This fixes the cluster size tests in the FAT32 file system.
The current implementation of VFAT support doesn't work if the
referred cluster has an offset > 16bit representation, causing
"fatload" and "fatls" commands etc. to fail.
Signed-off-by: michael trimarchi <trimarchi@gandalf.sssup.it>
The 405EZ only supports 512 bytes of rx-/tx-fifo EMAC sizes. But
currently 4k/2k is configured. This patch fixes this issue.
Thanks to Thomas Kindler <tkindler@lenord.de> for pointing this out.
Fix alignment fault on ARM when running modules. With out an explicit
linker file gcc4.2.1 will half word align __bss_start's value. The word
dereference will crash hello_world.
signed-off-by Richard Woodruff <r-woodruff2@ti.com>
The ext2 aligned process will corrupt the key
data struct, the patch fix this.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Make sure CDPATH settings cannot interfere.
Update CHANGELOG.
Add cscope build target to generate cscope database for code browsing.
Signed-off-by: Li Yang <leoli@freescale.com>
erratum 5.6 states the autoneg completion bit is functional only if the
autoneg bit is asserted.
This fixes any secondarily-issued networking commands on non-gigabit
links on the mpc8360 mds board.
Adds PCI support for MPC5121
Tested with drivers/net/rtl8139.c
Support is conditional since PCI on old silicon does not work.
ads5121_PCI_config turns on PCI
In this version, condition compilation of PCI code has been moved
from ifdef in board/ads5121/pci.c to board/ads5121/Makefile as
suggested by Jean-Christophe PLAGNIOL-VILLARD
Signed-off-by: John Rigby <jrigby@freescale.com>
Fix warnings while compilation with new gcc in eldk-4.2
U-Boot crashes in the net loop if CONFIG_4xx_DCACHE is
enabled. To reproduce the problem ensure that 'ethrotate'
environment variable isn't set to "no" and then run
"tftp 200000 not_existent_file".
This patch tries to fix the issue.
Currently (since commit b2e2142c) u-boot crashes on
sequoia board while SPR test if CONFIG_4xx_DCACHE is
enabled. This patch disables the cache while SPR test.
Call fdt_fixup_memory() on the boards TQM5200, TQM5200_B, TQM5200S,
TB5200 and TB5200_B to fixup the /memory node with the memory values
detected by U-Boot.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
include/asm-arm/arch-imx/imx-regs.h
detected by U-Boot.
This patch fixes a bug in the SDRAM initialization code for the
TQM5200. The hi_addr bit is now set correctly. Without this patch
the hi_addr bit is always set to 1, if the second SDRAM bank is
not populated.
For other MPC5200 boards a correspondig patch has already been applied
some time ago, see commit a63109281ad41b0fb489fdcb901171f76bcdbc2c.
Forget the first patch please. I confused flash with SDRAM in
the comment ...
"pointer targets in assignment differ in signedness"
Sync register definitions with linux
- actua1:
actux1.c: In function 'checkboard':
actux1.c:92: warning: unused variable 'revision'
- actua2:
actux2.c: In function 'checkboard':
actux2.c:100: warning: unused variable 's'
actux2.c:99: warning: unused variable 'revision'
actux2.c: In function 'reset_phy':
actux2.c:130: warning: unused variable 'i'
- actua3:
actux3.c: In function 'checkboard':
actux3.c:114: warning: unused variable 'revision'
targets.
The previous patch was lacking of i386, microblaze, nios and nios2. This
patch tries to fix them.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
There is no reason to icbi when invalidating the temporary stack in
the d-cache. Its impossible on e500 to have the i-cache contain
any addresses in the temp stack and it can be problematic in generating
transactions on the bus to non-valid addresses.
The source vector for the ECM was being set to 2,
but that's what the source vector for DDR was being
set to. Change it to 1.
Signed-off-by: Andy Fleming <afleming@freescale.com>
Commit 0db37dc... (and some others) changed the INIT_RAM TLB
mappings to be unguarded. This collided with an existing "bug"
where the mappings for the INIT_RAM were being kept around.
This meant that speculative loads to those addresses were
succeeding in the TLB, and going out to the bus, where they
were causing an exception (there's nothing at that address). The
Flash code was coincidentally causing such a speculative load.
Rather than go back to mapping the INIT RAM as guarded, we fix
it so that the entries for the INIT_RAM are invalidated. Thus
the speculative loads will fail in the TLB, and have no effect.
Back in commit a551cee99ad1d1da20fd23ad265de47448852f56
(86xx: Fix GUR PCI config registers properly), we should have
changed the MPC86xx_PORBMSR_HA and MPC86xx_PORDEVSR_IO_SEL
symbols in the sbc8641d board as well. Fix this oversight.
Don't include testdram() on NAND-booting target acadia_nand. This saves
a few bytes and makes the target build clean again.
Sync registers definition with linux
- actua1:
- actua2:
- actua3:
targets.
Olaf Hering [Wed, 17 Oct 2007 06:27:13 +0000 (23:27 -0700)]
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on
32bit targets.
GCC can be made to warn about usage of long long types with ISO C90
(-ansi), but only with -pedantic. You can write this in a way that even
then it doesn't cause warnings, namely by:
#ifdef __GNUC__
__extension__ typedef __signed__ long long __s64;
__extension__ typedef unsigned long long __u64;
#endif
The __extension__ keyword in front of this switches off any pedantic
warnings for this expression.
Signed-off-by: Olaf Hering <olh@suse.de>
Cc: <linux-arch@vger.kernel.org>
This will reduce the build time.
This reduces the build time by ~10%. Here's the gth2_config example.
BEFORE AFTER
real 0m31.441s 0m27.833s
user 0m24.766s 0m23.045s
sys 0m10.425s 0m7.468s
In the thread "[1.3.2-rc1] MPC8548CDS/MPC8555CDS configs fails to link",
the define2mk.sed script was identified as the source of the link
failure on FreeBSD. The problem is that sed(1) does not always support
the '+' operator. It isn't on FreeBSD. The attach patch implements the
equivalent, using the '*' operator instead and should work everywhere.
Signed-off-by: Marcel Moolenaar <marcelm@juniper.net>
The Linux commit fac8b209b1084bc85748bd54e13d00c1262b220f ("Remove
final traces of long-deprecated "ramdisk" kernel parm") makes these
changes neccessary.
Signed-off-by: Detlev Zundel <dzu@denx.de>
When the LM75 temperature sensor measures a temperature below 0 C, the
current driver does not perform sign extension, so the result returned is
256 C too high. This patch fixes the problem.
Signed-off-by: Larry Johnson <lrj@acm.org>
Rename the "scc" node in "ethernet" for the mgsuvd board.
Some boards (e.g. lwmon5) may use rather small watchdog intervals, so
causing it to reboot the board if U-Boot does a long busy-wait with
udelay(). Thus, for these boards we have to restart WD more
frequently.
This patch splits the busy-wait udelay() into smaller, predefined,
intervals, so that the watchdog timer may be resetted with the
configurable (CONFIG_WD_PERIOD) interval.
Signed-off-by: Yuri Tikhonov <yur@emcraft.com>
Adds configuration option for ATI Radeon 9200 card
support to sequoia config file. If CONFIG_VIDEO
is enabled, TEXT_BASE should be changed to 0xFFF80000.
