- add support for Logotronic DL datalogger board
- cleanup serial line after kermit binary download
- add debugX macro (debug level support)
- update mach-types.h to latest arm.linux.org.uk master list.
- rewrite of the S3C24X0 register definitions stuff
- "driver" for the built-in S3C24X0 RTC
* Patches by Yuli Barcohen, 12 Jun 2003:
- Add MII support and Ethernet PHY initialization for MPC8260ADS board
- Fix incorrect SIUMCR initialisation caused by wrong Hard Reset
configuration word supplied by FPGA on some MPC8260ADS boards
* Patch by Pantelis Antoniou, 10 Jun 2003:
Unify status LED interface
Modifications for Atmel AT91RM9200DK ARM920T based development kit
- Add Atmel DataFlash support for reading and writing.
- Add possibility to boot a Linux from DataFlash with BOOTM command.
- Add Flash detection on Atmel AT91RM9200DK
(between Atmel AT49BV1614 and AT49BV1614A flashes)
- Replace old Ethernet PHY layer functions
- Change link address
* Patch by Frank Smith, 9 Jun 2003:
use CRIT_EXCEPTION for machine check on 4xx
* Patch by Detlev Zundel, 13 Jun 2003:
added implementation of the "carinfo" command in cmd_immap.c
* Patches by Kyle Harris, 13 Mar 2003:
- Add FAT partition support
- Add command support for FAT
- Add command support for MMC
- Add Intel PXA support for video
- Add Intel PXA support for MMC
- Enable MMC and FAT for lubbock board
- Other misc changes for lubbock board
fix for SMSC91111 driver
make ppc405 ethernet driver compatible with CONFIG_NET_MULTI option
* Add support for TQM862L at 100/50 MHz
* Patch by Pantelis Antoniou, 02 Jun 2003:
major reconstruction of networking code;
add "ping" support (outgoing only!)
(tschaefer@giga-stream.de). Now inital stack in data cache can be used even if the chip select is in use.
add support for the MIP405T board
- Added support for custom keyboards, initialized by defining a
board-specific drv_keyboard_init as well as defining CONFIG_KEYBOARD .
- Added support for the RBC823 board.
- cpu/mpc8xx/lcd.c now automatically calculates the
Horizontal Pixel Count field.
* Fix alignment problem in BOOTP (dhcp_leasetime option)
[pointed out by Nicolas Lacressonnière, 2 Jun 2003]
* Patch by Mark Rakes, 14 May 2003:
add support for Intel e1000 gig cards.
* Patch by Nye Liu, 3 Jun 2003:
fix critical typo in MAMR definition (include/mpc8xx.h)
* Fix requirement to align U-Boot image on 16 kB boundaries on PPC.
* Patch by Klaus Heydeck, 2 Jun 2003
Minor changes for KUP4K configuration
Fixed rarp boot method for IA32 and other little-endian CPUs.
* Patch by Marc Singer, 28 May 2003:
Added port I/O commands.
* Patch by Matthew McClintock, 28 May 2003
- cpu/mpc824x/start.S: fix relocation code when booting from RAM
- minor patches for utx8245
* Patch by Daniel Engström, 28 May 2003:
x86 update
* Patch by Dave Ellis, 9 May 2003 + 27 May 2003:
add nand flash support to SXNI855T configuration
fix/extend nand flash support:
- fix 'nand erase' command so does not erase bad blocks
- fix 'nand write' command so does not write to bad blocks
- fix nand_probe() so handles no flash detected properly
- add doc/README.nand
- add .jffs2 and .oob options to nand read/write
- add 'nand bad' command to list bad blocks
- add 'clean' option to 'nand erase' to write JFFS2 clean markers
- make NAND read/write faster
* Patch by Rune Torgersen, 23 May 2003:
Update for MPC8266ADS board
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
* Fix alignment problems with flash driver for TRAB board
* Patch by Donald White, 21 May 2003:
fix calculation of base address in pci_hose_config_device()
* Fix bug in command line parsing: "cmd1;cmd2" is supposed to always
execute "cmd2", even if "cmd1" fails. Note that this is different
to "run var1 var2" where the contents of "var2" will NOT be
executed when a command in "var1" fails.
In preparation for an ixp port, rename cpu/xscale and arch-xscale
into cpu/pxa and arch-pxa.
- CPCI4052 added (PPC405GP based).
- CPCI405AB added (PPC405GP based).
- PCI405 added (PPC405GP based).
- PMC405 added (PPC405GP based).
- BUBINGA405EP added (PPC405EP based).
add support for the MIP405-3 board
- CONFIG_UART1_CONSOLE added (see README).
- "nand_init" (NAND FLASH) added.
Fix problem with only partially cleared .bss segment
* Patch by Rune Torgersen, 12 May 2003:
get PCI to work on a MPC8266ADS board; incorporate change to
cpu/mpc8260/pci.c to enable overrides of PCI memory parameters
allow to pass boot bitmap addresses in environment variables;
allow for zero boot delay
* Patch by Christian Geißinger, 19 May 2002:
On TRAB: wait until the dummy byte has been completely sent
update for CrayL1 board
* Patch by Pantelis Antoniou, 21 Apr 2003:
add boot support for ARTOS (a proprietary OS)
* Patch by Steven Scholz, 11 Apr 2003:
Add support for RTC DS1338
* Patch by Rod Boyce, 24 Jan 2003:
Fix counting of extended partitions in diskboot command
allow the use of CFG_LOADS when CFG_NO_FLASH is set
(includes support for Intel 82365 and compatible PC Card controllers,
and Yenta-compatible PCI-to-CardBus controllers)
Add lan91c96 driver (tested on Lubbock and custom PXA250 board only)
