We only need the function found in cmd/disk.c when we have IDE, SCSI or
USB_STORAGE enabled. While the first two are easy to get right, in the
3rd case we assume that the set of cases where we do have USB and do not
enable USB_STORAGE are small enough that we can take the small bloat of
un-discarded strings on gcc prior to 6.x
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
A previous patch (net: asix: fix operation without eeprom) added a
two-byte shift to the packet buffer when receiving a packet on the
AX88772B.
This shift was not included when the driver was updated to work with
DriverModel. Testing on a Marvell DB-88F6820-ACM showed that the adapter
was not functioning correctly (EHCI timeouts).
This patch brings the two-byte shift to the DriverModel implementation
of ops->recv (asix_eth_recv).
Testing on the same board, we were able to TFTP a file over and confirm
that the crc32 was correct.
Signed-off-by: Joshua Scott <joshua.scott@alliedtelesis.co.nz>
This reverts commit 6279b49e6c2fdaf8665355d1777bc90cd41fcf90.
This caused a bad data crc.
Reported-by: Guillaume GARDET <guillaume.gardet@free.fr>
This reverts commit 998372b4798fd7ebb666f571950df925b8d80f69.
This caused a data abort on some platform.
Update the README to add support for K2G EVM. Also
- Add steps on how to use MMC boot
- Fix load address when using CCS
- Update build target to u-boot.bin from u-boot-dtb.bin as all ks2
platforms uses DT.
Provide version of struct efi_mem_desc in efi_get_memory_map().
EFI_BOOT_SERVICES.GetMemoryMap() in UEFI specification v2.6 defines
memory descriptor version to 1. Linux kernel also expects descriptor
version to be 1 and prints following warning during boot if its not:
Unexpected EFI_MEMORY_DESCRIPTOR version 0
Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@gmail.com>
ENOLINK is not required by POSIX and does not exist on OpenBSD
and likely other systems.
Signed-off-by: Jonathan Gray <jsg@jsg.id.au>
The u-boot endian macros map directly to system endian
macros on OpenBSD.
When beagleboard-X15 is booted, we see the following log:
Unidentified board claims BBRDX15_ in eeprom header
This is because of the missing check for x15 (the default) and reports
an error for a valid board configuration. Fix the same.
Signed-off-by: Nishanth Menon <nm@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Felipe Balbi has move on from TI and the current email ID is no longer
valid. So, replacing with Lokesh.
While at it, update missing config file which was untracked.
Line up comments for readibility.
Use environment variable "kernel_addr_r" to indicate the location
in RAM where FIT image will be stored.
Use label command "kernel" to indicate which <path> the FIT image at.
Signed-off-by: Wenbin Song <wenbin.song@nxp.com>
When FIT image is used, a single image provides kernel, device
tree and optionally ramdisk. Argc and argv need to be adjusted
to support this.
Test cases:
1. Booting with legacy images
2. Booting with legacy images without initrd
3. Booting with FIT image
Test commands:
1. pxe get && pxe boot
2. sysboot
Signed-off-by: York Sun <york.sun@nxp.com>
Correct a small number of spelling mistakes.
As bootargs is hard-coded for the default behavior on the
omap3_pandora, only set the bootargs if distro_bootcmd fails to
load. This leaves distro_bootcmd free to use alternate boot arguments.
Signed-off-by: Vagrant Cascadian <vagrant@debian.org>
Add support for using distro_bootcmd to the omap3_pandora target,
falling back to prior behavior.
We are supposed to not add config entries with only "default y"
in board/SoC Kconfig files.
Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
If both SPL_DM and SPL_OF_CONTROL are enabled, SPL needs to bind
several devices, but CONFIG_SYS_MALLOC_F_LEN=0x400 is apparently
not enough. Increase the default to 0x2000 for the case. This
will be helpful for shorter defconfigs.
Move this option to Kconfig and set its default value to 4; this
increases the number of supported CPUs for some boards.
It consumes 1KB memory per CPU for PSCI stack, but it should not
be a big deal, given the amount of memory used for the modern OSes.
Reviewed-by: Alexander Graf <agraf@suse.de>
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms
can select. Then, move CONFIG_ARMV7_PSCI, which is automatically
enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled.
If CONFIG_ARMV7_NONSEC is enabled, the linker script requires
CONFIG_ARMV7_PSCI_NR_CPUS regardless of CONFIG_ARMV7_PSCI.
SPL_BUILD is not a CONFIG in Kconfig, so !SPL_BUILD is always true.
CONFIG_CMD_FS_GENERIC is enabled; use it to load the autoboot script,
rather than first attempting with fatload and falling back to
ext2load.
Acked-by: Grazvydas Ignotas <notasas@gmail.com>
fatload/ext2load both require that the device and partition be
specified after specifying the device type. Specify the first
partition on mmc device 0, which is the only mmc device currently
configured on the pandora.
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
The PBIAS fixing is done in the MMC driver, and doing it in the
the board file conflicts with the driver causing intermittent
hangs on reboot. Remove this from the board file and let
the driver do it.
All of the command files have moved to cmd directory, add description to
Directory Hierarchy.
Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Sometimes boards may need more time to become stable network connection
due to several reasons:
- phy speed
- link-partner (switch)
Therefore we increase the retry-count to 10 for making sure that network
connection works always.
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
An issue in the TI secure image generation tool causes the ROM to
load the SPL at a different load address than what is specified by
CONFIG_ISW_ENTRY_ADDR while doing a peripheral boot on HS devices.
This causes the SPL to fail on secure devices during peripheral
boot.
The TI secure image generation tool has been fixed so that the SPL
will always be loaded at 0x403018E0 by the ROM code for both
peripheral and memory boot modes.
Signed-off-by: Madan Srinivas <madans@ti.com>
Reviewed-by: Nishanth Menon <nm@ti.com>
Enable the platform-specific post-processing of FIT-extracted blobs such
as Kernel, DTB, and initramfs on TI AM57xx high-security (HS) devices
which will ultimately invoke a ROM-based API call that performs secure
processing such as blob authentication.
Signed-off-by: Andreas Dannenberg <dannenberg@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
as Kernel, DTB, and initramfs on TI DRA7xx high-security (HS) devices
as Kernel, DTB, and initramfs on TI AM43xx high-security (HS) devices
This reworks spl_set_header_raw_uboot to allow having both os boot
(which comes with a valid header) and aborting when no valid header is
found (thus excluding raw u-boot.bin images).
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
When enabling a fixed regulator, it may take some time to rise to the
correct voltage. If we do not delay here then subsequent operations
will fail.
Signed-off-by: John Keeping <john@metanate.com>
Prior to this commit, the tool could not move options guarded by
CONFIG_SPL_BUILD ifdef conditionals because they do not show up in
include/autoconf.mk. This new option, if given, makes the tool
parse spl/include/autoconf.mk instead of include/autoconf.mk,
which is probably preferred behavior when moving options for SPL.
Currently, the tool gives up moving an option quietly if its entry
was not found in Kconfig.
If the option is not defined in the config header in the first
place, it is no problem (as the Kconfig entry may have been hidden
by reasonable "depends on").
However, if the option is defined in the config header, the missing
Kconfig entry is a sign of possible behavior change. It is highly
recommended to manually check if the option has been moved as
expected. In this case, let's add "suspicious" in the log and
change the log color (if --color option is given) to make it stand
out.
This was suggested by Tom in [1].
[1] http://lists.denx.de/pipermail/u-boot/2016-July/261988.html
Suggested-by: Tom Rini <trini@konsulko.com>
The sets feature is handier for adding unique elements.
Since commit cc008299f852 ("tools: moveconfig: do not rely on type
and default value given by users"), we do not have this error case.
Remove the device definition from board file, update the driver with
the new compatible property and update config with necessary options.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Add a pin controller driver for Meson GXBB adapted from Linux kernel.
Import DTS files and dt-bindings includes from Linux 4.8-rc1.
In cases where the pins and groups definitions are in a sub-node, as:
uart_a {
mux {
groups = "uart_tx_a", "uart_rx_a";
function = "uart_a";
pinctrl_generic_set_state_subnode() returns an error for the top-level
node and pinctrl_generic_set_state() fails. Instead, return success so
that the child nodes are tried.
Commit 62afc601883e788f3f22291202d5b2a23c1a8b06 introduced fpga image load via
bootm but broke the OS check in fit_image_load().
This commit removes following compiler warning:
---8<---
In file included from tools/common/image-fit.c:1:
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: warning: use of logical '||' with constant operand [-Wconstant-logical-operand]
os_ok = image_type == IH_TYPE_FLATDT || IH_TYPE_FPGA ||
/Volumes/devel/u-boot/tools/../common/image-fit.c:1715:39: note: use '|' for a bitwise operation
1 warning generated.
--->8---
Signed-off-by: Andreas Bießmann <andreas@biessmann.org>
Acked-by: Michal Simek <michal.simek@xilinx.com>
On the raspberry pi, you can disable the serial port to gain dynamic frequency
scaling which can get handy at times.
However, in such a configuration the serial controller gets its rx queue filled
up with zero bytes which then happily get transmitted on to whoever calls
getc() today.
This patch adds detection logic for that case by checking whether the RX pin is
mapped to GPIO15 and disables the mini uart if it is not mapped properly.
That way we can leave the driver enabled in the tree and can determine during
runtime whether serial is usable or not, having a single binary that allows for
uart and non-uart operation.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
So far we could only tell the gpio framework that a GPIO was mapped as input or
output, not as alternative function.
This patch adds support for determining whether a function is mapped as
alternative.
warp7 has two targets:
- warp7_defconfig: boots in non-secure mode
- warp7_secure_defconfig: boots in secure mode
Print the mode that is being used to help users to easily identify
which target is running on the board.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
