The "nand info" and "nand device" now set shell/environment variables:
nand_writesize ... nand page size
nand_oobsize ..... nand oob area size
nand_erasesize ... nand erase block size
Also, the "nand info" command now displays this info.
Cc: Scott Wood <scottwood@freescale.com>
Cc: Detlev Zundel <dzu@denx.de>
[scottwood@freescale.com: removed unnecessary memsets]
The eLBC NAND driver currently follows up each program/write operation with a
read-back of the page, in order to [ostensibly] fill in ECC data for the
caller. However, the page address used for this read is always -1, so the read
will never work correctly. Remove this useless (and potentially problematic)
block of code.
v2: fix broken mailer
Signed-off-by: mhench <mhench@elutions.com>
This allows the scrub command to scrub without asking the user if he really
wants to scrub the area. Useful in scripts.
These commands should work around various "hardware" ECC and BCH methods.
[scottwood@freescale.com: s/write the page/access the page/]
[scottwood@freescale.com: use chip instead of redundant priv_nand]
cc: Scott Wood <scottwood@freescale.com>
When writing 0x4000 to the unlockend_blkaddr register, large writes to
a 2k page NAND sometimes fail. The current kernel driver writes 0xFFFF
to this register for V2 of the nand controller.
However on an i.MX31 this also fixes writes larger than 32MB.
The datasheet is very unspecific, but (0x4000=16384)*2000
roughly fits the limits we're encountering with NAND writes.
This problem might be NAND chip specific.
Signed-off-by: Helmut Raiger <helmut.raiger@hale.at>
The new SAMSUNG NAND Flash K9F1G08U0D require a bigger chip_delay.
The Data Transfer from Cell to Register is >= 35us. Other Vendors
and older chips normally use >= 25us. To have enough margin 40us
is selected.
Signed-off-by: Stefan Bigler <stefan.bigler@keymile.com>
Signed-off-by: Holger Brunck <holger.brunck@keymile.com>
cc: Prafulla Wadaskar <prafulla@marvell.com>
cc: Stefan Roese <sr@denx.de>
lzo1x_decompress.c: In function ‘parse_header’:
lzo1x_decompress.c:35:5: warning: variable ‘level’ set but not used
[-Wunused-but-set-variable]
cmd_ubi.c: In function ‘ubi_volume_read’:
cmd_ubi.c:319:9: warning: variable ‘count_save’ set but not used
vmt.c: In function ‘ubi_free_volume’:
vmt.c:681:6: warning: variable ‘err’ set but not used
cmd_nand.c: In function ‘do_nand’:
cmd_nand.c:490:7: warning: variable ‘chip’ set but not used
cmd_nand.c:489:7: warning: variable ‘part’ set but not used
nand_bbt.c: In function ‘search_bbt’:
nand_bbt.c:465:6: warning: variable ‘bits’ set but not used
cmd_mem.c: In function ‘do_mem_loop’:
cmd_mem.c:474:25: warning: variable ‘junk’ set but not used
The assigned variable can be removed because the pointers are volatile so
accesses to their addresses are always generated.
ipu_disp.c: In function ‘ipu_disp_set_global_alpha’:
ipu_disp.c:1237:11: warning: variable ‘flow’ set but not used
ipu_disp.c: In function ‘ipu_disp_set_color_key’:
ipu_disp.c:1302:16: warning: variable ‘flow’ set but not used
lcd.c: In function ‘lcd_drawchars’:
lcd.c:214:9: warning: variable ‘off’ set but not used
lcd.c: In function ‘lcd_display_bitmap’:
lcd.c:617:16: warning: variable ‘compression’ set but not used
cmd_nvedit.c: In function ‘do_env_edit’:
cmd_nvedit.c:463:6: warning: variable ‘len’ set but not used
cmd_flash.c: In function ‘do_protect’:
cmd_flash.c:474:6: warning: variable ‘p’ set but not used
Fix the following gcc4.6 problems:
cmd_date.c: In function ‘do_date’:
cmd_date.c:50:6: warning: variable ‘old_bus’ set but not used
asix.c: In function ‘asix_init’:
asix.c:317:6: warning: variable ‘rx_ctl’ set but not used
usb.c: In function ‘usb_parse_config’:
usb.c:331:17: warning: variable ‘ch’ set but not used
usb.c: In function ‘usb_hub_port_connect_change’:
usb.c:1123:29: warning: variable ‘portchange’ set but not used
usb.c: In function ‘usb_hub_configure’:
usb.c:1183:25: warning: variable ‘hubsts’ set but not used
usb_storage.c: In function ‘usb_stor_CB_reset’:
usb_storage.c:466:6: warning: variable ‘result’ set but not used
The EST SBC8260 is over 10 years old, and the SBC8240 older than
that. With the tiny amount of RAM (by today's standards), there
really isn't anyone interested in running the latest U-boot on
these EOL products anymore.
CC: jon.diekema@smiths-aerospace.com
This e-mail address is no longer valid, and the boards are long
since EOL.
When include/linux/compiler.h is included, the associated gcc3
header is required for older build environments.
Signed-off-by: Scott McNutt <smcnutt@psyent.com>
Signed-off-by: Philip Balister <philip@opensdr.com>
There are some locations in the code which anticipate printf() being called
before the console is ready by squelching printf() on gd->have_console.
Move this squelching into printf(), vprintf(), puts() and putc(). Also
make tstc() and getc() return 0 if console is not yet initialised
Signed-off-by: Graeme Russ <graeme.russ@gmail.com>
If CONFIG_SYS_NS16550_MEM32 is defined then 32 bit memory
mapped access will be used to read/write the uart registers.
This is especially useful for SoC devices that implement 16550
compatible uarts but that have peripheral access width constraints.
Signed-off-by: Dave Aldridge <fovsoft@gmail.com>
This tidies up duplicate code, and checks that default_serial_console() does
in fact produce a device.
Currently in do_fat_read() when reading FAT sectors, we have to divide down
LINEAR_PREFETCH_SIZE by the sector size, whereas it's defined as 2 sectors
worth of bytes. In order to avoid redundant multiplication/division, introduce
#define PREFETCH_BLOCKS instead of #define LINEAR_PREFETCH_SIZE.
Signed-off-by: Sergei Shtylyov <sshtylyov@mvista.com>
The root directory cluster field only exists in a FAT32 boot sector, so the
'root_cluster' variable in do_fat_read() contains garbage in case of FAT12/16.
Make it contain 0 instead as this is what is passed to get_vfatname() in that
case anyway.
The code multiples the FAT size in sectors by the sector size and then tries to
compare that to the number of sectors in the 'getsize' variable. While fixing
this, also change the initial value of 'getsize' as the division of FATBUFSIZE
by the sector size gets us FATBUFBLOCKS.
Apple iPod nanos have sector sizes of 2 or 4 KiB, which crashes U-Boot when it
tries to read the boot sector into 512-byte buffer situated on stack. Make the
FAT code indifferent to the sector size.
* 'sf' of git://git.denx.de/u-boot-blackfin:
sf: eon: add support for EN25Q32B parts
cmd_sf: add "update" subcommand to do smart SPI flash update
* 'post' of git://git.denx.de/u-boot-blackfin:
Blackfin: uart: implement loop callback for post
Blackfin: bf537-stamp/bf548-ezkit: update POST flash block range
Blackfin: post: generalize led/button tests with GPIOs
Blackfin: bf537-stamp: drop uart/flash post tests
Blackfin: post: drop custom test list
Blackfin: bf537-stamp: convert to gpio post hotkey
mxc_ata.c: In function ‘set_ata_bus_timing’:
mxc_ata.c:118: warning: dereferencing type-punned pointer will break
strict-aliasing rules
mxc_ata.c:125: warning: dereferencing type-punned pointer will break
mxc_ata.c:129: warning: dereferencing type-punned pointer will break
Let common code set the machine ID.
When building the zmx25 target we get:
Configuring for zmx25 board...
generic.c:108: warning: 'get_reset_cause' defined but not used
Fix this warning by defining get_reset_cause only if CONFIG_DISPLAY_CPUINFO is defined.
Cc: Matthias Weisser <weisserm@arcor.de>
As only one RAM bank is used we can rely on the code from arch/arm/lib/board.c
Rewrite the mxc_i2c driver.
* This version is much closer to Linux implementation.
* Fixes IPG_PERCLK being incorrectly used as clock source
* Fixes behaviour of the driver on iMX51
* Clean up coding style a bit ;-)
Cc: Jason Hui <jason.hui@linaro.org>
Acked-by: Jason Liu <jason.hui@linro.org>
Acked-by: Heiko Schocher <hs@denx.de>
Tested-by: Jason Liu <jason.hui@linro.org>
The new output looks like this:
> clocks
PLL1 800 MHz
PLL2 665 MHz
PLL3 216 MHz
AHB 133000 kHz
IPG 66500 kHz
IPG PERCLK 665000 kHz
Acked-by: Jason Liu <jason.hui@linaro.org>
Cc: Jason Liu <jason.hui@linaro.org>
The PLL decoding algorithm didn't take into account many configuration bits.
Adjust it according to Linux kernel. Also, add PLL4 for MX53.
Tested-by: Jason Liu <Jason.hui@linaro.org>
