Extract all extern declarations for console_buffer[] out of c files into
the common.h header.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Frank Gottschling <fgottschling@eltec.de>
Cc: Murray Jensen <Murray.Jensen@csiro.au>
Though one warning left:
WARNING: do not add new typedefs
#149: FILE: u-boot/include/environment.h:149:
+typedef struct environment_s {
total: 0 errors, 1 warnings, 181 lines checked
No one uses this driver, and it isn't converted to the NET_MULTI
framework (which we dropped recently), so drop this driver too.
This printf() string should be %ld now that uintptr_t is defined
as long. Also fix a size_t error.
If uintptr_t can be either an unsigned int or an unsigned long int, it is
tricky to use it in a printf() format string. This changes it to
unsigned long int consistently. This should do the right thing on both
32-bit and 64-bit architectures.
This tool takes a key=value configuration file (same as would a `printenv' show)
and generates the corresponding environment image, ready to be flashed.
use case: flash the environment with an external tool
Signed-off-by: David Wagner <david.wagner@free-electrons.com>
Acked-by; Mike Frysinger <vapier@gentoo.org>
Tested-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Signed-off-by: Wolfgang Grandegger <wg@denx.de>
Commit 79ad54400932d6484178a372fb3b659e3437473b broke MAC address
programming in the SMSC95xx register set.
Cc: Marek Vasut <marek.vasut@gmail.com>
* 'sr@denx.de' of git://git.denx.de/u-boot-staging:
Makefile: Add the missing dependency for spl target
gpio: Adapt PCA9698 to standard GPIO API
* 'master' of git://git.denx.de/u-boot-blackfin:
Blackfin: cache result of cpp check
Blackfin: traps: fix up printf warnings from debug
Blackfin: drop now unused local variable
* 'master' of git://git.denx.de/u-boot-nds32:
nds32/lib: add ide generic support
nds32: enhance io.h for compatibility with periphals
ftide020: fix incorrect information display format
* 'master' of git://git.denx.de/u-boot-nios:
nios2: Offer ft_board_setup() capability and call fdt_fixup_ethernet().
board/nios2-generic: Use altera_pio driver and remove board specific driver
gpio: Add driver for Altera's PIO core
nios2: Pseudo implement dcache_status/enable/disable()
Avoid overhead of computing this value multiple times.
Cast uint32_t to void* for %p, and use %zu for size_t.
Wolfgang's patch for build time improvement is bringing
out issues due to missing dependencies in the top-level
Makefile. I get errors such as the below while building
with many threads.
make[1]: /home/a0393566local/u-boot-denx/tools/mkimage: Command not found
This also allows one to do:
$ make spl/u-boot-spl.bin
if you want to build only spl
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Dirk Eibach <eibach@gdsys.de>
Add ide generic support.
Signed-off-by: Macpaul Lin <macpaul@andestech.com>
Enhance io.h for periphals origin design on x86 systems.
For example, pci, ide, etc.
Fix incorrect information display format when probing the device.
Added from Linux - commit 30ecad51849ae132dc6ef6ddb62d499c7257515b
Include config file to ignore common false-positives
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Fix the following build warning in drivers/net/e1000.c
e1000.c: In function 'e1000_reset_hw':
e1000.c:1373:11: warning: variable 'icr' set but not used [-Wunused-but-set-variable]
e1000.c: In function 'e1000_phy_init_script':
e1000.c:4395:11: warning: variable 'ret_val' set but not used [-Wunused-but-set-variable]
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Cc: Kyle Moffett <Kyle.D.Moffett@boeing.com>
Some of the EEPROM Word Offset macros, and a few others, are defined
twice in e1000.h.
The last maintainer (Eran Man) cannot be reached any more.
This reverts commit 355a835747c6f7c5071ead295a7dfc489c73cb03.
The original commit broke long standing assumption that md commands work
on effective addresses. This normally isn't an issue for most systems
that map 1:1, however on systems with a 36-bit address map it breaks.
Configuring for vme8349 board...
cmd_tsi148.c: In function 'tsi148_init':
cmd_tsi148.c:56:17: warning: variable 'lastError' set but not used [-Wunused-but-set-variable]
Configuring for kmeter1 board...
km83xx_i2c.c: In function 'i2c_make_abort':
km83xx_i2c.c:44:8: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
Acked-by: Heiko Schocher <hs@denx.de>
Configuring for MPC8360EMDS_66_HOST_33 - Board: MPC8360EMDS, Options: CLKIN_66MHZ,PCI,PCI_33M,PQ_MDS_PIB=1
mpc8360emds.c: In function 'board_eth_init':
mpc8360emds.c:178:12: warning: array subscript is above array bounds [-Warray-bounds]
Configuring for sbc8349 board...
spd_sdram.c: In function 'spd_sdram':
spd_sdram.c:152:41: warning: variable 'trfc_high' set but not used [-Wunused-but-set-variable]
Sorry if this is already fixed somewhere - I could not find it.
This fixes the warnings show below.
yaffs_tagscompat.c: In function 'yaffs_TagsCompatabilityReadChunkWithTagsFromNAND':
yaffs_tagscompat.c:151: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:150: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:149: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:148: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:147: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:146: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:145: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:144: warning: dereferencing pointer 'tu' does break strict-aliasing rules
yaffs_tagscompat.c:141: note: initialized from here
Fix:
s3c24x0_rtc.c: In function 'rtc_get':
s3c24x0_rtc.c:67:53: warning: variable 'a_armed' set but not used
s3c24x0_rtc.c:67:45: warning: variable 'a_year' set but not used
s3c24x0_rtc.c:67:38: warning: variable 'a_mon' set but not used
s3c24x0_rtc.c:67:30: warning: variable 'a_date' set but not used
s3c24x0_rtc.c:67:22: warning: variable 'a_hour' set but not used
s3c24x0_rtc.c:67:15: warning: variable 'a_min' set but not used
s3c24x0_rtc.c:67:8: warning: variable 'a_sec' set but not used
Fix:
yaffs_guts.c: In function 'yaffs_CheckChunkErased':
yaffs_guts.c:854:6: warning: variable 'result' set but not used
yaffs_guts.c: In function 'yaffs_UpdateObjectHeader':
yaffs_guts.c:3463:6: warning: variable 'result' set but not used
yaffs_guts.c: In function 'yaffs_GrabChunkCache':
yaffs_guts.c:3774:6: warning: variable 'pushout' set but not used
yaffs_guts.c: In function 'yaffs_Scan':
yaffs_guts.c:5237:6: warning: variable 'result' set but not used
yaffs_guts.c: In function 'yaffs_CheckObjectDetailsLoaded':
yaffs_guts.c:5748:6: warning: variable 'alloc_failed' set but not used
yaffs_guts.c:5747:6: warning: variable 'result' set but not used
yaffs_guts.c: In function 'yaffs_ScanBackwards':
yaffs_guts.c:5808:6: warning: variable 'deleted' set but not used
yaffs_guts.c:5806:6: warning: variable 'result' set but not used
yaffs_guts.c: In function 'yaffs_GetObjectName':
yaffs_guts.c:6657:7: warning: variable 'result' set but not used
Fix:
pwm.c: In function 'pwm_config':
pwm.c:85:16: warning: variable 'timer_rate_hz' set but not used
Fix:
bus_vcxk.c: In function 'vcxk_display_bitmap':
bus_vcxk.c:396:16: warning: variable 'compression' set but not used
Fix:
da8xx-fb.c: In function 'video_hw_init':
da8xx-fb.c:688:6: warning: variable 'ret' set but not used
Fix:
flash.c: In function 'flash_erase':
flash.c:209:6: warning: variable 'flag' set but not used
flash.c: In function 'write_data':
flash.c:373:6: warning: variable 'flag' set but not used
Fix:
Fix:
enc28j60.c: In function 'enc_receive':
enc28j60.c:435:5: warning: variable 'eir_reg' set but not used
enc28j60.c: In function 'enc_poll':
enc28j60.c:503:5: warning: variable 'estat_reg' set but not used
Fix:
at91_emac.c: In function 'at91emac_write_hwaddr':
at91_emac.c:477:15: warning: variable 'dev' set but not used
Fix:
dataflash.c: In function 'AT91F_DataflashInit':
dataflash.c:42:6: warning: variable 'last_part' set but not used
Fix:
atmel_spi.c: In function 'spi_xfer':
atmel_spi.c:139:7: warning: variable 'ret' set but not used
Fix:
pip405.c: In function 'board_early_init_f':
pip405.c:192:16: warning: variable 'tctp_clocks' set but not used [-Wunused-but-set-variable]
pip405.c:182:16: warning: variable 'dataout' set but not used [-Wunused-but-set-variable]
Fix:
mip405.c: In function 'init_sdram':
mip405.c:250:4: warning: variable 'tctp_clocks' set but not used [-Wunused-but-set-variable]
mip405.c: In function 'initdram':
mip405.c:629:9: warning: variable 'ds' set but not used [-Wunused-but-set-variable]
Fix:
../common/auto_update.c: In function 'au_check_header_valid':
../common/auto_update.c:94:16: warning: variable 'checksum' set but not used [-Wunused-but-set-variable]
../common/auto_update.c: In function 'do_auto_update':
../common/auto_update.c:400:30: warning: variable 'got_ctrlc' set but not used [-Wunused-but-set-variable]
Fix:
iop480_uart.c: In function 'serial_init':
iop480_uart.c:137:16: warning: variable 'val' set but not used [-Wunused-but-set-variable]
Fix:
cmd_dasa_sim.c: In function 'updatePci9054':
cmd_dasa_sim.c:135:6: warning: variable 'val' set but not used [-Wunused-but-set-variable]
cmd_dasa_sim.c: In function 'clearPci9054':
cmd_dasa_sim.c:189:6: warning: variable 'val' set but not used [-Wunused-but-set-variable]
Fix:
cmd_pci405.c: In function 'do_loadpci':
cmd_pci405.c:45:6: warning: variable 'status' set but not used [-Wunused-but-set-variable]
Fix:
dlvision-10g.c: In function 'print_fpga_info':
dlvision-10g.c:90:11: warning: variable 'feature_compression' set but not used [-Wunused-but-set-variable]
Fix:
nand_boot.c: In function 'nand_read_page':
nand_boot.c:190:6: warning: variable 'stat' set but not used [-Wunused-but-set-variable]
nand_boot.c: In function 'nand_boot':
nand_boot.c:271:6: warning: variable 'ret' set but not used [-Wunused-but-set-variable]
Fix:
sata_dwc.c: In function 'sata_dwc_softreset':
sata_dwc.c:444:5: warning: variable 'status' set but not used [-Wunused-but-set-variable]
sata_dwc.c:443:6: warning: variable 'serror' set but not used [-Wunused-but-set-variable]
sata_dwc.c: In function 'scan_sata':
sata_dwc.c:654:16: warning: variable 'lba_desc' set but not used [-Wunused-but-set-variable]
sata_dwc.c:538:16: warning: variable 'xfer_mask' set but not used [-Wunused-but-set-variable]
sata_dwc.c: In function 'ata_dev_read_id':
sata_dwc.c:747:14: warning: variable 'reason' set but not used [-Wunused-but-set-variable]
sata_dwc.c: In function 'ata_dev_read_sectors':
sata_dwc.c:1810:6: warning: variable 'rc' set but not used [-Wunused-but-set-variable]
sata_dwc.c: In function 'ata_dev_write_sectors':
sata_dwc.c:1994:6: warning: variable 'rc' set but not used [-Wunused-but-set-variable]
