2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2009-01-28pcs440ep: Clean up led command definitionPeter Tyser
The pcs440ep's led command usage formatting is non-standard. It was made standard in preparation for larger command usage updates. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Clean up diufb command definitionsPeter Tyser
The diufb command usage formatting is non-standard. It was made standard in preparation for larger command usage updates. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Update CHANGELOG, tiny coding style cleanup.Wolfgang Denk
2009-01-27SATA: do not auto-initialize during bootMike Frysinger
Rather than have the board code initialize SATA automatically during boot, make the user manually run "sata init". This brings the SATA subsystem in line with common U-Boot policy. Rather than having a dedicated weak function "is_sata_supported", people can override sata_initialize() to do their weird board stuff. Then they can call the actual __sata_initialize(). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-27part_efi: Fix partition size calculation due to inclusive ending LBA.Richard Retanubun
The ending LBA is inclusive. Hence, the partition size should be ((ending-LBA + 1) - starting-LBA) to get the proper partition size. This is confirmed against the results from the parted tool. (e.g. use parted /dev/sda -s unit S print) and observe the size. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
2009-01-27jffs2: Fix zero sector_size when not using CONFIG_JFFS2_CMDLINETomasz Figa
This patch fixes a bug (?) introduced after inclusion of the new JFFS2 code. When not using CONFIG_JFFS2_CMDLINE, the code in cmd_jffs2.c doesn't fill in part->sector_size (keeping it as 0), but a correct value is needed by the code in jffs2_1pass.c. This causes all JFFS2 accesses to be in the same place of the memory, what obviously means impossibility to use the JFFS2 partition. This problem is fixed in this patch by including sector size calculation in non-CONFIG_JFFS2_CMDLINE mtdparts_init variant. Signed-off-by: Tomasz Figa <tomasz.figa_at_gmail.com>
2009-01-27saveenv: standardize enablementMike Frysinger
Rather than special casing each environment type for enabling the saveenv command, have them all behave the same. This avoids bitrot as new env sources are added/removed. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-27soft_i2c.c add option for repeated start in i2c_read()Andrew Dyer
This patch adds a #define to optionally change the behaviour of i2c_read() in soft_i2c.c to send an I2C repeated start instead of a stop-start between sending the device address pointer write and reading back the data. The current behaviour is retained as the default. While most devices will work either way, I have a smart battery(*) that requires repeated start, and someone at some point found a device that required a stop-start. (*) http://www.inspired-energy.com/Standard_Products/NL2054/NL2054%20Rev1.0%20Data%20Sheet.pdf Signed-off-by: Andrew Dyer <adyer@righthandtech.com>
2009-01-27{delta,zylonite}/lowlevel_init.S: fix typoWolfgang Denk
Commit 9d803d8c mistakenly changed some constants from 0x300 into 300 - this patch fixes it. Pointed out by Tom Evans <tom@ceos.com.au>, see http://article.gmane.org/gmane.comp.boot-loaders.u-boot/51992 for details. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-27drivers/net/e1000.c: missing terminator for supported devicesStefan Althoefer
Signed-off-by: Stefan Althoefer <stefan.althoefer@web.de>
2009-01-27fat.c: fix warning: array subscript is above array boundsWolfgang Denk
Fix based on suggestion by David Hawkins <dwh@ovro.caltech.edu>. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-27Fix gunzip in case of insufficient output bufferMatthias Fuchs
U-Boot's gunzip() function does not handle the return code of zlib's inflate() function correctly. gunzip() is implemented to uncompress all input data in one run. So the correct return code for the good case is Z_STREAM_END. In case of insufficient output buffer memory inflate returns Z_OK. For gunzip() this is an error. It also makes sense to me to call inflateEnd() also in case of an error. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2009-01-27Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2009-01-27Merge branch 'master' of git://git.denx.de/u-boot-cfi-flashWolfgang Denk
2009-01-27MIPS: Add VCT board series support (Part 3/3)Stefan Roese
2009-01-27MIPS: Add VCT board series support (Part 2/3)Stefan Roese
2009-01-27MIPS: Add VCT board series support (Part 1/3)Stefan Roese
2009-01-27MIPS: Add flush_dcache_range() and invalidate_dcache_range()Stefan Roese
This patch adds flush_/invalidate_dcache_range() to the MIPS architecture. Those functions are needed for the upcoming dcache support for the USB EHCI driver. I chose this API because those cache handling functions are already present in the PPC architecture. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2009-01-26CFI: Add geometry reversal for STMicro M29W320ETRichard Retanubun
Added flash_fixup_stm to fix geometry reversal on STMicro M29W320ET flash chip. Modeled after flash_fixup_amd, this patch handles the geometry reversal or erase sectors that exist for ST Micro (now Numonyx) M29W320ET flash. Since I cannot test all STM's chips, the detection is implemented as narrow as possible for now. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26CFI: increase performance of function find_sector()Jens Gehrlein
Tested on TQM5200S-BD with Samsung K8P2815UQB Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26CFI: avoid redundant function call in single word programming modeJens Gehrlein
The function find_sector() doesn't need to be called twice in the case of AMD command set. Tested on TQM5200S-BD with Samsung K8P2815UQB. Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Remove compilation warning in gdppc440etc.cStefan Roese
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Add GDsys PowerPC 440 ETX board support.Dirk Eibach
Board support for the Guntermann & Drunck PowerPC 440 ETX module. Based on the AMCC Yosemite board support by Stefan Roese. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Improve DDR autodetectDirk Eibach
Added support for a second memory bank to DDR autodetection for 440 platforms. Made hardcoded values configurable. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
2009-01-24Merge branch 'master' of git://git.denx.de/u-boot-mpc83xxWolfgang Denk
2009-01-24easylogo: add optional gzip supportMike Frysinger
Some images can be quite large, so add an option to compress the image data with gzip in the U-Boot image. Then at runtime, the board can decompress it with the normal zlib functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-24fat: fix unaligned errorsBryan Wu
A couple of buffers in the fat code are declared as an array of bytes. But it is then cast up to a structure with 16bit and 32bit members. Since GCC assumes structure alignment here, we have to force the buffers to be aligned according to the structure usage. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-24spi flash: fix crash due to spi flash miscommunicationBrad Bozarth
Higher spi flash layers expect to be given back a pointer that was malloced so that it can free the result, but the lower layers return a pointer that is in the middle of the malloced memory. Reorder the members of the lower spi structures so that things work out. Signed-off-by: Brad Bozarth <bflinux@yumbrad.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-01-24FPU POST: fix warnings when building with 2.18 binutilsYuri Tikhonov
When compile u-boot with the 2.18 binutils the following warning messages for each object file in post/lib_ppc/fpu/ is produced at the linking stage: post/libpost.a(acc1.o) uses hard float, u-boot uses soft-float ... This is because of the fact that, in general, the soft-float and hard-float ABIs are incompatible; the 2.18 binutils do checking of the Tag_GNU_Power_ABI_FP attribute of the files to be linked, and produce the worning like above if these are not compatible. The incompatibility of ABIs is concerned only the float values: e.g. the soft-float ABI assumes the float argument passing in the pair of rX registers, and the hard-float ABI assumes passing of the float argument in the fX register. When we don't pass the float arguments between the functions compiled with different floatness, then such an application will work correctly. This is the case for the FPU POST: u-boot (compiled with soft-float) doesn't pass to (and doesn't get from) the FPU POST functions any floats; there are no functions exported from the post/lib_ppc/fpu/ objects which would work with float parameters/returns too. So, we can reassure the linker not to worry about the difference in ABI attributes of linking files just by setting the 'soft-float' attribute for the objects in post/lib_ppc/fpu. And this patch does this. Also, to avoid passing both soft- and hard-float options in CFLAGS when compiling the files from post/lib_ppc/fpu (which is OK, but looks rather dirty) this patch removes the soft-float string from CFLAGS in post/lib_ppc/fpu/Makefile. Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
2009-01-24Add support for Maxim's DS4510 I2C devicePeter Tyser
Initial support for the DS4510, a CPU supervisor with integrated EEPROM, SRAM, and 4 programmable non-volatile GPIO pins. The CONFIG_DS4510 define enables support for the device while the CONFIG_CMD_DS4510 define enables the ds4510 command. The additional CONFIG_DS4510_INFO, CONFIG_DS4510_MEM, and CONFIG_DS4510_RST defines add additional sub-commands to the ds4510 command when defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-24common: Iteration limit for memory test.Dirk Eibach
The iteration limit is passed to mtest as a fourth parameter: [start [end [pattern [iterations]]]] If no fourth parameter is supplied, there is no iteration limit and the test will loop forever. Signed-off-by: Dirk Eibach <eibach@gdsys.de>
2009-01-24serial: Rename driver vcth to vct to support other board variantsStefan Roese
Moved driver vcth.c to vct.c to better reflect the VCT board series. This driver is now used by the VCT platforms: vct_premium vct_platinum vct_platinumsvc Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-24nios: Move README.nios_CONFIG_SYS_NIOS_CPU to doc/ dirShinya Kuribayashi
2009-01-24common/main: support bootdelay=0 for CONFIG_AUTOBOOT_KEYEDPeter Korsgaard
Support bootdelay=0 in abortboot for the CONFIG_AUTOBOOT_KEYED case similar to the CONFIG_ZERO_BOOTDELAY_CHECK support for the !CONFIG_AUTOBOOT_KEYED case. Do this by reversing the loop so we do at least one iteration before checking for timeout. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
2009-01-24Added legacy flash ST Micro M29W040BNiklaus Giger
2009-01-24Fixed off-by-one errors in lib_m68k/interrupts.cGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Removed all references to CONFIG_SYS_RESET_GENERICGraeme Russ
Generic i386 reset - #define made redundant by weak function Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Remove #ifdef CONFIG_SC520 in source codeGraeme Russ
CONFIG_SC520 is now used for conditional compile Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Added MMCR reset functionalityGraeme Russ
Reset function specific to AMD SC520 microcontroller - Is more of a 'hard reset' that the triple fault. Requires CONFIG_SYS_RESET_SC520 to be defined in config I would have liked to add this to a new file (cpu/i386/sc520/reset.c) but ld requires that a object file in a library arhive MUST contain at least one function which does not override a weak function (and is called from outside the object file) in order for that object file to be extracted from the archive. This would be the only function on the new file, and hence, will never get linked in. Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Moved generic (triple fault) reset codeGraeme Russ
Moved from interrupts.c to cpu.c and made into a weak function to allow vendor specific override Vendor specific CPU reset (like the AMD SC520 MMCR reset) can now be added to the vendor specific code without the need to remember to #undef usage of the generic method and if you forget to include your custom reset method, you will always get the default. Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Moved definition of set_vector() to new header fileGraeme Russ
This allows for future tidy ups and functionality that will require set_vector () Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Moved sc520 specific code into new cpu/i386/sc520 folderGraeme Russ
Signed-off-by: Graeme Russ <graeme.russ@gmail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-24Renamed cpu/i386/reset.S to resetvec.SGraeme Russ
Brings i386 in line with other CPUs with a reset vector and frees up reset.c for CPU reset functions Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
2009-01-24Makefile: keep lists sorted.Wolfgang Denk
2009-01-24Added initial eNET board supportGraeme Russ
2009-01-23Merge branch 'next'Kim Phillips
2009-01-24POWERPC 82xx: add the SCC as an HDLC controllerGary Jennejohn
Right now this is only used by keymile. Signed-off-by: Gary Jennejohn <garyj@denx.de>
