This adds ethernet driver for Calxeda xgmac found on Highbank SOC.
Fix: WARNING: __aligned(size) is preferred over
__attribute__((aligned(size)))
Also, fix some comments (minor)
Signed-off-by: David Wagner <david.wagner@free-electrons.com>
After susccessful write to the FAT partition,
fsck program may print warning message due to different FAT,
provided that the filesystem supports two FATs.
This patch makes the second FAT to be same with the first one
when writing a file.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
When performing large bulk reads from a CD or DVD using the U-Boot
usb_storage driver, it generates requests of up to 20 blocks at a time.
With a standard 512-byte block size, that is 10240 bytes and within the
limit of U-Boot's EHCI driver (maximum 5 pages at 4k per page).
Unfortunately CD-ROM media has a 2048-byte blocksize, resulting in a
maximum transfer size of 40960 bytes, which does not fit.
Since the EHCI specification is impossibly obtuse and far beyond my
comprehension, I chose to dynamically compute the limit based on the
blocksize.
Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com>
The FAT filesystem fails silently in inexplicable ways when given a
filesystem with a block-size that does not match the device sector size.
In theory this is not an unsupportable combination but requires a major
rewrite of a lot of the filesystem. Until that occurs, the filesystem
should detect that scenario and display a helpful error message.
This scenario in particular occurred on a 512-byte blocksize FAT fs
stored in an El-Torito boot volume on a CD-ROM (2048-byte sector size).
Additionally, in many circumstances the ->block_read method will not
return a negative number to indicate an error but instead return 0 to
indicate the number of blocks successfully read (IE: None).
The FAT filesystem should defensively check to ensure that it got all of
the sectors that it asked for when reading.
The FAT filesystem code currently ends up requiring that the partition
table be a DOS MBR, as it checks for the DOS 0x55 0xAA signature on the
partition table (which may be Mac, EFI, ISO9660, etc) before actually
computing the partition offset.
This fixes support for accessing a FAT filesystem in an ISO9660 boot
volume (El-Torito format) by reordering the filesystem checks and
reading the 0x55 0xAA "DOS boot signature" and FAT/FAT32 magic number
from the first sector of the partition instead of from sector 0.
Fix build warning: fat.c: In function 'fat_register_device':
fat.c:66:15: warning: variable 'found_partition' set but not used
[-Wunused-but-set-variable]
Make ext2 use cache line aligned buffers for reading from the filesystem.
This is needed when caches are enabled because unaligned cache invalidates
are not safe.
This patch allows the U-Boot user space companion utility, fw_setenv,
to overwrite the 'ethaddr' key/value pair if the current value is set
to a per-board-configured default.
This change allows 'fw_setenv' to match the behavior of 'setenv' /
'env set' on the U-Boot command line.
Signed-off-by: Grant Erickson <marathon96@gmail.com>
Fixed excessive white space.
* 'master' of git://git.denx.de/u-boot-arm:
tegra2: Optimize out-of-tree build for Ventana.
tegra: Move boards over to use arch-level board UART function
tegra: Add support for UART init in cpu board.c
tegra: Add a function mux feature
tegra: add clock_ll_start_uart() to enable UART prior to reloc
tegra: Move clock_early_init() to arch_cpu_init()
tegra: Move cpu_init_cp15() to arch_cpu_init()
arm: Tegra: Fix Harmony and Ventana builds in u-boot-tegra/master
tegra: Fix build error in plutux, medcom
tegra2: Add Avionic Design Medcom support.
tegra2: Add Avionic Design Plutux support.
tegra2: Add common Avionic Design Tamonten support.
tegra2: Move tegra2_mmc_init() prototype to public header.
tegra2: Change CONFIG_SYS_TEXT_BASE to 0x00108000.
tegra2: Always build with USE_PRIVATE_LIBGCC=yes.
tegra2: Plumb in SPI/UART switch code
tegra2: spi: Support SPI / UART switch
tegra2: Implement SPI / UART GPIO switch
tegra2: Enable SPI environment on Seaboard
tegra2: config: Enable SPI flash on Seaboard
tegra2: spi: Add SPI driver for Tegra2 SOC
tegra2: Add UARTB support
tegra2: Tidy UART selection
arm, davinci: Fix build warnings for cam_enc_4xx
Devkit8000: Switch over to enable_gpmc_cs_config
arm, davinci: Add support for generating AIS images to the Makefile
mkimage: Fix variable length header support
arm, da850evm: Add an SPL for SPI boot
arm, davinci: Add SPL support for DA850 SoCs
sf: Add spi_boot() to allow booting from SPI flash in an SPL
spl: display_options.o is required for SPI flash support in SPL
ARM: omap3: add support to Technexion twister board
ARM: omap3: added common configuration for Technexion TAM3517
vision2: Fix checkpatch warning
With bfcc40bb09b05c90cc3b1496abb270eb8aa72134 'optopt' was reverted.
Signed-off-by: Horst Kronstorfer <hkronsto@frequentis.com>
Several boolean defines have a value assigned.
Remove the value as defining the symbol is enough.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
env_get_char_spec() function is duplicated across multiple environment
files.
Remove the duplication by providing a default implementation.
Add "weak" declaration, so the default implementation can be overridden.
CONFIG_SYS_FPGA_PROG_FEEDBACK was already introduced to print
the current status of FPGA loading - an undef in the code made this
CONFIG_ useless.
Replace also __FUNCTION__ with standard __func__
This trivial change removes a compilation warning:
----8<----
phy.c: In function 'phy_init':
phy.c:448:2: warning: implicit declaration of function 'phy_smsc_init'
----8<----
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
The README file lists 4 defined that were not actually present in the .h
file but that were needed to get things working with settings compiled in.
They are
Added these to the .h file
(the values above are the ones from the README file)
Signed-off-by: Frans Meulenbroeks <fransmeulenbroeks@gmail.com>
The VFAT short alias checksum read from a long file name is only overwritten
when another long file name appears in a directory list. Until then it renders
short file names invisible that have the same checksum. Reset the checksum on
first match.
Signed-off-by: Martin Mueller <martin.mueller5@de.bosch.com>
Adding a 'ti' alias since not all parts are "omap" or "davinci" and
adding myself to that alias as co-custodian of u-boot-ti
As proposed by Mike Frysinger, mkdir can take more than one argument.
Instead of spawning two processes, create both the common and seaboard
directories in one go.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Signed-off-by: Tom Warren <twarren@nvidia.com>
Now that we can set up the UART in common tegra code, make the boards
use it.
We add a way of initialising the selected of UARTs prior to relocation.
Boards can use the board_init_uart_f() instead of repeating this code
themselves.
funcmux permits selection of config options for particular peripherals,
such as the pins that are used for that peripheral, if there are several
options.
Add UART selection to start with.
Most boards will want to enable a UART early. This function provides
that feature in Tegra architecture code so the code does not need to be
copied on every board.
The clock init is not board specific, so move it into
the cpu code.
This call is more of an architecture requirement than a board
one, so move it there.
Seaboard changes have removed the need for common/board.o in the
Makefile. Propagate this change to the other Tegra2 builds.
We need to define CONFIG_ENV_IS_NOWHERE to avoid this error:
cmd_nvedit.c:69:3: error: #error Define one of CONFIG_ENV_IS_IN_...
The Medcom is a 16:9 15" terminal that is used for patient infotainment
in hospitals.
Changes in v3:
* Remove unused implementation of gpio_config_uart().
* Implement MMC/SD card detection.
* Drop board_mmc_getcd() which is now implemented by common Tegra2
code.
* Add MAINTAINERS entry.
Changes in v2:
* No longer override the default CONFIG_SYS_TEXT_BASE setting.
The Plutux is a set-top box device based on the Tamonten processor
module. It can be connected to a display via an HDMI output.
Changes in v3:
code.
Changes in v2:
Tamonten is an NVIDIA Tegra2-based SO-DIMM processor module that is
derived from the Harmony reference design.
Changes in v3:
* Remove unused gpio_config_uart().
* Remove call to tegra2_start().
* Use new tegra2_mmc_init().
tegra2_mmc_init() is implemented by the Tegra2 MMC driver. Since most of
the Tegra2-based boards will need to call it, this commit exports it in
the new public asm/arch/mmc.h header file to prevent each board from
providing its own prototype.
NVIDIA's flashing tools assume that the bootloader is loaded at address
0x00108000. Instead of requiring non-standard builds of those tools
which allow a load address of 0x00E08000, this commit just switches all
Tegra2 boards to use the standard load address.
The AVP on Tegra2 doesn't boot properly when U-Boot is linked against
the GCC provided libgcc. To work around this, always build and link
against a private libgcc for Tegra2-based boards.
On Seaboard the UART and SPI interfere with each other. This causes the UART
to receive spurious zero bytes after SPI transactions and also means that
SPI can corrupt a few output characters when it starts up if they are still
in the UART buffer.
This updates the board to use the SPI/UART switch to avoid the problem.
For now this feature is turned off since it needs changes to the NS16550
UART to operate.
Add the SPI / UART switch logic into the Tegra2 SPI driver so that it
can co-exist with the NS16550 UART.
We need the ns16550.h header for NS16550_t for now.
The Tegra2 Seaboard has the unfortunate feature that SPI and the console
UART are multiplexed on the same pins. We need to switch between one
and the other during SPI and console activity.
This new file implements a switch and keeps track of which peripheral
owns the pins. It also flips over the controlling GPIO as needed
Since we are adding a second file to board/nvidia/common, we create
a proper Makefile there and remove the direct board.o include from
board/nvidia/seaboard/Makefile
This uses the SPI flash on Seaboard to store an 8KB environment.
The Seaboard includes a Winbond 4MB flash part.
This driver supports SPI on Tegra2, running at 48MHz.
UARTB is used on some boards, so support it here.
UART selection is done with a lot of #ifdefs. This cleans things up
a little.
This patch fixes a build warning for the cam_enc_4xx board introduced by
commit d6ec0c0dfc70447cf615ae80a952da81f73f16b4:
spl.c:35:13: warning: 'gdata' defined but not used
spl.c:36:13: warning: 'bdata' defined but not used
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Tom Rini <trini@ti.com>
Use enable_gpmc_cs_config instead of local writing
timing configuration for GPMC.
Signed-off-by: Thomas Weber <weber@corscience.de>
Cc: Mike Frysinger <vapier@gentoo.org>
Support for variable length images like AIS image was introduced
in commit f0662105b674a3874227316abf8536bebc9b5995. A parameter
"-s" was also introduced to prohibit copying of the image file
automatically in the main program. However, this parameter
was implemented incorrectly and the image file was copied
nevertheless.
Cc: Sandeep Paulraj <s-paulraj@ti.com>
Cc: Sudhakar Rajashekhara <sudhakar.raj@ti.com>
This code adds an SPL for booting from SPI flash on DA850 SoCs.
Acked-by: Tom Rini <trini@ti.com>
Cc: Scott Wood <scottwood@freescale.com>
