This commit also deletes post/rules.mk,
which in not necessary any more.
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Andreas Bießmann <andreas.devel@googlemail.com>
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Vipin Kumar <vipin.kumar@st.com>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Tom Rini <trini@ti.com>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Macpaul Lin <macpaul@gmail.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Before this commit, arch/sparc/lib/Makefile used
both COBJS and COBJS-y.
And it missed to add COBJS-y into OBJS.
This means bootm.o was never compiled even if
CONFIG_CMD_BOOTM=y
This patch moves S5PC, EXYNOS specific directory entries
from the toplevel Makefile to arch/arm/cpu/armv7/Makefile
using Kbuild descending feature.
This patch moves OMAP specific directory entries
from the toplevel Makefile and spl/Makefile
to arch/arm/cpu/armv7/Makefile using Kbuild descending feature.
This patch moves Tegra specific directory entries
to arch/arm/cpu/*/Makefile using Kbuild descending feature.
Cc: Tom Warren <TWarren@nvidia.com>
This commit moves some subdirectories of fs
from the toplevel Makefile to fs/Makefile
This commit moves some drivers subdirectory entry
from the toplevel Makefile to drivers/Makefile
This patch tweaks scripts/Makefile.build to allow
the build system to descend into subdirectories like Kbuild.
To use this feature, use "obj-y += foo/" syntax.
Example:
obj-$(CONFIG_FOO) += foo/
Note:
arch/powerpc/cpu/mpc8260/Makefile is originally like follows:
---<snip>---
START = start.o kgdb.o
COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \
---<snip>---
COBJS-$(CONFIG_ETHER_ON_SCC) = ether_scc.o
---<snip>---
$(LIB): $(OBJS)
$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)
The link rule `$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)'
is weird.
kbdg.o is not included in $(OBJS) but linked into $(LIB)
and $(LIB) is not dependent on kgdb.o.
(Broken dependency tracking)
So,
shoud have been
START = start.o
SOBJS = kgdb.o
That is why this commit adds kgdb.o to obj-y, not to extra-y.
Multiple targets are included in arch/arm/imx-common/Makefile
In order to refactor it,
we need to tweak Makefile and spl/Makefile.
Note1:
In arch/arm/cpu/arm926ejs/spear/Makefile
START := start.o
was changed
extra-$(CONFIG_SPL_BUILD) := start.o
because spear/start.o is only used for SPL.
Note2:
START := start.o
was missing from arch/arm/cpu/arm926ejs/mxs/Makefile.
This commit simply adds
Every makefile in sub directories has common lines
at the top and the bottom.
This commit pushes the common parts into script/Makefile.build.
Going forward sub-makefiles only need to describe this part:
COBJS := ...
COBJS += ...
SOBJS := ...
But using obj-y is preferable to prepare for switching to Kbuild.
The conventional (non-Kbuild) Makefile style is still supported.
This is achieved by greping the Makefile before entering into it.
U-Boot conventional sub makefiles always include some other makefiles.
So the build system searches a line beginning with "include" keyword
in the makefile in order to distinguish which style it is.
If the Makefile include a "include" line, we assume it is a conventional
U-Boot style. Otherwise, it is treated as a Kbuild-style makefile.
With this tweak, we can switch sub-makefiles
from U-Boot style to Kbuild style little by little.
obj-y := foo/
syntax (descending into the sub directory) is not supportd yet.
It will be implemented in the upcomming commit.
Prior to SPDX licensing this file was GPL-2.0 with Freescale granting
rights for "or later" for their contributed code. We incorrectly moved
this file to GPL-2.0+, so correct it to GPL-2.0. In addition we cannot
easily denote in the file where or what code is "or later", so just set
that aside for now and the file as a whole is GPL-2.0 regardless.
Cc: Scott Wood <scottwood@freescale.com>
T4240QDS eSDHC host capabilities reigster should have VS33 bit define.
Add quirk CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 to deal with capacity
missing
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Signed-off-by: Haijun Zhang <Haijun.Zhang@freescale.com>
Acked-by: Pantelis Antoniou <panto@antoniou-consulting.com>
struct mmc should be clear to all '0' after malloc to avoid
unexpect variable value.
Like mmc->has_init = xxx.
In this case mmcinfo will believe the card had been initialized before
and skip the initialization.
Test on P5040 and T4240,
Error Log:
=> mmcinfo
Device: FSL_SDHC
Manufacturer ID: 0
OEM: 0
Name: Tran Speed: 0
Rd Block Len: 0
MMC version 0.0
High Capacity: No
Capacity: 0 Bytes
Bus Width: 0-bit
Signed-off-by: Xie Shaohui-B21989 <B21989@freescale.com>
Tested-by: Ryan Barnett <rjbarnet@rockwellcollins.com>
Add some descriptions for esdhc register for easily using.
Signed-off-by: Haijun Zhang <haijun.zhang@freescale.com>
eSDHC host controller has new register to support SD Spec 3.0.
And the according host controller version was Freescale eSDHC
Version 3.0.
SMDK5420 has a new Security Management Unit added
for dwmmc driver, hence, configuring the control
registers to support booting via eMMC.
Signed-off-by: Alim Akhtar <alim.akhtar@samsung.com>
Signed-off-by: Rajeshwari Shinde <rajeshwari.s@samsung.com>
Acked-by: Jaehoon Chung <jh80.chung@samsung.com>
Old command timeout value was too small and it caused I/O errors which
led to uncompleted read/write/erase operations and filesystem errors.
Timeout adaptation fixes this issue.
Changes in sdhci_send_command() function:
- change timeout variable to static
- increase default command timeout to 100 ms
- add definition of max command timeout value,
which can be redefined in each board config file
- wait for card ready state for max defined time
if it doesn't exceed defined maximum or return COMM_ERR
Once successfully increased timeout value will be used in next function
call. This fix was tested on Goni, Trats, Trats2 boards by testing UMS
on MMC storage.
Changes v2:
- move global variable cmd_timeout into function sdhci_send_command()
- change condition "==" to ">=" when comparing time with timeout
- print information about timeout increasing and card busy timeout
Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com>
Cc: Pantelis Antoniou <panto@antoniou-consulting.com>
To prevent the confusion, use the get_mmc_clk() instead of mmc_clk().
get_mmc_clk() is more exactly name.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
