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-14mpc83xx: increase MONITOR_LEN to offset growing painsKim Phillips
Saving the environment leads to overwriting u-boot itself, bricking boards. Increase u-boot's image size so the environment base address doesn't end up overlapping u-boot text. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-14usb: mpx8349itx: added support of loading images from USB storage (MPH/DR)Valeriy Glushkov
Signed-off-by: Valeriy Glushkov <gvv@lstec.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-14usb: mpc834x: added support of the MPH USB controller in addition to the DR oneValeriy Glushkov
2009-07-14mpc83xx: set 64BIT_VSPRINTF for boards using nand_utilKim Phillips
When enabling NAND support for a board, one must also define CONFIG_SYS_64BIT_VSPRINTF because this is needed in nand_util.c for correct output. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Ron Madrid <ron_madrid@sbcglobal.net> Cc: Anton Vorontsov <avorontsov@ru.mvista.com>
2009-07-14mpc5121ads: add JFFS2 and MTDPARTS support; adjust flash mapWolfgang Denk
2009-07-14aria: add JFFS2 and MTDPARTS support; adjust flash mapWolfgang Denk
2009-07-14aria: enable NAND flash supportWolfgang Denk
2009-07-14MPC512x: fix typo in comment listing the NAND driver nameWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14mecp5123: cleanup - remove dead codeWolfgang Denk
Remove dead code that was obviously a left-over from copy & paste. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14aria: adjust memory controller initializationWolfgang Denk
Needed for Rev. 2 silicon at 400 MHz Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-14MPC512x: factor out common codeWolfgang Denk
Now that we have 3 boards for the MPC512x it turns out that they all use the very same fixed_sdram() code. This patch factors out this common code into cpu/mpc512x/fixed_sdram.c and adds a new header file, include/asm-ppc/mpc512x.h, with some macros, inline functions and prototype definitions specific to MPC512x systems. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14mecp5123: fix build errorWolfgang Denk
The mecp5123 board did not compile because the MSCAN Clock Control Registers were missing; these got added, but as an array instead of 4 individual registers. Adapt the code so it builds. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com>
2009-07-14MPC512x: Add MSCAN1...4 Clock Control RegistersWolfgang Denk
