The board supports following features:
- Boot media support: SD card/e.MMC/SPI flash,
- Support LCD display (optional, disabled by default),
- Support ethernet,
- Support USB mass storage.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
[fix checkpatch warnings]
The PIO4 is introduced from SAMA5D2, as a new version
for Atmel PIO controller.
Use the correct function name in the function description.
Enabling the new tiny-printf function makes the SPL image fit again in
the 8KiB restricted area.
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
There are already Kconfig options for SPI drivers, but we
commit does this in a batch.
serial_init() reads global_data, since global_data is not yet
initialized, this can cause unwanted behaviour leading to QSPI XIP boot
hang. Also, since serial_init() is anyways called later from
boar_init_f(), it does not make sense to do the same in s_init().
Tested on AM437x IDK EVM with QSPI XIP boot.
Signed-off-by: Vignesh R <vigneshr@ti.com>
If the ext3 journal gets out of sync with what is written on disk, for
example because of an unexpected power cut, ext4fs_read_file can
return an all-zero directory entry. In that case, ext4fs_iterate_dir
would infinite loop.
This patch detects when a directory entry's direntlen member is 0 and
returns a failure status, which breaks out of the infinite loop. As a
result, U-Boot will not find files that may subsequently be recovered
when the journal is replayed.
This is better behaviour than hanging in an infinite loop, but as a
further improvement maybe U-Boot could interpret the ext3 journal and
actually find the unsynced entries.
Signed-off-by: Thomas Fitzsimmons <fitzsim@cisco.com>
The address range check may overflow if the memory region is located at
the top of the 32-bit address space. This can e.g. be seen on TK1 if
using the E1000 gigabit Ethernet driver where start and size are both
0x80000000 leading to the following messages:
Apalis TK1 # tftpboot $loadaddr test_file
Using e1000#0 device
TFTP from server 192.168.10.1; our IP address is 192.168.10.2
Filename 'test_file'.
Load address: 0x80408000
Loading: pci_hose_phys_to_bus: invalid physical address
This patch fixes this by changing the order of the addition vs.
subtraction in the range check just like already done in
__pci_hose_bus_to_phys().
Reported-by: Ivan Mercier <ivan.mercier@nexvision.fr>
The optional parameter bootable is added in gpt command to set the
partition attribute flag "Legacy BIOS bootable"
This flag is used in extlinux and so in with distro to select
the boot partition where is located the configuration file
(please check out doc/README.distro for details).
With this parameter, U-Boot can be used to create the boot partition
needed for device using distro.
example of use:
setenv partitions "name=u-boot,size=60MiB;name=boot,size=60Mib,bootable;\
name=rootfs,size=0"
> gpt write mmc 0 $partitions
> part list mmc 0
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00000022 0x0001e021 "u-boot"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
guid: cceb0b18-39cb-d547-9db7-03b405fa77d4
2 0x0001e022 0x0003c021 "boot"
attrs: 0x0000000000000004
guid: d4981a2b-0478-544e-9607-7fd3c651068d
3 0x0003c022 0x003a9fde "rootfs"
guid: 6d6c9a36-e919-264d-a9ee-bd00379686c7
> part list mmc 0 -bootable devplist
> printenv devplist
devplist=2
Then the distro scripts will search extlinux in partition 2
and not in the first partition.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
This commit adds support for "gpt verify" command, which verifies
correctness of on-board stored GPT partition table.
As the optional parameter one can provide '$partitons' environment variable
to check if partition data (size, offset, name) is correct.
This command should be regarded as complementary one to "gpt restore".
Signed-off-by: Lukasz Majewski <l.majewski@majess.pl>
Reviewed-by: Przemyslaw Marczak <p.marczak@samsung.com>
This commit provides definition and declaration of GPT verification
functions - namely gpt_verify_headers() and gpt_verify_partitions().
The former is used to only check CRC32 of GPT's header and PTEs.
The latter examines each partition entry and compare attributes such as:
name, start offset and size with ones provided at '$partitions' env
variable.
./doc/README.gpt entry has been updated to explain usage of "gpt verify"
command.
Exactly the same check is performed in set_gpt_info() function executed
just after this check.
With this patch now, the tiny printf() function also supports numbers
bigger than 0xffff. Additionally the code is simplified a bit and
some static variables are moved to function parameters. Also the
upper case hex variable output support is removed, as its not really
needed in this simple printf version. And removing it reduces the
complexity and the code size again a bit.
Here the new numbers, again on the db-mv784mp-gp (Armada XP):
Without this patch:
56542 18536 1956 77034 12cea ./spl/u-boot-spl
With this patch:
56446 18536 1936 76918 12c76 ./spl/u-boot-spl
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
This patch adds a small printf() version that supports all basic formats.
Its intented to be used in U-Boot SPL versions on platforms with very
limited internal RAM sizes.
To enable it, just define CONFIG_USE_TINY_PRINTF in your defconfig. This
will result in the SPL using this tiny function and the main U-Boot
still using the full-blown printf() function.
This code was copied from:
http://www.sparetimelabs.com/printfrevisited
With mostly only coding style related changes so that its checkpatch
clean.
The size reduction is about 2.5KiB. Here a comparison for the db-mv784mp-gp
(Marvell AXP) SPL:
Without this patch:
58963 18536 1928 79427 13643 ./spl/u-boot-spl
With this patch:
Note:
To make it possible to compile tiny-printf.c instead of vsprintf.c when
CONFIG_USE_TINY_PRINTF is defined, the functions printf() and vprintf() are
moved from common/console.c into vsprintf.c in this patch.
Change some comments to match the U-Boot coding style rules.
As done in commit da229e4e [sandbox: Drop special-case sandbox console code],
this patch drops the sandbox special-case code in vprintf() that was
missed by Simon at that time.
compiling U-Boot for avr32 boards shows since
commit 3d1957f0ea01 "dm: i2c: Add support for multiplexed I2C buses"
this warning:
Building current source for 4 boards (4 threads, 8 jobs per thread)
avr32: + atstk1002
+(atstk1002) drivers/i2c/built-in.o: warning: input is not relaxable
avr32: + grasshopper
+(grasshopper) drivers/i2c/built-in.o: warning: input is not relaxable
avr32: + atngw100
+(atngw100) drivers/i2c/built-in.o: warning: input is not relaxable
avr32: + atngw100mkii
+(atngw100mkii) drivers/i2c/built-in.o: warning: input is not relaxable
0 4 0 /4 0:00:16 : atngw100mkii
Fix it.
Reviewed-by: Roger Meier <r.meier@siemens.com>
Reviewed-by: Andreas Bießmann <andreas.devel@googlemail.com>
After introduction of CONFIG_SYS_NS16550 these defconfig files were
added and need to be updated.
The lamobo-r1 board, sometimes called the BPI-R1 but not labelled as such
on the PCB, is meant as a A20 based router board. As such the board comes
with a built-in switch chip giving it 5 gigabit ethernet ports, and it
has a large empty area on the pcb with mounting holes which will fit a
2.5 inch harddisk. To complete its networking features it has a
Realtek RTL8192CU for WiFi 802.11 b/g/n.
The dts file is identical to the one submitted upstream.
Signed-off-by: Jelle de Jong <jelledejong@powercraft.nl>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Add defconfig files for the Orangepi Plus and Orangepi PC.
These files are based on the current latest upstream kernel work. The
bus_gates bindings may still change, but for u-boot that does not matter
as we do not (yet) use any clock info from devicetree for sunxi u-boot.
The 3.4 kernel from the Allwinner SDK is clocking AHB1 at 200MHz
on Allwinner H3 and using PLL6 as the clock source (PLL6/3).
This can be verified by reading the value of the AHB1_APB1_CFG_REG
register via /dev/mem. It always reads as 0x3180 regardless of
the current cpufreq operating point. So this configuration should
be safe for use in U-Boot too.
PLL6 also needs to be configured before it is used as the clock
source, according to the "CCU / Programming Guidelines" section
of the Allwinner manual.
The current low AHB1 clock speed is limiting the USB transfer
speed when booting via FEL. This patch can increase the FEL USB
transfer speed from ~510 KB/s to ~950 KB/s.
Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Based on existing A23/A33 code and the original H3 boot0.
Signed-off-by: Jens Kuske <jenskuske@gmail.com>
Add initial sun8i H3 support, only uart + mmc are supported for now.
This is necessary to distinguish between the "dfu-util --detach" and
the "dfu-util --reset" requests.
The default weak implementation of dfu_usb_get_reset() unconditionally
reboots the device, but we want to be able to continue the boot.scr
execution after writing the kernel, fdt and ramdisk to RAM via DFU.
The DFU protocol implementation in U-Boot is much faster than the
FEL protocol implementation in the boot ROM on Allwinner devices.
Using DFU instead of FEL improves the USB transfer speed from
500-900 KB/s to 3.2-3.7 MB/s. This is particularly useful for
reducing the time needed for booting systems with large initrd
images.
FEL is still useful for loading the U-Boot bootloader and a boot
script, which may then activate DFU in the following way:
setenv dfu_alt_info ${dfu_alt_info_ram}
dfu 0 ram 0
bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r}
The rest of the files can be transferred to the device using the
"dfu-util" tool.
Add support for storing the environment in CFI NOR flash on Juno and FVP
models.
I also removed some config values that are not used by CFI flash parts.
Juno has 1 flash part with 259 sectors. The first 255 sectors are
0x40000 (256kb) and are followed by 4 sectors of 0x10000 (64KB).
FVP models simulate a 64MB NOR flash part at base address 0x0FFC0000.
This part has 256 x 256kb sectors. We use the last sector to store the
environment.
To save the NOR flash to a file, the following parameters should be
passed to the model:
-C bp.flashloader1.fname=${FILENAME}
-C bp.flashloader1.fnameWrite=${FILENAME}
Foundation models don't simulate the NOR flash, but having NOR support
in the u-boot binary does not harm: attempting to write to the NOR will
fail gracefully.
Signed-off-by: Ryan Harkin <ryan.harkin@linaro.org>
This patch allows vexpress64 targets to be compiled when
CONFIG_SYS_FLASH_CFI is enabled.
I considered using #warning instead of #error, but this just clutters up
the build output and hides real warnings.
Without this patch, you see errors during compilation like this:
include/configs/vexpress_aemv8a.h:42:2: error: #error "Unknown board
variant"
#error "Unknown board variant"
include/configs/vexpress_aemv8a.h:115:2: error: #error "Unknown board
variant"
include/configs/vexpress_aemv8a.h:280:2: error: #error "Unknown board
variant"
make[1]: *** [tools/envcrc.o] Error 1
make: *** [tools] Error 2
In file included from include/config.h:5:0,
from tools/envcrc.c:19:
This patch makes the 2nd DRAM bank available on Juno only and not on
other vexpress64 targets, eg. the FVP models.
The commit below added a 2nd bank of NOR flash for Juno, but also for
all vexpress64 targets:
commit 2d0cee1ca2b9d977fa3214896bb2e30cfec77059
Author: Liviu Dudau <Liviu.Dudau@foss.arm.com>
Date: Mon Oct 19 11:08:31 2015 +0100
vexpress64: Juno: Declare all 8GB of RAM and make them visible to the kernel.
Juno comes with 8GB RAM, but U-Boot only passes 2GB to the kernel.
Declare a secondary memory bank and set the sizes correctly.
Signed-off-by: Liviu Dudau <Liviu.Dudau@foss.arm.com>
Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org>
Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
Unfortunately, I only fully tested on Juno R0, R1 and the FVP Foundation
model. Whilst FVP Base AEMV8 models run U-Boot OK, they fail to boot
the kernel.
Acked-by: Liviu Dudau <liviu.dudau@foss.arm.com>
Only compile in PCIe support if the board really uses it. Provide
a __weak stub for the init function if e.g. FVP is being built.
On a Juno r1 the PCI controller init routine outputs the rather boring
ATR entry information.
Do this only with DEBUG defined to avoid cluttering the user's
terminal.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Ryan Harkin <ryan.harkin@linaro.org>
Cosmetic fixes to the file, make it checkpatch clean.
Add additional parameter into the eeprom command to select
the I2C bus on which the eeprom resides.
Add bus argument to eeprom_init(), so that it can select
the I2C bus number on which the eeprom resides. Any negative
value of the $bus argument will preserve the old behavior.
This is in place so that old code does not randomly break.
[trini: Wrap i2c_set_bus_num() call with CONFIG_SYS_I2C test]
Unify the code for doing read/write into single function, since the
code for both the read and write is almost identical. This again
trims down the code duplication.
Pull out the code which computes the length of the transfer
into separate code and clean it up a little. This again trims
Implement default value of 8 for this macro and pull out all of
this macro out of the code. The default value of 8 actually does
implement exactly the same behavior as the previous code which
was in the #else clause of the ifdef.
Just suck the ugly ifdef around eeprom_init() call into eeprom_init()
function itself. This puts all of the ifdef mess into one place.
Pull this macro to the beginning of the cmd_eeprom.c and remove
another nasty ifdef from the code. Note that this is legal, since
udelay(0) changes the behavior only such that it pings the WDT if
WDT is enabled and otherwise does not wait.
Make this function weak and implement it's weak implementation
so that the boards can just reimplement it. This zaps the horrid
CONFIG_SYS_EEPROM_WREN macro.
Pull out the code computing the EEPROM address into separate function
so that it's not duplicated.
Pull out the code which does the I2C or SPI read/write, so that
the beefy ifdef around it is contained in a single function.
This macro is no longer used, so just reap it.
Remove this function as it's no longer used.
Now that the only user of CONFIG_SYS_EEPROM_X40430 was removed,
remove this unused code from cmd_eeprom.c
