If the USR partition we usually mount as root file system could not be
found which is e.g. the case for Android make sure mtdparts does not
start with a spurious coma separator the kernel would interpret as an
empty partition entry.
arch/arm/cpu/armv7/tegra3/warmboot_avp.c
arch/arm/include/asm/arch-tegra/clk_rst.h
tegra: add enterrcm command
Tegra's boot ROM supports a mode whereby code may be downloaded and flash
programmed over a USB connection. On dev boards, this is typically entered
by holding down a "force recovery" button and resetting the CPU. However,
not all boards have such a button (one example is the Compulab Trimslice),
so a method to enter RCM from software is useful.
This change implements the command "enterrcm" to do this, and enables it
for all Tegra boards by default. Even on boards other than Trimslice,
controlling this over a UART may be useful, e.g. to allow simple remote
control without the need for mechanical button actuators, or hooking up
relays/... to the button.
Signed-off-by: Tom Warren <twarren@nvidia.com>
As the kernel recently passed the 4 MB size limit simply copying 4 MB
won't quite cut it. Increase to 8 MB for now. In the future properly
parsing the SD card's partition table would be the way to go.
Fix build issues introduced with NVIDIA partition table parsing
integration.
If booting from SD card BCT contains information specific to SD card
partition layout which is bogus if used for NAND partition parsing.
Simply fall back to default offset just like in recovery BCT case.
Note: in the future we could parse SD partition table as well to more
generically support SD booting from various card densities.
Rather than relying on hard-coded offsets actually make use of
partition table parsing implementation.
NVIDIA's NAND layout includes a partition table that can be used to
generically construct the mtdparts kernel boot argument. As an added
benefit this is completely independent of the underlying NAND part
used which differs with various module versions. It further allows our
customer easy adoption to their own custom partition layout.
Initial partition table parsing courtesy of Mitja Špes from LXNAV.
Change SD boot bootdevice in environment variable sdargs from mmcblk3p1
to mmcblk0p1 due to later kernels using a different numbering scheme.
While at it clean-up some white space indentation stuff.
Colibri T20 does not use OdmData but rather relies on memory controller
configuration done by boot ROM based on BCT information. Unfortunately
it is possible to at least boot a 256 MB module with a 512 MB BCT
therefore double check whether we really do have that.
Add comment concerning PMIC initialisation of VDD_CPU via VDDCtrl.
User space tools like init just use last console kernel boot argument
as their one and only console. Re-order them in order to output boot
messages on serial debug console.
Examples: Properly append LDFLAGS to LD command
The LD command in examples/standalone/Makefile ignored platform specific
LDFLAGS setup. Pass these LDFLAGS to the command.
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
Activate BL_ON backlight GPIO PT4 on SODIMM pin 71.
While at it add commented out XGA 1024x768 display timing values as well.
Change tegra2's entry address to its default address 0x108000.
BUG=none
TEST=flashed with local built u-boot. Kernel boots up fine.
Change-Id: I6ff4ed1f2901df73b21d033fbd191550108e96b5
Signed-off-by: Jimmy Zhang <jimmzhang@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/22171
0x108000/0x80108000 is used as tegra2/tegra3's default boot loader entry
address. This change makes u-boot to comply with nvidia standard flash tools.
BUG=none
TEST=run cros_write_firmware with local build u-boot. Kernel boots up
fine.
Change-Id: I55e9b5d1847cf7e6a94d362935deef5f6855ba5a
Reviewed-on: https://gerrit.chromium.org/gerrit/21979
At bootup time device enters in standby state as
CLK_RST_CONTROLLER_SCLK_BURST_POLICY is not set correctly.
This change correctly sets clock burst policy.
BUG = None
TEST= Build OK for Seaboard,Cardhu and Waluigi.
Tested on Cardhu and waluigi. Device boots up.
Change-Id: I598ca7bcfc4a39ecaa68c211d3439ac3569c6e44
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/24164
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Tom Warren <twarren@nvidia.com>
Reviewed-by: Jimmy Zhang <jimmzhang@nvidia.com>
Tested-by: Tom Warren <twarren@nvidia.com>
Commit-Ready: Tom Warren <twarren@nvidia.com>
The cros_write_firmware has updated flash script command 'crc32' with -v
option. To support this change, u-boot needs to be built with
CONFIG_CRC32_VERIFY for seaboard.
BUG=none
Change-Id: I49046ce2424c4624a335af32051421e44bd388bb
Reviewed-on: https://gerrit.chromium.org/gerrit/21420
Reviewed-by: Mark Zhang <markz@nvidia.com>
Reviewed-by: Wei Ni <wni@nvidia.com>
This change allows to build a customized u-boot image, which includes
networking capabilities, provides diagnostic commands and supports
command line editing. These features are necessary to facilitate the
factory flow.
This image needs to be clearly distinguishable by ChromeOS. This is
achieved by modifying the value presented by the BINF.3 ACPI object.
To build this modified image one needs to add BUILD_FACTORY_IMAGE=1 to
the make invocation line.
BUG=chrome-os-partner:7952
TEST=manual
. build the new firmware image as follows:
USE='pcserial factory-mode' emerge-link chromeos-u-boot \
chromeos-coreboot chromeos-bootimage
. program the new image on the Link target with ChromeOS installed
on the SSD and restart it
. observe the target stop at u-boot command prompt (boot >)
. connect the target to an Ethernet network with a DHCP server
using a USB Ethernet dongle
. run the following commands at the u-boot prompt
boot > usb start
(Re)start USB...
USB: Register 203007 NbrPorts 7
USB EHCI 1.00
Register 20400b NbrPorts 11
USB EHCI 1.00
8 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
scanning bus for ethernet devices... 1 Ethernet Device(s) found
boot > dhcp
Waiting for Ethernet connection... done.
BOOTP broadcast 1
BOOTP broadcast 2
[a few warnings of unsupported DHCP options]
DHCP client bound to address 172.22.75.25
Using asx0 device
TFTP from server 172.16.255.7; our IP address is 172.22.75.25; sending through gateway 172.22.75.254
Filename 'pxelinux.0'.
Load address: 0x100000
Loading: ##
done
Bytes transferred = 15840 (3de0 hex)
boot >
. start ChromeOS on the target by issuing
vboot_twostop
. once ChromeOS boots check the mainfw_type crossystem reported value
localhost ~ # echo $(crossystem mainfw_type)
netboot
localhost ~ #
Change-Id: I1c50517754b6b5f773e432b9adec4b290f303e6f
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/21071
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
- Fix bug in traversal of vendor name list.
- Sending "command ready" needs additional logic to handle
TPMs that need that bit set twice: once to empty the read
FIFOs and once to actualy set command ready.
- Certain TPMs need a small delay between requesting locality
and attempting to set command ready or they will hang the bus.
BUG=chrome-os-partner:8558
TEST=manual
Successful boot and suspend/resume with all TPMs listed
in the driver vendor/device list.
Change-Id: I22021b24f9498c3cafe0e1d5f1c6562ea0be5aad
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/18480
Reviewed-by: Ronald G. Minnich <rminnich@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@google.com>
The full range of LPC controllers should be accepted by u-boot when
looking for the SPI controller. The values come from Intel's
Panther_Point_EDS_v072.pdf (document #472178).
BUG=chrome-os-partner:7734
TEST=manual
. program the new image on the target
. reboot it and observe coming up to ChromeOS login screen
Change-Id: Id8f7068c3b48885f868a1f30e7927e678d2154b6
Reviewed-on: https://gerrit.chromium.org/gerrit/19147
Reviewed-by: Jon Salz <jsalz@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/19310
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
Link's MRC produces significantly more training data than
the one used on Stumpy/Lumpy.
Signed-off-by: Stefan Reinauer <reinauer@chromium.org>
BUG=none
TEST=boot tested on Link
Change-Id: I9310c3bcc77fb4318db0635b97b115ab0eb7e5ec
Reviewed-on: https://gerrit.chromium.org/gerrit/18748
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Cardhu boards can use Atmel and Winbond SPI flash
parts - support both in one binary.
BUG=chromium-os:23496
TEST=build all OK, test on Cardhu.
'sf probe 0' returns:
SF: Detected AT25DF321A with page size 256, total 4 MiB.
sf read/write/erase all work OK.
Change-Id: I7df3abb030a49b572e1172ca77227cd4d63e0c21
Reviewed-on: https://gerrit.chromium.org/gerrit/18539
Reviewed-by: Mike Frysinger <vapier@chromium.org>
BUG=none
TEST=check fmap on generated binary for unique names
Change-Id: Id1ac5cf223ec6a333fc8f4c587e972afd087f90d
Reviewed-on: https://gerrit.chromium.org/gerrit/18435
This saves 500ms in the RW BIOS path and still leaves 130K
overhead from the current U-boot size (372K) which should be
more than enough for any future updates on stumpy/lumpy.
This should be re-visited if/when vboot is smart enough to
just read+validate the actual binary within the section.
BUG=chrome-os-partner:8518
TEST=boot lumpy/stumpy through RW BIOS path and gather
timestamps to see 500ms improvement.
Change-Id: Ia714b4b95245f02f6e781247f820ca915bb403f5
Reviewed-on: https://gerrit.chromium.org/gerrit/18372
When U-boot is loaded via verified boot it starts at the
_x86boot_start entry point and promptly disables caching,
resulting in about a 500ms hit to boot time.
TEST=boot on lumpy with RW BIOS and gather timestamps
to observe 500ms less time spent in u-boot init.
Change-Id: I4eb1ad5ebcb20a156fef77452030e47a5e510115
Reviewed-on: https://gerrit.chromium.org/gerrit/18371
For some still unknown reason writes to localtion 0xcf9 do not cause
the Link to reboot, they cause it to shut down instead. While this
will have to be investigated and fixed, this change modifies the code
to use the keyboard controller (implemented by the EC on Link) to
restart the system.
Once the 0xcf9 problem is resolved, this change could be reverted.
BUG=chrome-os-partner:8397
TEST=manual
. when u-boot tires restarting the system it now reboots. before
this change it would just shut down.
Change-Id: I8076f897304f705e20ec8f2e30cce17d7fdd31c4
Reviewed-on: https://gerrit.chromium.org/gerrit/18332
Reviewed-by: Hung-Te Lin <hungte@chromium.org>
The code in this file tries to print an LBA using the format specifier
"%10ld", but when CONFIG_SYS_64BIT_LBA is turned on, the argument passed in
this position is a 64 bit value and isn't compatible. This change selects the
appropriate format specifier, the original or "10lld", based on whether
CONFIG_SYS_64BIT_LBA is turned on.
BUG=chrome-os-partner:8180
TEST=Built for Stumpy with BUILD_PART_FS_STUFF turned on and
CONFIG_SYS_64BIT_LBA enabled and disable, and saw the compile errors go away.
Change-Id: Ib80b1567ce07673aea2b47dfba9b3526b32f9de5
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/18219
Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
TEST=build on Waluigi, Seaboard, Cardhu
Change-Id: I9ccd3085fb551e9887815592e9b518b6944beda7
Reviewed-on: https://gerrit.chromium.org/gerrit/14474
In the structure returned by the ATA identify device command, there are two
fields which describe the device capacity. One is a 32 bit data type which
reports the number of sectors as a 28 bit LBA, and the other is a 64 bit data
type which is for a 48 bit LBA. If the device doesn't support 48 bit LBAs,
the small value is the only value with the correct size. If it supports more,
if the number of sectors is small enough to fit into 28 bits, both fields
reflect the correct value. If it's too large, the smaller field has 28 bits of
1s, 0xfffffff, and the other field has the correct value.
The AHCI driver is implemented by attaching to the generic SCSI code and
translating on the fly between SCSI binary data structures and AHCI data
structures. It responds to requests to execute specific SCSI commands by
executing the equivalent AHCI commands and then crafting a response which
matches what a SCSI disk would send.
The AHCI driver now considers both fields and chooses the correct one when
implementing both the SCSI READ CAPACITY (10) and READ CAPACITY (16) commands.
TEST=Built and booted to ChromeOS with this code on a CRB with a 250 GB drive
and a Stumpy with a 16 GB drive. Checked the serial output to make sure U-Boot
reported the correct size. Forced the READ CAPACITY (10) command to saturate
so that the READ CAPACITY (16) command would be used and verified that that
also booted correctly on a CRB.
Change-Id: I31b662498f4c9657d70bb90400032c83e9d9c8da
Reviewed-on: https://gerrit.chromium.org/gerrit/18061
The generic SCSI code in U-Boot was only aware of the READ CAPACITY (10) SCSI
command which can detect the size of disks up to 2TB in size. If that size is
exceeded, it should then try the READ CAPACITY (16) command which returns a
64 bit block count value.
TEST=In conjunction with the next change, built and booted into ChromeOS on
the Emerald Lake 2 CRB with a 250 GB SSD. Did the same but forced the READ
CAPACITY (10) command to saturate and the code to fall back to READ CAPACITY
(16). Note that this code has not be tested with a real SCSI disk, just the
AHCI code pretending to be a SCSI disk as it historically has.
Change-Id: Ia0ee3fa1264649f25065658d5d368101d39ce614
Reviewed-on: https://gerrit.chromium.org/gerrit/18060
TEST=Built and booted on emeraldlake2 and Stumpy.
Change-Id: If14ff4930015fae36d421fd30ab5bd126c464db9
Reviewed-on: https://gerrit.chromium.org/gerrit/18059
These drivers wouldn't compile when the CONFIG_SYS_64BIT_LBA option is turned
on because the used fixed size data types in their exported functions when they
should have used lbaint_t for the block count parameter. That meant that when
the sizes happened to be the same, when using a 28 bit LBA, the driver would
build, but when it wasn't, a 48 bit LBA, things broke.
This change adjusts the signatures to use the right type and makes small
adjustments in the affected functions.
TEST=Built for emeraldlake2 with the CONFIG_SYS_64BIT_LBA option enabled and
saw its compile errors go away.
Change-Id: I7443b5976d3d06b82070344011fba46a28bd77de
Reviewed-on: https://gerrit.chromium.org/gerrit/18058
TEST=Built u-boot for emeraldlake2.
Change-Id: Iae62f047ddc102fbf530e1f8f9af34939971a6a3
Reviewed-on: https://gerrit.chromium.org/gerrit/18057
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
This uses a format which is not supported by the upstream dtc, so
remove this.
BUG=chromium-os:23249
TEST=emerge-tegra2_kaen chromeos-u-boot with new dtc
Change-Id: I18b9420dbee20c2d115cc5ff1b13425faffe2a3e
Reviewed-on: https://gerrit.chromium.org/gerrit/17630
In bug reports with screen shots of the firmware screens with tab
pressed, it would be extremely useful to see the version of the
currently running firmware and the read-only firmware, so output
this information.
BUG=none
TEST=press TAB at dev screen, see firmware versions printed on the
screen.
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Change-Id: If91d4b1da8a7f69ff797b0b00c507248139601cd
Reviewed-on: https://gerrit.chromium.org/gerrit/17002
Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
Reviewed-by: Randall Spangler <rspangler@chromium.org>
cold_reboot() should wait until the reset kicks in, instead of
returning and continuing in an undefined code path. Without this
patch, vboot_twostop will return, and secure_boot() will start
printing an error message, which results in a sporadic # on
the screen when pressing space or ESC on the dev screen in order
to go to recovery mode.
BUG=chrome-os-partner:7683
TEST=boot to dev screen on lumpy, press ESC or space. Observe
there is no # character printed before going to recovery
mode.
Change-Id: Ic2ee570032686e48603f0fb3b1ec9cbfae9451bc
Reviewed-on: https://gerrit.chromium.org/gerrit/17007
This will trigger setting gbb.flags to 1 in cros_bundle_firmware so the
factory time is reduced.
GBB.flags will be changed in the factory process.
Also needs https://gerrit.chromium.org/gerrit/#change,16845
BUG=chrome-os-partner:7671
TEST=manual
emerge-stumpy chromeos-bootimage
gbb_utility -g --flags /build/stumpy/firmware/image.bin
Should report "flags: 0x00000001"
Change-Id: Ie05433ad737005bd5dcca2f88232b0a5bbd00df9
Reviewed-on: https://gerrit.chromium.org/gerrit/16113
enable CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT
TEST=build and boot on Cardhu
Change-Id: If21303468193c7f5f6ba1c0c0b7cd0ccb5a08c0e
Reviewed-on: https://gerrit.chromium.org/gerrit/13801
TEST=build and boot on Waluigi
Change-Id: I622d228d02767954ffa7e101ad6f5f5fb1146702
Reviewed-on: https://gerrit.chromium.org/gerrit/13802
TEST=build and boot on Waluigi, Cardhu by enabling
CONFIG_TEGRA_LP0 and CONFIG_TEGRA3_WARMBOOT.
odification of the work done by:
a. Jimmy Zhang <jimmzhang@nvidia.com>
b. Yen Lin <yelin@nvidia.com>
c. Wei Ni <wni@nvidia.com>
Change-Id: If2fa63ccd23341694955bca25fb5cfc4a8a805ad
Reviewed-on: https://gerrit.chromium.org/gerrit/13800
warmboot_avp.h needs to be present in include/arch-tegra
in order to use it for Tegra3.
TEST=build for Seaboard
Change-Id: I3f369194e4002e8257c9d2ff37253bc20733138d
Reviewed-on: https://gerrit.chromium.org/gerrit/15394
TEST=build for Cardhu, Waluigi and Seaboard
Change-Id: I6d26502d1ecc393b266ffe06b540f59c595e19ae
Reviewed-on: https://gerrit.chromium.org/gerrit/14811
Change-Id: Ifa06f941798ff242197dcd31f4091567d91fe4b2
Reviewed-on: https://gerrit.chromium.org/gerrit/14810
Change-Id: I74bb2418ab996e362060351de3ba7efd538ffd87
Reviewed-on: https://gerrit.chromium.org/gerrit/14809
Change-Id: I20ac75c71d86d65ff422ff3f4f966a69718f4f91
Reviewed-on: https://gerrit.chromium.org/gerrit/14808
These registers would be useful for the warmboot code.
Change-Id: I58f52b6b8653d72b2e842ee44bdf3632eff304a2
Reviewed-on: https://gerrit.chromium.org/gerrit/14690
Would be useful for the warmboot code.
Change-Id: I271f6cdcc0248337e516c2c32014c6ec4f08fb15
Reviewed-on: https://gerrit.chromium.org/gerrit/14689
code.
Change-Id: I8da1ed3a382e1b65247236cb19f527f81d8ecaac
Reviewed-on: https://gerrit.chromium.org/gerrit/14688
