2015-06-12ARM: DRA7: Make do_set_mux32() genericLokesh Vutla
do_set_mux32() is redefined in dra7xx and beagle_x15 boards. IO delay recalibration sequence also needs this. Making it generic to avoid duplication. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Nishanth Menon <nm@ti.com>
2015-06-12ARM: DRA7xx: EMIF: Fix DLL_CALIB_CTRL registerLokesh Vutla
When DLL_CALIB_INTERVAL is set, an extra delay is added which is not required and it consumes EMIF bandwidth. So making the DLL_CALIB_CTRL[8:0]DLL_CALIB_INTERVAL bits to 0. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2015-06-12ARM: DRA7: Update DDR IO registersLokesh Vutla
Update DDR IO register values. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: Update DDR IO configurationLokesh Vutla
DDRIO_2 and LPDDR2CH1_1 registers are not present for DRA7. So not configuring these registers for DRA7xx Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: Add is_dra72x cpu check definitionLokesh Vutla
A generic is_dra72x cpu check is useful for grouping all the revisions under that. This is used in the subsequent patches. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA72-evm: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on DRA72-evm. Also updating the timing registers. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7-evm: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on DRA7-evm. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: BeagleBoard-X15: Enable HW levelingLokesh Vutla
Updating EMIF registers to enable HW leveling on BeagleBoard-X15. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12ARM: DRA7: DDR3: Add support for HW levelingLokesh Vutla
DRA7 EMIF supports Full leveling for DDR3. Adding support for the Full leveling sequence. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-06-12kconfiglib: sync with the latest in Kconfiglib projectMasahiro Yamada
This commit imports some updates of kconfiglib.py from https://github.com/ulfalizer/Kconfiglib - Warn about and ignore the "allnoconfig_y" Kconfig option - Statements in choices inherit menu/if deps - Add Symbol.is_allnoconfig_y() - Hint that modules are still supported despite warnings. - Add warning related to get_defconfig_filename(). - Fix typo in docs. - Allow digits in $-references to symbols. Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Signed-off-by: Philip Craig <philipjcraig@gmail.com> Signed-off-by: Jakub Sitnicki <jsitnicki@gmail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-12Nokia RX-51: Fix calculating return address in save_boot_paramsPali Rohár
Commit e11c6c279d823dc0d2f470c5c2e3c0a9854a640f broke calculating lr register in function save_boot_params() and caused U-Boot to crash at early boot time on Nokia N900 board. This patch fix calculating return address in lr register and make Nokia N900 board bootable again. Patch was tested in qemu and also on real N900 HW. Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
2015-06-11Merge git://git.denx.de/u-boot-dmTom Rini
2015-06-11common/cmd_bdinfo: show gd->board_typeHannes Schmelzer
sometimes it is usefull to know if board-detection has written the correct value into gd->board_type. For this we add some output to the bdinfo command. Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
2015-06-11blackfin: fix undefined reference to srand and randMasahiro Yamada
Commit 9ba9e85f3f1c (net: Fix NET_RANDOM_ETHADDR dependencies) accidentally dropped CONFIG_LIB_RAND defines for 14 Blackfin boards. Prior to that commit, those boards defined CONFIG_LIB_RAND, but not CONFIG_NET_RANDOM_ETHADDR. So, commit 9ba9e85f3f1c should not have touched them, but in fact it ripped CONFIG_LIB_RAND off from all the header files, which caused undefined reference to srand and rand. CONFIG_LIB_RAND=y must be revived for such boards. BTW, this commit indeed makes it better, but even with this fix, three boards (bf533-stamp, bf538f-ezkit, cm-bf548) still can not build due to region 'ram' overflowed error. This was cause by commit 6eed3786c68c (net: Move the CMD_NET config to defconfigs) because CMD_NET selects NET, and NET selects REGEX. Eventually, some boards were newly enabled with CONFIG_REGEX, increasing the memory footprint. A patch is expected to fix the build error. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-11README.scrapyard: add entries for dead AVR32 boardsMasahiro Yamada
Some AVR32 boards were dropped by the following commits: 9eb45aabe078 (avr32: delete non generic board favr-32-ezkit) e36930764471 (avr32: delete non generic board hammerhead) c62d2f8fc5c6 (avr32: delete non generic board mimc200) e5354b8a9e2a (avr32: delete non generic board's atstk100{3, 4, 6}) Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-10Merge branch 'master' of http://git.denx.de/u-boot-samsungTom Rini
2015-06-10dm: usb: tegra: Drop legacy USB codeSimon Glass
Drop the code that doesn't use driver model for USB. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10sandbox: Move CONFIG_SANDBOX_SERIAL to KconfigSimon Glass
Move this over to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10Remove SPL undefine of CONFIG_OF_CONTROLSimon Glass
Allow SPL to be built with this option so that we can support device tree control. Disable the simple bus for now in SPL. It may be needed later. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10Add a simple version of memalign()Simon Glass
This is used when the full malloc() is not available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dm: serial: Don't support CONFIG_CONS_INDEX with device treeSimon Glass
This feature should be deprecated for new boards, and significantly adds to SPL code size. Drop it. Instead, we can use stdout-path in the /chosen node. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dts: Disable device tree for SPL on all boardsSimon Glass
We plan to enable device tree in SPL by default. Before doing this, explicitly disable it for all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10fdt: arm: Drop device tree paddingSimon Glass
The 4KB padding doesn't seem necessary since we don't normally adjust the control device tree file within U-Boot. Also drop the memory table space. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dm: ns16550: Support CONFIG_SYS_NS16550_MEM32 with driver modelSimon Glass
This option is used by some boards, so support it with driver model. This is really ugly - we should rewrite this driver once all users are moved to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10lcd: Support colour lookup table on 16bpp display in BMP imagesSimon Glass
For 16-bit-per-pixel displays it is useful to support 8 bit-per-pixel images to reduce image size. Add support for this when drawing BMP images. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10Remove typedefs from bmp_layout.hSimon Glass
We try to avoid typedefs and these ones are easy enough to remove. Before changing this header in the next patch, remove the typedefs. Signed-off-by: Simon Glass <sjg@chromium.org> Suggested-by: Joe Hershberger <joe.hershberger@gmail.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-06-10sandbox: Add an implementation for cleanup_before_linux_select()Simon Glass
Support this function so we can use Chrome OS verified boot with sandbox. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10arm: Allow cleanup_before_linux() without disabling cachesSimon Glass
This function is used before jumping to U-Boot, but in that case we don't always want to disable caches. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Vadim Bendebury <vbendeb@chromium.org>
2015-06-10arm: spl: Add an API to detect when U-Boot is started from SPLSimon Glass
For secure boot systems it is common to have a read-only U-Boot which starts the machine and jumps to a read-write U-Boot for actual booting the OS. This allows the read-write U-Boot to be upgraded without risk of permanently bricking the machine. In the event that the read-write U-Boot is corrupted, the read-only U-Boot can detect this with a checksum and boot into a recovery flow. To support this, add a way to detect when U-Boot is run from SPL as opposed to some other method, such as booted directly (no SPL) or started from another source (e.g. a primary U-Boot). This works by putting a special value in r0. For now we rely on board-specific code to actually check the register and set a flag. At some point this could be generalised, perhaps by using a spare register and passing a flag to _main and/or board_init_f(). This commit does not implement any feature, but merely provides the API for boards to implement. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dm: usb: Implement usb_detect_change() for driver modelSimon Glass
Support this function with driver model also (CONFIG_DM_USB). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-06-10dm: tegra: usb: Move USB to driver modelSimon Glass
Somehow this change was dropped in the various merges. I noticed when I came to turn off the non-driver-model support for Tegra. We need to make this change (and deal with any problems) before going further. Change-Id: Ib9389a0d41008014eb0df0df98c27be65bc79ce6 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2015-06-10dm: i2c: Add compatibility functions for dm_i2c_reg_read/write()Simon Glass
Add the legacy i2c_reg_read/write() functions to the compatibility layer so that they can be used when CONFIG_DM_I2C_COMPAT is defined. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-06-10Merge branch 'master' of http://git.denx.de/u-boot-sunxiTom Rini
2015-06-10sunxi: Enable CONFIG_SYS_64BIT_LBA when AHCI is usedBernhard Nortmann
Due to absence of CONFIG_SYS_64BIT_LBA, u-boot-sunxi currently has no support for the (GPT) partioning scheme of large disks > 2TB. While the AHCI driver seems to handle this nicely, the problem is that lbaint_t values get truncated to 32-bit. This patch sets CONFIG_SYS_64BIT_LBA from sunxi_common.h for all SoCs that support AHCI (CONFIG_SUNXI_AHCI). Signed-off-by: Bernhard Nortmann <bernhard.nortmann@web.de> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-06-10sunxi: Request macpwr gpio before using itHans de Goede
This fixes ethernet no longer working on boards which use a gpio to enable the phy. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-06-10Merge branch 'master' of git://git.denx.de/u-boot-avr32Tom Rini
2015-06-10avr32: delete ancient board.cAndreas Bießmann
2015-06-10avr32: take maintainership for atstk1002Andreas Bießmann
I have this board at work, so I can trun tests on it. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-06-10avr32: delete non generic board's atstk100{3, 4, 6}Andreas Bießmann
2015-06-10avr32: delete non generic board mimc200Andreas Bießmann
2015-06-10avr32: delete non generic board hammerheadAndreas Bießmann
2015-06-10avr32: delete non generic board favr-32-ezkitAndreas Bießmann
2015-06-10atngw100: convert to generic boardAndreas Bießmann
2015-06-10odroid: dts: cleanup of MAX77686 regulatorsPrzemyslaw Marczak
This commit cleanup MAX77686 regulator node by: - remove the sub-nodes of unconnected regulators - remove the "regulator-compatible" properties of all regulators This prevents printing init errors for the regulators, with duplicated name strings. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-06-09tegra: config: nyan-big: Add options required by Chrome OS bootSimon Glass
We need to match the device tree in the FIT with the U-Boot model so we can automatically select the right device tree. Also adjust the load address so that the device tree is not in the way when a zImage kernel tries to extract itself. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: Replace 'Norrin' with 'Nyan-big' and fix typoSimon Glass
With the rename the MAINTAINER file was not updated. Fix it and the 'Chrombook' typo in Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: config: Allow Chrome OS environment settings to be includedSimon Glass
Bring these in if they are provided by the board. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: nyan-big: Add additional clock and kernel initSimon Glass
We need to turn on all audio-related clocks for the Chrome OS kernel to boot. Otherwise it will hang when trying to enable audio. Also for Linux set up graphics driver video protection. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: Allow board-specific initSimon Glass
Add a hook to allows boards to add their own init to board_init(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-09tegra: lcd: Tidy up clock initSimon Glass
Use the correct function for clock init. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
