The file was generated from building versatile_defconfig.
Compiling dbau1x00 and gth2 boards with GCC-4.2, you would see new warnings
like this:
skuribay@ubuntu:u-boot.git$ ./MAKEALL dbau1000
Configuring for dbau1x00 board...
au1x00_eth.c: In function 'au1x00_send':
au1x00_eth.c:158: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
au1x00_eth.c: In function 'au1x00_recv':
au1x00_eth.c:211: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
au1x00_eth.c: In function 'au1x00_init':
au1x00_eth.c:252: warning: passing argument 1 of 'virt_to_phys' discards qualifiers from pointer target type
We're passing a volatile pointer to a function which is expecting a non-
volatile pointer. That's potentially dangerous, so gcc warns about it.
Confirmed with ELDK 4.2 (GCC 4.2.2) and Sourcey G++ 4.2 (GCC 4.2.3).
To fix this, we add a volatile attribute to the argument in question.
The virt_to_phys function in Linux kernel also does the same thing.
Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
Clean up OMAP3 MMC code:
* Convert register access to struct & readx/writex style
* Replace hardcode values by macros
* Remove macro defined twice
Signed-off-by: Dirk Behme <dirk.behme@googlemail.com>
Clock pin must have input enabled for MMC3 to work.
Also enable pull-ups for cmd/data lines to be consistent
with remaining MMC host pin setup.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
This patch adds OMAP3 cpu type auto detection based on OMAP3 register
and removes hardcoded values.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
With BeagleBoard revision C some HW changes are introduced (e.g. PinMUX)
which might need different software handling. For this, GPIO pin 171 (GPIO
module 6, offset 11) can be used to check for board revision. If this pin
is low, we have a rev C board. Else it must be a revision Ax or Bx board.
To handle board differences you can call function beagle_get_revision().
E.g.:
if (beagle_get_revision()) {
/* do special revision C stuff here */
* Make Overo GPIO114 an input for touchscreen PENDOWN
* Make Overo GPIO144-147 readable
* Make Overo EHCI pinmux match beagle rev c setup
* Adjust pinmux for SMSC911X network chip support
* Remove unnecessary GPIO setup
* Fix merge error in Makefile
Serial driver via the EmbeddedICE macrocell's DCC channel using
co-processor 14.
It does include a timeout to ensure that the system does not
totally freeze when there is nothing connected to read.
Taken all the duplicated code for enabling common modules and apply
software workarounds from the board specific code into common
functions. Also added comments explaining the workarounds
(from TI errata documents) and replaced some numerical bit numbers
with more meaningful defines.
Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com>
This trivially enables Ethernet support in the debug board
by setting up the proper chip select.
Signed-off-by: Alessandro Rubini <rubini@unipv.it>
Acked-by: Andrea Gallo <andrea.gallo@stnwireless.com>
This driver implements the ECC algorithm described in
the CPU data sheet and uses the OOB layout chosen in
already-released development systems (shipped with a custom-made
u-boot 1.3.1).
Fix the problem that cannot use external hub, because this driver
did not control correctly a DEVADDx register.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
Looks like the initcode updates fell out of order during my merges. The
patch that really fixes up this code is part of power-on overhaul and so
is too large for merging at this point. Instead, we can disable the code
as no currently in-tree board depends on it. The next merge window will
fix things up properly.
The previous merge for cleaning up the I2C driver incorrectly reverted the
CFG_xxx rename for some of the I2C defines.
Commit e4943ec5 moved the ARM boards to a vendor directory but forgot
to adapt the cleanup rules in the Makefile
This patch clarifies the way m68k passes linux boot argument.
The one gotcha here is that the assembly instruction that
the compiler uses to jump to the kernel is 'jsr' which pushes the
program counter for the instruction after the jsr into the stack pointer.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Signed-off-by: Peter Griffin <pgriffin@mpc-data.co.uk>
Although load address and image start address are same address,
bootm command always does memmove.
That is unnecessary memmove and can be taken few milliseconds
(about 500 msec to 1000 msec).
If skip this memmove, we can reduce the boot time.
This patch does some minor fixing of the Xilinx Spartan III
FPGA boot code:
- Fixed call order of post configuration callback and
success message printing (result of copy-paste?)
- remove obsolete comment
- minor coding style cleanup
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
FPGA boot code:
- relocate post configuration callback only when it
is implemented
Signed-off-by: Derek Ou <dou@siconix.com>
In the commit 79b51ff8205f0354d5300570614c1d2db499679c ([MIPS] cpu/mips/
Makefile: Split [CS]OBJS onto separate lines), I wrongly deleted a START
line. This patch puts it back.
Signed-off-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com>
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
These names are being taken over by the new MMC framework. Hopefuly
the PXA can be easily ported, and these functions will go away entirely.
Signed-off-by: Andy Fleming <afleming@freescale.com>
introduce new macro CONFIG_PXA_MMC to activate it
These structures are defined in the common mmc.h
This was compile checked on cerf250.
Fixing the get_timer function to return time in miliseconds instead of
ticks. Also fixed PXA boards to use the conventional value of 1000 for
CONFIG_SYS_HZ.
Signed-off-by: Micha Kalfon <smichak.uv@gmail.com>
omap3_mmc.c was changed to define mmc_legacy_init.
Remove unused functions.
Compile tested on all arm
Runtime tested on Zoom1.
- activate CS4 for accessing the FPGA
- activate Rx buf len > 1 on SMC
- pram activated
- MTDPARTS_DEFAULT defined
- update the size of the flashes in the DTS
before booting Linux
- MONITOR_LEN updated to 384k
- added CONFIG_HOSTNAME
- added CONFIG_ENV_BUFFER_PRINT
- Environment size reduced to 16k
- pram activated
- update the size of the flash in the DTS
Don't use code of new MMC framework in cmd_mmc if CONFIG_GENERIC_MMC
isn't enabled.
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the
small boot sectors in the flash. This patch makes some room in the
first sector to prepare for a size increase of lib_generic/vsprintf.o
by a future patch.
it's been around since the original commit (2ad6b513) that added two
identical entries.
