2015-04-18net: cosmetic: Name ethaddr variables consistentlyJoe Hershberger
Use "_ethaddr" at the end of variables and drop CamelCase. Make constant values actually 'const'. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names for DHCP stringsJoe Hershberger
Remove CamelCase variable naming. Move the definition to the same compilation unit as the primary use. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Fixup var names related to boot fileJoe Hershberger
The variables around the bootfile were inconsistent and used CamelCase. Update them to make the code more readable. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18net: cosmetic: Change IPaddr_t to struct in_addrJoe Hershberger
This patch is simply clean-up to make the IPv4 type that is used match what Linux uses. It also attempts to move all variables that are IP addresses use good naming instead of CamelCase. No functional change. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18powerpc: ids8313: use "select" instead of default value in defconfigMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18ARM: cm_fx6: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: stv0991: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: bav335x: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: socfpga: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: mx6: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: snapper9260: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: rmobile: use "select" instead of default value in defconfigMasahiro Yamada
2015-04-18ARM: zynq: use "select" instead of default value in defconfigMasahiro Yamada
All the Zynq boards have switch to Driver Model. "select DM" is better than default value in each defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18ARM: UniPhier: use "select" instead of default value in defconfigMasahiro Yamada
All the UniPhier boards have switch to Driver Model. "select DM" is better than default value in each defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: select CONFIG_DM* optionsMasahiro Yamada
As mentioned in the previous commit, adding default values in each Kconfig causes problems because it does not co-exist with the "depends on" syntax. (Please note this is not a bug of Kconfig.) We should not do so unless we have a special reason. Actually, for CONFIG_DM*, we have no good reason to do so. Generally, CONFIG_DM is not a user-configurable option. Once we convert a driver into Driver Model, the board only works with Driver Model, i.e. CONFIG_DM must be always enabled for that board. So, using "select DM" is more suitable rather than allowing users to modify it. Another good thing is, Kconfig warns unmet dependencies for "select" syntax, so we easily notice bugs. Actually, CONFIG_DM and other related options have been added without consistency: some into arch/*/Kconfig, some into board/*/Kconfig, and some into configs/*_defconfig. This commit prefers "select" and cleans up the following issues. [1] Never use "CONFIG_DM=n" in defconfig files It is really rare to add "CONFIG_FOO=n" to disable CONFIG options. It is more common to use "# CONFIG_FOO is not set". But here, we do not even have to do it. Less than half of OMAP3 boards have been converted to Driver Model. Adding the default values to arch/arm/cpu/armv7/omap3/Kconfig is weird. Instead, add "select DM" only to appropriate boards, which eventually eliminates "CONFIG_DM=n", etc. [2] Delete redundant CONFIGs Sandbox sets CONFIG_DM in arch/sandbox/Kconfig and defines it again in configs/sandbox_defconfig. Likewise, OMAP3 sets CONFIG_DM arch/arm/cpu/armv7/omap3/Kconfig and defines it also in omap3_beagle_defconfig and devkit8000_defconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-04-18dm: spi_flash: fix wrong dependencyMasahiro Yamada
CONFIG_SPI does not exist in Kconfig in the first place, so the dependency "depends on DM && SPI" is never met, i.e., DM_SPI_FLASH can never be enabled (unless you ignore the dependency in an illegal way. See below.) Actually, some defconfigs such as socfpga_*_defconfig define CONFIG_DM_SPI_FLASH=y, but it never appears in the .config file because of this wrong dependency. On the other hand, all the Tegra boards enable DM_SPI_FLASH because config DM_SPI_FLASH default y silently ignores the dependency. Unfortunately, this style of CONFIG definition is abused everywhere in U-Boot, so we easily miss such a wrong dependency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: Add a README for driver modelSimon Glass
Add some documentation describing how USB is implemented with USB. This might make things easier for people to understand. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-04-18dm: usb: Add tests for the USB uclassSimon Glass
This adds a simple test for probing and a functional test using the flash stick emulator, which tests a large chunk of the USB stack. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: test: Allow 'dm test' to select a particular test to runSimon Glass
As well as running all tests, it is useful to be able to run a selected test. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: test: Correct printf() output nit in 'dm uclass'Simon Glass
Neither the hyphen nor the equals sign is needed. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Enable USBSimon Glass
Enable USB emulation and associated features so that USB can be used in sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Tidy up pipe value decodingSimon Glass
Add a few more shifts/masks to make it easier to decode a pipe value (rather than just building it). We need this for USB device emulation. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Add a generic descriptor structSimon Glass
This is useful for creating lists of descriptors, and is better than using void * for this purpose. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Enable both EHCI and XHCI on snowSimon Glass
Since we can support both controllers now, enable this in the device tree. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Enable both USB ports on snowSimon Glass
Switch snow over to use both EHCI and XHCI at the same time. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Use driver model for USBSimon Glass
Convert Exynos boards over to use driver model for USB. This does not remove any unnecessary code so far. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Adjust XHCI driver to support driver modelSimon Glass
Support driver model in the exynos XHCI driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Rename the XHCI HCD to U-BootSimon Glass
This should be "U-Boot", not "u-boot". Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Support driver model in XHCISimon Glass
Add driver model support in the XHCI support code so that it can be used by XHCI USB drivers. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Factor out common init/uninitSimon Glass
Since driver model will want to use most of the same code for XHCI init and uninit, put it in a separate function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Use explicit parameters for xhci_setup_addressable_virt_dev()Simon Glass
This function should not be delving into struct usb_device. Pass in the parameters it needs directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: xhci: Use explicit parameters for xhci_alloc_virt_device()Simon Glass
2015-04-18dm: usb: xhci: Use a function to get xhci_ctrlSimon Glass
Rather than getting this directly from struct usb_device, call a function to obtain it. This will make it possible for driver model to provide it another way. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Add driver model support to tegra EHCISimon Glass
Update this driver with driver model support for USB. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Move most of init/uninit into a functionSimon Glass
We want to use mostly the same init and uninit code for driver model, so move the common part into two functions. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Tidy up error handling and a static functionSimon Glass
Try to return useful error numbers where possible. Also avoid swallowing an error number when it is returned by a called function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Remove the port_addr_clear_csc variableSimon Glass
This variable is a bit of a hack. We can obtain the same information from the normal device config. This will fit better with driver model, where global variables are best avoided. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: exynos: Add driver model support to exynos EHCISimon Glass
2015-04-18dm: usb: Add support for USB ethernet devices with driver modelSimon Glass
Add support for scanning USB etghernet devices with driver model. This mostly involves scanning all buses since device numbering is not unique across buses. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: dts: sandbox: Add some sample USB devices to sandboxSimon Glass
These allow basic testing of the USB functionality within sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add a driver for sandboxSimon Glass
This driver supports using emulation devices to provide a USB bus within sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add an emulator for USB hub emulationSimon Glass
All USB controllers need a root hub. Add a sandbox emulation for this so that we can add USB devices to sandbox. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add an emulator for USB flash devicesSimon Glass
This emulator supports USB enumeration and allows a local file to be provided as the contents of the emulated flash stick. U-Boot can then use the file as it would a normal device, with all access passing through the usb_stor layer and the USB stack. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Reset emulation devices in usb stop()Simon Glass
These devices must have their addresses removed ready for the next USB bus enumeration. Add this logic to usb_stop(). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: sandbox: Add a uclass for USB device emulationSimon Glass
With sandbox we want to be able to emulate USB devices so that we can test the USB stack. Add a uclass to support this. It implements the same operations as a normal USB device driver, but in this case passes them on to an emulation driver. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Move struct usb_string to a common placeSimon Glass
This is needed for sandbox USB device emulation, so move it to a place where it can be found by things other than gadgets. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: tegra: Add vbus GPIOs for nyanSimon Glass
These are needed to enable the USB bus (although not sufficient since it still does not work). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Support driver model with USB keyboardsSimon Glass
Allow USB keyboards to work with driver model. The main difference is that we can have multiple buses (each with its own device numbering) and each bus must be scanned. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Split out the keyboard probe into its own functionSimon Glass
Before adding driver model support, split out code from this over-long function. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
2015-04-18dm: usb: Allow setting up a USB controller as a device/gadgetSimon Glass
Some controllers support OTG (on-the-go) where they can operate as either host or device. The gadget layer in U-Boot supports this. While this layer does not interact with driver model, we can provide a function which sets up the controller in the correct way. This way the code at least builds (although it likely will not work). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Marek Vasut <marex@denx.de>
