This commit moves:
CONFIG_OF_CONTROL
CONFIG_OF_SEPARATE
CONFIG_OF_EMBED
CONFIG_OF_HOSTFILE
Because these options are currently not supported for SPL,
the "Device Tree Control" menu does not appear in the SPL
configuration.
Note:
zynq-common.h should be adjusted so as not to change the
default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME.
Cc: Stephen Warren <swarren@nvidia.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
This tools is unnecessary since commit f6c8f38ec601
(tools/genboardscfg.py: improve performance more with Kconfiglib).
The mentioned binutils port got removed while the patch was
pending. As Ian pointed out there is another port providing
the binutils for arm now. Update the instructions accordingly.
Cc: ian@FreeBSD.org
Cc: Tom Rini <trini@ti.com>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
The libc headers on FreeBSD and likely related projects as well contain an
header file, cdefs.h which provides similiar functionality as linux/compiler.h.
It provides compiler independent defines like __weak __packed, to allow
compiling with multiple compilers which might have a different syntax for such
extension.
Since that header file is included in multiple standard headers, like stddef.h
and stdarg.h, multiple definitions of those defines will be present if both are
included. When compiling u-boot the compiler will warn about it hundreds of
times since e.g. common.h will include both files indirectly.
commit 7ea50d52849fe8ffa5b5b74c979b60b1045d6fc9 "compiler_gcc: do not redefine
__gnu_attributes" prevented such redefinitions, but this was undone by commit
fb8ffd7cfc68b3dc44e182356a207d784cb30b34 "compiler*.h: sync
include/linux/compiler*.h with Linux 3.16".
Add the checks back where necessary to prevent such warnings.
As the original patch this checkpatch warning is ignored:
"WARNING: Adding new packed members is to be done with care"
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
[1] Move driver/core/, driver/input/ and drivers/input/ entries
from the top Makefile to drivers/Makefile
[2] Remove the conditional by CONFIG_DM in drivers/core/Makefile
because the whole drivers/core directory is already selected
by CONFIG_DM in the upper level
[3] Likewise for CONFIG_DM_DEMO in drivers/demo/Makefile
[4] Simplify common/Makefile - both CONFIG_DDR_SPD and
CONFIG_SPD_EEPROM are boolean macros so they can directly
select objects
Now MIN, MAX, MIN3, MAX are not used.
Going forward, use min, max, min3, max3.
The macro MIN, MAX is defined as the aliase of min, max,
respectively.
Since clang has a different definition for uninitialized_var
it will complain that it is redefined in include/compiler.h.
Since these are already defined in linux/compiler.h just remove
this instance.
The arg_off() and arg_off_size() update the 'current NAND
device' variable (dev). This is then used when assigning the
(nand_info_t*)nand value. Place the assignment after the
arg_off(_size) calls to prevent using incorrect (nand_info_t*)
nand value.
Signed-off-by: Rostislav Lisovy <lisovy@merica.cz>
The section name and the C variable name seem to be opposite.
Now config_cmd_defaults.h is empty so it can be deleted safely.
Since CONFIG_CMD_IMPORTENV is defined in config_cmd_defaults.h,
it should be enabled for all the boards except bf506f-ezkit
that undefs it explicitely.
Since CONFIG_CMD_GO is defined in config_cmd_defaults.h
(and no board undefs it its own header), it can be moved to
Kconfig with the default value "y".
Since CONFIG_CMD_EXPORTENV is defined in config_cmd_defaults.h,
Since CONFIG_CMD_CRC32 is defined in config_cmd_defaults.h,
it is enabled for all the boards except the ones undefining it
explicitly:
kwb
tseries_mmc
tseries_nand
tseries_spi
vct_platinum_onenand_small
vct_platinum_small
vct_platinumavc_onenand_small
vct_platinumavc_small
vct_premium_onenand_small
vct_premium_small
The default value of this config option should be "y" and
"# CONFIG_CMD_CRC32 is not set" should be added for those exceptions.
CONFIG_CMD_BOOTM is defined in config_cmd_defaults.h
which is forcebly included from each board.
So, the default value of "config CMD_BOOTM" should be "y".
For some boards undefining it (bf506f-ezkit, controlcenterd_TRAILBLA,
controlcenterd_TRAILBLAZER_DEVELOP, controlcenterd_TRAILBLAZER),
"# CONFIG_CMD_BOOTM is not set" should be added to their defconfig.
If this option is enabled, the objects under lib/ directory
are compiled with speed optimization, not size optimization.
(Currently, only used by some Blackfin boards.)
This would be useful to start moving various config options.
Scsi disks need to be probed before we try to access them, otherwise all
accesses fail with: ** Bad device size - scsi 0 **.
Reported-by: Karsten Merker <merker@debian.org>
Tested-by: Karsten Merker <merker@debian.org>
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4
(patman: RunPipe() should not pipe stdout/stderr unless asked),
Patman spits lots of "Invalid MAINTAINERS address: '-'"
error messages for patches with global changes.
It takes too long for Patman to process them.
Anyway, "M: -" does not carry any important information.
Rather, it is just like a place holder in case of assigning
a new board maintainer. Let's comment out.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/'
The "S: Orphan" in MAINTAINERS means that the maintainer in the
"M:" field is unreachable (i.e. the email address is not working).
(Refer to the definition of "Orphan" adopted in U-Boot
in the log of commit 31f1b654b2f395b69faa5d0d3c1eb0803923bd3b,
"boards.cfg: move boards with invalid emails to Orphan")
For patch files adding global changes, scripts/get_maintainer.pl
adds bunch of such invalid email addresses, which results in
tons of annoying bounce emails.
/^M:[[:blank:]]/ {
N
/S:[[:blank:]]Orphan/s/^/#/
We are still keeping invalid email addressed in MAINTAINERS
because they carry information.
The problem is that scripts/get_maintainer.pl adds emails in the
"M:" field including invalid ones.
We want to comment out invalid email addresses in MAINTAINERS
to prevent scripts/get_maintainer.pl from picking them up.
On the other hand, we want to collect them for boards.cfg
to know the last known maintainer of each board.
This commit adjusts tools/genboardscfg.py to parse also
the commented "M:" fields, which is useful for the next commit.
This performs a command, then repeats it, and checks that the repeat
happens.
These cause U-Boot to print a list of available commands. It doesn't break
the test, but it is best to remove them from the output.
This is not supported properly on sandbox, and interferes with running
tests, since when a test script is piped in, some commands will call
ctrlc() which will drop characters from the test script.
This was lost sometime in the Kbuild conversion. Add it back.
Check that the trace test now passes:
$ ./test/trace/test-trace.sh
Simple trace test / sanity check using sandbox
/tmp/filemHKPGw
Build sandbox
O=sandbox FTRACE=1
GEN /home/sjg/c/src/third_party/u-boot/files/sandbox/Makefile
Configuring for sandbox board...
Check results
Test passed
Cleanup disk/part.c
Signed-off-by: Pavel Machek <pavel@denx.de>
Each CPU of PowerPC has its default linker script under the CPU
directory, except mpc8xx.
Every mpc8xx board has its own linker script under the board
directory, resulting in lots of duplication of linker scripts.
I notice eight mpc8xx boards have the same linker script.
We can decrease the number of linker scripts by putting a single
default linker script, arch/powerpc/cpu/mpc8xx/u-boot.lds.
Fix the following build error in case CONFIG_E1000_NO_NVM is enabled:
CC drivers/net/e1000.o
drivers/net/e1000.c: In function ‘e1000_initialize’:
drivers/net/e1000.c:5365:5: error: ‘struct e1000_hw’ has no
member named ‘eeprom_semaphore_present’
make[1]: *** [drivers/net/e1000.o] Error 1
make: *** [drivers/net] Error 2
When building the U-Boot tools for non-ELF platforms (such as Blackfin
FLAT), since commit 79fc0c5f498c3982aa4740c273ab1a9255063d9c
("tools/env: cross-compile fw_printenv without setting HOSTCC"), the
build fails because it tries to strip a FLAT binary, which does not
make sense.
This commit solves this by changing the stripping logic in
tools/env/Makefile to be similar to the one in tools/Makefile. This
logic continues to apply strip to the final binary, but does not abort
the build if it fails, and does the stripping in place on the final
binary. This allows the logic to work fine if stripping doesn't work,
as it leaves the final binary untouched.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Reviewed-by: Sonic Zhang <sonic.zhang@analog.com>
- add capability to "fastboot flash" with sparse format images
Signed-off-by: Steve Rae <srae@broadcom.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
- update static function
- additional debugging statements
- update "fastboot command" information
- add missing include file
- update spelling
- implement 'fastboot flash' for eMMC devices
- add support for 'fastboot flash' command for eMMC devices
Enable the Extend address to support SPI flash more than 16MB.
Signed-off-by: Hou Zhiqiang <B48286@freescale.com>
Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Cc: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
Acked-by: Prafulla Wadaskar <prafulla@marvell.com>
Tested-by: Luka Perkov <luka@openwrt.org>
Reviewed-by: Jagannadha Sutradharudu Teki <jaganna@xilinx.com>
This patch introduces the clrsetbits_le32() accessor functions in the
kirkwood SPI driver. Note that it also includes a fix:
- writel(~KWSPI_CSN_ACT | KWSPI_SMEMRDY, &spireg->ctrl);
+ writel(KWSPI_SMEMRDY, &spireg->ctrl);
Here the bit KWSPI_CSN_ACT (0x1) should have been cleared. Instead
0xfffffffe is written into this control register. This is the main
reason to use the clrsetbits() functions now. As they make clearing
bits much less error prone.
Additionally KWSPI_IRQUNMASK is not used in spi_cs_activate() and
spi_cs_deactivate() any more. Its the wrong macro but has the same
value as the correct one (KWSPI_CSN_ACT).
This is in preparation for use of this driver on the Marvell Armada XP
platform as well.
Add ID for this Numonix / STMicro chip.
Tested on Marvell DB-78460-BP board.
Currently, CONFIG_SPL_SPI_* #defines are used for controlling SPI boot in
SPL. These #defines do not allow the user to select SPI mode for the SPI flash
(there's no CONFIG_SPL_SPI_MODE, so the SPI mode is hardcoded in
spi_spl_load.c), and duplicate information already provided by
CONFIG_SF_DEFAULT_* #defines.
Kill CONFIG_SPL_SPI_*, and use CONFIG_SF_DEFAULT_* instead.
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Hannes Petermaier <hannes.petermaier@br-automation.com>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
MXC SPI driver has a feature whereas a GPIO line can be used to force CS high
across multiple transactions. This is set up by embedding the GPIO information
in the CS value:
cs = (cs | gpio << 8)
This merge of cs and gpio data into one value breaks the sf probe command:
if the use of gpio is required, invoking "sf probe <cs>" will not work, because
the CS argument doesn't have the GPIO information in it. Instead, the user must
use "sf probe <cs | gpio << 8>". For example, if bank 2 gpio 30 is used to force
cs high on cs 0, bus 0, then instead of typing "sf probe 0" the user now must
type "sf probe 15872".
This is inconsistent with the description of the sf probe command, and forces
the user to be aware of implementaiton details.
Fix this by introducing a new board function: board_spi_cs_gpio(), which will
accept a naked CS value, and provide the driver with the relevant GPIO, if one
is necessary.
Cc: Eric Nelson <eric.nelson@boundarydevices.com>
Cc: Eric Benard <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Add support for M25PE16 and M25PX16
Since dev->req_seq value is initialized from "reg" property of fdt node,
there is posibility, that address value contained in fdt is greater than
INT_MAX, and then value in dev->req_seq is negative which led to probe()
fail.
This patch fix this problem by ensuring that req_seq is positive, unless
it's one of errno codes.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Allow serial_find_console_or_panic() to work without a device tree.
The sequence number support in driver model requires device tree control.
It should be skipped if CONFIG_OF_CONTROL is not defined, and should not
require functions from fdtdec.
The list is supposed to be terminated with a NULL name, but is not. If a
board probes a chip which does not appear in the table, U-Boot will crash
(at least on sandbox).
A merge error ended up repeating a similar sentence twice. Fix it.
