Add PMIC support. Tested by command "pmic PFUZE3000 dump".
Signed-off-by: Vanessa Maegima <vanessa.maegima@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
Add support for Advantech DMS-BA16 board. The board is based on Advantech
BA16 module which has a i.MX6D processor. The board supports:
- FEC Ethernet
- USB Ports
- SDHC and MMC boot
- SPI NOR
- LVDS and HDMI display
Basic information about the module:
- Module manufacturer: Advantech
- CPU: Freescale ARM Cortex-A9 i.MX6D
- SPECS:
Up to 2GB Onboard DDR3 Memory;
Up to 16GB Onboard eMMC NAND Flash
Supports OpenGL ES 2.0 and OpenVG 1.1
HDMI, 24-bit LVDS
1x UART, 2x I2C, 8x GPIO,
4x Host USB 2.0 port, 1x USB OTG port,
1x micro SD (SDHC),1x SDIO, 1x SATA II,
1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Cc: u-boot@lists.denx.de
Cc: sbabic@denx.de
mx7dsabresd has two targets:
- mx7dsabresd_defconfig: boots in non-secure mode
- mx7dsabresd_secure_defconfig: boots in secure mode
Print the mode that is being used to help users to easily identify
which target is running on the board.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Currently the command buffer gets allocated with a size of 32 bytes.
This causes warning messages on systems with cache lines bigger than
32 bytes:
CACHE: Misaligned operation at range [9df17a00, 9df17a20]
Define command buffer to be at least 32 bytes, but more if cache
line is bigger.
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
HDMI output must be enabled very early to also enable the pre-console buffer
Signed-off-by: Soeren Moch <smoch@web.de>
'usb start' is much faster now, so always enable usb keyboard
The Colorado TK1 SOM is a small form factor board similar to the
Jetson TK1. The main differences lie in the pinmux, and in that the
PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by
Colorado Engineering using the tegra-pinmux scripts. The spreadsheet
was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The board ID EEPROM and board ID stickers on p2771-0000 will use a numeric
versioning scheme, with version numbers such as 000/100/200/300/400/500.
Within NVIDIA, these versions are also known as A00/A01/A02/A03/A04/B00.
However, that numbering scheme is not easily visible outside of NVIDIA,
and so does not make much sense to use. Convert U-Boot to use the readily
visible numeric scheme.
Also, it turns out that the current A02 DT actually applies to board
versions 000/100/200 (A00..A02). Consequently rename this to 000 not 200
so that all U-Boot builds are named after the first version of the HW they
support.
This introduces two board defconfig files for generating EFI 32-bit
and 64-bit payloads, to run on QEMU x86 target.
With these in place, hopefully buildman will catch any build error
with EFI payload support on x86.
There are lots of warnings when building EFI 64-bit payload.
include/asm-generic/bitops/__fls.h:17:2:
warning: left shift count >= width of type
if (!(word & (~0ul << 32))) {
In fact, U-Boot itself as EFI payload is running in 32-bit mode.
So BITS_PER_LONG needs to still be 32, but EFI status codes are
64-bit when booting from 64-bit EFI. Introduce EFI_BITS_PER_LONG
to bridge those status codes with U-Boot's BITS_PER_LONG.
Since commit 73c5c39 "Makefile: Drop unnecessary -dtb suffixes",
EFI payload does not build anymore. This fixes the build.
Add a debug() at this point to help figure out what is wrong.
Generally the microcode is combined into a single block only (and removed
from the device tree) when there are multiple blocks. But this is not a
requirement.
Adjust the ivybridge code to avoid assuming this.
Reviewed-by: Heiko Schocher<hs@denx.de>
This will be useful, for example, to load firmware to DRAM and make
it visible to other agents.
This is very likely to be necessary for normal use cases.
Set its default to 'y' for shorter defconfig files.
The eMMC on sLD3 is assigned with dedicated pins (only multiplexed
with GPIO), so it shouldn't hurt to enable eMMC on SPL all the time.
Commit 76c52ce29fd7 ("ARM: uniphier: increase CONFIG_SYS_MALLOC_F_LEN
to bind all nodes") missed to increase this config for sLD3.
This change is needed to add "u-boot,dm-pre-reloc" to some nodes;
more devices are bound, more malloc memory is needed.
The revision of the original support card (rev 3.5, rev 3.6) fits in
the 8 bit width revision register. When it was extended in a weird
way, it was versioned in the format of "3.6.x" (where it should have
been "3.7", of course). What is worse, only the sub-level version
"6.x" was recorded in the 8 bit width register, completely ignoring
the compatibility of the revision register format.
This patch saves madly-versioned support cards by assuming the major
version "3" when the MSB 4 bit of the register is read as "6". With
this, the support card revision that were displayed as "6.10" is now
corrected to "3.6.10".
This supports the system reset via PSCI for ARMv7 SoCs.
Because the system reset is not supported on PSCI 0.1, let's define
CONFIG_ARMV7_PSCI_1_0. (it is supported since PSCI 0.2, but there
is no CONFIG to enable it in U-Boot for now.)
With this, we can save unnecessary udelay().
With the CONFIG_DM_MMC_OPS migration, the .set_ios callback can
return an integer now. Return an appropriate error value rather
than sudden death by BUG().
No more reason to define this function above the ops structure.
Move it near the caller. Also, change its return type to void
because it never fails.
Catch up with the DM migration.
As struct dm_mmc_ops does not have .init callback, call the init
function directly from the probe function.
They are both only referenced in this file.
This patch add maintainer information for rk3399 evb.
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
Reviewed-by: Andreas Färber <afaerber@suse.de>
If we do nand device 0 command in u-boot on a device that has NAND support
enabled but no NAND chip, we can get data abort at least on omaps.
Fix the issue by replacing the check with nand_info[dev] as
suggested by Scott Wood. The check for name existed before because before
the array-to-pointer conversion there was no way to directly test
nand_info[dev] for emptiness.
Most of them are my mistakes.
This is needed to move CONFIG options for the recently-added
xtfpga_defconfig.
The tarball of the pre-built toolchain can be downloaded from:
https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/
The page table is maintained by the CPU, hence it is safe to always
align cache flush to a whole cache line size. This allows to use
mmu_page_table_flush for a single page table, e.g. when configure
only small regions through mmu_set_region_dcache_behaviour.
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Add LPAE support for mmu_set_region_dcache_behaviour. The function
is in use in some LPAE capable board such TI DRA7xx or NXP i.MX 7.
Use a tab not 8 spaces.
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Stefan Roese <sr@denx.de>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
The H3 PLL5 used for DRAM barely manages to lock to the required
frequency before DRAM controller starts, sometimes leading to wrong
delay-line calibration results.
This patch changes the PLL tuning parameters to the same values as
boot0 used, which speeds up the locking and fixes the problem.
Signed-off-by: Jens Kuske <jenskuske@gmail.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
When the backlight's pwm input is connected to a pwm output of the SoC,
actually use pwm to drive the backlight.
The mean reason for doing this is to fix the backlight turning off
for aprox. 1 second while the kernel is booting. This is caused by
the kernel actually using pwm to drive the backlight, so that it
can dim the backlight. First the pwm driver loads and switches the
pinmux for the pin driving the backlight's pwm input to the pwm
controller. Then about 1s later the actual backlight driver loads
and tells the pwm driver to actually update the pwm settings, which
have a power-on-reset value of "off".
An additional advantage is that this allows us to initatiate the
backlight at 80%, which is the kernel default, avoiding a brightness
change while the kernel loads.
Reviewed by: Peter Korsgaard <peter@korsgaard.com>
Add a defconfig and dts file for the Empire Electronix M712 tablet, this
is a 7" A13 tablet, with micro-usb (otg), headphone and micro-sd slots on
the outside. It uses a Goodix gt811 touchscreen controller, a RTL8188CTV
wifi chip and a DMART06 (1238a4) accelerometer.
The dts file is identical to the one submitted to the upstream kernel.
Sync dts files with the current (Aug 18th 2016) state of Maxime's
linux/sunxi/for-next repo.
Note this commit also updates configs/MSI_Primo81_defconfig,
adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary
because the tablet does not have a reachable uart so the dts sync
drops its serial0 alias.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add a defconfig and dts file for tablets using the generic inet-q972 PCB.
Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host,
micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot,
(mini) power-barrel and an usb wifi module.
This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet.
The dts files are identical to the ones submitted to the upstream kernel.
Commit f4db6c976cf ("arm: mvebu: Add runtime detection of UART (xmodem)
boot-mode") added a change to hdr->destaddr when dynamically patching an
image for UART boot mode. With this change, kwboot ceases to work on
Kirkwood.
Thus, let's change hdr->destaddr only when we are patching an image with
header version 1 (Orion and Kirkwood use header version 0).
Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
Fixes: f4db6c976cf ("arm: mvebu: Add runtime detection of UART (xmodem) boot-mode")
Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
Signed-off-by: Chris Packham <judge.packham@gmail.com>
Ensure appropriate error messages are generated. Previously all errors
indicated that the serdes was already in use. Now appropriate error
messages are given.
As of commit 88e34e5 ("spl: replace CONFIG_SPL_SPI_* with
CONFIG_SF_DEFAULT_*") these defines are not used. Remove them to avoid
confusion.
The NAND interface on the Armada-38x series is similar to that on the
Armada-XP. The key difference is that the NAND ECC clock ratio is
provided via the DFX Server registers instead of the Core Clock.
Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Dirk Eibach <eibach@gdsys.de>
Patch f8a10ed1 [i2c: mvtwsi: Make address length variable] accidentally
inverted the sequence of address bytes sent to the I2C device. This
patch corrects this by sending the highest byte first and the lowest
byte last again.
Tested on theadorable Armada-XP board.
Cc: Mario Six <mario.six@gdsys.cc>
