Remove duplicated SYS_SOC Kconfig entry from board Kconfig,
because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Markus Niebel <Markus.Niebel@tq-group.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
Old revisions of Utilite (a miniature PC based on cm-fx6) do not have
a card detect for mmc, and thus the kernel needs to be told that
there's a persistent storage on usdhc3 to force it to probe the mmc
card.
Check the baseboard revision and modify the device tree accordingly
if needed.
Cc: Igor Grinberg <grinberg@compulab.co.il>
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Introduce cl_eeprom_get_product_name() for obtaining product name
from the eeprom.
cl_eeprom_read_mac_addr() doesn't differentiate between success case and
inability to access eeprom. Fix this by propagating the return value of
cl_eeprom_setup().
Add support for selecting which eeprom is queried for board revision by
extending cl_eeprom_get_board_rev() to accept an i2c bus number.
This patch is to support mx6ul_9x9_evk board based on mx6ul_14x14_evk,
the difference between mx6ul 9x9 evk and mx6ul 14x14 evk are:
1. mx6ul 9x9 evk use pfuze3000, while mx6ul 14x14 evk use DCDC.
2. mx6ul 9x9 evk supports 256MB LPDDR2, while mx6ul 14x14 evk
supports 512MB DDR3
3. mx6ul_9x9_evk use 9x9 package, while mx6ul_14x14_evk use 14x14 package.
This patch add the following:
1. Discard PHYS_SDRAM_SIZE from header file, use imx_ddr_size()
2. Introduce a macro is_mx6ul_9x9_evk using
CONFIG_IS_ENABLED(TARGET_MX6UL_9X9_EVK) to avoid "#ifdef xxx" in non-SPL
part. To SPL part, CONFIG_IS_ENABLED(TARGET_MX6UL_9X9_EVK) can not work,
so still use "#ifdef CONFIG_TARGET_MX6UL_9X9_EVK" to differentiate with
mx6ul_14x14_evk. And we have no way to dymaically checking this chip
is 9x9 or 14x14.
3. mx6ul_9x9_evk use pfuze3000, so enabled POWER related configurations.
POWER related configurations also effect for mx6ul_14x14_evk. But
power_init_board implementation using 'if (is_mx6ul_9x9_evk())' to
do initialization for mx6ul_9x9_evk, and do nothing for mx6ul_14x14_evk.
4. mx6ul_9x9_evk use lpddr2 with size 256MB, so add related SPL DRAM
configurations.
5. Enable CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG and setting dtb file
according to board_rev and board_name.
6. Add TARGET_MX6UL_9X9_EVK Kconfig entry
Boot Log:
U-Boot SPL 2015.10-rc2-00356-g536ce34 (Sep 06 2015 - 12:22:53)
reading u-boot.img
reading u-boot.img
U-Boot 2015.10-rc2-00356-g536ce34 (Sep 06 2015 - 12:22:53 +0800)
CPU: Freescale i.MX6UL rev1.0 792 MHz (running at 396 MHz)
CPU: Commercial temperature grade (0C to 95C) at 41C
Reset cause: POR
Board: MX6UL 9x9 EVK
I2C: ready
DRAM: 256 MiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC: FSL_SDHC: 0, FSL_SDHC: 1
In: serial
Out: serial
Err: serial
Net: FEC1
Hit any key to stop autoboot: 0
We have CONFIG_MXC_OCOTP and CONFIG_CMD_FUSE in mx6_common.h,
discard duplicated macro definitions in board header files.
Cc: Peter Robinson <pbrobinson@gmail.com>
This reverts commit 059323fb6a8f21637bb617919715c2427f24777c.
This commit 059323fb6a8f21637bb617919715c2427f24777c use JESD79-3E which
is not the newest spec. Should use JESD79-3F in which tRFC is 260ns for
4Gb chip.
Running mxsboot on a big-endian system produces a sd image which
cannot be started by the i.MX28 ROM. It complains on the debug
uart as following:
0x8020a009
0x80502008
0x8020a009
0x80502008
Enforcing all fields within the BCB to little-endian make
the image bootable again.
Signed-off-by: Michael Heimpold <mhei@heimpold.de>
* Add i.MX7D SABRESD target board support with enabled modules:
UART, PMIC, USB/OTG, SD, eMMC, ENET, I2C, 74LV IOX.
Build target: mx7dsabresd_config
Signed-off-by: Fugang Duan <B38611@freescale.com>
Signed-off-by: Ye.Li <B37916@freescale.com>
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
Add imx-common cpu support for imx7d SoC
- Update reset_cause for imx7d
- Enable watchdog driver built for imx7d
Add imx7 SoC thermal driver support
Rework imx_set_wdog_powerdown to be reused by imx6 and imx7
Extend init_aips to support imx7 SoC, use is_soc_type
and is_cpu_type to resolve at run time aips3 settings
Add imx7d basic SoC system support
Misc arch dependent functions for system bring up
* Add Clock control module (CCM) support
* iMX7D SoC introduces 3 main clock sysmtem abstraction for clock
root frequency generation denominated clock slices.
Core clock slice: hihg speed clock for ARM core
Bus clock slice: for bus clocks
IP clock slice: Peripheral clocks
* At system boot ROM enables PLL_ARM, PLL_DDR, PLL_SYS, PLL_ENET
In u-boot, we have to:
- Configure PFD3- PFD7 for freq we needed in u-boot
- Set clock root for peripherals (ip channel)
* Add system arch level header files
- imx-regs.h: iMX7D SoC system architecture registers
- crm_regs.h: Clock control module registers
- sys_proto.h: helper callback function for SoC setup
Add system counter driver for imx7d and mx6ul
imx7 and imx6ul supports system counter timer as well as
GPT timer (arch/arm/imx-common/timer.c); The default for
imx7 is systemcounter timer.
Move common imx6 arch init setup, init.c can be extended
and reused to support imx7 SoC keeping init arch common
code.
Rework cache settings for imx6, move cache configuration
to imx-common/cache.c so it can be reused for newer SoC
Rework imx_thermal driver to be used across i.MX
processor that support thermal sensor
Add helper macro is_soc_type to identify iMX SoC family
The MCV SoM has DDR3-1600 DRAMs on it, update the DRAM speed
to 400MHz to make use of these DRAMs completely.
Commit 6a132416359e "ci_udc: Update the ci_udc driver to support bulk
transfers" caused the value of "len" to change without updating subsquent
users of that variable in ci_ep_submit_next_request(). This caused the
code that detects when to emit ZLPs (Zero Length Packets) never to
trigger, which in turn caused host timeouts when a ZLP was required,
which in turn broke tests/dfu/, even despite the assertion in that
commit's description that "These changes are tested for both the DFU and
lthor."
Fix this by modifying the added dtd iteration code not to modify "len",
but rather to keep state in a separate variable. Rename the variables
while we're at it so they describe their purpose better.
Fixes: 6a132416359e ("ci_udc: Update the ci_udc driver to support bulk transfers")
Cc: Siva Durga Prasad Paladugu <siva.durga.paladugu@xilinx.com>
Implement endpoint dequeue callback function.
Without this function, uboot will hang when executing fastboot comamnd.
See following flow:
"fastboot_tx_write_str->fastboot_tx_write->usb_ep_dequeue->ep->ops->dequeue"
without implement ci_udc dequeue function, ep->ops->dequeue is NULL, then
uboot will hang.
Tested on mx6qsabresd board with fastboot enabled.
Tested-by: Fabio Estevam <fabio.estevam@freescale.com>
Cc: "Łukasz Majewski" <l.majewski@samsung.com>
The current simplify lpc32xx gpio driver implementation assume a
maximum of 32 GPIO per port; there are a total of 22 GPI, 24 GPO
and 6 GPIO to managed on port 3.
Update the driver to fix the following:
1) When requesting GPI_xx and GPO_xx on port 3 (xx is the same number)
the second call to "gpio_request" will return -EBUSY.
2) The status of GPO_xx pin report the status of the
corresponding GPI_xx pin when using the "gpio status" command.
3) The gpio driver may setup the direction register for the wrong
gpio when calling "gpio_direction_input" (GPI_xx) or
"gpio_direction_output" (GPO_xx) on port 3; the call to the
direction is require to use the "gpio status" command.
The following change were done in the driver:
1) port3 GPI are cache in a separate 32 bits in the array.
2) port3 direction register written only for GPIO pins.
3) port3 GPO & GPIO (as output) are read using "p3_outp_state".
4) LPC32XX_GPI_P3_GRP updated to match the change.
Signed-off-by: Sylvain Lemieux <slemieux@tycoint.com>
Define CONFIG_MACH_TYPE to allow non DT Linux boot.
Signed-off-by: Dmitry Lifshitz <lifshitz@compulab.co.il>
Mainline CM-T3517 U-Boot environment size differs from that one
shipped with CM-T3517 boards.
Update environment size, to avoid backward compatibility issues.
Fix MMC1 pinmux setup, thus enable SD/MMC card support with CM-T3517.
SBC-T3517 evaluation board has two Eth interfaces.
Enable network retry of another interface if the default if failed
or disconnected.
Add 'netretry=yes' in the default env. Setup relevant
timeout values in the board config file.
introduce BIT() definition, used in at91_udc gadget
driver.
[remove all other occurrences of BIT(x) definition]
Acked-by: Anatolij Gustschin <agust@denx.de>
Since last API changes for files >2GB, the read of symlink is broken as
ext4fs_read_file now returns 0 instead of the length of the actual read.
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
This patch changes a little bit the environment, current environment was broken
for a long time, and board don't as expected sometimes, on production systems
this is fixed adding boot script. I think it's time to change this to make a
system conformant environment and use generic distro configurations and
environment instead. We can use a boot script for the old way boot mode.
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Add support for Lightwriter SL50 series board, a small, robust and portable
Voice Output Communication Aids (VOCA) designed to meet the particular and
changing needs of people with speech loss resulting from a wide range of
acquired, progressive and congenital conditions.
This allows transferring data directly to/from RAM. For example, one
could create a boot script that starts DFU on a RAM region, then once
DFU exits (which is under the control of the attached USB host, via a
USB bus reset), uses the code/data that was received over DFU.
Writing to files is a useful feature in general, so enable it everywhere.
The primary purpose is to make DFU useful on filesystems in addition to
raw devices.
CONFIG_SYS_DFU_DATA_BUF_SIZE defines the size of chunks transferred
across USB. This doesn't need to be particularly large, since it doesn't
limit the overall transfer size.
CONFIG_SYS_DFU_MAX_FILE_SIZE is used to buffer an entire file before
writing it to a filesystem. This define limits the maximum file size that
may be transferred. Bump this up to 32MiB in order to support large
uncompressed kernel images.
Both of these buffers are dynamically allocated, and so the size of both
needs to be taken into account when calculating the required malloc
region size.
Commit 52a7c98a1772 "tegra-common: increase malloc pool len by dfu mmc
file buffer size" updated the definition of CONFIG_SYS_MALLOC_LEN for
Tegra to take account of the DFU buffer size. However, this change had
no effect, since typical Tegra board config headers don't set the DFU-
related defines until after tegra-common.h is included. Fix this by
moving the affected conditional code to tegra-common-post.h, which is
included last. Also move the definition of SYS_NONCACHED_MEMORY since
it's a related and adjacent definition.
Fix the condition to test for the DFU feature, rather than specifically
MMC DFU support, so it applies in all cases.
When writing to files in a filesystem on MMC, dfu_mmc.c buffers up the
entire file content until the end of the transaction, at which point the
file is written in one go. This allows writing files larger than the USB
transfer size (CONFIG_SYS_DFU_DATA_BUF_SIZE); the maximum written file
size is CONFIG_SYS_DFU_MAX_FILE_SIZE (the size of the temporary buffer).
The current file reading code does not do any buffering, and so limits
the maximum read file size to the USB transfer size. Enhance the code to
do the same kind of buffering as the write path, so the same file size
limits apply.
Remove the size checking code from dfu_read() since all read paths now
support larger files than the USB transfer buffer.
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
DFU currently allocates buffer memory at the start of each data transfer
operation and frees it at the end. Especially since memalign() is used to
allocate the buffer, and various other allocations happen during the
transfer, this can expose the code to heap fragmentation, which prevents
the allocation from succeeding on subsequent transfers.
Fix the code to allocate the buffer once when DFU mode is initialized,
and free the buffer once when DFU mode is exited, to reduce the exposure
to heap fragmentation.
The failure mode is:
// Internally to memalign(), this allocates a lot more than s to guarantee
// that alignment can occur, then returns chunks of memory at the start/
// end of the allocated buffer to the heap.
p = memalign(a, s);
// Various other malloc()s occur here, some of which allocate the RAM
// immediately before/after "p".
// DFU transfer is complete, so buffer is released.
free(p);
// By chance, no other malloc()/free() here, in DFU at least.
// A new DFU transfer starts, so the buffer is allocated again.
// In theory this should succeed since we just free()d a buffer of the
// same size. However, this fails because memalign() internally attempts
// to allocate much more than "s", yet free(p) above only free()d a
// little more than "s".
p = memalign(a, s);
root_first_block_buffer should be free()d in all cases, not just when an
error occurs. Fix the success exit path of the function to do this.
parse_path() malloc()s the entries in the array it's passed. Those
allocations must be free()d by the caller, ext4fs_get_parent_inode_num().
Add code to do this.
For this to work, all the array entries must be dynamically allocated,
rather than a mix of dynamic and static allocations. Fix parse_path() not
to over-write arr[0] with a pointer to statically allocated data.
ext4_write_file() is only called from the "fs" layer, which calls both
ext4fs_mount() and ext4fs_close() before/after calling ext4_write_file().
Fix ext4_write_file() not to call ext4fs_mount() again, since the mount
operation malloc()s some RAM which is leaked when a second mount call
over-writes the pointer to that data, if no intervening close call is
made.
By the time g_dnl_unbind() is run, cdev->config has been set to NULL,
so the free() there does nothing, and the config struct is leaked.
Equally, struct usb_gadget contains a linked list of config structs, so
the code should iterate over them all and free each one, rather than
freeing one particular config struct.
composite_unbind() already iterates over the list of config structs, and
unlinks each from the linked list. Fix this loop to free() each struct as
it's unlinked and otherwise forgotten.
It is very common that FAT code is using following pattern:
if (disk_{read|write}() < 0)
return -1;
Up till now the above code was dead, since disk_{read|write) could only
return value >= 0.
As a result some errors from medium layer (i.e. eMMC/SD) were not caught.
The above behavior was caused by block_{read|write|erase} declared at
struct block_dev_desc (@part.h). It returns unsigned long, where 0
indicates error and > 0 indicates that medium operation was correct.
This patch as error regards 0 returned from block_{read|write|erase}
when nr_blocks is grater than zero. Read/Write operation with nr_blocks=0
should return 0 and hence is not considered as an error.
Signed-off-by: Lukasz Majewski <l.majewski@samsung.com>
Test HW: Odroid XU3 - Exynos 5433
Enable dwc3, dwc3-omap and PHY to get DWC3 functional in OMAP5
uEVM. Also enable support for DFU.
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
Now that we have a new header file for cache-aligned allocation, we should
move the stack-based allocation macro there also.
At present malloc.h is included everywhere since it recently was added to
common.h in this commit:
4519668 mtd/nand/ubi: assortment of alignment fixes
This seems wasteful and unnecessary. We have been trying to trim down
common.h and put separate functions into separate header files and that
change goes in the opposite direction.
Move malloc_cache_aligned() to a new header so that this can be avoided.
The header would perhaps be better named as alignmem.h but it needs to be
included after common.h and people might be confused by this. With the name
memalign.h it fits nicely after malloc() in most cases.
