Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the
per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the
future.
Done automatically with:
sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I)
Signed-off-by: Ian Campbell <ijc@hellion.org.uk>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
And make TARGET_SUN[45678]I a choice variable under this.
configs updated with:
sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/*
The defconfig for Ippo-q8h-v5 was incorrectly committed as
"Ippo_q8h". This patch renames it correctly, as well as
correct a typo in my name in the maintainers listing.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Hans de Goede <hdegoede@redhat.com>
This patch fix the kwimage tools for version 0 fileformat used for kirkwood
Tested on sheevaplug
Signed-off-by: Gerald Kerma <drEagle@doukki.net>
Tested-by: Stefan Roese <sr@denx.de>
Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
Trivial fix (unless Pantelis has a new email address):
Pantelis Antoniou <panto.antoniou-consulting.com>
make it:
Pantelis Antoniou <panto@antoniou-consulting.com>
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
* Escape use of - in description of -F.
* Fix line continuations in examples so that the continued lines are
also bold.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
These lines originate in Linux; it looks like Linux folks chose to
hide bunch of warnings reported by clang rather than fixing C code.
In U-boot, warnings are being fixed thanks to Jeroen's great efforts.
Let's stop suppressing clang warnings.
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Defining CONFIG_SYS_TEXT_BASE in config.mk is very old style.
Create CONFIG_SYS_TEXT_BASE option in Kconfig, but let it
depend on CONFIG_SPARC because we do not want to disturb
the other architectures that still define CONFIG_SYS_TEXT_BASE
in their header files.
Cc: Daniel Hellstrom <daniel@gaisler.com>
For now, all the SPARC boards in U-Boot are provided by Gaisler.
Remove arch/sparc/cpu/{leon2,leon3}/config.mk and move duplicated
defines of -fPIC to arch/sparc/config.mk.
The Board names in the board select menu were simply taken from the
board directory name by a conversion tool when switching to Kconfig.
Let's use more descriptive prompts taken from
include/configs/gr*.h and board/gaisler/*/config.mk.
While at it, sort them.
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
R8A7791, R8A7793 and R8A7794 have same IP of USB controller.
This collect up address data of each SoCs.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
R8A7793 has same IP of USB controller as R8A7791 and R8A7794 of rmobile
ARM SoCs. This adds support R8A7793 to EHCI HCD of rmobile.
Waiting an interrupt packet to complete in usb_kbd_poll_for_event, causes
a 40 ms latency for each call to usb_kbd_testc, which is undesirable.
Using control messages leads to lower (but still not 0) latency, but some
devices do not work well with control messages (e.g. my kvm behaves funny
with them).
This commit adds support for using the int_queue mechanism which at least
the ehci-hcd driver supports. This allows polling with 0 latency, while
using interrupt packets.
Instead of looking them up every time we need them.
stdio_register makes a malloc-ed copy of struct stdio_dev through stdio_clone,
free the malloc-ed memory on stdio_deregister.
Free the keyboard hid-report buffer and private data on deregister.
This is not used anywhere, so lets remove it.
Preperation patch to use poll_int_queue outside of ehci-hcd.c .
Preperation patch to use create_int_queue outside of ehci-hcd.c .
When periodic_schedules == 0, the schedule is disabled and there is no reason
to disable it again.
Do as the Linux kernel does and power on any ports which are not yet one,
this is enough.
If the device has a parent, it is instantiated from usb_hub_port_connect_change
and the portnr is right there in dev->portnr, so there is no need for this
whole dance to look it up.
Commit 79fd7e649e287228a1445820a72f7dd33baedb96
MIPS: always keep all sections in u-boot ELF binary.
Always keep all sections in u-boot ELF binary. Move all unneeded
sections after _end to avoid allocating space in the final binary.
Also remove .deadcode section which is now obsolete.
removed section .deadcode because the original symptoms were not
visible anymore. Unfortuneatly the binutils bug still exists.
The size of .rel.dyn section is often bigger than needed for all
entries. But objcopy only allocates space as much as required for all
reloc entries. Thus there is a gap between the last entry and
__rel_dyn_end in u-boot.bin. If u-boot is booted from RAM (e.g. in
SPL scenarios) that area could contain garbage data which could lead
to CPU exceptions during relocation.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
Refactor and unify all compiler settings in arch/mips/config.mk.
Also add tune flags for each supported CPU type.
The vct board can be built with various variants which are
configured via CONFIG_SYS_EXTRA_OPTIONS. This is deprecated. Thus
add new Kconfig options for those board variants.
The dbau1x00 board can be built with various variants which are
Now the user can separately select the CPU type. Thus the
targets qemu_mips and qemu_mips64 can be merged to a single
target.
Now the user can select the CPU type for each target. Thus
CONFIG_SYS_CPU could be set globally.
Add new Kconfig option to let the user select the targets
CPU type. Each target have to select SUPPORTS_CPU_MIPS[32,64]_R[1,2]
to indicate which CPU types are supported.
endianess. Each target have to select SUPPORTS_BIG_ENDIAN
and/or SUPPORTS_LITTLE_ENDIAN to indicate which endianess
is supported.
This file is not maintained these days.
We use MAINTAINERS for the maintainership of the supported boards.
For dead boards, we have some clues in doc/README.scrapyard and
also imperishable history in git-log.
Acked-By: Wolfgang Denk <wd@denx.de>
Commit f91c09acf5c58c ("ARM: mx6: Add support for Kosagi Novena") missed to
add a MAINTAINERS file, so add Marek as the maintainer.
Commit d58a9451e733 (ppc/arm: zap EMK boards) removed
TOP* boards support but missed to remove entries in Kconfig.
[1] arch/arm/include/asm/arch-at91/at91_shdwn.h
The top9000 was the last board to use this header file.
It was removed by commit d58a9451e733 (ppc/arm: zap EMK boards).
[2] board/matrix_vision/common/*
Some Matrix Vision boards were dropped by commit e7a565638a7a
(powerpc: mpc83xx: remove board support for MERGERBOX and MVBLM7)
and commit af55e35d3389
(powerpc: mpc5xxx: remove board support for MVBC_P and MVSMR).
Since then these files have been unused.
[3] include/usb/omap1510_udc.h
The omap5912osk was the last board to use this header file.
It was removed by commit 62d636aa2ac2
(omap: remove omap5912osk board support).
This enables the VMMC2 LDO, which powers the MMC2 device.
When the device starts from MMC2, this has already been enabled by the BootROM,
but when starting from peripheral boot (USB, UART), it is not the case.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
This patch fixes a compilation warning of kwbimage.c:
tools/kwbimage.c: In function ‘kwbimage_set_header’:
tools/kwbimage.c:784:8: warning: ‘headersz’ may be used uninitialized in this function [-Wmaybe-uninitialized]
memcpy(ptr, image, headersz);
Instead of using multiple if statements, use a switch statement with
a default entry. And return with error if an unsupported version
is configured in the cfg file.
kwbimage uses get_current_dir_name(3) which is a gnu extension and not
available on darwin host. Fix this by converting to portable getcwd(3)
function.
This patch fixes the following error:
---8<---
HOSTCC tools/kwbimage.o
tools/kwbimage.c:399:16: warning: implicit declaration of function 'get_current_dir_name' is invalid in C99 [-Wimplicit-function-declaration]
char *cwd = get_current_dir_name();
tools/kwbimage.c:399:10: warning: incompatible integer to pointer conversion initializing 'char *' with an expression of type 'int' [-Wint-conversion]
2 warnings generated.
Undefined symbols for architecture x86_64:
"_get_current_dir_name", referenced from:
_image_headersz_v1 in kwbimage.o
ld: symbol(s) not found for architecture x86_64
--->8---
Cc: Stefan Roese <sr@denx.de>
[agust: fixed getcwd() return warning]
Setting gpio value before dm gpio init has no effect,
so now, odroid gpio settings are moved after the gpio uclass init.
Using non-requested gpio pin cases printing error messages.
To avoid this, gpio_request() is added for those gpios.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
This patch adds extra gpio part addresses to exynos4
and exynos4x12_gpio_data arrays, which are required
since the gpio enum lists are linear
