2015-02-24kconfig: switch to single .config configurationMasahiro Yamada
When Kconfig for U-boot was examined, one of the biggest issues was how to support multiple images (Normal, SPL, TPL). There were actually two options, "single .config" and "multiple .config". After some discussions and thought experiments, I chose the latter, i.e. to create ".config", "spl/.config", "tpl/.config" for Normal, SPL, TPL, respectively. It is true that the "multiple .config" strategy provided us the maximum flexibility and helped to avoid duplicating CONFIGs among Normal, SPL, TPL, but I have noticed some fatal problems: [1] It is impossible to share CONFIG options across the images. If you change the configuration of Main image, you often have to adjust some SPL configurations correspondingly. Currently, we cannot handle the dependencies between them. It means one of the biggest advantages of Kconfig is lost. [2] It is too painful to change both ".config" and "spl/.config". Sunxi guys started to work around this problem by creating a new configuration target. Commit cbdd9a9737cc (sunxi: kconfig: Add %_felconfig rule to enable FEL build of sunxi platforms.) added "make *_felconfig" to enable CONFIG_SPL_FEL on both images. Changing the configuration of multiple images in one command is a generic demand. The current implementation cannot propose any good solution about this. [3] Kconfig files are getting ugly and difficult to understand. Commit b724bd7d6349 (dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to Kconfig) has sprinkled "if !SPL_BUILD" over the Kconfig files. [4] The build system got more complicated than it should be. To adjust Linux-originated Kconfig to U-Boot, the helper script "scripts/multiconfig.sh" was introduced. Writing a complicated text processor is a shell script sometimes caused problems. Now I believe the "single .config" will serve us better. With it, all the problems above would go away. Instead, we will have to add some CONFIG_SPL_* (and CONFIG_TPL_*) options such as CONFIG_SPL_DM, but we will not have much. Anyway, this is what we do now in scripts/Makefile.spl. I admit my mistake with my apology and this commit switches to the single .config configuration. It is not so difficult to do that: - Remove unnecessary processings from scripts/multiconfig.sh This file will remain for a while to support the current defconfig format. It will be removed after more cleanups are done. - Adjust some makefiles and Kconfigs - Add some entries to include/config_uncmd_spl.h and the new file scripts/Makefile.uncmd_spl. Some CONFIG options that are not supported on SPL must be disabled because one .config is shared between SPL and U-Boot proper going forward. I know this is not a beautiful solution and I think we can do better, but let's see how much we will have to describe them. - update doc/README.kconfig More cleaning up patches will follow this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24kconfig: Adjust ordering so that defaults work as expectedSimon Glass
At present defaults in arch-specific Kconfig files are ignored if the top-level item comes ahead of it in include order. This means that it is not possible to have a U-Boot default that architectures and boards can override. This does not seem very useful. Move the include earlier to support this. Signed-off-by: Simon Glass <sjg@chromium.org> Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-24ARM: UniPhier: set CONFIG_SYS_MALLOC_F to the global default valueMasahiro Yamada
It is true that malloc is necessary for Driver Model before relocation, but there is no good reason to reserve the malloc space more than enough. The default value 0x400 works well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-24OMAP3: igep0032: Fix regression due commit f3b4bc45.Enric Balletbo i Serra
Commit referenced in subject breaks IGEP0032 build with the following error: drivers/misc/status_led.c:30:7: error: 'RED_LED_GPIO' undeclared here (not in a function) scripts/Makefile.build:275: recipe for target 'drivers/misc/status_led.o' failed make[2]: *** [drivers/misc/status_led.o] Error 1 scripts/Makefile.build:420: recipe for target 'drivers/misc' failed make[1]: *** [drivers/misc] Error 2 Makefile:1093: recipe for target 'drivers' failed make: *** [drivers] Error 2 Fix this by skipping the status led on IGEP0032 machine as is not available and throw an error for future machines if the status led is not configured to avoid build breakage. Reported-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
2015-02-23Merge branch 'master' of git://git.denx.de/u-boot-mmcTom Rini
2015-02-23mmc: sdhci: fix bus width switching on Samsung SoCsMatt Reimer
Fix bus width switching from 8-bit mode down to 4-bit or 1-bit modes on Samsung SoCs using SDHCI_QUIRK_USE_WIDE8. These SoCs report controller version 2.0 yet they support 8-bit bus widths. If 8-bit mode was previously enabled and then an operation like "mmc dev" caused a switch back down to 4-bit or 1-bit mode, WIDE8 was left set, causing failures. This problem was manifested by "mmc dev" timing out. Signed-off-by: Matt Reimer <mreimer@sdgsystems.com>
2015-02-23mmc: print SD/eMMC type for inited mmc devicesPrzemyslaw Marczak
Depending on the boot priority, the eMMC/SD cards, can be initialized with the same numbers for each boot. To be sure which mmc device is SD and which is eMMC, this info is printed by 'mmc list' command, when the init is done. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
2015-02-23mmc: exynos dwmmc: check boot mode before init dwmmcPrzemyslaw Marczak
Before this commit, the mmc devices were always registered in the same order. So dwmmc channel 0 was registered as mmc 0, channel 1 as mmc 1, etc. In case of possibility to boot from more then one device, the CONFIG_SYS_MMC_ENV_DEV should always point to right mmc device. This can be achieved by init boot device as first, so it will be always registered as mmc 0. Thanks to this, the 'saveenv' command will work fine for all mmc boot devices. Exynos based boards usually uses mmc host channels configuration: - 0, or 0+1 for 8 bit - as a default boot device (usually eMMC) - 2 for 4bit - as an optional boot device (usually SD card slot) And usually the boot order is defined by OM pin configuration, which can be changed in a few ways, eg. - Odroid U3 - eMMC card insertion -> first boot from eMMC - Odroid X2/XU3 - boot priority jumper By this commit, Exynos dwmmc driver will check the OM pin configuration, and then try to init the boot device and register it as mmc 0. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Pantelis Antoniou <panto@antoniou-consulting.com> Cc: Simon Glass <sjg@chromium.org> Cc: Akshay Saraswat <akshay.s@samsung.com>
2015-02-23sunxi: mmc: Always declare High Capacity capabilityHans de Goede
High Capacity (e)MMC cards work fine on sun4i / sun5i, and not having this capability set causes u-boot to not recognize the eMMC on an Utoo P66 A13 tablet, so always set it thereby fixing this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-23mmc: exynos_dw_mmc: use the exynos specific data structureJaehoon Chung
Clksel value is exynos specific value. It removed "clksel_val" into dwmci_host and created the "dwmci_exynos_priv_data" structure for exynos specific data. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2015-02-23mmc: exynos_dw_mmc: set to clksel_val into board-init functionJaehoon Chung
"clksel_val" is assigned to property of mmc or defined value. But it doesn't write at initial sequence. There is a reason that get the wrong source-clock value. This patch fixed it. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2015-02-23mmc: dw_mmc: fixed the wrong bit controlJaehoon Chung
If mode is not DDR-mode, then it needs to clear it. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
2015-02-23mmc: Implement SD/MMC versioning properlyPantelis Antoniou
The SD/MMC version scheme was buggy when dealing with standard major.minor.change cases. Fix it by using something similar to the linux's kernel versioning method. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> Tested-by: Jaehoon Chung <jh80.chung@samsung.com> Reported-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-02-21Merge git://git.denx.de/u-boot-sunxiTom Rini
2015-02-21sunxi: Machine id hack to prevent loading buggy sunxi-3.4 kernelsSiarhei Siamashka
Right now U-Boot supports the CONFIG_OLD_SUNXI_KERNEL_COMPAT option, which makes it go out of its way in limiting the selection of PLL clock frequencies and PMIC voltages in order not to upset outdated buggy sunxi-3.4 kernel releases. And if the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is not set, then booting such old kernels exhibits various failures at runtime. This is very user unfriendly, and there were already several incidents when people wasted their time being hit by these runtime failures and trying to debug them. The right solution is not to add hacks and workarounds to the mainline U-Boot, but to fix these bugs in the sunxi-3.4 kernel. And in fact, the updated sunxi-3.4 kernels already exist. Still we need to follow the 'Principle of Least Surprise' and U-Boot needs to ensure that the old buggy kernels are not getting happily booted when the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is not set. And this patch addresses this particular issue. This patch makes U-Boot store the 'compatibility revision' number in the top 4 bits of the machine id and pass it to the kernel. The old buggy kernels will fail to load with a very much googlable error message on the serial console (the "r1 = 0x100010bb" part of it): "Error: unrecognized/unsupported machine ID (r1 = 0x100010bb)" This error message can be documented in the linux-sunxi wiki with proper explanations about how to resolve this situation and where to get the necessary bugfixes for the sunxi-3.4 kernel. The fixed sunxi-3.4 kernels implement a revision compatibility check and clear the top 4 bits of the machine id if everything is alright. By accepting the machine id with the bits 31:28 set to 1, the sunxi-3.4 kernel effectively certifies that it has the PLL5 clock speed and AXP209 DCDC3 voltage fixes applied. It is still possible to set the CONFIG_OLD_SUNXI_KERNEL_COMPAT option in U-Boot if the user desires to use an outdated unpatched sunxi-3.4 kernel. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-21sunxi: Set the /chosen/stdout-path fdt property for sunxi boardsHans de Goede
While discussing with some people how to get the Linux kernel to do the right thing wrt sending output to both the serial console and the hdmi out / lcd screen when booting on ARM devices, Grant Likely pointed out that there already is a solution for this. All we need to do is set the /chosen/stdout-path fdt property, and if no console= arguments were specified on the kernel commandline the kernel will honor this and add this device as a console (next to the primary video output on hdmi). And u-boot already has support for setting this, all we need to do is define OF_STDOUT_PATH and then everything will just work ootb, without people needing to meddle with adding console= arguments in extlinux.conf . Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Tom Rini <trini@ti.com>
2015-02-21sunxi: Fix sun5i mbus speed when booting old kernelsHans de Goede
Older linux-sunxi-3.4 kernels override our PLL6 setting with 300 MHz, halving the mbus frequency, so set it to 300 MHz ourselves and base the mbus divider on that. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-21sunxi: musb: Check Vbus-det before enabling otg port powerHans de Goede
Sending out 5V when there is a charger connected to the otg port is not a good idea, so check for this and error out. Note this commit currently breaks otg support on the q8h tablets, as we need to do some magic with the pmic there to get vbus info, this is deliberate (better safe then sorry), fixing this is on my TODO list. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-21sunxi: Add support for the UTOO P66 tabletHans de Goede
The UTOO P66 is a 6" A13 tablet / lcd ereader. It features a 6" 480x800 ips lcd screen, 512MB RAM & 4GB emmc. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-21sunxi: mmc: Always declare High Capacity capabilityHans de Goede
2015-02-21rpi: add support for Raspberry Pi 2 model BStephen Warren
USB doesn't seem to work yet; the controller detects the on-board Hub/ Ethernet device but can't read the descriptors from it. I haven't investigated yet. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21bcm2836 SoC support (used in Raspberry Pi 2 model B)Stephen Warren
The bcm2835 and bcm2836 are essentially identical, except: - The CPU is an ARM1176 v.s. a quad-core Cortex-A7. - The physical address of many IO controllers has moved. Rather than introducing a whole new bcm2836 value for $(SOC) or $(ARCH), update the existing bcm2835 code to handle the minor differences, and plumb it into the ARMv7 CPU architecture. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2015-02-21bcm2835/rpi: add SPDX license tags for some filesStephen Warren
2015-02-21ARM: prepare for including <mach/*.h>Masahiro Yamada
This commit adds $(srctree)/arch/arm/$(machdirs)/include/mach to the headers search path. It allows us to replace "#include <asm/arch/foo.h>" with "#include <mach/foo.h>". As "#include <asm/arch/foo.h>" is still supported, we can modify each file one by one. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-21ARM: keystone: move SoC headers to mach-keystone/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-keystone/* -> arch/arm/mach-keystone/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2015-02-21ARM: orion5x: move SoC headers to mach-orion5x/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-orion5x/* -> arch/arm/mach-orion5x/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-02-21ARM: nomadik: move SoC headers to mach-nomadik/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-nomadik/* -> arch/arm/mach-nomadik/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nomadik Linux Team <STN_WMM_nomadik_linux@list.st.com> Cc: Alessandro Rubini <rubini@unipv.it>
2015-02-21ARM: kirkwood: move SoC headers to mach-kirkwood/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-kirkwood/* -> arch/arm/mach-kirkwood/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: davinci: move SoC headers to mach-davinci/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-davinci/* -> arch/arm/mach-davinci/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2015-02-21ARM: at91: move SoC headers to mach-at91/include/machMasahiro Yamada
Move arch/arm/include/asm/arch-at91/* -> arch/arm/mach-at91/include/mach/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-21kbuild: prepare for moving headers into mach-*/include/machMasahiro Yamada
In U-Boot, SoC-specific headers are placed in arch/$(ARCH)/include/asm/arch-$(SOC) and a symbolic link to that directory is created at the early stage of the build process. Creating and removing a symbolic link during the build is not preferred. In fact, Linux Kernel did away with include/asm-$(ARCH) directories a long time time ago. As for ARM, now it is possible to collect SoC sources into arch/arm/mach-$(SOC). It is also reasonable to move SoC headers into arch/arm/mach-$(SOC)/include/mach. This commit prepares for that. If the directory arch/$(ARCH)/mach-$(SOC)/include/mach exists, a symbolic to that directory is created. Otherwise, a symbolic link to arch/$(ARCH)/include/asm/arch-$(SOC) or arch-$(CPU) is created. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-21ARM: keystone: move SoC sources to mach-keystoneMasahiro Yamada
Move arch/arm/cpu/armv7/keystone/* -> arch/arm/mach-keystone/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2015-02-21ARM: versatile: move SoC sources to mach-versatileMasahiro Yamada
Move arch/arm/cpu/arm926ejs/versatile/* -> arch/arm/mach-versatile/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-21ARM: orion5x: move SoC sources to mach-orion5xMasahiro Yamada
Move arch/arm/cpu/arm926ejs/orion5x/* -> arch/arm/mach-orion5x/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2015-02-21ARM: highbank: move SoC sources to mach-highbankMasahiro Yamada
Move arch/arm/cpu/armv7/highbank/* -> arch/arm/mach-highbank/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Rob Herring <robh@kernel.org>
2015-02-21ARM: nomadik: move SoC sources to mach-nomadikMasahiro Yamada
Move arch/arm/cpu/arm926ejs/nomadik/* -> arch/arm/mach-nomadik/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Nomadik Linux Team <STN_WMM_nomadik_linux@list.st.com> Cc: Alessandro Rubini <rubini@unipv.it>
2015-02-21ARM: kirkwood: move SOC sources to mach-kirkwoodMasahiro Yamada
Move arch/arm/cpu/arm926ejs/kirkwood/* -> arch/arm/mach-kirkwood/* Note: Perhaps, can we merge arch/arm/mach-kirkwood and arch/arm/mvebu-common into arch/arm/mach-mvebu, like Linux? Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Prafulla Wadaskar <prafulla@marvell.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2015-02-21ARM: davinci: move SoC sources to mach-davinciMasahiro Yamada
Move arch/arm/cpu/arm926ejs/davinci/* -> arch/arm/mach-davinci/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com>
2015-02-21ARM: tegra: collect SoC sources into mach-tegraMasahiro Yamada
This commit moves files as follows: arch/arm/cpu/arm720t/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/arm720t/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/arm720t/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/arm720t/tegra124* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/arm720t/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/armv7/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/armv7/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/armv7/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/armv7/tegra124/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/armv7/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/tegra20-common/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/tegra30-common/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/tegra114-common/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/tegra124-common/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/tegra-common/* -> arch/arm/mach-tegra/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> [ on nyan-big ] Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2015-02-21ARM: at91: collect SoC sources into mach-at91Masahiro Yamada
This commit moves source files as follows: arch/arm/cpu/arm920t/at91/* -> arch/arm/mach-at91/arm920t/* arch/arm/cpu/arm926ejs/at91/* -> arch/arm/mach-at91/arm926ejs/* arch/arm/cpu/armv7/at91/* -> arch/arm/mach-at91/armv7/* arch/arm/cpu/at91-common/* -> arch/arm/mach-at91/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.co>
2015-02-21ARM: prepare for moving SoC sources into mach-*Masahiro Yamada
In U-boot, the directory structure, arch/$(ARCH)/cpu/$(CPU)/$(SOC)/ has been adopted except that $(CPU) is missing from some architectures and $(SOC) is missing from some CPUs. This structure did not fit very well in some cases. [1] AT91 AT91 SoC family have been developed across some ARM processor generations. Generally speaking, some IPs are often re-used in the same SoC family (same SoC vendor) even when the main processor is updated. As a result, a SoC-common directory is needed in the upper level. Currently, AT91 source files are placed as follows: arch/arm/cpu/arm920t/at91/* arch/arm/cpu/arm926ejs/at91/* arch/arm/cpu/armv7/at91/* arch/arm/cpu/at91-common/* Once directories are split, the motivation for refactorings across CPU directories is lost. Some files in arm920t/at91/ and arm926ejs/at91/ are so similar that they could be merged. [2] Tegra Tegra is a little bit special case where different CPUs are used for SPL and the main U-boot. To obey the arch/$(ARCH)/cpu/$(CPU)/$(SOC) structure, the source files must be placed across the CPUs, again SoC-common directory is necessary in the upper level. Moreover, there are several families in Tegra: Tegra20, Tegra30, Tegra114, Tegra124. Here again, the tegra-common directory is needed to contain commonly-used files. Tegra directories have been sprinkled in the directory structure. arch/arm/cpu/arm720t/tegra20 arch/arm/cpu/arm720t/tegra30 arch/arm/cpu/arm720t/tegra114 arch/arm/cpu/arm720t/tegra124 arch/arm/cpu/arm720t/tegra-common arch/arm/cpu/armv7/tegra20 arch/arm/cpu/armv7/tegra30 arch/arm/cpu/armv7/tegra114 arch/arm/cpu/armv7/tegra124 arch/arm/cpu/armv7/tegra-common arch/arm/cpu/tegra20-common arch/arm/cpu/tegra30-common arch/arm/cpu/tegra114-common arch/arm/cpu/tegra124-common arch/arm/cpu/tegra-common As you see, splitting SoC code by the CPU is not going well, especially for ARM. Why don't we collect SoC-specific files into a single place? A good example we can follow is Linux's arch/arm/mach-* structure. This item was discussed in the following thread: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/188548/ Looks like I got some positive responses and we are almost ready to start this movement. This commit prepares arch/arm/Makefile for describing machdirs in it. After this commit, we can move SoC directory to arch/arm/mach-$(SOC) in simple steps although some cases such as AT91 and Tegra need more fixes. What we generally have to do is: [1] Move files arch/arm/cpu/$(CPU)/$(SOC)/* to arch/arm/mach-$(SOC)/* [2] Add machine entry into arch/arm/Makefile [3] Remove "obj-y += $(SOC)" from arch/arm/cpu/$(CPU)/Makefile [4] Fix the Kconfig file path in arch/arm/Kconfig [5] Modify MAINTAINERS if necessary Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2015-02-21Merge git://git.denx.de/u-boot-dmTom Rini
2015-02-20sunxi: video: Add support for tl059wv5c0 lcd panelsHans de Goede
Add support for the 6" 480x800 tl059wv5c0 panel used on e.g. Utoo P66 and Aigo M60/M608/M606 tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-20sunxi: video: Add support for LCD panels which need to be configured via i2cHans de Goede
This commits adds support for configuring a a bitbang i2c controller, which is used on some boards to configure the LCD panel (via i2c). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-20sunxi: video: Add support for LCD reset pinHans de Goede
On some boards there is a gpio to reset the LCD panel, add support for this. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-19dm: Protect device_unbind() with CONFIG_DM_DEVICE_REMOVEMarek Vasut
Since device_unbind() is also defined in device-remove.c, which is compiled in only in case CONFIG_DM_DEVICE_REMOVE is defined, protect the device_unbind() prototype with the same CONFIG_DM_DEVICE_REMOVE check. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stefan Roese <sr@denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-02-19serial: ns16550: Support debug UARTSimon Glass
Add debug UART functions to permit ns16550 to provide an early debug UART. Try to avoid using the stack so that this can be called from assembler before a stack is set up (at least on ARM and PowerPC). Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19serial: ns16550: Add access functions that don't need platdataSimon Glass
For the debug UART we need to be able to provide any parameters before driver model is set up. Add parameters to the low-level access functions to make this possible. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19serial: Support an early UART for debuggingSimon Glass
This came up in a discussion on the mailing list here: https://patchwork.ozlabs.org/patch/384613/ My concerns at the time were: - it doesn't need to be written in assembler - it doesn't need to be ARM-specific This patch provides a possible alternative. It works by allowing any serial driver to export one init function and provide a putc() function. These can be used to output debug data before the real serial driver is available. This implementation does not depend on driver model, and it is possible for it to operate without a stack on some architectures (e.g. PowerPC, ARM). It provides the same features as the ARM-specific debug.S but with more UART and architecture support. Signed-off-by: Simon Glass <sjg@chromium.org>
