Scan Manager driver will be called to configure the IOCSR
scan chain. This configuration will setup the IO buffer settings
Signed-off-by: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@altera.com>
CC: Pavel Machek <pavel@denx.de>
Cc: Tom Rini <trini@ti.com>
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
To enable the DesignWare watchdog support at SOCFPGA
Cyclone V dev kit.
To add the DesignWare watchdog driver support. It required
information such as register base address and clock info from
configuration header file within include/configs folder.
This patch returns back support for old ep93xx processors family
Signed-off-by: Sergey Kostanbaev <sergey.kostanbaev@gmail.com>
Cc: albert.u.boot@aribaud.net
In current gpio_set_value() implementation, it always sets the gpio control bit
no matter the value argument is 0 or 1. Thus the GPIOs never set to low.
This patch fixes this bug.
The address bus is used as a mask on read/write operations, so that independent
software drivers can set their GPIO bits without affecting any other pins in a
single write operation. Thus we don't need a read-modify-write to update the
register.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Reviewed-by: Vipin Kumar <vipin.kumar@st.com>
Reviewed-by: Michael Trimarchi <michael@amarulasolutions.com>
This is not only more readable but also prevents a warning
about a missing prototype. The prototypes which are actually
missing are added.
cc: Albert Aribaud <albert.u.boot@aribaud.net>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
Reviewed-by: Tom Rini <trini@ti.com>
LS2085A is an ARMv8 implementation. This adds board support for emulator
and simulator:
Two DDR controllers
UART2 is used as the console
IFC timing is tightened for speedy booting
Support DDR3 and DDR4 as separated targets
Management Complex (MC) is enabled
Support for GIC 500 (based on GICv3 arch)
Signed-off-by: York Sun <yorksun@freescale.com>
Signed-off-by: Arnab Basu <arnab.basu@freescale.com>
Signed-off-by: J. German Rivera <German.Rivera@freescale.com>
Signed-off-by: Bhupesh Sharma <bhupesh.sharma@freescale.com>
Adding support to load and start the Layerscape Management Complex (MC)
firmware. First, the MC GCR register is set to 0 to reset all cores. MC
firmware and DPL images are copied from their location in NOR flash to
DDR. MC registers are updated with the location of these images.
Deasserting the reset bit of MC GCR register releases core 0 to run.
Core 1 will be released by MC firmware. Stop bits are not touched for
this step. U-boot waits for MC until it boots up. In case of a failure,
device tree is updated accordingly. The MC firmware image uses FIT format.
Signed-off-by: Lijun Pan <Lijun.Pan@freescale.com>
Signed-off-by: Shruti Kanetkar <Shruti@Freescale.com>
Freescale LayerScape with Chassis Generation 3 is a set of SoCs with
ARMv8 cores and 3rd generation of Chassis. We use different MMU setup
to support memory map and cache attribute for these SoCs. MMU and cache
are enabled very early to bootst performance, especially for early
development on emulators. After u-boot relocates to DDR, a new MMU
table with QBMan cache access is created in DDR. SMMU pagesize is set
in SMMU_sACR register. Both DDR3 and DDR4 are supported.
Signed-off-by: Varun Sethi <Varun.Sethi@freescale.com>
Make MMU function reusable. Platform code can setup its own MMU tables.
CC: David Feng <fenghua@phytium.com.cn>
This is needed for accessing peripherals with 64-bit MMIO registers,
from ARMv8 processors.
The armv8 ARM Trusted Firmware (ATF) can be used to load various ATF
images and u-boot, and does this for virtual platforms by using
semihosting. This commit extends this idea by allowing u-boot to also
use semihosting to load the kernel/ramdisk/dtb. This eliminates the need
for a bootwrapper and produces a more realistic boot sequence with
virtual models.
Though the semihosting code is quite generic, support for armv7 in
fastmodel is less useful due to the wide range of available silicon
and the lack of a free armv7 fastmodel, so this change contains an
untested armv7 placeholder for the service trap opcode.
Please refer to doc/README.semihosting for a more detailed description
of semihosting and how it is used with the armv8 virtual platforms.
Signed-off-by: Darwin Rambo <drambo@broadcom.com>
Cc: trini@ti.com
Cc: fenghua@phytium.com.cn
Cc: bhupesh.sharma@freescale.com
Since tegra_i2c_{read,write}'s debug() call dumps the chip address, dump
the address length (alen) too, so the address value can be correctly
interpreted.
Reviewed-by: Yen Lin <yelin@nvidia.com>
The Tegra I2C controller's TX FIFO contains 32-bit words. If the final
FIFO entry of a transaction contains fewer than 4 bytes, the driver
currently fills the unused FIFO bytes with uninitialized data. This can
be confusing when reading back the FIFO content for debugging purposes.
Solve this by explicitly initializing the variable containing FIFO data
before filling it (partially) with data. With this change,
send_recv_packets()'s loop's if (is_write) code mirrors the else (i.e.
read) branch.
I2C read transactions are typically implemented as follows:
START(write) address REPEATED_START(read) data... STOP
However, Tegra's I2C driver currently implements reads as follows:
START(write) address STOP START(read) data... STOP
This sequence confuses at least the AS3722 PMIC on the Jetson TK1 board,
leading to corrupted read data in some cases. Fix the driver to chain
the transactions together using repeated starts to solve this.
Almost all of ci_udc.c uses variable name "ep" for a struct usb_ep and
"ci_ep" for a struct ci_ep. This is nice and consistent, and helps people
know what type a variable is without searching for the declaration.
handle_ep_complete() doesn't do this, so fix it to be consistent.
A UDC's alloc_request method should zero out the newly allocated request.
Ensure the Atmel driver does so. This issue was found by code inspection,
following the investigation of an intermittent issue with ci_udc, which
was tracked down to failing to zero out allocated requests following some
of my changes. All other UDC drivers already zero out requests in one
way or another.
struct ci_req is a purely software structure, and needs no specific
memory alignment. Hence, allocate it with calloc() rather than
memalign(). The use of memalign() was left-over from when struct ci_req
was going to hold the aligned bounce buffer, but this is now dynamically
allocated.
There's no need to store an array of QTD pointers in the controller.
Since the calculation is so simple, just have ci_get_qtd() perform it
at run-time, rather than pre-calculating everything.
2 QTDs are allocated for each EP. The current allocation scheme aligns
the first QTD in each pair, but simply adds the struct size to calculate
the second QTD's address. This will result in a non-cache-aligned
addresss IF the system's ARCH_DMA_MINALIGN is not 32 bytes (i.e. the
size of struct ept_queue_item).
Similarly, the original ilist_ent_sz calculation aligned the value to
ARCH_DMA_MINALIGN but didn't take the USB HW's 32-byte alignment
requirement into account. This doesn't cause a practical issue unless
ARCH_DMA_MINALIGN < 32 (which I suspect is quite unlikely), but we may
as well fix the code to be explicit, so it's obviously completely
correct.
The new value of ILIST_ENT_SZ takes all alignment requirements into
account, so we can simplify ci_{flush,invalidate}_qtd() by simply using
that macro rather than calling roundup().
Similarly, the calculation of controller.items[i] can be simplified,
since each QTD is evenly spaced at its individual alignment requirement,
rather than each pair being aligned, and entries within the pair being
spaced apart only by structure size.
This will allow functions other than ci_udc_probe() to make use of the
constants in a future change.
This in turn requires converting the const int variables to #defines,
since the initialization of one global const int can't depend on the
value of another const int; the compiler thinks it's non-constant if
that dependency exists.
Fix ci_ep_submit_next_request()'s ZLP transmission code to explicitly
call ci_get_qtd() to find the address of the other QTD to use. This
will allow us to correctly align each QTD individually in the future,
which may involve leaving a gap between the QTDs.
ci_udc_probe() initializes a pair of QHs and QTDs for each EP. After
each pair has been initialized, the pair is cache-flushed. The
conversion from QH/QTD index [0..2*NUM_END_POINTS) to EP index
[0..NUM_ENDPOINTS] is incorrect; it simply subtracts 1 (which yields
the QH/QTD index of the first entry in the pair) rather than dividing
by two (which scales the range). Fix this.
On my system, this avoids cache debug prints due to requests to flush
unaligned ranges. This is caused because the flush calls happen before
the items[] array entries are initialized for all but EP0.
boards.cfg
Conflict was trivial between goni maintainer change and
lager_nor removal.
Robert Baldyga will now take care of this board.
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
With CONFIG_SYS_GENERIC_BOARD the board hangs after issuing a 'save' command.
Remove CONFIG_SYS_GENERIC_BOARD until this issue can be fixed properly.
When dfu_init_env_entities() fails part-way through, some entities may
have been added to dfu_list. These are only removed by dfu_free_entities().
If that function isn't called, those stale entities will still exist the
next time dfu_init_env_entities() is called, leading to confusion. Fix
do_dfu() to ensure that dfu_free_entities() is always called, to avoid
this confusion.
Tested-by: Lukasz Majewski <l.majewski@samsung.com>
Add LAN9500A product ID (0x9e00) in order to support LAN9500A based dongles.
Tested on cm_t335.
Signed-off-by: Ilya Ledvich <ilya@compulab.co.il>
cb_getvar tries to prevent overflowing the response buffer
by using strncat. But strncat takes the number of data bytes
copied as a limit not the total buffer length so it can still
overflow. Pass the correct value instead.
cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
cc: Rob Herring <robh@kernel.org>
Because of the brackets the & and && is evaluated before
the comparison. This is likely not the intention. Change
it to test the first and second condition to both be true.
cc: Marek Vasut <marex@denx.de>
since ALLOC_CACHE_ALIGN_BUFFER defines a pointer and not a
buffer, the memset with sizeof(rqt) likely does something else
then intended. Since there is a memcpy directly after it with
the full size, drop the memset completely.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Since the struct fsg_common is calloced, reset it completely
with zero's when reused. While at it, make checkpatch happy.
cc: Lukasz Majewski <l.majewski@samsung.com>
cc: Piotr Wilczek <p.wilczek@samsung.com>
cc: Kyungmin Park <kyungmin.park@samsung.com>
cc: Marek Vasut <marek.vasut@gmail.com>
Initialization of r8a66597 info structure is not enough.
Because initilization was used size of pointer.
This fixes that use size of r8a6659 info structure.
Signed-off-by: Yasuhisa Umano <yasuhisa.umano.zc@renesas.com>
This driver is processed as two USB hub despite one.
The number of root hub is defined in R8A66597_MAX_ROOT_HUB.
This fixes that register is accessed by using the definition
of R8A66597_MAX_ROOT_HUB.
For plain array const can be either before or after
the type definition. Adding both is simply redundand.
Remove the later one.
cc: marex@denx.de
s/ot/to/
ci_udc.c's usb_gadget_unregister_driver() doesn't call driver->unbind()
unlike other USB gadget drivers. Fix it to do this.
Without this, when ether.c's CDC Ethernet device is torn down,
eth_unbind() is never called, so dev->gadget is never set to NULL.
For some reason, usb_eth_halt() is called both at the end of the first
use of the Ethernet device, and prior to any subsequent use. Since
dev->gadget is never cleared, all calls to usb_eth_halt() attempt to
stop, disconnect, and clean up the device, resulting in double cleanup,
which hangs U-Boot on my Tegra device at least.
ci_udc allocates its own singleton EP0 request object, and cleans it up
during usb_gadget_unregister_driver(). This appears necessary when using
the USB gadget framework in U-Boot, since that does not allocate/free
the EP0 request. However, the CDC Ethernet driver *does* allocate and
free its own EP0 requests. Consequently, we must protect
ci_ep_free_request() against double-freeing the request.
commit 67a04ab3ab8522a3a34491853e46105317580df5
fix the build for MX25. The same error
happens for VF610 SOC.
local_irq_save() should be a macro, not a function
because local_irq_save() saves flag to the given argument.
GCC is silent about this issue, but Clang warns:
In file included from lib/asm-offsets.c:15:
In file included from include/common.h:20:
In file included from include/linux/bitops.h:110:
arch/sandbox/include/asm/bitops.h:59:17:
warning: variable 'flags' is uninitialized when used here
[-Wuninitialized]
local_irq_save(flags);
That change causes another warning:
In file included from include/linux/bitops.h:110:0,
from include/common.h:20,
arch/sandbox/include/asm/bitops.h: In function ‘test_and_set_bit’:
arch/sandbox/include/asm/bitops.h:56:16: warning: unused variable ‘flags’ [-Wunused-variable]
So, flags should be set to __always_unused.
Cc: Jeroen Hofstee <jeroen@myspectrum.nl>
Acked-by: Jeroen Hofstee <jeroen@myspectrum.nl>
