Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
backport commit 0c7c6fb7641646c45630235ea906200981f4fe80:
i.MX6ULL has different speed grades than i.MX6UL.
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Clean up the print info, so that the reset cause print can display in
a new line.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit f84b9d512f92b66076357820b1003a1006ff619d)
Fix incorrect value for 696MHz CPU frequency on i.MX6UL.
(cherry picked from commit 0b70df1d0e888d046cec4bd030c78eb746270ec0)
With commit 84d46e7e8948 ("tools: env: allow to print U-Boot version")
the fw_env utilities need the version.h header file. Building only
the envtools in a pristine build directory will fail due to missing
header files.
Make sure the header files are a dependency of the envtools target.
Fixes: 84d46e7e8948 ("tools: env: allow to print U-Boot version")
The fw_env utility family has a default environment compiled in
which ties it quite strongly to the U-Boot source/config it has
been built with. Allow to display the U-Boot version it has been
built with using the -v/--version argument.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
(cherry picked from commit 84d46e7e8948780d7ca20c24dfc7b653b900f728)
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Rename IXORA_FAN_GPIO to FAN_EN as per schematics.
With the Colibri iMX6ULL there is a second user of the bch algorithms
to encode the FCB.
Use the more universal CONFIG_CMD_WRITEBCB_MX7 to decide if the
modifications are needed.
Remove m4boot options not available on i.MX 6ULL.
Cleanup U-Boot environment settings.
This undefs CONFIG_ISO_PARTITION.
This removes NAND torture no longer needed after bringup.
Cleanup whitespace and unify order with colibri_imx7.h.
No functional change intended.
Remove/change two NAND releated configs. They are not used in the GPMI
driver and likely confuse readers.
Use the correct compatible string for the i.MX6ULL GPMI device
tree node to make sure MTD partition passing to the Linux kernel
works.
Some NAND chips do not provide a ONFI or JEDEC parameter page.
In this case the driver should fallback to a sensible default.
The kernel uses legacy_set_geometry to set a default geometry
in this case. U-Boot does support the legacy BCH geometry too,
but errors out if no ONFI/JEDEC parameter page is available.
Synchronize behavior with Linux where we automatically fall
back to legacy BCH geometry if no information from ONFI/JEDEC
parameter page are available. Assume default chunk/step size
of 512 like the Linux kernel is doing.
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
Just like the following commit for distro boot also use the 2nd instance
for legacy sdboot:
colibri_imx7_emmc: distro boot from external SD card
93ef92091832128259ab342a314d0f3e844bb331
Finish the work started by the following commit:
apalis/colibri: fix and synchronize mount options
6ed47e0f143df1c80426edb3b705c87c443c27f7
Currently distro boot is only used for external media. Use mmc 1
which is the external SD card when booting using distro boot.
Store U-Boot environment in eMMC, before config block at the end of 1st
"boot sector".
Use proper emmc specific device tree and boot from eMMC by default
rather than from NAND aka ubi.
Clean-up config header file. Re-order boot commands.
The kernel does not know about rw,noatime. The string rw by itself
is valid, and to pass additional arguments rootflags=noatime can
be used. The kernel mounts ext3/ext4 file systems by default ro,
hence so far the kernel mounted the rootfs read-only. The init
manager systemd then remounts the rootfs after file system checking.
This makes sense and does not add measureable boot time. Let the
kernel explicitly mount ro on block device based rootfs.
The root mount flag noatime is only relevant when re-mounting
read-write, hence it needs to be present in /etc/fstab.
UBIFS used on raw NAND devices has no user space file checking,
hence there is no value to mount it in read-only first. Also mount
time for UBIFS is larger, and mounting first read-only and then
read-write has higher boot time (300ms, likely due to missing block
cache). Let the kernel explicitly mount rw on raw NAND based rootfs.
UBIFS has no atime support, hence no root mount flags needed.
This makes sure that all Colibri iMX7 modules work with the
same timing. The changes are:
- Disable ODT on read (JEDEC standard JESD79-3F says in chapter
5.2.3 ODT during Reads: "As the DDR3 SDRAM can not terminate
and drive at the same time, RTT must be disabled at least half
a clock cycle..." and also MX7D SABRESD is disabling it)
This alone fixed memory issues for two Colibri iMX7 1GB modules
which showed issues before
- Make sure tRFC(min) is at least 260ns
- Make sure tRC is >50.625ns
- tRP needs to be >13.125ns, we can lower from 18.75ns to 15ns
- tFAW is not relevant, leave at reset
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
The ISO partition support is mainly useful for CD drives which
are not really common in embedded space and in general anymore.
Removing ISO partition support saves 1.5kB and gets rid of the
somewhat confusing message when no partition table is present:
** First descriptor is NOT a primary desc on 0:1 **
When using ISO partitions with a DMA enabled block device driver
reading the ISO partition leads to unaligned DMA operations:
CACHE: Misaligned operation at range [bffb7da8, bffb85a8]
Align the buffer to make sure we pass a buffer which works for
DMA operations.
Setup all UARTs in DTE mode, so that when Linux does the pinmuxing
the data direction is already correct and no two outputs are working
against each other.
Make sure that with the switch also the UARTs' RI and DCD interrupts
are masked.
The resulting U-Boot boots at least from serial downloader mode.
On i.MX6ULL, according to the latest REFTOP_TRIM fuse define, we need
to set the REFTOP_VBGADJ bits in PMU_MISC0 register as below table:
'000" - set REFTOP_VBGADJ[2:0] to 3'b000
'001" - set REFTOP_VBGADJ[2:0] to 3'b001
'010" - set REFTOP_VBGADJ[2:0] to 3'b010
'011" - set REFTOP_VBGADJ[2:0] to 3'b011
'100" - set REFTOP_VBGADJ[2:0] to 3'b100
'101" - set REFTOP_VBGADJ[2:0] to 3'b101
'110" - set REFTOP_VBGADJ[2:0] to 3'b110
'111" - set REFTOP_VBGADJ[2:0] to 3'b111
Signed-off-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit b2690f5cf54390999acb2f1f7b788bfd18fa11be)
(cherry picked from commit 30ce7adebd443ef777e820c4a891cbb3b28ac671)
Per to design team, we need to set REFTOP_VBGADJ
in PMU MISC0 according to the REFTOP_TRIM[2:0] fuse. the
actually table is as below:
'000' - set REFTOP_VBGADJ[2:0] to 3b'110
'110' - set REFTOP_VBGADJ[2:0] to 3b'000
'001' - set REFTOP_VBGADJ[2:0] to 3b'001
'010' - set REFTOP_VBGADJ[2:0] to 3b'010
'011' - set REFTOP_VBGADJ[2:0] to 3b'011
'100' - set REFTOP_VBGADJ[2:0] to 3b'100
'101' - set REFTOP_VBGADJ[2:0] to 3b'101
'111' - set REFTOP_VBGADJ[2:0] to 3b'111
(cherry picked from commit 911fcf93bad8c0a595c350b92f107b626029559b)
arch/arm/cpu/armv7/mx6/soc.c
Not all of the following commit from the nxp vendor tree made
it into 2016.11.
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/commit/?h=imx_v2016.03_4.1.15_2.0.0_ga&id=05922b0abf848949df778c19312cb1cf7fdfbe6a
commit 05922b0abf848949df778c19312cb1cf7fdfbe6a
Author: Peng Fan <peng.fan@nxp.com>
Date: Mon May 9 17:31:34 2016 +0800
MLK-12767 imx6ull: fix runtime checking for i.MX6ULL
Fix runtime checking for i.MX6ULL. Add is_cpu_type(MXC_CPU_MX6ULL)
to avoid using wrong code path.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
The MIB RAM and FIFO receive start register does not exist on
i.MX6ULL. Accessing these register will cause enet not work well or
cause system report fault.
Reported-by: Bai Ping <ping.bai@nxp.com>
(cherry picked from commit 5fb09cab9bb3cc4cef02239299d02cec666396ab)
drivers/net/fec_mxc.c
Add i.MX6UL support in setup_gpmi_io_clk and change
mx6ul_14x14_evk to use it.
(cherry picked from commit f39d809ef99c3727e17285c52df9cd01020bee65)
board/freescale/mx6ul_14x14_evk/mx6ul_14x14_evk.c
For Some USB mass storage devices, such as:
- Kingston DataTraveler 2.0 001D7D06CF09B04199C7B3EA
- Class: (from Interface) Mass Storage
- PacketSize: 64 Configurations: 1
- Vendor: 0x0930 Product 0x6545 Version 1.16
When `usb read 0x80000000 0 0x2000`, we met
"EHCI timed out on TD - token=0x80008d80".
The devices does not support scsi VPD page, we are not able
to get the maximum transfer length for READ(10)/WRITE(10).
So we limit this to 256 blocks as READ(6).
(cherry picked from commit df0052575b2bc9d66ae73584768e1a457ed5d914)
CONFIG_SYS_NAND_MX7_GPMI_62_ECC_BYTES is no longer used in code.
Remove it.
The nand torture command is a potentially destructive command used
for board bring up and qualification. Do not deploy it regularly.
PXE boot is broken with GCC 7.1 due option '-fstore-merging' enabled
by default for '-O2':
BOOTP broadcast 1
data abort
pc : [<8ff8bb30>] lr : [<00004f1f>]
reloc pc : [<17832b30>] lr : [<878abf1f>]
sp : 8f558bc0 ip : 00000000 fp : 8ffef5a4
r10: 8ffed248 r9 : 8f558ee0 r8 : 8ffef594
r7 : 0000000e r6 : 8ffed700 r5 : 00000000 r4 : 8ffed74e
r3 : 00060101 r2 : 8ffed230 r1 : 8ffed706 r0 : 00000ddd
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
Core reason is usage of structures for network headers without packed
attribute.
Reviewed-by: Yauheni Kaliuta <yauheni.kaliuta@redhat.com>
Signed-off-by: Denis Pynkin <denis.pynkin@collabora.com>
(cherry picked from commit 704f3acfcf55343043bbed01c5fb0a0094a68e8a)
include/net.h
upstream changed magic numbers with define
Use ext4 file system by default.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Use similar info message as on other modules.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
The current mechanism using SCR/GPR registers work well when
the serial downloader boot mode has been selected explicitly
(either via boot mode pins or using bmode command). However,
in case the system entered boot ROM due to unbootable primary
boot devices (e.g. empty eMMC), the SPL fails to detect that
it has been downloaded through serial loader and tries to
continue booting from eMMC:
Trying to boot from MMC1
mmc_load_image_raw_sector: mmc block read error
SPL: failed to boot from all boot devices
### ERROR ### Please RESET the board ###
The only known way to reliably detect USB serial downloader
is by checking the USB PHY receiver block power state...
This macro allows to detect whether the boot ROM initialized USB
already (serial downloader). This is helpful to reliably detect
if the system has been recovered via USB serial downloader.
