Commit 309a292e deleted OXC board, but
missed to remove the standalone example specific to OXC board.
eepro100_eeprom.c has been an orphan file for a long term.
Commit 7e8c53d7 removed eNET board but missed to
add eNET to README.scrapyard.
This commit adds it for the record.
Cc: Graeme Russ <graeme.russ@gmail.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Since commit c2dd0d455 and 45bf05854 introduced
the new cache maintainance framework to ARM,
CONFIG_L2_OFF has not been used at all.
In 6789e84 we update u-boot-spl.lds for OMAP to ensure we include
adapter information, as we use i2c during SPL. However, the regex used
also means we included commands that may have been built. On omap5_uevm
this leads to a failure as we include the command from the do_tca642x
command, and fail to link. The fix is to restrict our regex to only the
i2c list parts.
When indexing freqProcessor[] we use the first
value in the cpu's "reg" property, which on
new e6500 cores IDs the threads.
But freqProcessor[] should be indexed with a
core index so, when fixing "the clock-frequency"
cpu node property, access the freqProcessor[]
with the core index derived from the "reg' property.
If we don't do this, last half of the "cpu" nodes
will have broken "clock-frequency" values.
Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Update the code that builds the pci endpoint liodn
offset list so that it doesn't overlap with other
liodns and doesn't generate negative offsets like:
fsl,liodn-offset-list = <0 0xffffffcd 0xffffffcf
0xffffffd1 0xffffffd3
0xffffffd5 0xffffffd7
0xffffffd9 0xffffffdb>;
The update consists in adding a parameter to the
function that builds the list to specify the base
liodn.
On PCI v2.4 use the old base = 256 and, on PCI 3.0
where some of the PCIE liodns are larger than 256,
use a base = 1024. The version check is based on
the PCI controller's version register.
Cc: Scott Wood <scottwood@freescale.com>
The liodn for the T4240's PCIE controller is no longer set
through a register in the guts register block but with one
in the PCIE register block itself.
Use the already existing SET_PCI_LIODN_BASE macro that puts
the liodn in the correct register.
Define base addresse for both MPH(USB1) and DR(USB2) controllers
for MPC834x socs
Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
T1042RDB_PI is Freescale Reference Design Board supporting the T1042
QorIQ Power Architecture™ processor. T1042 is a reduced personality
of T1040 SoC without Integrated 8-port Gigabit. The board is designed
with low power features targeted for Printing Image Market.
T1042RDB_PI is similar to T1040RDB board with few differences like
it has video interface, supports T1042 personality
T1042RDB_PI board Overview
- Four e5500 cores, each with a private 256 KB L2 cache
- 256 KB shared L3 CoreNet platform cache (CPC)
- Interconnect CoreNet platform
- 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving
support
- Data Path Acceleration Architecture (DPAA) incorporating acceleration
for the following functions:
- Packet parsing, classification, and distribution
- Queue management for scheduling, packet sequencing, and congestion
management
- Cryptography Acceleration
- RegEx Pattern Matching Acceleration
- IEEE Std 1588 support
- Hardware buffer management for buffer allocation and deallocation
- Ethernet interfaces
- Two on-board RGMII 10/100/1G ethernet ports.
- SERDES Connections, 8 lanes supporting:
— PCI
— SATA 2.0
- DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and
Interleaving
-IFC/Local Bus
- NAND flash: 1GB 8-bit NAND flash
- NOR: 128MB 16-bit NOR Flash
- Ethernet
- PHY #0 remains powered up during deep-sleep
- CPLD
- Clocks
- System and DDR clock (SYSCLK, “DDRCLK”)
- SERDES clocks
- Video
- DIU supports video at up to 1280x1024x32bpp
- HDMI connector
- Power Supplies
- USB
- Supports two USB 2.0 ports with integrated PHYs
- Two type A ports with 5V@1.5A per port.
- SDHC
- SDHC/SDXC connector
- SPI
- On-board 64MB SPI flash
- I2C
- Device connected: EEPROM, thermal monitor, VID controller, RTC
- Other IO
- Two Serial ports
- ProfiBus port
- Four I2C ports
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
T1040RDB is Freescale Reference Design Board supporting
the T1040 QorIQ Power Architecture™ processor.
T1040RDB board Overview
support
management
- Integrated 8-port Gigabit Ethernet switch
- Four 1 Gbps Ethernet controllers
- PCI
- SGMII
- QSGMII
- SATA 2.0
Interleaving
-IFC/Local Bus
- Ethernet
- CPLD
- Clocks
- SERDES clocks
- Power Supplies
- USB
- SDHC
- SPI
- I2C
- Devices connected: EEPROM, thermal monitor, VID controller
- Other IO
- Two Serial ports
- ProfiBus port
[York Sun: fixed Makefile]
Acked-by: York Sun <yorksun@freescale.com>
T1040 Soc has four personalities:
-T1040 (4 cores with L2 switch)
-T1042:Reduced personality of T1040 without L2 switch
-T1020:Reduced personality of T1040 with less cores(2 cores)
-T1022:Reduced personality of T1040 with 2 cores and without L2 switch
Update defines in arch/powerpc header files, Makefiles and in
driver/net/fm/Makefile to support all T1040 personalities
[York Sun: fixed Makefiles]
- Remove duplicate doc/README.p1010rdb
- Rename README to README.P1010RDB-PA
- Add new README.P1010RDB-PB
P1010RDB-PB is a variation of previous P1010RDB-PA board.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
Use a default RCW of protocol 0x66.
A PBI configure file which uses CPC as 256KB SRAM. It can be used by
PBL tool on T1040 to build a pbl boot image.
This delay applies to any data transfer on I2C bus.
For example 1kB data read with per-byte access (which happens if
environment is stored in I2C EEPROM) takes more than 10 seconds.
Moreover data bus driver has to care about bus state and data transfer,
but not about internal states of attached devices.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Tom Rini <trini@ti.com>
cc: Armando Visconti <armando.visconti@st.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Vipin KUMAR <vipin.kumar@st.com>
Cc: Tom Rix <Tom.Rix@windriver.com>
Cc: Mischa Jonker <mjonker@synopsys.com>
As it is stated in DesignWare I2C databook: writes to IC_TAR (0x4)
register succeed only when IC_ENABLE[0] is set to 0.
Data "offset" is not used directly in case of I2C EEPROM. Istead it is
split into "block number" and "offset within mentioned block". Which are
"addr[0]" and "addr[1]" respectively.
Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
cc: Peter Tyser <ptyser@xes-inc.com>
remove omap1510 i2c driver, as there is no board which uses it
Cc: Jian Zhang <jzhang@ti.com>
- add zync i2c driver to new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Michal Simek <michal.simek@xilinx.com>
- add omap24xx driver to new multibus/multiadpater support
Tested on the am335x based siemens boards rut, dxr2 and pxm2
posted here:
http://patchwork.ozlabs.org/patch/263211/
Tested-by: Tom Rini <trini@ti.com>
Cc: Lars Poeschel <poeschel@lemonage.de>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Thomas Weber <weber@corscience.de>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Cc: Luca Ceresoli <luca.ceresoli@comelit.it>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Ilya Yanok <yanok@emcraft.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Pali Rohár <pali.rohar@gmail.com>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Michael Jones <michael.jones@matrix-vision.de>
Cc: Raphael Assenat <raph@8d.com>
The endless waiting for a bit to be set can cause a hang, add a timeout
so we prevent such situation. A testcase for such a hang is below. The
testcase assumes a device to be present at address 0x50 and a device to
NOT be present at address 0x42 . Also note that the "sleep 1" induced
delays are imperative for this bug to manifest .
i2c read 0x42 0x0.2 0x10 0x42000000 ; sleep 1 ; \
i2c read 0x50 0x0.2 0x10 0x42000000 ; sleep 1 ; \
The expected result of the above command is:
Error reading the chip.
While without this patch, we observe a hang in the last read from 0x42
precisely when waiting for this bit to be set.
Cc: Fabio Estevam <fabio.estevam@freescale.com>
This updates to new I2C framwwork on sh_i2c.
And this also updates boards(kzm9g and ecovec) that using sh_i2c.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Use scf0403 driver to add scf0403x LCD support for cm-t35 and cm-t3730
boards.
Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
Add DSS_ONOFF to polarity defines
Acked-by: Anatolij Gustschin <agust@denx.de>
Add SPI-based driver for DataImage SCF0403852GGU04 and SCF0403526GGU20
LCD panels.
The flag combination "SPI_XFER_BEGIN | SPI_XFER_END" is a common use
case of spi_xfer, and it can easily cause an already long line (spi_xfer
takes 5 parameters) to go over the 80 character limit.
define SPI_XFER_ONCE to be a shorter version of the above flag combination.
Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
Current implementation only supports 8 bit word lengths, even though
omap3 can handle anything between 4 and 32.
Update the spi interface to support changing the SPI word length,
and implement it in omap3_spi driver to support the full range of
possible word lengths.
This implementation is backwards compatible by defaulting to the old
behavior of 8 bit word lengths.
Also, it required a change to the omap3_spi non static I/O functions,
but since they are not used anywhere else, no collateral changes are required.
Remove unnecessary semicolon from #define SPI_WAIT_TIMEOUT
Cc: Gerhard Sittig <gsi@denx.de>
Depending on the firmware's video options [1] the active SDTV or
HDTV mode can yield a framebuffer with noncontiguous horizontal lines,
giving a messed up display, for both, u-boot and the loaded kernel.
Fix this by setting lcd_line_length to the pitch value of the configured
framebuffer.
[1] http://elinux.org/RPiconfig#Video_mode_options
Signed-off-by: Andre Heider <a.heider@gmail.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Remove the redundant lcd_line_length initialisation which
sneaked in when an earlier version of the patch of commit
6d330719 has been rebased.
Some lcd drivers need to setup lcd_line_length not from the
panel_info parameters but by different means. Make the
lcd_get_size() weak to allow setting lcd_line_length in
a driver specific way.
Add the missing "right" field to struct bcm2835_mbox_tag_overscan.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
The MPC824x processors have long reached EOL, and the PN62 board has
not seen any board-specific updates for more than a decade. It is now
causing build issues. Instead of wasting time on things nobody is
interested in any more, we rather drop this board.
Cc: Wolfgang Grandegger <wg@grandegger.com>
cc: Tom Rini <trini@ti.com>
Commit 8dfafdde88eb3e71d5569846396ae67a91017232 introduced
new gcc warnings on MIPS64:
time.c: In function 'tick_to_time':
time.c:59:2: warning: comparison of distinct pointer types lacks a cast [enabled by default]
time.c:59:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default]
In file included from time.c:10:0:
./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *'
time.c: In function 'usec_to_tick':
time.c:76:2: warning: comparison of distinct pointer types lacks a cast [enabled by default]
time.c:76:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This patch replaces the GPL-2.0 text with a GPL-2.0
SPDX-License-Identifier tag, and adds Imagination Technologies copyright
following my recent changes.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
arch/arm/cpu/arm926ejs/mxs/Makefile
board/compulab/cm_t35/Makefile
board/corscience/tricorder/Makefile
board/ppcag/bg0900/Makefile
drivers/bootcount/Makefile
include/configs/omap4_common.h
include/configs/pdnb3.h
Makefile conflicts are due to additions/removals of
object files on the ARM branch vs KBuild introduction
on the main branch. Resolution consists in adjusting
the list of object files in the main branch version.
This also applies to two files which are not listed
as conflicting but had to be modified:
board/compulab/common/Makefile
board/udoo/Makefile
include/configs/omap4_common.h conflicts are due to
the OMAP4 conversion to ti_armv7_common.h on the ARM
side, and CONFIG_SYS_HZ removal on the main side.
Resolution is to convert as this icludes removal of
CONFIG_SYS_HZ.
include/configs/pdnb3.h is due to a removal on ARM side.
Trivial resolution is to remove the file.
Note: 'git show' will also list two files just because
they are new:
include/configs/am335x_igep0033.h
include/configs/omap3_igep00x0.h
The memsize environment variable must contain the
memory size in bytes on the Malta board. Otherwise
Linux will use wrong memory size which causes a kernel
panic.
Define CONFIG_MEMSIZE_IN_BYTES in malta.h to avoid
that.
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Paul Burton <paul.burton@imgtec.com>
This patch adds me as a maintainer of the malta(el) board(s). I have
access to physical Malta boards and the desire for U-boot to run well on
them.
This patch adds a script which may be used with MIPS Navigator Console
and a MIPS Nagivator Probe in order to flash U-boot to a MIPS Malta
development board.
Please see the newly added doc/README.malta for usage instructions.
Without setting up the PIRQ[A:D] interrupt routes, PCI interrupts will
be left disabled. Linux does not set up this routing but relies upon it
having been set up by the bootloader, reading back the IRQ lines which
the PIRQ[A:D] signals have been routed to.
This patch routes PIRQA & PIRQB to IRQ 10, and PIRQC & PIRQD to IRQ 11.
This matches the setup used by YAMON.
Allow the environment to be stored in the monitor flash of a Malta
board. The environment is stored in the final 128KB of the flash, which
both leaves the majority of the flash available for U-boot code and also
matches the location which YAMON uses.
This is actually required in order for a Linux kernel to boot
successfully on a physical Malta board. Without enabling the RTC, a
Malta Linux kernel will get stuck in its estimate_frequencies function
on boot.
Malta boards may be used with cores which support L2 caches, however
U-boot does not yet support L2 cache for MIPS. Thus for the moment we'll
disable L2 caches by setting the L2B bit in Config2. This is specific to
MTI/Imagination MIPS cores which is why this is done for the Malta board
rather than generically.
These will now be detected at runtime, allowing a single U-boot
configuration to function correctly with different bitstreams. Without
this you may need to re-configure, re-build and re-flash U-boot to your
Malta if you flash a new bitstream with a different cache configuration
to your old bitstream.
This model of the pcnet is used in current Malta boards, at least in the
Malta-R rev 3. Enable support for it.
The Malta also has the ethernet controller PROM containing its MAC
address, so enable support for that in order to read that MAC address.
DHCP is a very useful feature to have available for many networks,
enable support for it also.
Displaying a message on the LCD screen is a simple yet effective way to
show the user that the board has booted successfully.
This patch adds support for running on Malta boards using coreFPGA6
core cards, including support for the msc01 system controller used
with them. The system controller is detected at runtime allowing one
U-boot binary to run on a Malta with either.
Due to the PCI I/O base differing between Maltas using gt64120 & msc01
system controllers, the UART setup is modified slightly. A second UART
is added so that there is one pointing at the correct address for each
system controller. The Malta board then defines its own
default_serial_console function to select the correct one at runtime.
The incorrect UART will simply not function.
Tested on:
- A coreFPGA6 Malta running interAptiv and proAptiv bitstreams, both
with and without an L2 cache.
- QEMU.
On a real Malta the Super I/O needs to be configured before we are able
to access the UARTs. This patch performs that configuration, setting up
the UARTs in the same way that YAMON would.
