2014-03-07kbuild: improve Kbuild speedMasahiro Yamada
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass. After some discussions and analysis, it turned out its main cause is in $(call cc-option,...). Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again. $(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags. This commit changes the build system as follows: - Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y. - Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported. This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile) - Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS - Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> [on Sandbox] Tested-by: Stephen Warren <swarren@nvidia.com> [on Tegra]
2014-03-07config.mk: specify the exact path to standalone linker scriptMasahiro Yamada
We want to change the build system to include config.mk only from ./Makefile and spl/Makefile. We must prepare for that in this commit. $(src) is a moving target and not handy for our purpose. We must replace it with a fixed path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-07kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCCMasahiro Yamada
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile. We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way. By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.) Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk. It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding #ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif to include/configs/tegra-common.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com>
2014-03-07kbuild, blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEEDMasahiro Yamada
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized. We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method. CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory. Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Sonic Zhang <sonic.zhang@analog.com>
2014-03-07cmd_nvedit: Make 'env import -c' require size parameterTom Rini
When importing a checksummed area we need to be told how big the area in question is so that we know that will match the size of the area which the checksum is generated against. Reported-by: Pierre AUBERT <p.aubert@staubli.com> Signed-off-by: Tom Rini <trini@ti.com>
2014-03-07Cosmetic: Typo fixesVasili Galka
Signed-off-by: Vasili Galka <vasili@visionmap.com>
2014-03-07ppc4xx: Remove 4xx NAND booting supportStefan Roese
As ppc4xx currently only supports the deprecated nand_spl infrastructure and nobody seems to have time / resources to port this over to the newer SPL infrastructure, lets remove NAND booting completely. This should not affect the "normal", non NAND-booting ppc4xx platforms that are currently supported. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-03-07net/phy: Correct AR8021 phy_maskHaijun.Zhang
There was wrong phy_mask for AR8021 device, so the AR8021 can't be probed correctly. Changed it from 0x4fffff to 0x4ffff0. Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
2014-03-07xilinx: delete meaningless .gitignore filesMasahiro Yamada
config.tmp is never generated Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Michal Simek <michal.simek@xilinx.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-03-07unit-test: make "test -e" test independent of $CWDStephen Warren
The unit-test for hush's "test -e" currently relies upon being run in the U-Boot build directory, because it tests for the existence of a file that exists in that directory. Fix this by explicitly creating the file we use for the existence test, and deleting it afterwards so that multiple successive unit-test invocations succeed. This required adding an os.c function to erase files. Reported-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-03-07hush: fix some quoted variable expansion issuesStephen Warren
The following shell command fails: if test -z "$x"; then echo "zero"; else echo "non-zero"; fi (assuming $x does not exist, it prints "non-zero" rather than "zero"). ... since "$x" expands to nothing, and the argument is completely dropped, causing too few to be passed to -z, causing cmd_test() to error out early. This is because when variable expansions are processed by make_string(), the expanded results are concatenated back into a new string. However, no quoting is applied when doing so, so any empty variables simply don't generate any parameter when the combined string is parsed again. Fix this by explicitly replacing quoting any argument that was originally quoted when re-generating a string from the already-parsed argument list. This also fixes loss of whitespace in commands such as: setenv space " " setenv var " 1${space}${space} 2 " echo ">>${var}<<" Reported-by: Russell King <linux@arm.linux.org.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@wwwdotorg.org>
2014-03-07unit-test: clean up evironment after Hush testsStephen Warren
Delete the temporary variables that are used to save unit-test results from the environment after running the test. This prevents polluting the environment, or growing it too much. Signed-off-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-03-07net: asix: don't pad odd-length TX packetsStephen Warren
For Ethernet/USB RX packets, the ASIX HW pads odd-sized packets so that they have an even size. Currently, asix_recv() does remove this padding, and asic_send() adds equivalent padding in the TX path. However, the HW does not appear to need this packing for TX packets in practical testing with "ASIX Elec. Corp. AX88x72A 000001" Vendor: 0x0b95 Product 0x7720 Version 0.1. The Linux kernel does no such padding for the TX path. Remove the padding from the TX path: * For consistency with the Linux kernel. * NVIDIA has a Tegra simulator which validates that the length of USB packets sent to an ASIX device matches the packet length value inside the packet data. Having U-Boot and the kernel do the same thing when creating the TX packets simplifies the simulator's validation. Cc: Lucas Stach <dev@lynxeye.de> Cc: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de> Tested-by: Marek Vasut <marex@denx.de> Tested-by: Gerhard Sittig <gsi@denx.de>
2014-03-04Merge branch 'master' of git://git.denx.de/u-boot-nand-flashTom Rini
2014-03-04mtd: nand: omap: move omap_elm.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_elm.h is a generic header used by OMAP ELM driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: move omap_gpmc.h from arch/arm/include/asm to drivers/mtd/nandpekon gupta
omap_gpmc.h is a generic header used by OMAP NAND driver for all TI platfoms. Hence this file should be present in generic folder instead of architecture specific include folder. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: merge duplicate GPMC data from different arch-xx headers ↵pekon gupta
into common omap_gpmc.h Each SoC platform (AM33xx, OMAP3, OMAP4, OMAP5) has its own copy of GPMC related defines and declarations scattered in SoC platform specific header files like include/asm/arch-xx/cpu.h However, GPMC hardware remains same across all platforms thus this patch merges GPMC data scattered across different arch-xx specific header files into single header file include/asm/arch/omap_gpmc.h Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: remove unused #defines from common omap_gpmc.hpekon gupta
OMAP NAND driver can detect Page-size and OOB-size of NAND device from ONFI params or nand_id[] table. And based on that it defines ECC layout. This patch 1) removes following board configs used for defining NAND ECC layout - GPMC_NAND_ECC_LP_x16_LAYOUT (for large page x16 NAND) - GPMC_NAND_ECC_LP_x8_LAYOUT (for large page x8 NAND) - GPMC_NAND_ECC_SP_x16_LAYOUT (for small page x16 NAND) - GPMC_NAND_ECC_SP_x8_LAYOUT (for small page x8 NAND) 2) removes unused #defines in common omap_gpmc.h depending on above configs Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04mtd: nand: omap: remove redundant platform specific header: arch-xx/omap_gpmc.hpekon gupta
Currently there are two sets of omap_gpmc.h header files (a) arch/arm/include/asm/omap_gpmc.h common header file for all platforms, containing defines and declarations used by GPMC NAND driver. (b) arch/arm/include/asm/arch-xx/omap_gpmc.h SoC platform specific header file containing defines like ECC layout. This patch removes platform specific arch-xx/omap_gpmc.c because: - GPMC hardware engine is common for all SoC platforms hence only (a) is enough - ECC layout is now defined in omap_nand.c driver itself based on ecc-scheme selected. Hence all ECC layout declarations in (b) are redundant. Build tested using: ./MAKEALL -s am33xx -s omap3 -s omap4 -s omap5 Signed-off-by: Pekon Gupta <pekon@ti.com>
2014-03-04Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2014-03-04malta: correct tcl script path in README.maltaJames Hogan
README.malta referred to board/malta, but malta has now been moved within board/imgtec/, so correct the path. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Paul Burton <paul.burton@imgtec.com>
2014-03-04MIPS: fix types u64 and __u64 to unsigned long longDaniel Schwierzeck
Linux MIPS uses asm-generic/int-ll64.h in asm/types.h. Thus u64 and __u64 are defined as unsigned long long. Port this over to U-Boot. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2014-03-04arc: arcangel4: set board entry <none> to fix a build errorMasahiro Yamada
There are no source files in board/synopsys/arcangel4/ directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
2014-03-04kbuild: allow empty board directoriesMasahiro Yamada
U-Boot has compelled all boards to have board/${BOARD}/ or board/${VENDOR}/${BOARD}/ directory. Sometimes it does not seem suitable for some boards, for example Sandbox. (Is it a board?) And arcangel4 board has nothing to compile under the board directory. This commit makes the build system more flexible: If '<none>' is given to the 6th column (=Board name) of boards.cfg, Kbuild will not descend into the board directory. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: tools: fix a bug that always builds Denx logoMasahiro Yamada
LOGO_BMP was never overwritten by board-specific or vendor-specific logos. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Bo Shen <voice.shen@atmel.com> Tested-by: Bo Shen <voice.shen@atmel.com>
2014-03-04kbuild: add "cross_tools" target to build tools for the targetMasahiro Yamada
Programs in tools/ directory are usually built for the host. But some of them (mkimage, dumpimge, gen_eth_addr, etc.) are useful on the target OS too. Actually, prior to Kbuild, U-Boot could build tools for the target like follows: $ make <target_board>_config $ export CROSS_COMPILE=<cross_gcc_prefix> $ make HOSTCC=${CROSS_COMPILE}gcc HOSTSTRIP=${CROSS_COMPILE}strip tools In Kbuild, we can no longer replace HOSTCC at the command line. In order to get back that feature, this commit adds "cross-tools" target. Usage: Build tools for the host $ make CROSS_COMPILE=<cross_gcc_prefix> tools Build tools for the target $ make CROSS_COMPILE=<cross_gcc_prefix> cross_tools Besides, "make cross_tools" strip tools programs because we generally expect smaller storages on embedded systems. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reported-by: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tom Rini <trini@ti.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-03-04kbuild: fix "tools-all" targetMasahiro Yamada
The top Makefile must export HOST_TOOLS_ALL to use it in tools/Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-03-04board: config.mk: delete unused sinclude directiveMasahiro Yamada
config.tmp is not there. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04board: .gitignore: ignore board-specific generated filesMasahiro Yamada
Ignore - board/cray/L1/bootscript.{c|image} - board/matrix_vision/mvblm7/bootscript.img - board/maxtir_vision/mvsmr/bootscript.img Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andre Schwarz <andre.schwarz@matrix-vision.de>
2014-03-04board: gaisler: delete unnecessary include pathMasahiro Yamada
The same outputs are generated with or without -I$(TOPDIR)/board. I cannot understand why it is necessary. Remove. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: consolidate PLATFORM_LIBSMasahiro Yamada
We had switched to Kbuild so now we can specify PLATFORM_LIBS/PLATFORM_LIBGCC with relative path. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2014-03-04scripts: update checkpatch.pl to latest upstream versionTom Rini
Update to v3.14-rc4's version of checkpatch.pl. In doing so we drop the changes to top_of_kernel_tree() as we pass in --no-tree and drop our changes about MAINTAINERS as that's for reporting checkpatch.pl problems itself (and upstream has said they'll reword this section to be clearer). Signed-off-by: Tom Rini <trini@ti.com>
2014-03-04Add 64-bit data support for memory commandsYork Sun
Add 64-bit data for memory commands, such as md, mw, mm, cmp. The new size ".q " is introduced. For 64-bit architecture, 64-bit data is enabled by default, by detecting compiler __LP64__. It is optional for other architectures. Signed-off-by: York Sun <yorksun@freescale.com>
2014-03-04dm: Remove old driver model documentationSimon Glass
This documentation pertains to the planned implementation of driver model in U-Boot for each subsystem, but it has not been superseded. It is probably better to have this documentation in the source code for each subsystem where possible, so that docbook will pick it up. Where this does not make sense, new documentation can be placed in some suitable file in doc/driver-model. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Enable gpio command to support driver modelSimon Glass
Now that named GPIO banks are supported, along with a way of obtaining the status of a GPIO (input or output), we can provide an enhanced GPIO command for driver model. Where the driver provides its own operation for obtaining the GPIO state, this is used, otherwise a generic version is sufficient. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04sandbox: Convert GPIOs to use driver modelSimon Glass
Convert sandbox over to use driver model GPIOs. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Add GPIO support and testsSimon Glass
Add driver model support for GPIOs. Since existing GPIO drivers do not use driver model, this feature must be enabled by CONFIG_DM_GPIO. After all GPO drivers are converted over we can perhaps remove this config. Tests are provided for the sandbox implementation, and are a sufficient sanity check for basic operation. The GPIO uclass understands the concept of named banks of GPIOs, with each GPIO device providing a single bank. Within each bank the GPIOs are numbered using an offset from 0 to n-1. For example a bank named 'b' with 20 offsets will provide GPIOs named b0 to b19. Anonymous GPIO banks are also supported, and are just numbered without any prefix. Each time a GPIO driver is added to the uclass, the GPIOs are renumbered accordinging, so there is always a global GPIO numbering order. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-03-04dm: Add a demonstration/example driverSimon Glass
As an example of how to write a uclass and a driver, provide a demo version of each, accessible through the 'demo' command. To use these with driver model, define CONFIG_CMD_DEMO and CONFIG_DM_DEMO. The two demo drivers are enabled with CONFIG_DM_DEMO_SIMPLE and CONFIG_DM_DEMO_SHAPE. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-03-04dm: Add a 'dm' command for testingSimon Glass
This command is not required for driver model operation, but can be useful for testing. It provides simple dumps of internal data structures. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-03-04dm: Add basic testsSimon Glass
Add some tests of driver model functionality. Coverage includes: - basic init - binding of drivers to devices using platform_data - automatic probing of devices when referenced - availability of platform data to devices - lifecycle from bind to probe to remove to unbind - renumbering within a uclass when devices are probed/removed - calling driver-defined operations - deactivation of drivers when removed - memory leak across creation and destruction of drivers/uclasses - uclass init/destroy methods - automatic probe/remove of children/parents when needed This function is enabled for sandbox, using CONFIG_DM_TEST. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Set up driver model after relocationSimon Glass
Make driver model available after relocation, by setting up data structures and scanning for devices using compiled-in platform_data and (when available) the device tree. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04sandbox: config: Enable driver modelSimon Glass
Use driver model in sandbox to permit running of driver model unit test. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04dm: Add base driver model supportSimon Glass
Add driver model functionality for generic board. This includes data structures and base code for registering devices and uclasses (groups of devices with the same purpose, e.g. all I2C ports will be in the same uclass). The feature is enabled with CONFIG_DM. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Marek Vasut <marex@denx.de> Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com> Signed-off-by: Viktor Křivák <viktor.krivak@gmail.com> Signed-off-by: Tomas Hlavacek <tmshlvck@gmail.com>
2014-03-04dm: Add README for driver modelSimon Glass
This adds a README to help with understanding of this series. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04yaffs: Remove private list implementationSimon Glass
U-Boot already has a list implementation, and files which include both that and the yaffs implementation will get errors: In file included from ydirectenv.h:80:0, from yportenv.h:81, from yaffs_guts.h:19, from yaffs_allocator.h:19, from yaffs_allocator.c:14: yaffs_list.h:32:8: error: redefinition of ‘struct list_head’ struct list_head { ^ Remove the yaffs implementation. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04Add cmd_process_error() to report and process errorsSimon Glass
U-Boot now uses errors defined in include/errno.h which are negative integers. Commands which fail need to report the error and return 1 to indicate failure. Add this functionality in cmd_process_error(). For now this merely reports the error number. It would be possible also to produce a helpful error message by storing the error strings in U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04sandbox: Build a device tree file for sandboxSimon Glass
Add support for building a device tree for sandbox's CONFIG_OF_HOSTFILE option to make it easier to use device tree with sandbox. This adjusts the Makefile to build a u-boot.dtb file which can be passed to sandbox U-Boot with: ./u-boot -d u-boot.dtb Signed-off-by: Simon Glass <sjg@chromium.org>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2014-03-04nand_spl: display warning message to inform the end of nand_splMasahiro Yamada
Now we have two different frameworks for doing the same thing. I'd like to propose to drop nand_spl framework. How about deleting it before v2014.07 release? In the interim, this commit will display a warning message when compiling nand_spl board. Now we have 19 nand_spl boards: MPC8315ERDB_NAND SIMPC8313_LP SIMPC8313_SP MPC8536DS_NAND MPC8569MDS_NAND MPC8572DS_NAND P1023RDS_NAND P1011RDB_NAND P1020RDB_NAND P2010RDB_NAND P2020RDB_NAND acadia_nand bamboo_nand canyonlands_nand glacier_nand haleakala_nand kilauea_nand rainier_nand sequoia_nand They must be ported to SPL before the deadline, otherwise they will be removed. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Dave Liu <daveliu@freescale.com> Cc: Ron Madrid <info@sheldoninst.com> Cc: Roy Zang <tie-fei.zang@freescale.com> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
