- update for using splashfile instead of location->name
when loading the splash image from a FIT
- updates for loading internal and external splash data from FIT
- DM_GPIO/DM_VIDEO migration for mx53 cx9020 board
- fix boot issue on mx6sabresd board after DM_VIDEO migration
- increase the max preallocated framebuffer BPP to 32 in ipuv3
driver to prepare for configurations with higher color depth
- allow to use vidconsole_put_string() in board code for text
output on LCD displays
- H6 WDT reset fix (Clément)
- H6 SPL_TEXT_BASE fixes (Clément, Jonas)
- NPI-M1+ emac enablment (Emmanuel)
NanoPi M1 plus have a 10/100/1000M ethernet with external phy.
Phy power is controlled by PD6.
Add the required configuration for it.
Signed-off-by: Emmanuel Vadot <manu@freebsd.org>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
SPL_TEXT_BASE was moved into Kconfig, which previously part of
include/configs before this teres_i support gets merged.
Fix it by explicitly define in defconfig like other boards does.
Signed-off-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
SPL_TEXT_BASE has been moved to Kconfig with commit:
f89d6133ee configs: move CONFIG_SPL_TEXT_BASE to Kconfig
But Beelink GS1 config file has been introduced in the
same time without this modification.
Fix this by settings the CONFIG_SPL_TEXT_BASE
Suggested-by: Jonas Smedegaard <dr@jones.dk>
Signed-off-by: Clément Péron <peron.clem@gmail.com>
Some H6 boards have a watchdog which didn't make the SoC
reboot properly.
Reason is still unknown but several people have test it.
Chen-Yu Tsai :
Pine H64 = H6 V200-AWIN H6448BA 7782 => OK
OrangePi Lite 2 = H6 V200-AWIN H8068BA 61C2 => KO
Martin Ayotte :
Pine H64 = H8069BA 6892 => OK
OrangePi 3 = HA047BA 69W2 => KO
OrangePi One Plus = H7310BA 6842 => KO
OrangePi Lite2 = H6448BA 6662 => KO
Clément Péron:
Beelink GS1 = H6 V200-AWIN H7309BA 6842 => KO
After the series of result, Icenowy try to reach Allwinner about this
issue but they seems not interested to investigate it.
As we don't have the ARIS coproc to do power management and watchdogis
the only solution to reset the board.
So, Change from watchdog to R_watchdog to allow a reboot on all H6
boards.
- Fix for mxc_i2c driver in DM mode, thanks to Trent!
- Fix SPL build on Armada XP (theadorable etc) (Stefan)
Pull the vidconsole_put_string() function from DM tests, make it
available to e.g. boards that want to display information on the
LCD on boot.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
The IPUv3 can handle 1920x1080x32bpp displays , set the max preallocated
framebuffer BPP to 32 to cater for all eventualities.
Meet the following boot hang.
U-Boot SPL 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800)
Trying to boot from MMC1
U-Boot 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C)Reset cause: POR
Model: Freescale i.MX6 Quad SABRE Smart Device Board
Board: MX6-SabreSD
I2C: ready
DRAM: 1 GiB
Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Error binding driver 'ipuv3_video': -28
Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Some drivers failed to bind
Error binding driver 'generic_simple_bus': -28
initcall sequence 4ffe4500 failed at call 1780dfb7 (err=-28)
1. fdtdec_get_alias_seq will use "video" as base, however in alias node,
we use ipux, so add new alias for U-Boot dts.
2. DM_VIDEO is enabled, however reserve_video is called before
relocation, so to make DM_VIDEO work before relocation, need to
set SYS_MALLOC_F_LEN
3. defconfig is updated with savedefconfig
Note: I do not have a video panel to test, but with this patch, U-Boot
boots up again, below log.
U-Boot SPL 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800)
U-Boot 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800)
CPU: Automotive temperature grade (-40C to 125C) at 34C
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 3
Loading Environment from MMC... *** Warning - bad CRC, using default environment
PCI: pcie phy link never came up
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <peng.fan@nxp.com>
There are several includes in mx53cx9020.c which are not required
anymore.
Acked-by: Patrick Bruenn <p.bruenn@beckhoff.com>
Signed-off-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
These mmc functions were not used anymore since DM_MMC was introduced.
Enable DM_VIDEO in config and don't overwrite console so it can be set
from environment
The ipu node in imx53 is needed for DM_VIDEO. We also need to set
u-boot,dm-pre-reloc to initialize before relocation.
This code also works with imx53 ipus so we can enable it for them.
Switch to DM_GPIO and add gpio_request where necessary.
This is needed for DM_VIDEO and fixes an issue with sd card detection
which was introduced by the combination of these commits:
commit 7a0425dd969c ("mmc: fsl_esdhc: make get_cd work well in dm_mmc_ops")
commit 7e04b4c751a1 ("dm: arm: imx: migrate cx9020 to CONFIG_DM_MMC")
The FIT image could contain the splash data in 3 different structure:
- The splash data is embedded in FIT image (internal)
In this case, the property 'data' presents in FIT image header. And
internal information 'start' and 'end' represent the location and
size of splash data inside of FIT image.
- The splash data is external with absolute position in FIT image
This case is made by 'mkimage -p [pos]'. The splash data is stored
at the absolute position. Instead the property 'data', the properties
'data-position' and 'data-size' are used to specify the location and
size of the splash data.
- the splash data is external with relative offset in FIT image
This case is made by 'mkimage -E'. The splash data is placed after
the FIT image header with 4 byte alignment. Instead the property
'data', the properties 'data-offset' and 'data-size' are used to
specify the location and size of the splash data.
Currently, the splash only support to load external data with relative
offset from FIT image. This commit make it possible to load the splash
data embedded in FIT image or the external data with absolute position
This inspiration comes from Simon Glass <sjg@chromium.org>, see
common/spl_fit.c
Signed-off-by: Leo Ruan <tingquan.ruan@cn.bosch.com>
Signed-off-by: Mark Jonas <mark.jonas@de.bosch.com>
Reviewed-by: Stefano Babic <sbabic@denx.de>
The splash image could be loaded from different sources (e.g. sf, mmc)
with different formats (e.g. raw, file-system). These sources are
structured by a board dependent object 'splash_location'. To decide
where is the splash image loaded, following environment variables are
used to select the splash source and file:
- 'splashsource' is used to select the splash source by setting its
value to specified name of splash location.
- 'splashfile' specify the name of splash image file
But, when loads the splash image from FIT, the name of splash image
within FIT is specified by splash location name. Due to the splash
location name is already used for the splash source, its name may
conflicts with the name of splash image.
To solve the conflict, the environment variable 'splashfile' is used
to specify the splash image in FIT, and keeps the splash location
name for the splash source.
Reviewed-by: Tomas Melin <tomas.melin@vaisala.com>
Without this U-Boot specific property, booting on Armada XP theadorable
fails in SPL. All nodes in the "internal-regs" (simple-bus) DT node are
not scanned, so the UART node is missing (and others).
I'm not adding this property in an *u-boot.dtsi file, since there is
none matching the generic rules for all files including this dtsi
file. So to not miss any of the boards using this dtsi file, I'm
adding it to this file directly, which makes the Linux merge a less
easy unforunately.
Cc: Chris Packham <judge.packham@gmail.com>
Cc: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Chris Packham <judge.packham@gmail.com>
This is causing unexpected size growth in the normal case and is likely
to have been mis-applied by myself.
This reverts commit 3eaf6dcd9362b56e3217559401287dd8fa35b5b2.
Pull request for UEFI sub-system for v2019.07-rc3 (2)
Minor patches to improve UEFI specification compliance are provided.
To allow running the UEFI self compliance tests an outdated version of
the Unicode collation protocol has been added as a configuration option
(disabled by default).
- Allow coreboot to process unhandled tags
- Enable NVMe on QEMU x86_64 target
- Convert SYS_[DI]CACHE_OFF to Kconfig, introduce SPL variant.
- Various bcm96* fixes.
- Import include/android_bootloader_message.h from AOSP
- Assorted other small fixes.
NVMe was turned on in qemu-x86 but somehow we missed it for 64-bit.
When dma_addr_t is u32 in 64-bit, there are some warnings when
building NVME driver. Fix it by doing an additional (long) cast.
coreboot makes it possible to add own entries into coreboot's
table at a per mainboard basis. As there might be some custom
ones it makes sense to provide a way to process them.
Signed-off-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Check the parameters against NULL.
KeyToggleState is a pointer according to UEFI spec 2.8.
Do not write to address indicated by NULL pointer.
UEFI SCT II 2.6 (2017), 3.6.5 GetNextMonotonicCount(), 5.1.5.5.1
Not checking the parameters may lead reading or writing from NULL.
Implement the parameter checks prescribed in the UEFI spec.
According to the UEFI spec InstallMultipleProtocolInterfaces() must check
if a device path has already been installed. In this case it must return
EFI_ALREADY_STARTED.
Cf. UEFI SCT II 2.6 A (2017),
3.3.16 InstallMultipleProtocolInterfaces(), 5.1.3.16.1.
In EFI 1.10 a version of the Unicode collation protocol using ISO 639-2
language codes existed. This protocol is not part of the UEFI specification
any longer. Unfortunately it is required to run the UEFI Self Certification
Test (SCT) II, version 2.6, 2017. So we implement it here for the sole
purpose of running the SCT. It can be removed once a compliant SCT is
available.
The configuration option defaults to no.
Signed-off-by: Rob Clark <robdclark@gmail.com>
Most of Rob's original patch is already merged. Only the deprecated
protocol is missing. Rebase it and make it configurable.
Rename variables to make it clear they refer to the Unicode collation
protocol identified by the EFI_UNICODE_PROTOCOL2_GUID.
In the implementation of the device path to text protocol join adjacent
sprintf() statements.
Check buffer pointers are not NULL as required by the UEFI 2.7 spec.
Return EFI_UNSUPPORTED instead of EFI_INVALID_PARAMETER when trying to
transmit with non-zero header_size.
UEFI spec 2.7 erratum A leaves it undefined if Attributes should be set if
GetVariable() returns EFI_BUFFER_TOO_SMALL.
UEFI spec 2.8 defines that Attributes should be set if the return value is
either EFI_SUCCESS or EFI_BUFFER_TOO_SMALL.
Set Attributes if the return value is EFI_BUFFER_TOO_SMALL.
There appears to be enough RAM to support cache in SPL.
This pach enables block cache in SPL.
The current prompt text for FIT external offset is identical to
SYS_TEXT_BASE which might confuse the users. Provided more accurate
description for the prompt text.
Signed-off-by: Ibai Erkiaga <ibai.erkiaga-elorza@xilinx.com>
The MMC controller enabled card detect, so this patch enables
the GPIO driver in SPL to support it.
This takes the latest changes from AOSP from the file
bootloader_message/include/bootloader_message/bootloader_message.h
in the repository
https://android.googlesource.com/platform/bootable/recovery
and re-licensed them to BSD-3 for U-Boot.
Minimum local changes have been applied (convert C++ to C comments and
adding #ifndef __UBOOT__ block to skip all the function declarations).
Signed-off-by: Alex Deymo <deymo@google.com>
Reviewed-by: Sam Protsenko <semen.protsenko@linaro.org>
Add an option to open files in read-only mode in mmap_fdt so
that fit_check_sign can be used to inspect files on read-only
filesystems.
For example, this is useful when a key is shipped in a read-only
rootfs or squashfs.
Signed-off-by: Luca Boccassi <luca.boccassi@microsoft.com>
Also get rid of ahci_setup_port(..).
Configuration option CONFIG_CMD_BOOTEFI_SELFTEST is useful for the
development of the UEFI sub-system. For production it is not needed.
Remove CONFIG_CMD_BOOTEFI_SELFTEST from bcm968580xref_ram_defconfig.
Suggested-by: Tom Rini <trini@konsulko.com>
Remove CONFIG_CMD_BOOTEFI_SELFTEST from bcm963158_ram_defconfig.
Set the spl_image->fdt_addr pointer both for simple fitImage configuration
as well as full fitImage configuration, to let spl_perform_fixups() access
the DT and perform modifications to it if necessary.
Instead of using the watchdog, let's use PSCI to perform the reset
of the SoC.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
This board define the flag CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT
but it's a mistake. It's a workaround for an issue in nand core.
This issue was fixed by the commit 5f626e78491c ("mtd: nand: raw:
Fix CONFIG_SYS_NAND_DRIVER_ECC_LAYOUT behavior"). Now, this flag
break the nand on this board, so we simply remove it.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
