When a port is enabled at init time, the initializing function
touches more bits than necessary to enable a port (also touches
reserved bits and default bit values). This patch fixes this issue
by changing the value of the define used to enable the port and
assures that no other bits are changes by replacing out_le32()
with setbits_le32().
Signed-off-by: Codrin Ciubotariu <codrin.ciubotariu@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
This patch groups some macros defined for registers and
replaces some magic numbers from vsc9953 with macros. Also,
"port" and "port_nr" words are replaced with "port_no",
puts each variable declaration on a line and removes
unnecessary tabs.
Quark SoC does not support MSR MTRRs. Fixed and variable range MTRRs
are accessed indirectly via the message port and not the traditional
MSR mechanism. Only UC, WT and WB cache types are supported.
We configure all the fixed range MTRRs with common values (VGA RAM
as UC, others as WB) and 3 variable range MTRRs for ROM/eSRAM/RAM as
WB, which significantly improves the boot time performance.
With this commit, it takes only 2 seconds for U-Boot to boot to shell
on Intel Galileo board. Previously it took about 6 seconds.
Desktop Management Interface (DMI) is not supported by U-Boot now.
Add it to the TODO list.
Document porting considerations for Intel Quark based board,
including MRC parameters and PCIe initialization.
Now we have enabled PCIe root port on Quark SoC, add its PIRQ
routing information in the device tree as well.
Thermal sensor on Quark SoC needs to be properly initialized per
Quark firmware writer guide, otherwise when booting Linux kernel,
it triggers system shutdown because of wrong temperature in the
thermal sensor is detected by the kernel driver (see below):
[ 5.119819] thermal_sys: Critical temperature reached(206 C),shutting down
[ 5.128997] Failed to start orderly shutdown: forcing the issue
[ 5.135495] Emergency Sync complete
When Linux kernel boots, it hangs at:
[ 0.829408] Intel Quark side-band driver registered
This happens when Quark kernel Isolated Memory Region (IMR) driver
tries to lock an IMR register to protect kernel's text and rodata
sections. However in order to have IMR function correctly, HMBOUND
register must be locked otherwise the system just hangs.
Change existing codes to use clrbits, setbits, clrsetbits macros.
On Intel Quark, lots of registers on the message port need be
programmed. Add handy clrbits, setbits, clrsetbits macros for
message port access.
Not like other Intel Ethernet controllers (e.g.: E1000), Intel Quark
SoC integrated designware Ethernet controller does not have a chipset
defined way to store/restore mac address. Enable random mac address
so that we can use Ethernet even without 'ethaddr'.
This adds static register programming for PCIe and USB after memory
init as required by Quark firmware writer guide. Although not doing
this did not cause any malfunction, just do it for safety.
Convert to use DM version of Designware ethernet driver on Intel
quark/galileo.
The Designware ethernet controller is also seen on PCI bus, e.g.
on Intel Quark SoC. Add this support in the DM version driver.
Introduce device_is_on_pci_bus() which can be utilized by driver
to test if a device is on a PCI bus.
These properties are necessary to use full-featured pinctrl drivers
in SPL.
Enabling a PLL while IDDQ is high. The Linux kernel checks for this
condition and warns about it verbosely, so while this seems to work
fine, fix it up according to the programming guidelines provided in
the Tegra K1 TRM (v02p), Section 5.3.8.1 ("PLLC and PLLC4 Startup
Sequence"). The Tegra114 TRM doesn't contain this information, but
the programming of PLLC is the same on Tegra114 and Tegra124.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Sequence").
Reported-by: Nicolas Chauvet <kwizart@gmail.com>
Add the device tree node for the SPI controllers found on Tegra20 SOCs.
Signed-off-by: Mirza Krak <mirza.krak@hostmobility.com>
The counter frequency is derived from clk_m on Tegra, but that clock can
be configured by the primary bootloader to run at the same frequency as
the oscillator (38.4 MHz on Tegra210) or a divided down frequency (most
typically 19.2 MHz). Remove the hard-coded frequency and allow the timer
setup code to query the correct value at runtime.
While clk_m and the oscillator run at the same frequencies on Tegra114
and Tegra124, clk_m is the proper source for the architected timer. On
more recent Tegra generations, Tegra210 and later, both the oscillator
and clk_m can run at different frequencies. clk_m will be divided down
from the oscillator.
On currently supported SoCs, clk_m always runs at the same frequency as
the oscillator input. However newer SoC generations such as Tegra210 no
longer have that restriction. Prepare for that by separating clk_m from
the oscillator clock and allow SoC code to override the clk_m rate.
Some platforms have the means to determine the counter frequency at
runtime, so give them an opportunity to do so.
Commit 181bd9dc61d2 "kconfig: add config option for shell prompt" replaced
define V_PROMPT with Kconfig option SYS_PROMPT. This crossed with patches
adding Tegra T210 boards. Migrate the boards to the new scheme.
AFAIK, for all PLLs on all Tegra SoCs, the primary PLL output frequency
is (input * m) / (n * p). However, PLLP's primary output (pllP_out0) on
T210 is the VCO output, and divp is not applied. pllP_out2 does have divp
applied. All other pllP_outN are divided down from pllP_out0. We only
support pllP_out0 in U-Boot at the time of writing.
Fix clock_get_rate() to handle this special case.
This corrects the returned rate for PLLP to be 408MHz rather than 204MHz.
In turn, this causes high enough dividers to be calculated for the various
peripheral clocks that feed off of PLLP. Without this, some peripherals
failed to operate correctly. For instance, one of my SD cards worked
perfectly but an older (presumably slower) card could not be read.
Note that prior to commit 722e000ccd72 "Tegra: PLL: use per-SoC pllinfo
table instead of PLL_DIVM/N/P, etc.", the calculated PLL frequency was
816MHz since the wrong values were being extracted from the PLLP divider
register. This caused overly large peripheral dividers to be calculated,
which while wrong, didn't cause any correctness issues; things simply ran
slower than they could.
Reported-by: Thierry Reding <treding@nvidia.com>
While T210 boards all have 38.4MHz crystals, per the TRM, the only
supported configuration is to divide the crystal frequency by 2 to
generate clk_m, which is what feeds the ARM generic timers amongst other
things. Fix the value of COUNTER_FREQUENCY to reflect this divide-by-2.
When I queried the 19.2 value in Tom's original T210 patches, I wasn't
aware of this extra divide-by-2, and didn't notice any effect from the
incorrect value, since its only used if U-Boot is booted in EL3, whereas
I'm booting it in EL2.
This function is deleted by commit 2fccd2d96bad
"tegra: Convert tegra GPIO driver to use driver model".
Signed-off-by: Axel Lin <axel.lin@ingics.com>
P2371-2180 is a P2180 CPU board married to a P2597 I/O board. The
combination contains SoC, DRAM, eMMC, SD card slot, HDMI, USB
micro-B port, Ethernet via USB3, USB3 host port, SATA, PCIe, and
two GPIO expansion headers.
The clear_config() is called just once at the beginning of this
program, but the global variable hashtab[] is already zero-filled
at the start-up.
[ Linux commit: d179e22762fd38414c4108acedd5feca4cf7e0d8 ]
Signed-off-by: Michal Marek <mmarek@suse.com>
When enabling CONFIG_API and chain-loading GRUB2 on jetson-tk1, only the
eMMC would show up as (hd0), but not the SD card, leading to GRUB not
finding its configuration and modules, falling back to a rescue shell.
This is because enum_ended would get set for !more after returning a
cookie for the first MMC device in group 3.
Fix this by properly setting the "more" argument also in the case of the
first storage device of a group.
Signed-off-by: Andreas Färber <afaerber@suse.de>
Commit 0abdd9d0 "arm: Remove nhk8815 boards and nomadik arch" missed one
reference to this arch. Lets remove this as well.
This arch does not seem to be supported / used at all in the current
U-Boot mainline source tree any more. So lets remove the core u8500 code
and code that was only referenced by this platform.
Please note that this patch also removes these config options:
- CONFIG_PL011_SERIAL_RLCR
- CONFIG_PL011_SERIAL_FLUSH_ON_INIT
As they only seem to be referenced by u8500 based boards. Without any
such board in the current code, these config option don't make sense
any more. Lets remove them as well.
If someone still wants to use this platform, then please send patches
to re-enable support by adding at least one board that references this
code.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: John Rigby <john.rigby@linaro.org>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
This patch addresses some comments raised by Scott in the last versions.
Here the changes in detail:
- Removed __maybe_unused as its not needed
- Added check for strength == 4 and error out for the unsupported
ECC strength values
- Don't set .caclulate, .correct, and .bytes for NAND_ECC_SOFT_BCH as this
will be done in nand_scan_tail()
- Set .caclulate back to fsmc_read_hwecc() in the HW case
- Added comment that this function will only be called on SPEAr platforms,
not supporting the BCH8 HW ECC (FSMC_VER8)
Cc: Scott Wood <scottwood@freescale.com>
Acked-by: Scott Wood <scottwood@freescale.com>
ithout this patch memory is not released on early exit.
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
from file
Lets consider following scenario:
- One uses echo -n "key=value" to define environment variable in a file (single variable)
- The file content is "key=value" without any terminating byte (e.g. 0x0a or
0x0d).
- The file is loaded to u-boot non zero'ed RAM buffer (with load command).
- Then "env import -t -r $loadaddr $filesize" is executed.
- Due to lack of proper termination byte we have classical example of buffer
overrun.
This patch prevents from this by allocating one extra byte than size and
explicitly null terminate it.
There should be no change for normal env import operation after applying
this patch.
Bigger source buffer than dest buffer could overflow when copying
strings. Source and destination buffer sizes are same now.
Signed-off-by: Imran Zaman <imran.zaman@intel.com>
Tested on my TI186x rev E. (PG2.0) and take over maintainership.
Take over maintainership as well. Not tested as PG2.0 (which I have)
needs additional work over PG1.0 (which Matt has).
Cc: Matt Porter <mporter@konsulko.com>
Tested on my OMAP3 uEVM.
fdtdec_get_addr_size() hard-codes the number of cells used to represent
an address or size in DT. This is incorrect in many cases depending on
the DT binding for a particular node or property (e.g. it is incorrect
for the "reg" property). In most cases, DT parsing code must use the
properties #address-cells and #size-cells to parse addres properties.
This change splits up the implementation of fdtdec_get_addr_size() so
that the core logic can be used for both hard-coded and non-hard-coded
cases. Various wrapper functions are implemented that support cases
where hard-coded cell counts should or should not be used, and where
the client does and doesn't know the parent node ID that contains the
properties #address-cells and #size-cells.
dev_get_addr() is updated to use the new functions.
Core functionality in fdtdec_get_addr_size_fixed() is widely tested via
fdtdec_get_addr_size(). I tested fdtdec_get_addr_size_auto_noparent() and
dev_get_addr() by manually modifying the Tegra I2C driver to invoke them.
Much of the core implementation of fdtdec_get_addr_size_fixed(),
fdtdec_get_addr_size_auto_parent(), and
fdtdec_get_addr_size_auto_noparent() comes from Thierry Reding's
previous commit "fdt: Fix fdtdec_get_addr_size() for 64-bit".
Based-on-work-by: Thierry Reding <treding@nvidia.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Michal Suchanek <hramrach@gmail.com>
Dropped #define DEBUG at the top of fdtdec.c:
On the LaCie boards netspace_max_v2 and net2big_v2, two internal hard
drives are available. Additionally on the d2net_v2 board, an extra hard
drive can be plugged via eSATA.
This patch updates CONFIG_SYS_IDE_MAXBUS and CONFIG_SYS_IDE_MAXDEVICE
accordingly for this boards.
Signed-off-by: Simon Guinot <simon.guinot@sequanux.org>
Use CONFIG_SYS_GENERIC_BOARD in EDB93XX board family
This patch enables generic board support for the following
Kirkwood-based LaCie boards:
- Network Space v2 (Mini, Lite and Max).
- Internet Space v2.
- D2 Network v2.
- 2Big Network v2.
