SY8106A is a PMIC which is used on the Allwinner
H3 Orange Pi Pc and Plus board. The VOUT1_SEL register is
implemented to set the default V-CPU voltage to 1200 mV.
This driver is required to ensure the SY8106A V-CPU
voltage is set to 1200 mV after a software reset. On cold
boot the default SY8106A output voltage is selected to be
1200 mV by a pair of resistors on the Orange Pi PC and Plus.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Tested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
In current design, if any peripheral was assigned to both A7 and M4,
it will receive ipg_stop or ipg_wait when any of the 2 platforms
enter low power mode. We will have a risk that, if A7 enter wait,
M4 enter stop, peripheral will have chance to get ipg_stop and ipg_wait
asserted same time. Also if M4 enters stop mode, A7 will have no
chance to access the peripheral.
There are 26 peripherals affected by this IC issue:
SIM2(sim2/emvsim2)
SIM1(sim1/emvsim1)
UART1/UART2/UART3/UART4/UART5/UART6/UART7
SAI1/SAI2/SAI3
WDOG1/WDOG2/WDOG3/WDOG4
GPT1/GPT2/GPT3/GPT4
PWM1/PWM2/PWM3/PWM4
ENET1/ENET2
Software Workaround:
The solution is to set the peripherals to Domain0 by A core, since A core
in Domain0. The peripherals which will be used by M4, will be set to Domain1
by M4.
For example, A core set WDOG4 to domain0, but when M4 boots up, M4 will
set WDOG4 to domain1, because M4 will use WDOG4.
So the peripherals are not shared by them. This way requires
the uboot implemented the RDC driver and set the 26 IPs above
to domain 0 only. M4 image will set the M4 to domain 1 and
set peripheral which it will use to domain 1.
This patch enables the CONFIG_IMX_RDC and CONFIG_IMX_BOOTAUX for
i.MX7D SABRESD board, and setup the 26 IP resources to domain 0.
Signed-off-by: Ye.Li <ye.li@nxp.com>
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Introduce macros and command to support booting M4 core for
i.MX7D SabreSD board.
Implement arch_auxiliary_core_up and arch_auxiliary_core_check_up.
arch_auxiliary_core_check_up is used to check whether M4 is running
or not. arch_auxiliary_core_up is to boot M4 core, the m4 core will
use the pc and stack which is set in arch_auxiliary_core_up to set R15
and R13 register and boot.
i.MX6SX SabreSD board.
To boot a auxiliary core in asymmetric multicore system, introduce the
new command "bootaux" to do it. Example of boot auxliary core from
0x70000000 where stores the boot head information that should be
parsed by auxiliary core, "bootaux 0x70000000".
Introduce Kconfig option IMX_BOOTAUX.
If CONFIG_IMX_RDC is enabled, enable clock for RDC and SEMAPHORE.
Add the peripherals/masters definitions and registers base addresses
for mx7d RDC.
Add the definitions for the RDC mappings for i.MX6 SoloX.
Introduce Resource Domain Controller support for i.MX.
Now i.MX6SX and i.MX7D supports this feature to assign masters
and peripherals to different domains.
Introudce rdc regs structure and rdc sema reg structure for i.MX6.
For now, to i.MX6, only i.MX6SX supports this.
Add board_mmc_getcd function and declare CD_GPIO for SDCard.
Signed-off-by: Julien Corjon <corjon.j@ecagroup.com>
Specify max_bus_width directly in usdhc_cfg static definition instead
of tweaking it in the board_mmc_init() function.
USDHC2 does not exist on mx6quq7 board, as USDHC4 was already been
declared this is probably a typo.
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Implement board specific functions to select the environment device and
partition when booting from SD/MMC.
SD2: mmc 0 0
SD3: mmc 1 0
eMMC: mmc 2 1
Signed-off-by: Soeren Moch <smoch@web.de>
commit 216d286c7e3d3d83d4d8ccaf0415192e1b1040c0 [imx: mx6: implement
mmc_get_env_dev] introduced selection of the environment device according
to the boot device when booting from SD/MMC.
Extend this functionality for also selecting the device partition.
Introudce i.MX7 pinctrl driver support.
For now only i.MX7D supported.
There are two iomux controllers in i.MX7D, iomuxc and iomuxc_lpsr.
To iomuxc_lpsr, ZERO_OFFSET_VALID is set, means offset of mux_reg
and conf_reg can begin at 0.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Introduce pinctrl for i.MX6
1. pinctrl-imx.c is for common usage. It's used by i.MX6/7.
2. Add PINCTRL_IMX PINCTRL_IMX6 Kconfig entry.
3. To the pinctrl_ops implementation, only set_state is implemented.
To i.MX6/7, the pinctrl dts entry is as following:
&iomuxc {
pinctrl-names = "default";
pinctrl_csi1: csi1grp {
fsl,pins = <
MX6UL_PAD_CSI_MCLK__CSI_MCLK 0x1b088
MX6UL_PAD_CSI_PIXCLK__CSI_PIXCLK 0x1b088
MX6UL_PAD_CSI_VSYNC__CSI_VSYNC 0x1b088
there is no property named function or groups. So pinctrl_generic_set_state
can not be used here.
5. This driver is a simple implementation for i.mx iomux controller,
only parse the fsl,pins property and write value to registers.
6. With DEBUG enabled, we can see log when "i2c bus 0":
set_state_simple op missing
imx_pinctrl_set_state: i2c1grp
mux_reg 0x14c, conf_reg 0x3bc, input_reg 0x5d8, mux_mode 0x0, input_val 0x1, config_val 0x4000007f
write mux: offset 0x14c val 0x10
select_input: offset 0x5d8 val 0x1
write config: offset 0x3bc val 0x7f
mux_reg 0x148, conf_reg 0x3b8, input_reg 0x5d4, mux_mode 0x0, input_val 0x1, config_val 0x4000007f
write mux: offset 0x148 val 0x10
select_input: offset 0x5d4 val 0x1
write config: offset 0x3b8 val 0x7f
this means imx6 pinctrl driver works as expected.
Refactored data structure for CAAM's job ring and Secure Memory
to support i.MX7.
The new memory map use macros to resolve SM's offset by version.
This will solve the versioning issue caused by the new version of
secure memory of i.MX7
Signed-off-by: Ulises Cardenas <raul.casas@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
When running the 'ums' command we get:
=> ums 0 mmc 0
UMS: disk start sector: 0x0, count: 0xe18000
g_dnl_register: failed!, error: -22
ERROR: g_dnl_register failed
at common/cmd_usb_mass_storage.c:107/do_usb_mass_storage()
Fix this by initializing USB OTG1 port as USB device mode instead of host.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Use the new NXP email address for the board maintainer.
Select CONFIG_FSL_QSPI so that the SPI can be probed:
=> sf probe
SF: Detected N25Q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Commit 276d3ebb883024d753cd9c69ab2fd243ffa1262e removed htole32() but missed
to remove the corresponding header. This is annoying, since BSD systems do not
have endian.h.
Acked-by: Michael Heimpold <mhei@heimpold.de>
Update existing documentation to mention Intel Bayley Bay board
instructions, an additional Bay Trail based board to MinnowMax.
This also adds a minor change to QEMU section to indicate clearly
the instructions are for bare mode.
This adds basic support to Intel Cougar Canyon 2 board, a board
based on Chief River platform with an Ivy Bridge processor and
a Panther Point chipset.
Wrap initialization codes with #ifndef CONFIG_HAVE_FSP #endif,
and enable the build for both FSP and non-FSP configurations.
Intel IvyBridge FSP seems to be buggy that it does not report memory
used by FSP itself as reserved in the resource descriptor HOB. The
FSP specification does not describe how resource descriptor HOBs are
generated by the FSP to describe what memory regions. It looks newer
FSPs like Queensbay and BayTrail do not have such issue. This causes
U-Boot relocation overwrites the important boot service data which is
used by FSP, and the subsequent call to fsp_notify() will fail.
To resolve this, we find out the lowest memory base address allocated
by FSP for the boot service data when walking through the HOB list in
fsp_get_usable_lowmem_top(). Check whether the memory top address is
below the FSP HOB list, and if not, use the lowest memory base address
allocated by FSP as the memory top address.
Tested on link (ivybridge non-FSP)
The SMSC SIO1007 superio chipset integrates two ns16550 compatible
serial ports for legacy applications, 16 GPIO pins and some other
functionalities like power management.
This adds a simple driver to enable serial port and handle GPIO.
IvyBridge FSP package is built with a base address at 0xfff80000,
and does not use UPD data region. This adds basic FSP support.
Purely by code inspection, it looks like the parameter order to memalign()
is swapped; its parameters are (align, size). 4096 is a likely desired
alignment, and a variable named size sounds like a size:-)
Fixes: 45b5a37836d5 ("x86: Add multi-processor init")
Tested-by: Bin Meng <bmeng.cn@gmail.com>
Cc: Gregory CLEMENT <gregory.clement@free-electrons.com>
With release of ARC HS38 v2.1 new IO coherency engine could be built-in
ARC core. This hardware module ensures coherency between DMA-ed data
from peripherals and L2 cache.
With L2 and IOC enabled there's no overhead for L2 cache manual
maintenance which results in significantly improved IO bandwidth.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
ARC core could be configured with different L1 and L2 (AKA SLC) cache
line lengths. At least these values are possible and were really used:
32, 64 or 128 bytes.
Current implementation requires cache line to be selected upon U-Boot
configuration and then it will only work on matching hardware. Indeed
this is quite efficient because cache line length gets hardcoded during
code compilation. But OTOH it makes binary less portable.
With this commit we allow U-Boot to determine real L1 cache line length
early in runtime and use this value later on. This extends portability
of U-Boot binary a lot.
Since commit fd61d39970b9901217efc7536d9f3a61b4e1752a:
spl: mmc: add break statements in spl_mmc_load_image()
RAW and FS boot modes are now exclusive again. So, if MMCSD_MODE_RAW fails, the
board hangs. This patch allows to try MMCSD_MODE_FS then.
It has been tested on a beaglebone black to boot on an EXT partition.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
Cc: Matwey V. Kornilov <matwey.kornilov@gmail.com>
Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
The Versatile Industrial Communication platform is a community oriented
board from Landis + Gyr. It comes with:
- an RS-485 port
- 2 Ethernet ports
- a wireless M-BUS
- a 4G modem
- a 4MB SPI flash
- a 4GB eMMC
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
[rebase on current TOT]
The SAMA5D2 has a second internal SRAM that can be reassigned as a L2
cache memory.
Make sure it is configured as a L2 cache memory when booting from a SPL
image.
Based on the commit b5ea95ef2b5b from the at91bootstrap repository.
Signed-off-by: Samuel Mescoff <samuel.mescoff@mobile-devices.fr>
Reviewed-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
Add support for DENX MA5D4 SoM and MA5D4EVK board, based on the
Atmel SAMA5D4 SoC. The SoM contains the SoC, eMMC, SPI NOR, SPI
CAN controllers and DRAM, the baseboard contains UART connectors,
ethernet port, microSD slot, LCD header, 2x CAN connector and a
lot of expansion headers.
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
New features for smartweb:
* switch to hush command parser
* change autoboot stop to <ESC><ESC>
* allow to write ethaddr
Signed-off-by: Matthias Michel <matthias.michel@siemens.com>
Reviewed-by: Samuel Egli <samuel.egli@siemens.com>
Cc: Roger Meier <r.meier@siemens.com>
Due to introducing the PMC_PLLICPR init function, use this
function to clean up the code.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Tested-by: Heiko Schocher <hs@denx.de>
To avoid the duplicated code, add the PMC_PLLICPR init function.
Due to introducing the new PLLB clock handle functions,
use these functions to clean up the PLLB enable code.
use these functions to clean up the PLLB enable/disable code.
To avoid the duplicated code, add the PLLB handle functions.
[add enable/disable functions to arm920t]
Due to introducing the new UTMI PLL clock handle functions,
use the functions to reduce the duplicated code.
use these function to reduce the duplicated code.
