2006-10-09Add support for EP82xxM boardsWolfgang Denk
Patch by Aaron Sells, 20 Jun 2006
2006-10-08Merge with git+ssh://fifi/home/wd/git/u-boot/masterWolfgang Denk
2006-10-05Merge with /home/m8/git/u-bootWolfgang Denk
2006-10-04Fix TLB setup for Ocotea boardStefan Roese
Patch by Stefan Roese, 30 Sep 2006
2006-10-04Fix reset problem in sequoia sdram init codeStefan Roese
Patch by Stefan Roese, 23 Sep 2006
2006-10-03Update for CAM5200 board:Marian Balakowicz
- Map in a additional chip selects CS4 and CS5. - Modify the port configration, configure six UARTs and no PCI, ATA and USB. - Add custom flash driver to handle specific byte swapping
2006-09-20Fix comments in include/ppc440.hWolfgang Denk
Patch by Martin Hicks, 16 Jun 2006
2006-09-13Add support for AMCC Rainier PPX440GRx eval boardStefan Roese
Patch by Stefan Roese, 13 Sep 2006
2006-09-13Disable autoboot abort for FO300 when silent mode is enabledWolfgang Denk
(according to S1 switch setting). Patch by Marian Balakowicz, 12 Sep 2006
2006-09-13Cleanup examples binariesWolfgang Denk
2006-09-13Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-09-13Fix alignment problem in "mtdparts" commandWolfgang Denk
2006-09-12Add NAND environment support for PPC440EPx Sequoia NAND boot configStefan Roese
Patch by Stefan Roese, 12 Sep 2006
2006-09-12Update NAND boot documentationStefan Roese
2006-09-09Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-07Add documentation on the latest build environment extentions toMarian Balakowicz
the README file.
2006-09-07Fix build problem cpu/ppc4xx/ndfc.cStefan Roese
Patch by Stefan Roese, 07 Sep 2006
2006-09-07Fix build problem with CPCI440Stefan Roese
2006-09-07Change Yellowstone to use CFI write bufferStefan Roese
Patch by Stefan Roese, 07 Aug 2006
2006-09-07Remove dead code (i2o and dma) from cpu/mpc824x/drivers/ directory.Marian Balakowicz
2006-09-07Fix LOG_DIR directory creation error.Marian Balakowicz
Add support for automatic creation of BUILD_DIR directory.
2006-09-07Add support for AMCC Sequoia PPC440EPx eval boardStefan Roese
- Add support for PPC440EPx & PPC440GRx - Add support for PPC440EP(x)/GR(x) NAND controller in cpu/ppc4xx directory - Add NAND boot functionality for Sequoia board, please see doc/README.nand-boot-ppc440 for details - This Sequoia NAND image doesn't support environment in NAND for now. This will be added in a short while. Patch by Stefan Roese, 07 Sep 2006
2006-09-06Fix mkimage -l bug with multifile images on 64bit platformsWolfgang Denk
Patch by David Updegraff, 06 Sep 2006
2006-09-04Fix build problems on sorcery board.Wolfgang Denk
2006-09-04Merge with /home/m8/git/u-bootWolfgang Denk
2006-09-03Fixed problems on PRS200 board caused by adding splash screen on MCC200Wolfgang Denk
2006-09-03Merge with /home/wd/git/u-boot/masterWolfgang Denk
2006-09-01Remove the board/netstar/crcit binary from git repository.Marian Balakowicz
2006-09-01Fix tools/updater build error.Marian Balakowicz
2006-09-01tools/easylogo/easylogo.cMarian Balakowicz
2006-09-01Added David Updegraff as maintainer of CRAYL1Detlev Zundel
2006-09-01Added changelog entry for previous small commits and extended README onDetlev Zundel
coding style.
2006-09-01Added another example showing simple interrupt interception.Detlev Zundel
2006-09-01Added simple_strtoul(), getenv() and setenv() to the exported functions.Detlev Zundel
Also bumped up ABI version to reflect this change.
2006-09-01Added interrupt handling capabilities for mpc5xxx processors.Detlev Zundel
Also added Linux like BUG() macros.
2006-08-31Coding Style cleanup.Wolfgang Denk
Patch by Stefano Babic, 31 Aug 2006
2006-08-30Add splashscreen support for MCC200 board.Wolfgang Denk
2006-08-30Make the serial driver framework work with CONFIG_SERIAL_MULTI enabledWolfgang Denk
2006-08-29Merge with /home/sr/git/u-boot/denxWolfgang Denk
2006-08-29Fix typo.Wolfgang Denk
2006-08-29PCIe endpoint support for AMCC Yucca 440SPe boardStefan Roese
Patch by Tirumala R Marri, 26 Aug 2006
2006-08-29Improve DIMM detection for AMCC Yucca 440SPe boardStefan Roese
Improved the memory DIMM detection for the Yucca 440SPe board for the case where a memory DIMM is falsely detected as present. This issue is seen on some AMCC Yucca 440SPe validation boards if only one 512MB memory DIMM is installed, i.e. DIMM slot 0 is populated and DIMM slot 1 is empty. In this case, U-Boot does not correctly detect that there is only one DIMM memory module installed and will falsely detect two DIMM memory modules are present and therefore U-Boot will not calculate the correct amount of total memory and u-boot will not booting up. Patch by Adam Graham, 24 Aug 2006
2006-08-27Code cleanupWolfgang Denk
2006-08-25Fix typo in MCC200/PRS200 configurationWolfgang Denk
2006-08-25Update for MCC200 / PRS200 boards:Wolfgang Denk
- auto-adjust console device for Linux. - fix typos.
2006-08-25Merge with /home/tur/proj/fo300/u-bootWolfgang Denk
2006-08-24Updates for MCC200 / PRS200 boards:Wolfgang Denk
- support for configurations with SDRAM or DDR memory, - support for highboot and lowboot - adjusting environment definitions
2006-08-22Add a fix for a buggy USB device on the FO300 board.Bartlomiej Sieka
2006-08-18Minor cleanupWolfgang Denk
