Fix possible overflow condition in serial number to hexadecimal coded
decimal conversion routine.
As we have lots of impatient managers lets decrease the default boot
delay. One can still enter the interactive U-Boot console by hitting a
key just in time of boot/reset.
Please note currently at Toradex we from the Linux team concentrate on
feature stability rather than fast booting.
Due to a unoptimised PLL X table we were only running at 400MHz during
boot.
Incorporated the PLL X table from NVIDIA's latest public U-Boot sources:
http://nv-tegra.nvidia.com/gitweb/?p=3rdparty/u-boot.git;a=blob;f=arch/arm/cpu/arm720t/tegra-common/cpu.c;h=119342e9577f6b42f93d118b81c0e931c9c9423a;hb=chromeos/v2013.01.01-tegra114#l67
And actually set up the T30 PLLs regardless of slow flag as this is
anyway exclusively used on T20.
Issue report courtesy of Mariusz Bulkowski from Draminski.
As Apalis T30 uses DVI-D aka HDMI as its default external display
interface make sure to activate the framebuffer console on there.
Forgot to actually adjust the amount of available memory in the
previous commit. Wouldn't it be nice to actually be able to use the
full 2GB?
Add initial Apalis T30 support based off our current Colibri T30
implementation:
- Updated machine ID.
- USB host USBH2 and USBH3 support. Note: USBO1 support is currently broken.
- Updated MMC and SD card support.
- Adjusted available amount of memory.
Rather than relying on hard-coded offsets actually make use of
partition table parsing implementation.
While at it bring the whole config more in-line with the Colibri T20.
As the partition table parsing offset handling relies on the global
data structure prepare the EFI GPT implementation for that.
NVIDIA's MMC/SD layout includes a partition table that can be used to
generically determine U-Boot environment, kernel, configuration block
as well as GPT offsets. As an added benefit this is completely
independent of the underlying MMC/SD card used which might differ with
various future module versions or particularly cards used for T20 SD
boot. Also handles the case of T20 SD boot where the configuration
block is still taken from NAND flash while the rest resides on the SD
card.
Initial partition table parsing courtesy of Mitja Špes from LXNAV.
There was no space for the null byte. In our case it led to the lowest
byte of the pointer mtd used by nand_init_chip being cleared, which
made the system crash when it tried to call mtd->priv->select_chip.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
The Colibri T30 V1.1 modules actually use a different card detect GPIO.
After having registered the following proper machine type migrate to
actually using it.
http://www.arm.linux.org.uk/developer/machines/list.php?id=4493
While at it clean-out some obsolete Cardhu specific device-tree
nodes resp. properties and clean-up the mach-types header file as well.
This is a purely cosmetic clean-up of the common Toradex board file.
Add optional aka commented out 800x480@60 timing suitable for EDT
ET070080DH6.
Turns out our simplistic approach of just blindly enabling LAN_V_BUS
and releasing LAN_RESET_N does not prove very reliable.
Properly resetting the chip for 5 microseconds after VBUS is stable
just like we do on the Colibri T20 seems to fix the issue.
Include "colibri_" prefix in our board compatibility tables in
preparation to properly distinguish future e.g. Apalis modules.
While at it bring the device tree matching more in par with Linux
kernel 3.1.10 from NVIDIA's L4T R16-R2.
- board.c: changes required by different PMIC variant
CLK_RST_CONTROLLER_RST_CPU_CMPLX_SET/CLR_0
description in Android code. no bug visible as function is not called with run = 1
here this use did not show any adverse effects
Turns out we completely missed properly resetting the ASIX USB to FastEthernet chip which from time-to-time on certain modules caused severe Ethernet detection faults only a complete hardware reset or power-cycle could eliminate. Properly resetting the chip for 5 microseconds after VBUS is stable seems to fix the issue.
- kernel can now be up to 8MB
- cleanup, e.g. remove any NAND config
- unify with T20 file layout
If the USR partition we usually mount as root file system could not be
found which is e.g. the case for Android make sure mtdparts does not
start with a spurious coma separator the kernel would interpret as an
empty partition entry.
arch/arm/cpu/armv7/tegra3/warmboot_avp.c
arch/arm/include/asm/arch-tegra/clk_rst.h
tegra: add enterrcm command
Tegra's boot ROM supports a mode whereby code may be downloaded and flash
programmed over a USB connection. On dev boards, this is typically entered
by holding down a "force recovery" button and resetting the CPU. However,
not all boards have such a button (one example is the Compulab Trimslice),
so a method to enter RCM from software is useful.
This change implements the command "enterrcm" to do this, and enables it
for all Tegra boards by default. Even on boards other than Trimslice,
controlling this over a UART may be useful, e.g. to allow simple remote
control without the need for mechanical button actuators, or hooking up
relays/... to the button.
Signed-off-by: Tom Warren <twarren@nvidia.com>
As the kernel recently passed the 4 MB size limit simply copying 4 MB
won't quite cut it. Increase to 8 MB for now. In the future properly
parsing the SD card's partition table would be the way to go.
Fix build issues introduced with NVIDIA partition table parsing
integration.
If booting from SD card BCT contains information specific to SD card
partition layout which is bogus if used for NAND partition parsing.
Simply fall back to default offset just like in recovery BCT case.
Note: in the future we could parse SD partition table as well to more
generically support SD booting from various card densities.
NVIDIA's NAND layout includes a partition table that can be used to
generically construct the mtdparts kernel boot argument. As an added
benefit this is completely independent of the underlying NAND part
used which differs with various module versions. It further allows our
customer easy adoption to their own custom partition layout.
Change SD boot bootdevice in environment variable sdargs from mmcblk3p1
to mmcblk0p1 due to later kernels using a different numbering scheme.
While at it clean-up some white space indentation stuff.
Colibri T20 does not use OdmData but rather relies on memory controller
configuration done by boot ROM based on BCT information. Unfortunately
it is possible to at least boot a 256 MB module with a 512 MB BCT
therefore double check whether we really do have that.
Add comment concerning PMIC initialisation of VDD_CPU via VDDCtrl.
User space tools like init just use last console kernel boot argument
as their one and only console. Re-order them in order to output boot
messages on serial debug console.
Examples: Properly append LDFLAGS to LD command
The LD command in examples/standalone/Makefile ignored platform specific
LDFLAGS setup. Pass these LDFLAGS to the command.
Cc: Bryan Hundven <bryanhundven@gmail.com>
Cc: Michael Schwingen <rincewind@discworld.dascon.de>
