2008-04-26post/Makefile: make sure to use the correct flagsWolfgang Denk
ARFLAGS was not set, which caused "ppc_8xx-ar: creating libgenpost.a" messages to be printed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-26Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-04-26i.MX31: Enable SPI and MC13783/RTC support for the Litekit boardMagnus Lilja
This patch enables SPI and MC13783/RTC support for the Litekit board. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-04-26MPC8544DS: decode pcie3 end-point configuration correctly.Ed Swarthout
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-26MPC8544DS: Removes the unknown flash message informationRoy Zang
This patch removes the unknown flash message information: '## Unknown FLASH on Bank 1 - Size = 0xdeadbeef = -286261248 MB' This unknown flash message is caused by PromJet. Some of the board user is unhappy with this information. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-26Merge branch 'master' of git://www.denx.de/git/u-boot-mpc83xxWolfgang Denk
2008-04-26Merge branch 'master' of git://www.denx.de/git/u-boot-cfi-flashWolfgang Denk
2008-04-26Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-25mpc83xx: bump loadaddr over fdtaddr to 0x500000Kim Phillips
this seems as a good compromise between human memory, typing, and last but not least, to accommodate for current and future kernel bloat. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com>
2008-04-25mpc83xx: clean up the readme for 83xx boardsDave Liu
1. correct the typo 2. correct the memory map for 837xerdb board Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-04-25mpc83xx: remove the unused CPM's stuffDave Liu
The MPC83xx family never have CPM block, so remove it from 83xx. Signed-off-by: Dave Liu <daveliu@freescale.com>
2008-04-25cfi-flash: Add CFG_FLASH_AUTOPROTECT_LISTMatthias Fuchs
This patch adds a configurable flash auto protection list that can be used to make U-Boot protect flash regions in flash_init(). The idea has been discussed on the u-boot mailing list starting on Nov 18th, 2007. Even this patch brings a new feature it is used as a bugfix for 4xx platforms where flash_init() does not completely protect the monitor's flash range in all situations. U-Boot protects the flash range from CFG_MONITOR_BASE to (CFG_MONITOR_BASE + monitor_flash_len - 1) by default. This does not include the reset vector at 0xfffffffc. Example: #define CFG_FLASH_AUTOPROTECT_LIST {{0xfff80000, 0x80000}} This config option will auto protect the last 512k of flash that contains the bootloader on board like APC405 and PMC405. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2008-04-25ppc4xx: Remove double defines in lwmon5.hStefan Roese
introduced with latest lwmon5/POST merge Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25Use watchdog-aware functions when calculating hashes of images - take twoBartlomiej Sieka
Some files didn't get updated properly with the "Use watchdog-aware functions when calculating hashes of images" commit, this commit fixes this. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-25ppc4xx: Add bootcount limit handling for APC405 boardsMatthias Fuchs
2008-04-25Use watchdog-aware functions when calculating hashes of imagesBartlomiej Sieka
2008-04-25USB: fix more GCC 4.2.x aliasing warningsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-04-25lib_generic/crc32.c: add missing #include <watchdog.h>Wolfgang Denk
2008-04-25lib_generic/crc32.c: fix compile problemWolfgang Denk
2008-04-25ppc4xx: Pass PCIe root-complex/endpoint configuration to Linux via the fdtStefan Roese
The PCIe root-complex/endpoint setup as configured via the "pcie_mode" environment variable will now get passed to the Linux kernel by setting the device_type property of the PCIe device tree node. For normal root- complex configuration it will keep its defaults value of "pci" and for endpoint configuration it will get changed to "pci-endpoint". Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-25lwmon5: watchdog POST fixYuri Tikhonov
Use the GPT0_MASKx registers as the temporary storage for watch-dog timer POST test instead of GPT0_COMPx. The latter (GPT0_COMP1..GPT0_COMP5) are used for the log-buffer header. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2008-04-25Merge branch 'master' of /home/wd/git/u-boot/lwmon5Wolfgang Denk
Conflicts: common/cmd_bootm.c common/cmd_log.c include/common.h post/board/lwmon5/Makefile post/board/lwmon5/dsp.c post/board/lwmon5/dspic.c post/board/lwmon5/fpga.c post/board/lwmon5/gdc.c post/board/lwmon5/sysmon.c post/board/lwmon5/watchdog.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-nand-flashWolfgang Denk
2008-04-25Merge branch 'master' of git://www.denx.de/git/u-boot-at91Wolfgang Denk
2008-04-25lib_ppc: Revert "Make MPC83xx one step closer to full relocation."Kim Phillips
This reverts commit 70431e8a7393b6b793f77957f95b999fc9a269b8 which has proven problematic getting right from the start at least on 83xx and 4xx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-04-25Realining some header definitions.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-04-25NE2000: coding style cleanupJean-Christophe PLAGNIOL-VILLARD
2008-04-25qemu-mips.h: Add CFI supportJean-Christophe PLAGNIOL-VILLARD
CONFIG_ENV_OVERWRITE is also added. This patch is originally created by Jean-Christophe PLAGNIOL-VILLARD. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-25doc/README.mips: Add MIPS notesShinya Kuribayashi
2008-04-25Add support for calculating hashes with watchdog triggeringBartlomiej Sieka
Implement watchodg-aware variants of hash calculation functions: - crc32_wd() - md5_wd() - sha1_csum_wd() The above functions calculate the hash of the input buffer in chunks, triggering the watchdog after processing each chunk. The chunk size is given as a function call parameter. Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24qemu-mips: Cleanup whitespace, indentation, etc.Shinya Kuribayashi
No functional change. This patch was originally submitted by Jean-Christophe PLAGNIOL-VILLARD. Then I re-created from scratch, and changed more lines than the original. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-04-24Fixed pcnet io_baseVlad Lungu
Bus and phys address are not always the same Signed-off-by: Vlad Lungu <vlad@comsys.ro>
2008-04-24drivers/net/pcnet.c: Coding Style cleanup.Wolfgang Denk
2008-04-24Added Am79C970A chip id to pcnetVlad Lungu
2008-04-24i.MX31: Fix architecture numbers for ADS and Litekit boardsMagnus Lilja
Correct the Linux architecture number for i.MX31 Litekit and ADS boards. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-04-24i.MX31: Use symbolic names for Litekit membases.Magnus Lilja
Use symbolic names instead of hard coded addresses for Litekit membases. Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
2008-04-24Fix show_boot_progress prototypeJean-Christophe PLAGNIOL-VILLARD
in commit fad634071 "make show_boot_progress () weak." show_boot_progress is supposed to be declared as weak but declared as inline instead. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-24Memory footprint optimizationsBartlomiej Sieka
As suggested by Wolfgang Denk: - image printing functions: - remove wrappers - remove indentation prefix from functions' signatures - merge getenv_verify and getenv_autostart into one parametrized function Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-04-24MX31ADS environment variable update, spi and rtc supportGuennadi Liakhovetski
Update MX31ADS default environment to better match the flash layout and the memory map, support SPI and RTC. Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
2008-04-2485xx: Round up frequency calculations to get reasonable outputKumar Gala
eg. because of rounding error we can get 799Mhz instead of 800Mhz. Introduced DIV_ROUND_UP and roundup taken from linux kernel. Signed-off-by: Dejan Minic <minic@freescale.com> Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-04-24Merge branch 'master' of git://www.denx.de/git/u-boot-mpc85xxWolfgang Denk
2008-04-24fsl_pci: Only modify registers if we have themKumar Gala
pme_msg_det exists only on PCIe controllers only set it if we are a "bridge". Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-24Merge branch 'master' of git://www.denx.de/git/u-boot-videoWolfgang Denk
2008-04-24USB: remove a cpu bug workaround for an unsupported architecture.Markus Klotzbücher
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
2008-04-24USB: fix those pesky aliasing warnings issued by gcc-4.2Markus Klotzbücher
Signed-off-by: Markus Klotzbuecher <mk@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-04-24crc32: use uint32_t rather than unsigned longMike Frysinger
The envcrc.c does sizeof(unsigned long) when calculating the crc, but this is done with the build toolchain instead of the target tool chain, so if the build is a 64bit system but the target is 32bits, the size will obviously be wrong. This converts all unsigned long stuff related to crc32 to uint32_t types. Compile tested only: output of ./tools/envcrc when run on a 32bit build system matches that of a 64bit build system. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-04-22ARM: Davinci: Fix DM644x timer overflow handling and cleanupDirk Behme
Fix ARM based DaVinci DM644x timer overflow handling and cleanup timer code. Changes: - Remove *_masked() functions as noted by Wolfgang - Adapt register naming to recent TI spec (sprue26, March 2007) - Fix reset_timer() handling - As reported by Pieter [1] the overflow fix introduced a delay of factor 16 (e.g 2 seconds became 32). While the overflow fix is basically okay, it missed to divide udelay by 16, too. Fix this. [1] http://article.gmane.org/gmane.comp.boot-loaders.u-boot/38179 - Remove software division of timer count value (DIV(x) macro) and do it in hardware (TIM_CLK_DIV). Many thanks to Troy Kisky <troy.kisky@boundarydevices.com> and Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl> for the hints & testing! Patch is compile tested with davinci_dvevm & sonata & schmoogie configuration and tested by Pieter on DaVinci EVM hardware. Signed-off-by: Dirk Behme <dirk.behme@gmail.com> Acked-by: Pieter Voorthuijsen <pieter.voorthuijsen@Prodrive.nl>
2008-04-22Merge branch 'master' of git://www.denx.de/git/u-boot-ppc4xxWolfgang Denk
2008-04-22Added watchdog triggering calls in the "mtest" test function.Sergei Poselenov
2008-04-22lwmon5 watchdog: limit trigger rateYuri Tikhonov
Limit the rate of h/w watch-dog triggering on the LWMON5 board by the CONFIG_WD_MAX_RATE value. Note that an earlier version of this patch which used microseconds instead of ticks dis not work. The problem was that we used usec2ticks() to convert microseconds into ticks. usec2ticks() uses get_tbclk(), which in turn calls get_sys_info(). It turns out that this function does a lot of prolonged operations (like divisions) which take too much time so we do not trigger the watchdog in time, and it resets the system. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
