This patch extends pmic_bind_children prefix matching. In addition to
the node name the property regulator-name is used while trying to match
prefixes. This allows assigning different drivers to regulator nodes
named regulator@1 and regulator@10 for example.
I have discarded the idea of using other properties then regulator-name
as I do not see any benefit in using property compatible or even
regulator-compatible. Of course I am open to change this if there are
good reasons to do so.
Signed-off-by: Felix Brack <fb@ltec.ch>
The DM version of do_reset has been issuing a warm-reset, which (on
some platforms keeps GPIOs and other parts of the platform active).
This may cause unintended behaviour, as calling do_reset usually
indicates a desire to reset the board/platform and not just the CPU.
This changes do_reset to always request a COLD reset.
Note that programmatic uses can still invoke a WARM reset through
reset_cpu() or using sysreset_walk().
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Update tegra to use binman for image creation. This still includes the
current Makefile logic, but a later patch will remove this. Three output
files are created, all of which combine
SPL and U-Boot:
u-boot-tegra.bin - standard image
u-boot-dtb-tegra.bin - same as u-boot-tegra.bin
u-boot-nodtb-target.bin - includes U-Boot without the appended device tree
The latter is useful for build systems where the device is appended later,
perhaps after being modified.
Add this feature to the README.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
SPL supports reading U-Boot from a RAM location. At present this is
hard-coded to the U-Boot text base address. Use binman to allow this to
come from the image file, if binman is used.
Allow SPL to access binman symbols and use this to get the address of
U-Boot. This falls back to CONFIG_SYS_TEXT_BASE if the binman symbol
is not available.
This area of the image contains symbols whose values are filled in by
binman. If this feature is not used, the table is empty.
Add this to the ARM SPL link script.
Binman construct images consisting of multiple binary files. These files
sometimes need to know (at run timme) where their peers are located. For
example, SPL may want to know where U-Boot is located in the image, so
that it can jump to U-Boot correctly on boot.
In general the positions where the binaries end up after binman has
finished packing them cannot be known at compile time. One reason for
this is that binman does not know the size of the binaries until
everything is compiled, linked and converted to binaries with objcopy.
To make this work, we add a feature to binman which checks each binary
for symbol names starting with '_binman'. These are then decoded to figure
out which entry and property they refer to. Then binman writes the value
of this symbol into the appropriate binary. With this, the symbol will
have the correct value at run time.
Macros are used to make this easier to use. As an example, this declares
a symbol that will access the 'u-boot-spl' entry to find the 'pos' value
(i.e. the position of SPL in the image):
binman_sym_declare(unsigned long, u_boot_spl, pos);
This converts to a symbol called '_binman_u_boot_spl_prop_pos' in any
binary that includes it. Binman then updates the value in that binary,
ensuring that it can be accessed at runtime with:
ulong u_boot_pos = binman_sym(ulong, u_boot_spl, pos);
This assigns the variable u_boot_pos to the position of SPL in the image.
The elf module can provide some debugging information to assist with
figuring out what is going wrong. This is also useful in tests. Update the
-D option so that it is passed through to tests as well.
This is only 3 bytes long which is not enough to hold two symbol values,
needed to test the binman symbols feature. Increase it to 15 bytes.
Using very small regions is useful since we can easily compare them in
tests and errors are fairly easy to diagnose.
For testing we need to build some ELF files containing binman symbols. Add
these to the Makefile and check in the binaries:
u_boot_binman_syms - normal, valid ELF file
u_boot_binman_syms_bad - missing the __image_copy_start symbol
u_boot_binman_syms_size - has a binman symbol with an invalid size
This feature is now supported. Drop the incorrect comment.
This file contains SPL image without a device tree. Add support for
including this in images.
This file contains the SPL device tree. Add support for including this by
itself in images.
In some cases we need to read symbols from U-Boot. At present we have a
a few cases which does this via 'nm' and 'grep'.
It is better to use objdump since that tells us the size of the symbols
and also whether it is weak or not.
Add a new module which reads ELF information from files. Update existing
uses of 'nm' to use this module.
This symbol enables some library code used by various SATA drivers,
so make this a non-user-visible symbol select'ed by the respective
drivers, and let moveconfig handle the rest.
And use 'imply' liberally.
Use 'imply' here liberally to avoid the combinatorial explosion of
defconfig changes in the PowerPC boards.
The last user of this driver went away in August 2015 in commit:
b6073fd2115 ("arm: Remove mx51_efikamx, mx51_efikasb boards")
The last user of this driver went away in June 2017, in commit:
98f705c9ce ("powerpc: remove 4xx support")
This driver really is DM GPIO one and so we need to have a correct
dependency, because DM alone doesn't provide required for CMD_GPIO
call and we're seeing build failures like this:
---------------------->8---------------------
cmd/built-in.o: In function 'do_gpio':
.../cmd/gpio.c:188: undefined reference to 'gpio_request'
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Eugeniy Paltsev <paltsev@synopsys.com>
It is tedious to define both mask and bit-shift. <linux/bitfield.h>
provides a convenient way to get access to register fields with a
single shifted mask.
Use DIV_ROUND_CLOSEST(). To make the JK value even more precise,
I used a bigger coefficient, then divide it by 512.
Commit 682e09ff9f35 ("ARM: uniphier: add PLL init code for LD20 SoC")
missed to write the computed value to the SSCPLLCTRL2 register.
Fixes: 682e09ff9f35 ("ARM: uniphier: add PLL init code for LD20 SoC")
Signed-off-by: Dai Okamura <okamura.dai@socionext.com>
denali.c has no driver entry in itself. It makes sense only when
compiled together with denali_dt.c
Let NAND_DENALI_DT select NAND_DENALI, and hide NAND_DENALI from
the Kconfig menu.
Fix the link error for the combination of
CONFIG_ARCH_UNIPHIER_LD11=n
CONFIG_ARCH_UNIPHIER_LD20=n
CONFIG_ARCH_UNIPHIER_PXS3=y
Synopsys HSDK clock controller generates and supplies clocks to various
controllers and peripherals within the SoC.
Each clock has assigned identifier and client device tree nodes can use
this identifier to specify the clock which they consume. All available
clocks are defined as preprocessor macros in the
dt-bindings/clock/snps,hsdk-cgu.h header and can be used in device
tree sources.
Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com>
dcache_exists, icache_exists, slc_exists and ioc_exists global
variables in "arch/arc/lib/cache.c" remain uninitialized if
SoC doesn't have corresponding HW.
This happens because we use the next constructions for their
definition and initialization:
int ioc_exists __section(".data");
if (/* condition */)
ioc_exists = 1;
That's quite a non-trivial issue as one may think of it.
The point is we intentionally put those variables in ".data" section
so they might survive relocation (remember we initilaize them very early
before relocation and continue to use after reloaction). While being
non-initialized and not explicitly put in .data section they would end-up
in ".bss" section which by definition is filled with zeroes.
But since we place those variables in .data section we need to care
about their proper initialization ourselves.
Also while at it we change their type to "bool" as more appropriate.
ARCNUM [15:8] field in ARC_AUX_IDENTITY register allows us to
uniquely identify each core in a multi-core system.
I.e. with help of this macro each core may get its index in SMP system.
DW SDIO controller has external CIU clock divider controlled via
register in the SDIO IP. Due to its unexpected default value
(we expected it to divide by 1 but in reality it divides by 8)
SDIO IP uses wrong CIU clock (it should be 100000000Hz but actual
is 12500000Hz) and works unstable (see STAR 9001204800).
So increase SDIO CIU frequency from actual 12500000Hz to 50000000Hz
by switching from the default divisor value (div-by-8) to the
minimum possible value of the divisor (div-by-2) in HSDK platform
code.
With CONFIG_CMD_GPIO compilation reports error:
-------------------------->8---------------------
common/cmd_gpio.c:13:22: fatal error: asm/gpio.h: No such file or directory
#include <asm/gpio.h>
Linux preserves leading zeros in /proc/cpuinfo, so we
should as well.
Otherwise we have the situation that
/sys/firmware/devicetree/base/serial-number
and /proc/cpuinfo disagree in Linux.
Signed-off-by: Jakob Unterwurzacher <jakob.unterwurzacher@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Commit 21f4486faa5d ("armv8: update gd after relocate") sets x18
without checking the return value of spl_relocate_stack_gd().
Signed-off-by: York Sun <york.sun@nxp.com>
CC: Kever Yang <kever.yang@rock-chips.com>
CC: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Add documentation for the log system.
Add a test which tries out various filters and options to make sure that
logging works as expected.
Enable all logging features on sandbox so that the tests can be run.
Set up logging both before and after relocation.
Add a command which exercises the logging system.
