2009-03-20remove bi_enet*addr from global data for all archesMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-20ppc: mark global bi_enet*addr as legacyMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. In the ppc case, these things are part of the legacy ABI, so keep them around but mark them as legacy so no new code will touch them. Also stop calling load_sernum_ethaddr() since all boards now implement this as a stub. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: get mac address from env and move load_sernum_ethaddr() to board initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have common ppc code call a board-specific function like load_sernum_ethaddr(), have each board call it in its own board-specific misc_init_r() function. The boards that get converted here are: - kup4k/kup4x - pcs440ep - tqm8xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Stefan Roese <sr@denx.de>
2009-03-20cmc_pu2: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also rename load_sernum_ethaddr() to misc_init_r() so we don't need to handle this board specially in common ARM code. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20boards: move board_get_enetaddr() into board-specific initMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Rather than have the common ppc code have board-specific hooks, move the board_get_enetaddr() function into the board-specific init functions. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20arm: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Some warts are remaining and should be killed off (by moving the func to the appropriate board init code): - davinci_eth_set_mac_addr - cs8900_get_enetaddr - smc_set_mac_addr Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20nx823: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. For the nx823, the serial number is moved out of load_sernum_ethaddr() and into misc_init_r() as is the env setup. This lets us kill off the former function in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20lib_*/board.c: do not initialize bi_enet*addr in global dataMike Frysinger
Since everyone is using the environment for mac address storage, there is no point in seeding the global data. The arches that are converted here: i386 m68k microblaze mips nios nios2 sh sparc Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Michal Simek <monstr@seznam.cz> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Scott McNutt <smcnutt@psyent.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2009-03-20npe: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The resulting code can also be simplified even further. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Stefan Roese <sr@denx.de> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20cpu/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cpus that get converted here: at91rm9200 mpc512x mpc5xxx mpc8260 mpc8xx ppc4xx Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: John Rigby <jrigby@freescale.com> CC: Stefan Roese <sr@denx.de>
2009-03-20lan91c96/smc91111/smc911x: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Also, do not bother checking the EEPROM if the env is setup. This simplifies the code greatly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Wolfgang Dnek <wd@denx.de> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Erik Stahlman <erik@vt.edu> CC: Daris A Nevil <dnevil@snmc.com> CC: Sascha Hauer <s.hauer@pengutronix.de>
2009-03-20sh_eth: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The sh_eth driver can also be simplified a bit by using enetaddr member of the eth_device structure. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Carlos Munoz <carlos@kenati.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20cs8900: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The cs8900 driver also changes slightly in that the hardware is not consulted if the mac address in the env is sane. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Marius Groeger <mgroeger@sysgo.de> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20bcm570x: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. Since the address is in the PLM_DEVICE_BLOCK structure already, there is no need to pass the NodeAddress as a second parameter. So drop the second argument to the LM_SetMacAddress() function (and update the tigon3 driver accordingly). Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20drivers/net/: get mac address from environmentMike Frysinger
The environment is the canonical storage location of the mac address, so we're killing off the global data location and moving everything to querying the env directly. The drivers that get converted here: 3c589 4xx_enet dc2114x dm9000x enc28j60 fsl_mcdmafec ks8695eth mcffec rtl8019 rtl8169 s3c4510b_eth xilinx_emac xilinx_emaclite Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Rolf Offermanns <rof@sysgo.de> CC: Stefan Roese <sr@denx.de> CC: Sascha Hauer <saschahauer@web.de> CC: TsiChung Liew <Tsi-Chung.Liew@freescale.com> CC: Greg Ungerer <greg.ungerer@opengear.com> CC: Xue Ligong <lgxue@hotmail.com> CC: Masami Komiya <mkomiya@sonare.it> CC: Curt Brune <curt@cucy.com> CC: Michal SIMEK <monstr@monstr.eu>
2009-03-20boards: get mac address from environmentMike Frysinger
The boards that get converted here to use the environment for the mac address rather than global data: debris mgcoge mgsuvd muas3001 netstal pn62 sixnet vcma9 xilinx (the ones that use xilinx_enet) Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com> CC: Sangmoon Kim <dogoil@etinsys.com> CC: Heiko Schocher <hs@denx.de> CC: David Mueller <d.mueller@elsoft.ch> CC: Niklaus Giger <niklaus.giger@netstal.com> CC: Wolfgang Grandegger <wg@denx.de> CC: Dave Ellis <DGE@sixnetio.com> CC: Ricardo Ribalda <ricardo.ribalda@uam.es>
2009-03-20AmigaOneG3SE/enet: get mac address from environmentMike Frysinger
Always use the MAC address that is stored in the environment first before falling back to the ROM. This also cuts out any comparison steps: if the mac in the env is sane, the ROM is never consulted. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Thomas Frieden <ThomasF@hyperion-entertainment.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20nvedit: do not update global bi_enetaddr and do not call eth_set_enetaddr()Mike Frysinger
Since the ethernet layer handles updating of device addresses itself from the environment, there is no point in calling eth_set_enetaddr(). Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20lynxkdi: get mac address from environmentMike Frysinger
2009-03-20bootvx: get mac address from environmentMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Niklaus Giger <niklaus.giger@member.fsf.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20bdinfo: get mac address from environmentMike Frysinger
Add a new print_eth() function to automate the eth*addr env var acquisition and display. Affects all arches. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Scott McNutt <smcnutt@psyent.com> CC: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> CC: Michal Simek <monstr@seznam.cz> CC: Daniel Hellstrom <daniel@gaisler.com> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20net: get mac address from environment and use eth util funcsMike Frysinger
2009-03-20Blackfin: bfin_mac: force boards to setup the MAC themselvesMike Frysinger
Since the on-chip MAC does not have an eeprom or similar interface, force all Blackfin boards that use this driver to setup the board data with a proper MAC. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20doc/README.enetaddr: document proper MAC usageMike Frysinger
2009-03-20net: new utility functions for working with enetaddr'sMike Frysinger
Declare new utility functions for converting between the environment variables (eth*addr) and the binary MAC address representation. This way we can unify all the random places that already do this kind of thing. The functions in question: eth_parse_enetaddr - "..." -> {...} eth_getenv_enetaddr - env -> {...} eth_setenv_enetaddr - {...} -> env Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20convert print_IPaddr() to %pI4Mike Frysinger
Now that our printf functions support the %pI4 modifier like the kernel, let's drop the inflexible print_IPaddr() function and covert over to the %pI4 modifier. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-20vsprintf: pull updates from Linux kernelMike Frysinger
This brings in support for the %p modifier which allows us to easily print out things like ip addresses, mac addresses, and pointers. It also converts the rarely used 'q' length modifier to the common 'L' modifier when dealing with quad types. While this new code is a bit larger (~1k .text), most of it should be made up by converting the existing ip/mac address code to use format modifiers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-03-20.gitignore for generated files in api_examples directoryJon Smirl
Add .gitignore for generated files in api_examples directory Signed-off-by: Jon Smirl <jonsmirl@gmail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-03-20net: sh_eth: Remove sh_eth_reset() from halt functionNobuhiro Iwamatsu
sh_eth_reset is function to reset Ether IP. The MAC address is stored in IP, but it is initialized by this function. OS (e.g. Linux Kernel) can not use this device when initialized. This revises this problem. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
2009-03-20ppc4xx: Fix bug in PCI outbound map configuration for canyonlandsAnatolij Gustschin
PCI outbound address map configuration doesn't match the PCI memory address range covered by appropriate TLB entry configuration for canyonlands causing machine check exceptions while accessing PCI memory regions. This patch provides a fix for this issue. Kazuaki Ichinohe observed and reported this issue while testing display output with PCI ATI video card on canyonlands. Signed-off-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-19CFI: geometry reversal for STMicro M29W320DTRichard Retanubun
Follow up to the flash_fixup_stm to fix geometry reversal on STMicro M29W320ET flash chip. The M29W320DT has 4 erase region. Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-03-19smc911x_eeprom: update register APIMike Frysinger
The smc911x driver changed the naming convention for its register funcs, so update the eeprom code accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org> CC: Ben Warren <biggerbadderben@gmail.com>
2009-03-18mpc52xx: Get rid of board-specific #ifdef's in cpu/mpc5xxx/ide.cGrzegorz Bernacki
Total5200 and digsy MTC use I2C port 2 pins as a ATA chip select. To avoid adding board-specific ifdefs to cpu/mpc5xxx/ide.c new define CONFIG_SYS_ATA_CS_ON_I2C2 was introduced. It is used by Total5200 and will be used by digsy MTC and other boards with ATA CS on I2C pins. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2009-03-188xx: add support for new keymile kmsupx4 board.Heiko Schocher
This patch adds support for the kmsupx4 board from Keymile, based on a Freescale MPC852T CPU - serial console on SMC1 - 32 MB SDRAM - 32 MB NOR Flash - Ethernet over SCC3 - I2C Bitbang Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-188xx, mgsuvd: rename board to a more generic nameHeiko Schocher
renaming the "mgsuvd" board port into "km8xx", because there come more similar boards from keymile. Compiling the mgsuvd board with "make mgsuvd_config" remains. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-188xx, mgsuvd: Coding Style cleanup config fileHeiko Schocher
2009-03-18powerpc: common updates for keymile boardsHeiko Schocher
- added to keymile-common.h: - bootcount support - COMMAND HISTORY - CONFIG_AUTO_COMPLETE - CONFIG_SYS_FLASH_PROTECTION - JFFS2 support - CONFIG_VERSION_VARIABLE - extracted common I2C settings for all boards - common default environment settings summarized Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-188xx, icache: enabling ICache not before running from RAMHeiko Schocher
with the new CONFIG_SYS_DELAYED_ICACHE config option, ICache is not enabled before code runs from RAM. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-1882xx, mgcoge: fix environment sector sizeHeiko Schocher
Size of one environment sector is 0x20000. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-03-18NetStar: config reindentationLadislav Michl
Fix indentation broken by symbol renames. "Sort" driver related definitons. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2009-03-18Merge branch 'master' of git://git.denx.de/u-boot-coldfireWolfgang Denk
2009-03-18Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-03-17ColdFire: Fix incorrect definitionTsiChung Liew
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17ColdFire: Fix M5329EVB and M5373EVB nand issueTsiChung Liew
The Nand flash was unable to read and write properly due to Nand Chip Select (nCE) setup was in reverse order. Also, increase the Nand time out value to 60. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17ColdFire: PLATFORM_CPPFLAGS updates for new compilerTsiChung Liew
Update PLATFORM_CPPFLAGS to accept 4.3.x version of ColdFire compiler. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17ColdFire: Provide gzip image size V2 & V3 platformsTsiChung Liew
Default gzip bootm size is 8MB. Some platforms require more than 8MB Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17ColdFire: Fix M54451 serial boot dram setupTsiChung Liew
The serial boot dram extended/standard mode register was not setup and was using default DRAM setup causing the U-boot was unstable to boot up in serial mode. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2009-03-17Coldfire: XL Bus minor fixesarun c
According to coldfire manual data timeout > address time out also use correct macro to program XARB_CFG Signed-off-by: Arun C <arunedarath@mistralsolutions.com>
2009-03-17NAND: Have nboot accept .e and .i as legacy no-ops.Scott Wood
This was intended to happen before, but a trivial bug prevented it. Signed-off-by: Scott Wood <scottwood@freescale.com>
2009-03-17NAND: Make nboot skip bad blocksLadislav Michl
nboot command currently does not skip bad blocks and gives read error when loading image stored over bad block. With patch applied, nboot works as expected: Device 0 bad blocks: 00780000 014a0000 02000000 02cc0000 04aa0000 Loading from NAND 128MiB 3,3V 8-bit, offset 0x2c00000 Image Name: Linux-2.6.22-omap1 Created: 2008-11-20 23:44:32 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 1052520 Bytes = 1 MB Load Address: 10008000 Entry Point: 10008000 Skipping bad block 0x02cc0000 Automatic boot of image at addr 0x10400000 ... ... Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Scott Wood <scottwood@freescale.com>
