Becuase the board select menu in arch/arm/Kconfig is too big,
move the Tegra board select menu to tegra/Kconfig.
Insert the Tegra SoC select menu between the arch select and the
board select.
Architecture select
|-- Tegra Platform (Tegra)
|- Tegra SoC select (Tegra20 / 30 / 114 / 124)
|- Board select
Consolidate also common settings (CONFIG_SYS_CPU="armv7" and
CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows:
config TEGRA
bool
select SPL
Cc: Tom Warren <twarren@nvidia.com>
move the Zynq board select menu to zynq/Kconfig.
CONFIG_SYS_SOC="zynq").
Refactor board/xilinx/zynq/MAINTAINERS too.
Tested-by: Michal Simek <michal.simek@xilinx.com>
Commit 41623c9 'arm: move exception handling out of start.S files' missed some
linker scripts. Hence, some boards no longer had exception handling linked since
this commit. Restore the original behavior by adding the .vectors section to
these linker scripts.
Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Newer FLASH types used on these boards don't allow writing of subpages.
So disable subpage write in the NAND driver. Additionally we need to
tell the UBI layer in the kernel that he also should only write 2048
bytes. This is done with an additional command line parameter for the
kernel commandline.
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Valentin Longchamp <valentin.longchamp@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
Make it configurable to disable subpage writes like the DaVinci NAND
driver already does.
cc: Scott Wood <scottwood@freescale.com>
Add support for booting Images and for unzipping Image.gz files.
- Drop DEBUG
- Drop defines we can use the default of.
- Provide a larger malloc pool.
- Correct default locations for kernel / initrd / device tree
The default format for arm64 Linux kernels is the "Image" format,
described in Documentation/arm64/booting.txt. This, along with an
optional gzip compression on top is all that is generated by default.
The Image format has a magic number within the header for verification,
a text_offset where the Image must be run from, an image_size that
includes the BSS and reserved fields.
This does not support automatic detection of a gzip compressed image.
The Documentation/arm64/booting.txt document says that pass in x1/x2/x3
as 0 as they are reserved for future use.
Convert the bcm958300k and the bcm958622hr boards from "boards.cfg" to Kconfig.
Signed-off-by: Steve Rae <srae@broadcom.com>
The bcm_ep board configuration is used by a number of boards
including Cygnus and NSP.
Add builds for the bcm958300k and the bcm958622hr boards.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Base support for the Broadcom NSP SoC.
Based on iproc-common and the SoC specific reset function.
Base support for the Broadcom Cygnus SoC.
The iproc architecture code is present in several Broadcom
chip architectures, including Cygnus and NSP.
Add NFC (NAND Flash Controller) clock support and enable them
at board initialization time.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Add pin mux for NAND Flash Controller (NFC). NAND can be connected
using 8 or 16 data lines, this patch adds pin mux entries for all
16 data lines.
The email address of Matt Waddel is no longer working.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Alexei Fedorov <alexie.fedorov@arm.com>
The patch fixes a corner case where adding size to DRAM start resulted
in a value (1 << 32), which in turn overflew the u32 computation, which
resulted in 0 and it therefore prevented correct setup of the MMU tables.
The addition of DRAM bank start and it's size can end up right at the end
of the address space in the special case of a machine with enough memory.
To prevent this overflow, shift the start and size separately and add them
only after they were shifted.
Hopefully, we only have systems in tree which have DRAM size aligned to
1MiB boundary. If not, this patch would break such systems. On the other
hand, such system would be broken by design anyway.
Add board which has Broadcom StarFighter2 Ethernet capability.
The Broadcom StarFighter2 Ethernet driver is used in multiple Broadcom
SoC(s) and:
- supports multiple MAC blocks,
- provides support for the Broadcom GMAC.
This driver requires MII and PHYLIB.
Signed-off-by: Jiandong Zheng <jdzheng@broadcom.com>
Enable Ethernet clock when Broadcom StarFighter2 Ethernet block
(CONFIG_BCM_SF2_ETH) is enabled.
To enable hypervisors utilizing the ARMv7 virtualization extension
on the Arndale board, add the simple SMP pen address writer function
and add the required configuration variables to switch all cores to
HYP mode before launching the OS.
This allows booting KVM and Xen directly from u-boot.
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
However ep9315 don't use
interrupt vectors during startup, but _startup symbol is used inside uboot to
calculate actual monitor size.
Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com>
Cc: albert.u.boot@aribaud.net
Cleanups as suggested by wd on mailing list.
Signed-off-by: Pavel Machek <pavel@denx.de>
Acked-by: Chin Liang See <clsee@altera.com>
Enable initialization fo designware ethernet controller. With this
patch, ethernet works in my configuration, provided I set ethernet
address in the environment.
To fix the build error when build for Altera dev kit, not
virtual target. At same time, set the build for Altera dev
kit as default instead virtual target. With that, U-Boot
is booting well and SPL still lack of few drivers.
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Structure defining clock manager hardware was wrong, leading to
wrong registers being accessed and hang in MMC init.
This fixes structure to match hardware.
config.h is required for CONFIG_SYS_DV_NOR_BOOT_CFG.
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Reported-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
When compiling u-boot with W=1 the extern inline void for
read* is likely causing the most noise. gcc / clang will
warn there is never a actual declaration for these functions.
Instead of declaring these extern make them static inline so
it is actually declared.
cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
One specific USB 3.0 device behaves strangely when reset by
usb_new_device()'s call to hub_port_reset(). For some reason, the device
appears to briefly drop off the bus when this second bus reset is
executed, yet if we retry this loop, it'll eventually come back after
another two resets.
If USB bus reset is executed over and over within usb_new_device()'s call
to hub_port_reset(), I see the following sequence of results, which
repeats as long as you want:
1) STAT_C_CONNECTION = 1 STAT_CONNECTION = 0 USB_PORT_STAT_ENABLE 0
2) STAT_C_CONNECTION = 1 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 0
3) STAT_C_CONNECTION = 1 STAT_CONNECTION = 1 USB_PORT_STAT_ENABLE 1
The device in question is a SanDisk Ultra USB 3.0 16GB memory stick with
USB VID/PID 0x0781/0x5581.
In order to allow this device to work with U-Boot, ignore the
{C_,}CONNECTION bits in the status/change registers, and only use the
ENABLE bit to determine if the reset was successful.
To be honest, extensive investigation has failed to determine why this
problem occurs. I'd love to know! I don't know if it's caused by:
* A HW bug in the device
* A HW bug in the Tegra USB controller
* A SW bug in the U-Boot Tegra USB driver
* A SW bug in the U-Boot USB core
This issue only occurs when the device's USB3 pins are attached to the
host; if only the USB2 pins are connected the issue does not occur. The
USB3 controller on Tegra is in reset, so is not actively communicating
with the device at all - a USB3 analyzer confirms this. Slightly
unplugging the device (so the USB3 pins don't contact) or using a USB2
cable or hub as an intermediary avoids the problem. For some reason,
the Linux kernel (either on the same Tegra board, or on an x86 host)
has no issue with the device, and I observe no disconnections during
reset.
This change won't affect any USB device that already works, since such
devices could not currently be triggering the error return this patch
removes, or they wouldn't be working currently.
However, this patch is quite reliable in practice, hence I hope it's
acceptable to solve the problem.
The only potential fallout I can see from this patch is:
* A broken device that triggers C_CONNECTION/!CONNECTION now causes the
loop in hub_port_reset() to run multiple times. If it never succeeds,
this will cause "usb start" to take roughly 1s extra to execute.
* If the user unplugs a device while hub_port_reset() is executing, and
very quickly swaps in a new device, hub_port_reset() might succeed on
the new device. This would mean that any information cached about the
original device (from the descriptor read in usb_new_device(), which
simply caches the max packet size) might be invalid, which would cause
problems talking to the new device. However, without this change, the
new device wouldn't work anyway, so this is probably not much of a
loss.
As we support both Host and Device mode operation, an OTG controller
can return -ENODEV on a port which it found to be in Device mode during
Host mode scan for devices. In case -ENODEV is returned, print that the
port is not available and continue instead of screaming a bloody error
message.
Commit 3ff291f371fa9858426774f3732924bacb61ed1c
(kconfig: convert Kconfig helper script into a shell script)
restored "<board>_config" target for backward compatibility.
It should be documented.
This tool only works on python 2 (python 2.6 or lator).
Change the shebang to make sure the script is run by python 2
and clearly say the supported version in the comment block.
We noticed on the DXR2 platform (AM335x with a SMSC LAN9303 switch connected
to the CPSW MAC) that the network performance in U-Boot is quite poor. Only
when the transfer is started without a cable connected, and the cable is
plugged after the first timeout "T" occured, an increased in performance
can be seen. Debugging has revealed, that the cpsw driver has constant
link checking builtin into the rx and tx functions. This results in the
bad performance and seems to be unnecessary. The link has already been
checked in the init function, before the transfer is started. This usually
is sufficient.
BTW: I have seen no other network driver in U-Boot so far, that constantly
checks for link in the rx / tx functions.
The performance numbers on the DXR2 board are:
0.56 MiB/s cpsw_check_link() in rx and tx path
0.87 MiB/s cpsw_check_link() only in tx path
1.0 MiB/s cpsw_check_link() only in rx path
2.7 MiB/s no cpsw_check_link() in rx and tx path
So with this patch the network performance on DXR2 increases from 0.56
to 2.7 MiB/s (nearly 5 times as fast).
Tested-by: Samuel Egli <samuel.egli@siemens.com>
Tested-by: Heiko Schocher <hs@denx.de>
Cc: Vladimir Koutny <vladimir.koutny@streamunlimited.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: Joe Hershberger <joe.hershberger@gmail.com>
I guess some developers are already getting sick of this tool
because it generally takes a few minites to generate the boards.cfg
on a reasonable computer.
The idea popped up on my mind was to skip Makefiles and
to run script/kconfig/conf directly.
This tool should become about 4 times faster.
You might still not be satisfied, but better than doing nothing.
It looks silly to regenerate the boards.cfg even when it is
already up to date.
The tool should exit with doing nothing if the boards.cfg is newer
than any of defconfig, Kconfig and MAINTAINERS files.
Specify -f (--force) option to get the boards.cfg regenerated
regardless its time stamp.
This tool deletes the incomplete boards.cfg
if it encounters an error or is is terminated by the user.
I notice some problems even though they rarely happen.
[1] The boards.cfg is removed if the program is terminated
during __gen_boards_cfg() function but before boards.cfg
is actually touched. In this case, the previous boards.cfg
should be kept as it is.
[2] If an error occurs while deleting the incomplete boards.cfg,
the program throws another exception. This hides the privious
exception and we will not be able to know the real cause.
When an error occurs or the program is terminated by the user
on the way, the destructer __del__ of class Slot is invoked and
the work directories are removed.
We have to make sure there are no subprocesses (in this case,
"make O=<work_dir> ...") using the work directories before
removing them. Otherwise the subprocess spits a bunch of error
messages possibly causing more problems. Perhaps some users
may get upset to see too many error messages.
The tools/genboardscfg.py expects all the Kconfig and defconfig are
written correctly. Imagine someone accidentally has broken a board.
Error-out just for one broken board is annoying for the other
developers. Let the tool skip insane boards and continue processing.
tools/genboardscfg.py expects all the boards have MAINTAINERS.
If someone adds a new board but misses to add its MAINTAINERS file,
tools/genboardscfg.py fails to generate the boards.cfg file.
It is annoying for the other developers.
This commit allows tools/genboardscfg.py to display warning messages
and continue processing even if some MAINTAINERS files are missing
or have broken formats.
Kconfig in U-Boot creates a temporary file configs/.tmp_defconfig
during processing "make <board>_defconfig". The temporary file
might be left over for some reasons.
Just in case, tools/genboardscfg.py should make sure to
not read such garbage files.
The host filesystem name has changed, so update the tests. The tests now
run again correctly:
$ make O=b/sandbox sandbox_defconfig all
$ test/image/test-fit.py -u b/sandbox/u-boot
FIT Tests
Kernel load
Kernel + FDT load
Kernel + FDT + Ramdisk load
Tests passed
Caveat: this is only a sanity check - test coverage is poor
Commit e3a5bbce broke the FIT image tests by not loading a ramdisk even if
a load address is provided in the FIT. The rationale was that a load address
of 0 should be considered to mean 'do not load'.
Add a new load operation which supports this feature, so that the ramdisk
will be loaded if a non-zero load address is provided.
Copy the Kconfig option from "init/Kconfig" of Linux v3.16 tag
and adjust the help document.
