The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
Make AFEB9260 build again.
Based on fix for AT91SAM9260EK.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
This patch fixes following compile warning:
---8<---
macb.c: In function 'macb_write_hwaddr':
macb.c:525:2: warning: dereferencing type-punned pointer will break strict-aliasing rules
--->8---
Signed-off-by: Andreas Bießmann <andreas.devel@gmail.com>
This patch removes the warning
---8<---
at91_emac.c: In function 'at91emac_write_hwaddr':
at91_emac.c:487:2: warning: dereferencing type-punned pointer will break strict-aliasing rules
--->8---
Signed-off-by: Eric Bénard <eric@eukrea.com>
atmel rework changed define names which broke this file
The rework effort for ATMEL (AT91/AVR32) accidentially broke build of
this driver. Fix this to make it build again. However this driver should
be reworked as soon as possible!
Signed-off-by: Reinhard Meyer <u-boot@emk-elektronik.de>
Fix EMK TOP9000 board to build again:
- changes required due to ATMEL rework
Make ATMEL's at91sam9260/9g20/9xe-ek boards build again
Add support for Bluewater Systems AT91 based Snapper 9260 and 9G20
single board computer modules. Includes NAND flash and Ethernet
support.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
* convert at91rm9200ek and eb_cpux9k2 board to ATMEL_xxx name scheme
* Fix: timer.c compile error io.h not found with arm/at91rm9200
* update arm920t/at91 to ATMEL_xxx name scheme
* update arm920t/at91 soc lib
* update at91_emac driver
Signed-off-by: Jens Scharsig <js_at_ng@scharsoft.de>
Tested-by: Andreas Bießmann <andreas.devel@gmail.com>
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
Remove obsolete config.mk from QONG board.
Provide SDRAM base address and use SRAM for initial stack
Signed-off-by: Aneesh V <aneesh@ti.com>
Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
The clock-frequency property in an audio codec's device tree node is set to
the input clock frequency for that codec. On the Freescale P1022DS board,
the input clock is enabled only if the hwconfig 'audclk' option is set.
Therefore, the property should only be set in the device tree if the clock
is actually enabled.
* 'master' of git://git.denx.de/u-boot-arm:
SMDK6400: fix the compiler error
imx27lite: Remove local config.mk
mx31ads: Fix environment location on flash
imx31_litekit: Remove local config.mk
mx31litekit: Fix boot with the new relocation scheme.
mx31ads: Use the new relocation scheme
This patch adds _end for fix following compiler error
arch/arm/cpu/arm1176/start.o: In function `_end_ofs':
arch/arm/cpu/arm1176/start.S:61: undefined reference to `_end'
Local board config.mk should be avoided.
Place CONFIG_SYS_TEXT_BASE definition into the board config file instead.
At the moment u-boot and u-boot environment on flash
have overlapping addresses, so each u-boot update erases
the environment. Fix this by placing evironment right
after u-boot. Also, remove confusing comment about environment
location.
Signed-off-by: Felix Radensky <felix@embedded-sol.com>
imx31_litekit has been converted to the new relocation scheme, but it does not boot.
Make the boot functional by using board_early_init_f .
Tested-by: Magnus Lilja <lilja.magnus@gmail.com>
This fixes the MX31ADS build by using the new relocation scheme.
Tested-by: Felix Radensky <felix@embedded-sol.com>
The recent commit ea882baf9c1 broke embedding environments in the middle
of a sector, so relocate it to the start of the 2nd sector.
Signed-off-by: Harald Krapfenbauer <harald.krapfenbauer@bluetechnix.com>
Now that the zlib code has been relocated to a dedicated subdir, make
sure we still build it with -O2 for boards that want speed over size.
Relocate the env to one of the small end sectors to avoid issues with
embedding it, such as support being broken (by recent commit ea882baf9c1),
and for taking a while to save updates.
Turns out the documentation is wrong and doing "RAISE 1" does not result
in a software reset, only a core reset. So when the on-chip rom has a
functioning reset helper, use it.
Now that common code is a bit smarter when it comes to default LDSCRIPT
values, rename the default Blackfin file and drop the Blackfin-specific
config.mk logic.
All data in dtb is big endian. Some ARM devices are little-endian.
In print_data(), it displays data with big-endian format. For ARM device,
data should be converted to little-endian first.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Gerald Van Baren <vanbaren@cideas.com>
When we use the ntpserverip environment variable argv[1] may not be set.
Printing the error message using the NetNtpServerIP variable ensures the
correct output in both cases.
Signed-off-by: Luuk Paulussen <luuk.paulussen@alliedtelesis.co.nz>
Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz>
Cc: Ben Warren <biggerbadderben@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
The status polling can take a while, so make sure we kick the
watchdog after each successful poll.
Signed-off-by: Patrick Sestier <psestier@mircom.com>
At least on ARM the ipaddr is only set in board_init_r function. The
problem is if ipaddr is not defined in environment importing another
environment defined don't update the ipaddr value.
For example, suppose we've a default environment without net variables
defined and we want to import an uEnv.txt environment from SD-card like
this:
ipaddr=192.168.2.240
netmask=255.255.255.0
gatewayip=192.168.2.1
serverip=192.168.2.114
Then if you try boot from NFS results in:
Importing environment from mmc ...
Running uenvcmd ...
smc911x: detected LAN9221 controller
smc911x: phy initialized
smc911x: MAC ac:de:48:00:00:00
*** ERROR: `ipaddr' not set
The ipaddr at this point is NULL beacause is only set at board_init_r
function. This patch updates the ipaddr value if the environment has
changed.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
* 'master' of /home/wd/git/u-boot/custodians:
sh: sh7785lcr: Update BSC of USB area
* 'master' of git://git.denx.de/u-boot-sh:
SMDKV310: Fix incorrect conditional compilation for MIU linear mapping
SMDKV310: CPU fequency and mmc_pre_ratio modified
armv7: Add support for ST-Ericsson U8500 href platform
I2C: Add driver for ST-Ericsson U8500 i2c
armv7: Add ST-Ericsson u8500 arch
Kirkwood: boards cleanup for deprecated CONFIG_CMD_AUTOSCRIPT
ARMV7: Vexpress: Add missing MMC header
arm/km: update mgcoge3un board support
mvgbe: enable configurability of PORT_SERIAL_CONTROL_VALUE
arm/km: rename mgcoge2un to mgcoge3un
arm/km: add second serial interface for kirkwood
arm/km: disable ls (through jffs2 support)
arm/km: introduce bootcount env variable and clean km_arm
arm/km: move CONFIG_EXTRA_ENV_SETTINGS from board to km_arm file
arm/km: remove CONFIG_SYS_KWD_CONFIG from keymile-common.h
ARMV7: MMC SPL Boot support for SMDKV310 board
ARMV7: Add support for Samsung SMDKV310 Board
S5PC2XX: clock: support pwm clock for evt1 (cpu revision 1)
S5P: add set_mmc_clk for external clock control
S5PC2XX: Support the cpu revision
S5P:SROM config code moved to s5p-common directory
Add _end for the end of u-boot image for SMDK6400
MMC S5P: Fix typo
S5P: GPIO Macro Values Corrected.
SMDK2410: various cleanup/code style fixes
SMDK2410: use the CFI driver (and remove the old one)
SMDK2410: remove unneeded config.mk
SMDK2410: activate ARM relocation feature
BeagleBoard: fixed typo in typecast
mvsata: issue hard reset on initialization
VCMA9: use ARM relocation feature to fix build error
MX31: drop warnings due to missing prototype for mxc_watchdog_reset()
MX5: drop config.mk from efikamx board
MX31: Make get_reset_cause() static and drop unreachable code
MX53: Remove CONFIG_SYS_BOOTMAPSZ from mx53 config files.
MX53: Handle silicon revision 2.1 case
mx5: board: code clean up for checkboard code
MX51: vision2: Fix build for vision2 board.
MX51: vision: Let video mode struct be independant of watchdog.
MX53: Add initial support for MX53SMD board.
MX53: support for freescale MX53LOCO board
mx5: Fix CONFIG_OF_LIBFDT redefined warning
mx5: Remove unnecessary CONFIG_SYS_BOOTMAPSZ definition
mx31pdk: Clean up mx31pdk.h file
MMC S5P: Fix typo
powerpc/fsl_pci: Fix device tree fixups for newer platforms
* 'master' of git://git.denx.de/u-boot-mpc85xx:
