We were not searching on the last PCI bus.
Fix the loop to go up to pci_last_busno() included.
Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
BUG=None
TEST=run on Link with only one PCI bus active, see we can detect the
EHCI controllers.
Change-Id: Icdcd19df0c622039f56e7403c2616348b5d8b7d6
Reviewed-on: https://gerrit.chromium.org/gerrit/16481
Tested-by: Vincent Palatin <vpalatin@chromium.org>
Reviewed-by: Vadim Bendebury <vbendeb@chromium.org>
Commit-Ready: Vincent Palatin <vpalatin@chromium.org>
It turns out that running 'vbexport_test display' on coreboot
platforms fails to display bitmap images, sometimes reporting memory
corruption and rebooting the system.
The problem was twofold:
- the gbb pointer is not properly initialized (as it is supposed to
when CONFIG_HARDWARE_MAPPED_SPI is defined).
- the bitmap images block includes an element which in fact is not a
bitmap. When scanning the block, the test tried displaying all
elements, generating an error when this one-off element is
encountered.
This change fixes both issues.
BUG=chromium-os:26586
TEST=manual
. build a new chromeos-bootimage
. reboot the system stopping it in u-boot console dialogue
. run `vbexport_test display' command from the console
The test was failing before this change, it is passing now.
Change-Id: Iee9491d150b9ce5513f7446ab4df806d23e6d4d8
Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/16206
Reviewed-by: Bill Richardson <wfrichar@chromium.org>
When a USB card reader is empty, it will return "Not Ready - medium not
present" as Key Code Qualifier. In that situation, it's useless waiting
for the full timeout since the result won't change until the user
inserts a card.
U-Boot mass storage returns empty mass storage devices with a size of 0,
skip them in the VBoot devices enumeration.
BUG=None
TEST=On Link, run without a MMC card.
Change-Id: Iac37887742e5738e249f595e0413eec16b391fae
Reviewed-on: https://gerrit.chromium.org/gerrit/15582
BUG=chromium-os:23496
TEST=build for Cardhu, Waluigi
Change-Id: Iacd6fdb178afbfdb978dbe53bbe2766916bf26f9
Reviewed-on: https://gerrit.chromium.org/gerrit/14685
TEST=build for Cardhu, Waluigi and Seaboard
Change-Id: I32dbfa02ac1d6954b3a7e515914fbc0b6695f98b
Reviewed-on: https://gerrit.chromium.org/gerrit/14683
USB keyboard initialization was added in twostop_boot as a hack.
However, if u-boot is running from one of the RW sections, twostop_boot
is never executed, instead the code proceeds to
twostop_readwrite_main_firmware() which was lacking the USB keyboard
initialization.
This patch adds USB keyboard initialization to the RW code path.
BUG=chrome-os-partner:7940
TEST=boot from RW section in dev mode, observe that USB keyboard is
working. (stumpy)
Signed-off-by: Stefan Reinauer <reinauer@google.com>
Change-Id: Ie49d14680a72c2216b4a68091ae6e6adcca91242
Reviewed-on: https://gerrit.chromium.org/gerrit/15913
Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
Commit-Ready: Stefan Reinauer <reinauer@chromium.org>
Tested-by: Stefan Reinauer <reinauer@chromium.org>
Add this special handle of Ctrl-Enter, which is converted into '\n'
by i8042 driver.
BUG=chrome-os-partner:6759
TEST=compile the firmware and update it to Lumpy; during the dev screen,
press Ctrl-Enter to trigger USB boot.
Signed-off-by: Tom Wai-Hong Tam <waihong@chromium.org>
Change-Id: Ifde312f4ef6de9b328dc22b96ca02a2a9ccf6068
Reviewed-on: https://gerrit.chromium.org/gerrit/15805
Tested-by: Tom Wai-Hong Tam <waihong@chromium.org>
Commit-Ready: Tom Wai-Hong Tam <waihong@chromium.org>
Make Ctrl-Enter act like LF (Line Feed) such that u-boot can differentiate
it from pure Enter key. There are other Ctrl-(numeric keypad key)'s,
like Ctrl-[ for ESC (Escape) key, but they are not useful yet in current
u-boot. So keep the Ctrl-(key) and non-Ctrl-(key) tables the same except Enter.
This change is together with https://gerrit.chromium.org/gerrit/15749
Change-Id: Ie3197f7ba93ed63c851bdfb918c8e384c90977dd
Reviewed-on: https://gerrit.chromium.org/gerrit/15750
split the LP0 code for tegra2 into common
LP0 code and chip specific warm boot code
TEST=build for Seaboard
Change-Id: Ie04bf9ac17482a37afd0f4515dc3aafeb4f48ae7
Reviewed-on: https://gerrit.chromium.org/gerrit/15883
This reverts commit 4c7502242627f64d91432cb4958be5f93f65fbff
Don't think this is the cause of http://code.google.com/p/chromium-os/issues/detail?id=26116, but it was in the same batch so I'm reverting in the process.
Change-Id: Icc013ced6c22e29d569ee4ca8ef73522154ec1a8
Reviewed-on: https://gerrit.chromium.org/gerrit/15561
Reviewed-by: Brian Harring <ferringb@chromium.org>
Tested-by: Brian Harring <ferringb@chromium.org>
This reverts commit 9a3fbb5f0b02382c7abe0cf40a4f08abbf269d05
Broke tegra2: http://code.google.com/p/chromium-os/issues/detail?id=26116
Change-Id: I7d35211c6ebce7a10750cb1033c6f8ba9a0f63bc
Reviewed-on: https://gerrit.chromium.org/gerrit/15560
move away from the current method, where we add wb_end() immediately
after wb_start() and then use the function addresses to calculate the
WB code size. Add a .lds script to expose __wb_end after wb_start() in
the .text section and then reference this variable in the WB size
calculation code.
TEST=build on Seaboard. Verified that uboot.map has the correct address
assigned to __wb_end and that LP0 works reliably.
Change-Id: I170277f00b450d38063018453faf44d5a38abaaa
Reviewed-on: https://gerrit.chromium.org/gerrit/14682
Change-Id: Id9756c08f61502affa8beee636d883d01468e6ec
Reviewed-on: https://gerrit.chromium.org/gerrit/13799
As clock source for graphics related clocks is different
for Tegra2 and Tegra3, define it under platform specific
directories.
TEST=Build ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi.
Original work by -
Mayuresh Kulkarni <mkulkarni@nvidia.com>
Change-Id: I6cee11df5e75eaf3836565c4fa4f3ab3e45d8cac
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14700
Assert occurs due to LCD max height was bigger than default
Maximum LCD height, causing 'panel_info' is not initialized.
Increase default Max LCD height as Waluigi has LCD height in
pixel more than 768.
Initialize global variable 'lcd_line_length' correctly.
'lcd_line_length' was not initialized before use, causing
initialization of dependent variables wrongly.
Change-Id: I24a9fc54541c861c48fd885e2d58d32786c31bf8
Reviewed-on: https://gerrit.chromium.org/gerrit/14699
For Waluigi, existing frame buffer address does not fall
under external memory map.
Setting it to the location set as per the default initialization.
Change-Id: I2284d43c11f4d6622344429508b1f99e30929f19
Reviewed-on: https://gerrit.chromium.org/gerrit/14698
Set display parent clock separately for Tegra2 and Tegra3.
TEST=Built ok for Cardhu Walgui and Seaboard. Tested on Waluigi.
Change-Id: Ie03d37b8dda77dcfcb72e70c34e769a23323e598
Reviewed-on: https://gerrit.chromium.org/gerrit/14697
Add a case for returning RAM size as 2GB by reading
PMC scratch20 register.
Change-Id: I5dc8fdf7cd9718e5dd2ca24cd1f467c5b6e9a6aa
Reviewed-on: https://gerrit.chromium.org/gerrit/14696
For Tegra2, pinmuxing is done in each driver, For Tegra3
it is done at boot up time.
Handling it conditionally for Tegra2 and Tegra3.
Change-Id: I95e2dc4d46c0c47037611ff9177f2d8823c11d1f
Reviewed-on: https://gerrit.chromium.org/gerrit/14695
Move pwfm.c and display.c under common folder tegra-common.
TEST=Built ok for Cardhu, Waluigi and Seaboard. Tested on Waluigi.
Change-Id: I23c5f02270dde7bfdd6e1d26ed9984385986194e
Reviewed-on: https://gerrit.chromium.org/gerrit/14694
Enables common LCD support for Tegra2 and Tegra3
Change-Id: I39af6a01956a3f1545e7cccfa9c23a3f81d3dc0c
Reviewed-on: https://gerrit.chromium.org/gerrit/14693
Change-Id: I938824045440cc4964c2ac6bf727a90ee5f129b4
Reviewed-on: https://gerrit.chromium.org/gerrit/14692
Helps kernel developers using kernels with custom
ramdisk images. Some developers who would like to
work with upstream kernel specifically requested
for this feature, since it helps them during early
development days.
TEST=build and boot on Cardhu, Waluigi
Change-Id: I698da421bf924a5c86229a80c0a25021d3e6f046
Signed-off-by: Tom Warren <twarren@nvidia.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14475
Commit-Ready: Che-Liang Chiou <clchiou@chromium.org>
Reviewed-by: Che-Liang Chiou <clchiou@chromium.org>
Add Keyboard config options CONFIG_TEGRA_KEYBOARD and CONFIG_KEYBOARD.
TEST=Tested on Waluigi. key press echoes the key on console.
Build OK for cardhu.
Change-Id: I7856f2d22c935a4a94f91c67263913e1240f25b5
Reviewed-on: https://gerrit.chromium.org/gerrit/13790
Add Waluigi keyboard map in Waluigi fdt
TEST=Build and tested on Waluigi.
Change-Id: Iaf39dabc2bef2f12c2f0b875cc3c397386dbb446
Reviewed-on: https://gerrit.chromium.org/gerrit/13929
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Add Keyboard controller option in tegra30 fdt.
TEST=Build ok for Waluigi, Seaboard and Cardhu.
Change-Id: I20fe7feed42a96edea138dc32c532e0d1d535226
Reviewed-on: https://gerrit.chromium.org/gerrit/14546
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Replace Tegra2 specific tag "CONFIG_TEGRA2_KEYBOARD" by
common tag "CONFIG_TEGRA_KEYBOARD" to include tegra keyboard
driver.
TEST=Build ok for Cardhu,Seaboard and Waluigi.
Change-Id: Idd16990ba525b8391c3c14e37efd5587f09a25c8
Reviewed-on: https://gerrit.chromium.org/gerrit/13860
Rename CONFIG_TEGRA2_KEYBOARD to common CONFIG_TEGRA_KEYBOARD
TEST=Build OK for Waluigi, Cardhu and Seaboard.
Change-Id: Ice2741622fe6434ba25ece8fe7fbe2ca989c44ef
Reviewed-on: https://gerrit.chromium.org/gerrit/13930
Expand existing 4x6 keyboard support to 16x8 keyboard.
Add Tegra2 specific changes under Tegra2 config "CONFIG_TEGRA2".
TEST=Tested on Waluigi.key press echoes the key on console.
Built ok for Cardhu and Seaboard.
Change-Id: Iab291a636d41b721d914014a5fe9ecc8775bf260
Reviewed-on: https://gerrit.chromium.org/gerrit/13928
Change-Id: Ifb4deba51137251ea0564bf3e66f33f7c62420e4
Reviewed-on: https://gerrit.chromium.org/gerrit/14701
This command doesn't really do anything when talking to a SATA device, and
sending it confuses some of them. This change makes sending the command
optional, and defaults to not. The situations where it should be sent are not
the common case.
With the standard SSD in the machine, here are some times with the option
turned off:
1. 8277
2. 8273
3. 8050
And turned on:
1. 8303
2. 8155
3. 8276
Sending that command seems to have no meaningful effect on performance.
BUG=chrome-os-partner:7714
TEST=Booted off an SSD that hadn't worked with U-Boot previously. This SSD
was lent to us by Grant, and has chips labelled as Toshiba NV6424,
Taiwan 11159AE P, and TC58NVG5D2FTA10.
Change-Id: I750a6c7931a95a1529e0b99ee98528a549824ee4
Signed-off-by: Gabe Black <gabeblack@google.com>
Reviewed-on: https://gerrit.chromium.org/gerrit/14916
Reviewed-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@chromium.org>
Our security reviewers suggested that we update all copies
of lzma sdk code used in boot loaders to the latest version.
Updated code taken from latest lzma sdk release 9.20 at
http://downloads.sourceforge.net/sevenzip/lzma920.tar.bz2
BUG=chromium-os:24221
TEST=boot on stumpy, see it still work
Change-Id: I884546f3aaf013a083fa25f306d7d921245fbc16
Reviewed-on: https://gerrit.chromium.org/gerrit/14757
- remove unused ssleep macro
- add some useful debugging information
BUG=none
TEST=boot latest firmware on stumpy, no functional change.
Change-Id: Ieef3c199225b8c1aa979dfebf8a6f2178d5aa316
Reviewed-on: https://gerrit.chromium.org/gerrit/14836
- print the correct speed
- print all the AHCI capability flags
(information taken from Linux kernel driver)
- clean up some comments
TEST=See the following string in bios_log:
AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3 impl SATA mode
Change-Id: Ib32dbeddd0714359948e2bec033b2ec7aabbdb10
Reviewed-on: https://gerrit.chromium.org/gerrit/14754
Right now our code makes the assumption that there always is one
SCSI drive in the system (the AHCI attached SDD). However, this
might not be the case.
This patch prevents vboot from using an uninitialized disk entry
when instead it should go into recovery mode.
BUG=chrome-os-partner:7716
TEST=none
Change-Id: I761bbb3c92a60d4205a217c7b025f699deed83b0
Reviewed-on: https://gerrit.chromium.org/gerrit/14753
Generate ANSI 3.64 sequences to handle arrow keys, Fx and other special
keyboard keys.
BUG=chrome-os-partner:7666
TEST=on Stumpy in recovery mode, press arrow keys and see the language
of the message change.
Change-Id: I4560ca0c68ea5a9da4cde8247ea5ecc74938f84a
Reviewed-on: https://gerrit.chromium.org/gerrit/14596
Reviewed-by: Terry Lambert <tlambert@chromium.org>
Commit-Ready: Terry Lambert <tlambert@chromium.org>
Reviewed-by: Stefan Reinauer <reinauer@google.com>
(cherry picked from commit 93954c89f388f3f36149504ebbcd6f6a70fd3a8f)
Reviewed-on: https://gerrit.chromium.org/gerrit/14606
Change-Id: I86d029e09713b0d8f885b97d7ec34119266dfe11
Reviewed-on: https://gerrit.chromium.org/gerrit/13699
Reviewed-by: Tom Warren <twarren@nvidia.com>
BUG=none
TEST=manual
In dev-mode, press "Ctrl-U" with no USB stick inserted.
If "crossystem dev_boot_usb" is 0, you'll hear two 400Hz beeps.
If "crossystem dev_boot_usb" is 1, you'll hear one 200Hz beep.
Signed-off-by: Bill Richardson <wfrichar@google.com>
Change-Id: Ifd45a067ec8b922863331f13f3f4525ef40f7346
Reviewed-on: https://gerrit.chromium.org/gerrit/14529
Tested-by: Bill Richardson <wfrichar@chromium.org>
Commit-Ready: Bill Richardson <wfrichar@chromium.org>
By using arch_phys_memset, the wiping code doesn't need to worry about what
addresses can be accessed by memset or how to actually get at them.
BUG=chrome-os-partner:7579
TEST=From the original, larger patch:
Built and booted on Lumpy, Stumpy, and Kaen. Looked at the log to see
that the regions in high memory are listed as cleared. Artificially injected
a range to "clear" with 0xA5 and then 0x5A which was over the framebuffer and
covered part or all of the screen on Lumpy. Verified that the screen was
partially or completely filled with an appropriate looking color. Had U-Boot
print the PDTs it was generating to verify that the high address bits were
preserved. Identity mapped only some of memory and verified that things that
should be mapped were accessible and things that shouldn't be weren't.
Change-Id: Ia1859e8df5a0bbe41839a697829dfc775e1b1e48
Reviewed-on: https://gerrit.chromium.org/gerrit/14419
Reviewed-by: Gabe Black (Do Not Use) <gabeblack@google.com>
Tested-by: Gabe Black (Do Not Use) <gabeblack@google.com>
Implement arch_phys_memset so that it can set memory at physical addresses
above 4GB using PAE paging. Because there are only 5 page tables in PAE mode,
1 PDPT and 4 PDTs, those tables are statically allocated in the BSS. The
tables must be 4K page aligned and are declared that way, and because U-Boot
starts as 4K aligned and the relocation code relocates it to a 4K aligned
address, the tables work as intended.
While paging is turned on, all 4GB are identity mapped except for one 2MB
page which is used as the window into high memory. This way, U-Boot will
continue to work as expected when running code that expects to access memory
freely, but the code can still get at high memory through its window.
The window is put at 2MB so that it's 2MB page aligned, low in memory to be
out of the way of things U-Boot is likely to care about, and above the lowest
1MB where lots of random things live.
Change-Id: I1b3a038009de4312edba56ced1a91f9b0f6858b4
Reviewed-on: https://gerrit.chromium.org/gerrit/14418
The default implementation of this function is just memset, but other
implementations will be needed when physical memory isn't accessible by
U-Boot using normal addressing mechanisms.
Change-Id: Ie1ba5bbb8ee2847f450d0057611deee397c316cf
Reviewed-on: https://gerrit.chromium.org/gerrit/14417
On ARM, U-Boot is put at the end of memory, and the code that records the
unused areas of memory to be wiped uses the end of RAM as the upper bound
for the region occupied by U-Boot. On x86, U-Boot may have been relocated to
somewhere lower than the end of RAM because it can normally only address a 32
bit address space. This change makes the wiping code calculate where U-Boot
actually ends on x86 so the areas with large addresses will be wiped properly.
TEST=Built and booted on Lumpy, Stumpy, and Kaen. On Lumpy, verified that the
area with physical addresses above 4GB was now in the list to be wiped.
Change-Id: Ib7e0818e85daf512b76f85f4e68f88230d301cea
Reviewed-on: https://gerrit.chromium.org/gerrit/14223
When this code picked an area for U-Boot to relocate to, it was making sure
that there was enough space for U-Boot's various sections. It wasn't taking
into account the space needed for the heap and stack, however, so if it
happened to pick a very small region those areas might overlap with something
they shouldn't. This change fixes that.
Also, this change replaces the ROUND macro with the new rounddown introduced
in a previous change. It was assumed that ROUND rounded down, in contrast to
the other rounding function in common.h, roundup. It turns out that ROUND
rounds up even more agressively than roundup. If the value being rounded is
already exactly a multiple of the rounding amount, ROUND will still increase
it to the next multiple.
Because the region U-Boot had been choosing has plenty of space, there should
be no functional difference with this change.
Change-Id: I39a45be6487ed0f60ea0900fb10632da5b312ebe
Reviewed-on: https://gerrit.chromium.org/gerrit/14222
TEST=Build ok for Waluigi,Cardhu and Seaboard.
"printenv bootargs" shows the changed kernel arg on Waluigi.
Change-Id: I87934f9a887c367098152ac753f98681760ec160
Reviewed-on: https://gerrit.chromium.org/gerrit/13797
Tested-by: Olof Johansson <olofj@chromium.org>
If the USB keyboard is not answering properly the first request on its
interrupt endpoint, just skip it and try the next one.
This workarounds an issue with a wireless mouse dongle which presents
itself both as a keyboard and a mouse but has a non-functional keyboard
interface.
BUG=chrome-os-partner:7559
TEST=Boot a stumpy with the wireless mouse and the keyboard plugged in
such a way that the mouse enumerates first. Check we are booting
properly and the key strokes are working in the firmware.
Change-Id: I574f2a4bdb3bc7824b5bd747a237ef0b79dd83ac
Reviewed-on: https://gerrit.chromium.org/gerrit/14362
(cherry picked from commit 012bbf0ce0301be2482857e3f03b481dd15c2340)
Reviewed-on: https://gerrit.chromium.org/gerrit/14379
This adds support for generation of ANSI 3.64 escape sequences to the
PS/2 keyboard driver.
This change significantly refactors the code:
o It adds an FSA to support 0xE0 and 0xE1 multibyte PS/2
scan code sequences.
o It converts the PS/2 scan codes to USB scan code values
to facilitate sharing upper level code in future changes.
Reasons to use USB scan codes:
o Standard
o Simple conversion to ASCII / ANSI 3.64
o Ability to share complex processing / state code
o Shared international keymaps in higher level code
o It adds an ANSI 3.64 escape sequence generator for USB
special keys; the intent of doing this is to allow the
transparent use of PS/2, USB, and network or serial
devices using the same upper level u-boot clients.
o It adds an input FIFO which is an almost verbatim copy
of the Tegra matrix keyboard driver; future changes are
expected to share the FIFOcode among all keyboard drivers.
International keyboard support is expected to be handled at a higher
layer in the future, using a much smaller NRCS (National Replacement
Character Set) table instead of a duplicat table.
Combined, the changes reduce the overall source file size by about
5K, and removes about 4K from the data segment as well.
Note: Use of typedef for FSA states allows compiler to prohibit
switch statement without default case from omitting states.
BUG=chrome-os-partner:6580
TEST=Removed backslash from generated 3.64 sequences, stopped boot at
command line, verified character sequence generation.
Signed-off-by: tlambert@chromium.org
Change-Id: I00200c5ccefd44679335fb643b21794e5d77663a
modified: drivers/input/i8042.c
modified: include/i8042.h
Change-Id: I22c692f7bd65da5848908fc71c6cd7d04753f135
Reviewed-on: https://gerrit.chromium.org/gerrit/14218
Tested-by: Terry Lambert <tlambert@chromium.org>
The use of post-increment with a do-while loop results in
the loop going one step too far when handling relocation fixups.
In about 1/100 cases this would cause it to hang.
BUG=chromium-os:25121
TEST=boot with serial enabled and extra debug to dump
the relocation addresses to ensure that it stops when
getting to the end of the rel.dyn section.
Change-Id: I4d3686d9c90ccfd0df0dd4d8a6483c534c93d3f2
Signed-off-by: Duncan Laurie <dlaurie@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/14290
Reviewed-by: Ronald G. Minnich <rminnich@chromium.org>
The implementation of the twostop code blurs the boundary between the
vboot_reference API and the U-Boot implementation. This cleans it up a bit.
BUG=none
TEST=none
Change-Id: I518b4c436bbc52a97820705a9cc2ee949a58e438
Signed-off-by: Bill Richardson <wfrichar@chromium.org>
Reviewed-on: https://gerrit.chromium.org/gerrit/14182
Reviewed-by: Randall Spangler <rspangler@chromium.org>
Because calculate_relocation_address now uses the e820 map, it will be able
to avoid addresses over 32 bits and regions that are at high addresses but
not big enough for U-Boot. It also means we can remove the hack which
limitted U-Boot's idea of the size of memory to less than 4GB.
BUG=None
TEST=Built and booted on Lumpy. Built on Kaen.
Change-Id: I3ada4e5325ae3a0e652cf79486970e967aef6da6
Reviewed-on: https://gerrit.chromium.org/gerrit/14152
The way these are declared is different upstream, so these are being added in
a separate change to make rebasing easier.
BUG=None
Change-Id: If84e0c36bd3615a561dec80eb71741c78db869b3
Reviewed-on: https://gerrit.chromium.org/gerrit/14211
