Signed-off-by: Andreas Fenkart <andreas.fenkart@digitalstrom.com>
disabled original parsing, but not yet removed since the
argument indexing needs to be fixed
goal is to use getopt for all argument parsing instead of adhoc
parsing in fw_getenv/fw_setenv functions
passing argv/argc can produce off-by-one errors
NULL check is made after the pointer dereference. This patch
fixes this issue.
Signed-off-by: Vishwas Srivastava <vishu.kernel@gmail.com>
CC: Joe Hershberger <joe.hershberger@ni.com>
Fix device tree name:
+(xilinx-ppc405-generic) Device Tree Source is not correctly specified.
+(xilinx-ppc405-generic) Please define 'CONFIG_DEFAULT_DEVICE_TREE'
+(xilinx-ppc405-generic) or build with 'DEVICE_TREE=<device_tree>'
argument
+(xilinx-ppc405-generic) make[2]: ***
[arch/powerpc/dts/xilinx-ppc440-generic.dtb] Error 1
+(xilinx-ppc405-generic) make[1]: *** [dts] Error 2
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
emac module of the davinci platform supports only 8 tx and 8
rx channels (total 16). emac driver for davinci platform,
however, while doing initialization of the dma descriptor
head pointers, wrongly initializes the 16 head pointers
(instead of 8) for tx dma and 16 head pointers (insted of 8)
for rx dma, which is wrong. The result is, that this register
initilization spills over the other registers which was not
intended and is undesirable. This patch fixes this problem.
Introduce fdtdec_get_child_count for get the number of subnodes
of one parent node.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
The option was renamed to CONFIG_CONSOLE_ROTATION and Rockchip boards
were not updated. However this option is is not needed by default for
Rockchip since we don't need a rotated console for current boards. So just
remove the old option.
Use __maybe_unused which should avoid the Coverity error.
Reported-by: Coverity (CID: 134900)
Close the file earlier to hopefully fix a Coverity error.
Reported-by: Coverity (CID: 134901)
Using short doesn't save anything and is confusing when the width and height
variables are ulong.
This may fix Coverity CID134902 but I doubt it.
All paths should share the same return.
Reported-by: Coverity (CID:134903)
This fixes the following error when building microblaze-generic:
net/eth-uclass.c: In function 'eth_post_probe':
net/eth-uclass.c:466:18: error: 'gd' undeclared (first use in this function)
ops->start += gd->reloc_off;
Fixes: db9391e1 ("net: Move driver-model code into its own file")
Correct spelling of "U-Boot" shall be used in all written text
(documentation, comments in source files etc.).
Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
Set up the debug UART early if enabled, so that it is ready to use.
Acked-by: Chin Liang See <clsee@altera.com>
Now that we have converted all x86 codes to DM PCI, drop pci_type1.c
which is only built for legacy PCI. Also per checkpatch.pl warning,
DEFINE_PCI_DEVICE_TABLE is now deprecated so drop that too.
Now that all x86 codes have been converted to use proper DM PCI APIs,
it's time to disable the legacy compatible layer.
When CONFIG_DM_PCI_COMPAT is not on, there is only a forward declaration
for pci_write_config32(). Add other missing ones.
This board uses RTL8169 which is a driver model ethernet driver.
Now that the RTL8169 driver warning is fixed we can drop this.
It does not build if without CONFIG_DM_PCI_COMPAT. For now we just
disable it, until some day we add USB support to EFI application.
Move some #undef from efi-x86.h to efi-x86_defconfig as these are
already Kconfig options.
There are still two places in Quark's MRC codes that use the generic
legacy PCI APIs, but as we are phasing out these legacy APIs, switch
to use Quark's own PCI config routines.
Update this driver to use proper DM PCI APIs.
Convert to use native DM PCI API dm_pci_mem_to_phys().
Use native DM PCI APIs instead of legacy compatible ones.
Now that we have converted all x86 codes to use DM PCI APIs,
drop those legacy ones.
Drop legacy PCI APIs usage in pci_assign_irqs() as well.
Use pci_[read|write]_config intead of x86_pci_[read|write]_config.
With recent DM PCI changes to vesa_fb driver, external graphics
card does not work any more. This is because: after setting the
function disable bit, IGD and SDVO devices will disappear in the
PCI configuration space. This however creates an inconsistent state
from a driver model PCI controller point of view, as these two PCI
devices are still attached to its parent's child device list as
maintained by the driver model. Some driver model PCI APIs like
dm_pci_find_class() used in the vesa_fb driver, are referring to
the list to speed up the finding process instead of re-enumerating
the whole PCI bus, so it gets the stale cached data which is wrong.
To fix this, manually remove these two devices.
Once we get udevice of IGD and SDVO, we can use its udevice to
access PCI configuration space with dm_pci_write_config32().
So far disable_igd() does not have any return value, but we may need
that in the future.
Now that we have irq router's udevice passed as a parameter, it's
time to start using the DM PCI API instead of those legacy ones.
At present irq_router is declared as a static struct irq_router in
arch/x86/cpu/irq.c. Since it's a driver control block, it makes sense
to move it to a per driver priv. Adjust existing APIs to accept an
additional parameter of irq_router's udevice.
There is no need to parse PCH's <reg> property as we have already
a DM PCI API dm_pci_get_bdf() that can handle this.
IOBASE is now obtained from PCH driver, drop this <io-base> property.
asm/arch/gpio.h is not needed anymore as we get the GPIO base from
PCH driver.
At present this GPIO driver still uses the legacy PCI API. Now that
we have proper PCH drivers we can use those to obtain the information
we need. While the device tree has nodes for the GPIO peripheral it is
not in the right place. It should be on the PCI bus as a sub-peripheral
of the PCH device.
Update the device tree files to show the GPIO controller within the PCH,
so that PCI access works as expected. This also adds '#address-cells'
and '#size-cells' to the PCH node.
IO_BASE is only seen on PCH9 device, implement the get_io_base op.
On some newer chipset (eg: BayTrail), there is an IO base address
register on the PCH device which configures the base address of a
memory-mapped I/O controller.
Implement get_gpio_base op for bd82x6x, pch7 and pch9 drivers.
x86 GPIO registers are accessed via I/O port whose base address is
configured in a PCI configuration register on the PCH device. Add
an op get_gpio_base to get the GPIO base address from PCH.
Spell out 'sbase' to 'spi_base' so that it looks clearer.
pch_get_version op was only used by the ich spi controller driver,
and does not really provide a good identification of pch controller
so far, since we see plenty of Intel PCH chipsets and one differs
from another a lot, which is not simply either a PCHV_7 or PCHV_9.
Now that ich spi controller driver was updated to not get such info
from pch, the pch_get_version op is useless now.
