Add a minimalistic Broadcom BCM53xx (roboswitch) switch driver similar
to the Marvell MV88E617x. This takes care of configuring the minimum
amount out of the switch hardware such that each user visible port
(configurable) and the CPU port can forward packets between each other
while preserving isolation with other ports.
This is useful for e.g: the Lamobo R1 board featuring a Broadcom
BCM53125 switch.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
This implementation manages several clocks, disable and
free all of them in case of error during probe and in remove
callback.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Add missing dev_count_phandle_with_args() to avoid
compilation issue.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This patch fixes a problem in the mvneta driver where if more than
one packet arrives between calls to mvneta_recv(), the additional
descriptors will be marked as free even though only one descriptor
has been read and processed from the receive queue. This causes
the additional packet(s) to be delayed until the next packet arrives.
>From this point on all packets will be delayed because the receive
queue will contain unprocessed packets but the hardware shows no
busy descriptors.
Signed-off-by: Jason Brown <jason.brown@apcon.com>
Since the return value is a signed int, if the leading MSB of rdreg is a 1,
it will get signed extended and will return a negative value which is an
error even though we read the correct value.
Fixes: dfcc496ed7e2 ("net: mii: Changes not made by spatch")
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
First, this table could never be included in the build anyway because
SH_ETH_TYPE_RZ is not defined until later in the file.
Second, the register PIR was missing, so PHY MDIO never worked.
Third, after adding the PIR register, the table is EXACTLY the same as
sh_eth_offset_gigabit, so there is no value to it.
Therefore, just delete it use the gigabit one.
The macros inl and outl maybe already be defined from file
arch/arm/include/asm/io.h so there may be no reason to define them.
And if you do try defined them here, you get a redefined complier warning.
This commit allows extended Marvell registers to be read with:
foo > mdio rx FEC 3.10
Reading from bus FEC
PHY at address 0:
3.16 - 0x1063
foo > mdio wx FEC 3.10 0x1011
The above code changes the way ETH connector LEDs blink.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: York Sun <york.sun@nxp.com>
Nothing from this header is used there, so remove it.
Need to not access the byte after the input_buffer.
Reported-by: Coverity (CID: 144423)
Although Xilinx Zynq SoC was using MACB similar hardware. However,
U-boot MACB driver was not supporting Xilinx Zynq SoC. This patch is
to add support for the Xilinx Zynq SoC to the existing MACB network
driver.
This patch is to add Zynq GEM DMA Config, provide callback
function for different linkspeed for case of using Xilinx Zynq
Programmable Logic as GMII to RGMII converter.
This patch convert the return value to use error codes.
Signed-off-by: Wilson Lee <wilson.lee@ni.com>
Cc: Chen Yee Chew <chen.yee.chew@ni.com>
Cc: Keng Soon Cheah <keng.soon.cheah@ni.com>
Cc: Wenyou Yang <wenyou.yang@atmel.com>
With CONFIG_SYS_INIT_SP_BSS_OFFSET enabled, the initial (pre-relocation)
stack is placed some distance after bss_start. The control DTB is appended
to the U-Boot binary at bss_start. If the DTB is too large, or the SP BSS
offset too small, then the initial stack could corrupt the DTB. Enhance
the Makefile to check whether this is likely to occur.
Signed-off-by: Tom Warren <twarren@nvidia.com>
Request that all environment variables containing hard-coded address be
calculated at boot time instead.
In the presence of potentially fragemented memory, we cannot hard-code
addresses into environment variables such as kernel_addr_r. Instead, we
must calculate those addresses at run-time based on available memory
locations. Implement the code to perform such runtime calculation, based
on requirements described in environment variables, to allow the user
full control over the allocation.
Tegra186 currently restricts its DRAM usage to entries in the /memory node
in the DTB passed to it. However, the MMU configuration always maps the
entire first 2GB of RAM. This could allow the CPU to speculatively access
RAM that isn't part of the in-use banks. This patch switches to runtime
construction of the table that's used to construct the MMU translation
tables, and thus prevents access to RAM that's not part of a valid bank.
Note: This patch is intended to prevent access to RAM regions which U-Boot
does not need to access, with the primary purpose of avoiding theoretical
speculative access to physical regions for which the HW will throw errors
(e.g. carve-outs that the CPU has no permission to access at a bus level,
bad ECC pages, etc.). In particular, this patch is not deliberately
related to the speculation-related security issues that were recently
announced. The apparent similarity is a coincidence.
On this platform, there may be up to 1024 unusable chunks of memory.
Increase CONFIG_NR_DRAM_BANKS so that U-Boot can remember all the banks
required to represent such fragmented memory.
In the future, the list of DRAM regions passed to U-Boot in the DTB may
be quite long and fragmented. Due to this, U-Boot must search through the
regions to find the best region to relocate into, rather than relying on
the current assumption that the top of bank 0 is a reasonable relocation
target. This change implements such searching.
arch_lmb_reserve() currently assumes that the stack pointer is within DRAM
bank 0. This is not necessarily true. Enhance the code to search through
DRAM banks until the bank that does contain SP is found, and then reserve
the tail of that bank.
Fixes: 2d1916e48bd8 ("ARM: add flat device tree support")
Apply a few small fixes for the DTB /memory node parsing from NVIDIA's
downstream U-Boot:
- Allow arbitrary number of DRAM banks.
- Correctly calculate the number of DRAM banks.
- Clip PCIe memory in the same way as U-Boot CPU memory use.
Enable CONFIG_LINUX_KERNEL_IMAGE_HEADER for all 64-bit Tegra boards.
cboot (the boot SW that runs before U-Boot) will eventually use this
information.
Allow placing a Linux kernel image header at the start of the U-Boot
binary. This is useful since the image header reports the amount of memory
(BSS and similar) that U-Boot needs to use, but that isn't part of the
binary size. This can be used by the code that loads U-Boot into memory to
determine where to load U-Boot, based on other users of memory.
Enable CONFIG_SYS_INIT_SP_BSS_OFFSET for all 64-bit Tegra boards. Place
the stack/... 512KiB from the end of the U-Boot binary. This should be
plenty to accommodate the current DTBs (max 64 KiB), early malloc region
(6KiB), stack usage, and plenty of slack, while still not placing it too
far away from the U-Boot binary.
U-Boot typically uses a hard-coded value for the stack pointer before
relocation. Implement option SYS_INIT_SP_BSS_OFFSET to instead calculate
the initial SP at run-time. This is useful to avoid hard-coding addresses
into U-Boot, so that can be loaded and executed at arbitrary addresses and
thus avoid using arbitrary addresses at runtime. This option's value is
the offset added to &_bss_start in order to calculate the stack pointer.
This offset should be large enough so that the early malloc region, global
data (gd), and early stack usage do not overlap any appended DTB.
No 64-bit Tegra uses SPL. Remove various unused definitions from config
headers.
64-bit Tegra don't use SPL, and soon won't define CONFIG_SPL_TEXT_BASE
when building. Fix the binman .dts file so that it doesn't use undefined
values.
Current USDHC driver will reset VSELECT to 0 (3.3v) during mmc init,
then set to 1 for 1.8v eMMC I/O. When booting from eMMC, since ROM has
already set VSELECT to 1.8v before running the u-boot. This reset in
USDHC driver causes a short 2.2v pulse on CMD pin.
Fix this issue by not reset VSELECT to 0 when 1.8v flag is set.
Signed-off-by: Ye Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
In order to discard this code when unused in SPL we need to guard the
command with a check for CONFIG_SPL_BUILD and we rearrange the code
slightly to make this cleaner.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
Enable travis-ci support with a link having built.
Signed-off-by: Chih-Mao Chen <cmchen@andestech.com>
Signed-off-by: Rick Chen <rick@andestech.com>
Signed-off-by: Rick Chen <rickchen36@gmail.com>
Signed-off-by: Greentime Hu <green.hu@gmail.com>
Add documents to describe NX25 and AE250.
Also update other documents for RISC-V.
Support common commands bdinfo and image format,
also modify common generic flow for RISC-V.
Run hello_world successfully.
U-Boot 2018.01-rc2-00033-gb265b91-dirty (Dec 22 2017 - 13:54:21 +0800)
DRAM: 1 GiB
MMC: mmc@f0e00000: 0
SF: Detected mx25u1635e with page size 256 Bytes, erase size 4 KiB, total 2 MiB
In: serial@f0300000
Out: serial@f0300000
Err: serial@f0300000
Net:
Warning: mac@e0100000 (eth0) using random MAC address - 0a:47:9b:f8:b4:f2
eth0: mac@e0100000
RISC-V # mmc rescan
RISC-V # fatls mmc 0:1
318907 u-boot-ae250-64.bin
1252 hello_world_ae250_32.bin
328787 u-boot-ae250-32.bin
3 file(s), 0 dir(s)
RISC-V # fatload mmc 0:1 0x600000 hello_world_ae250_32.bin
reading hello_world_ae250_32.bin
1252 bytes read in 23 ms (52.7 KiB/s)
RISC-V # go 0x600000
Example expects ABI version 9
Actual U-Boot ABI version 9
Hello World
argc = 1
argv[0] = "0x600000"
argv[1] = "$B@"
Hit any key to exit ...
RISC-V #
Add prelink-riscv to arrange .rela.dyn and .rela.got
in compile time. So that u-boot can be directly
executed without fixup.
Add nx25-ae250 default configuration for RISC-V
Add nx25-ae250 board configuartion options for RISC-V
Add nx25-ae250 board to do platform initializations.
Add Kconfig and makefile for RISC-V
Also modify MAINTAINERS for it.
Cc: Padmarao Begari <Padmarao.Begari@microsemi.com>
Add header files for RISC-V.
Cache, ptregs, data type and other definitions are included.
AE250 is the Soc using NX25 cpu core base on RISC-V arch.
Details please see the doc/README.ae250.
Add makefile, interrupts.c and boot.c,... functions
to support RISC-V arch.
Add Andes nx25 cpu core (called AndesStar V5) to support RISC-V arch
Verifications:
1. startup and relocation ok.
2. boot from rom or ram both ok.
2. timer driver ok.
3. uart driver ok
4. mmc driver ok
5. spi driver ok.
6. 32/64 bit both ok.
Detail verification message please see doc/README.ae250.
hc_wp_grp_size is needed only if hardware partitionning is used.
On ARM removing it saves about 30 bytes of code space.
Signed-off-by: Jean-Jacques Hiblot <jjhiblot@ti.com>
This information is only used by the "mmc info" command.
On ARM removing this information from SPL saves about 140 of code space.
enabled
Also remove erase_grp_size and write_bl_len from struct mmc as they are
not used anymore. On ARM, removing them saves about 100 bytes of code
space in SPL.
The content of ssr is useful only for erase operations.
on ARM, removing sd_read_ssr() saves around 300 bytes.
This allows using CONFIG_IS_ENABLED(MMC_WRITE) to compile out code
needed only if write support is required.
The option is added for u-boot and for SPL
Using a table versus a switch() structure saves a bit of space
struct mmc_data contains the block size to use for the data transfer.
Use this information instead of using the default value or the block length
information stored in struct mmc.
