2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-10board/apollon/sys_info.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: sys_info.c: In function 'display_board_info': sys_info.c:260:16: warning: variable 'db_s' set but not used [-Wunused-but-set-variable] Also fix resulting warnings: sys_info.c:251:7: warning: unused variable 'db_ip' [-Wunused-variable] sys_info.c:250:7: warning: unused variable 'db_men' [-Wunused-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-12-10board/apollon/apollon.c: Fix GCc 4.6 build warnings.Wolfgang Denk
Fix: apollon.c: In function 'dram_init': apollon.c:188:29: warning: variable 'cpu' set but not used [-Wunused-but-set-variable] apollon.c:188:20: warning: variable 'rev' set but not used [-Wunused-but-set-variable] apollon.c:187:26: warning: variable 'size1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-12-10boards.cfg: sort listWolfgang Denk
2011-12-10fs/yaffs2/yaffs_guts.c: Fix GCC 4.6 compile warning (and bug)Wolfgang Denk
Fix: yaffs_guts.c: In function 'yaffs_GarbageCollectBlock': yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used [-Wunused-but-set-variable] Here GCC actually detected a bug. The code was always returning OK instead of the previously set retrun code. Fix that. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: William Juul <wiljuul@cisco.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: William Juul <wiljuul@cisco.com>
2011-12-10drivers/net/at91_emac.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: at91_emac.c: In function 'at91emac_phy_init': at91_emac.c:244:20: warning: variable 'duplex' set but not used [-Wunused-but-set-variable] at91_emac.c:244:13: warning: variable 'speed' set but not used [-Wunused-but-set-variable] Use new debug_cond() to fix these warnings. In the result, anumber of inconsistent printf() formats are detected: at91_emac.c: In function 'at91emac_read': at91_emac.c:147:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c: In function 'at91emac_write': at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'short unsigned int *' [-Wformat] at91_emac.c: In function 'at91emac_recv': at91_emac.c:451:3: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat] at91_emac.c:451:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat] Fix these, too. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-12-10drivers/net/ne2000_base.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: ne2000_base.c: In function 'dp83902a_send': ne2000_base.c:282:7: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_RxEvent': ne2000_base.c:376:5: warning: variable 'rsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_TxEvent': ne2000_base.c:513:5: warning: variable 'tsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_ClearCounters': ne2000_base.c:550:17: warning: variable 'cnt3' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:11: warning: variable 'cnt2' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:5: warning: variable 'cnt1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: M28: Cleanup memsize.o OOT build i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28 M28: Fix typo M28: Document that units has to be set to sectors on SD bootcard i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board i.mx: mxc_gpio: add the i.mx6q support i.mx: add the initial support for freescale i.MX6Q processor i.mx: introduce the armv7/imx-common folder S5PC2XX: Rename S5pc2XX to exynos tegra2: Don't use board pointer before it is set up tegra2: Remove unneeded 'dynamic ram size' message tegra2: Remove unused low-level Tegra2 UART code tegra2: Remove unneeded config option tegra2: Remove unneeded boot code tegra2: Enable instruction cache arm: Move CP15 init out of cpu_init_crit() tegra2: Simplify tegra_start() boot path tegra2: Add arch_cpu_init() to fire up Cortex-A9 tegra2: Use new GPIO APIs in gpio_config_uart() tegra2: Add support for Ventana tegra2: Modify MMC driver to handle power and cd GPIOs tegra2: Move board_mmc_init into board files
2011-12-10Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: Update pci_ids.h from current Linux sources omap: overo: Use ubifs instead of jffs2 for nand omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15V
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: mpc85xx: Add board support for the eXMeritus HWW-1U-1A devices
2011-12-09M28: Cleanup memsize.o OOT buildMarek Vasut
The current way memsize.c is built just made a symlink into the directory with SPL and then compiled it like any other file there. This was bad as that broke the out-of-tree build. The new way introduced in this patch uses the standard spl/Makefile methods (CONFIG_SPL_LIBCOMMON_SUPPORT / CONFIG_SPL_LIBGENERIC_SUPPORT) to let files in common/ be built. Because common/Makefile says memsize.c is always built (SPL and non-SPL build), this fixes our issue with memsize.c out-of-tree build. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28Marek Vasut
This moves SPL to common location so it can be reused by multiple boards. Also, this commit adjusts M28 SoM to avoid breakage due to the move. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09M28: Fix typoMarek Vasut
2011-12-09M28: Document that units has to be set to sectors on SD bootcardMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2011-12-09i.mx: i.mx6q: add the initial support for i.mx6q ARM2 boardJason Liu
Add the initial support for Freescale i.MX6Q Armadillo2 board Support: MMC boot from slot 0/1, debug UART(UART4), usdhc. There is two MMC slots on the boards: mmc dev 0 -> connect USDHC3 -> the lower slot on the board, mmc dev 1 -> connect USDHC4 -> the upper slot on the board, Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Dirk Behme <dirk.behme@de.bosch.com>
2011-12-09i.mx: mxc_gpio: add the i.mx6q supportJason Liu
Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-09i.mx: add the initial support for freescale i.MX6Q processorJason Liu
i.MX6Q is freescale quad core processors with ARM cortex_a9 complex. This patch is to add the initial support for this processor. Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de>
2011-12-09i.mx: introduce the armv7/imx-common folderJason Liu
In order to support the coming MX6 platform and to reducde the duplicated code, we had better move some common files or functions to the imx-common folder for sharing. This patch does the following: - move speed.c file from armv7/mx5/speed.c to armv7/imx-common/speed.c - move armv7/mx5/timer.c to armv7/imx-common/timer.c, no any new feature added but just fix the checkpatch errors in the old file and remove the CONFIG_SYS_MX5_CLK32 reference in the file - create one new file cpu.c file to store the common function with i.mx5/6 Signed-off-by: Jason Liu <jason.hui@linaro.org> Cc:Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de>
2011-12-09S5PC2XX: Rename S5pc2XX to exynosChander Kashyap
As per new naming convention for Samsung SoC's, all Cortex-A9 and Cortex-A15 based SoC's will be classified under the name Exynos. Cortex-A9 and Cortex-A15 based SoC's will be sub-classified as Exynos4 and Exynos5 respectively. In order to better adapt and reuse code across various upcoming Samsung Exynos based boards, all uses of s5pc210 prefix/suffix/directory-names are renamed in this patch. s5pc210 is renamed as exynos4210 and S5PC210/s5pc210 suffix/prefix are renamed as exynos4/EXYNOS4. Signed-off-by: Chander Kashyap <chander.kashyap@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2011-12-09tegra2: Don't use board pointer before it is set upSimon Glass
In board_init_f() the gd->bd pointer is not valid when dram_init() is called. This only avoids dying because DRAM is at zero on Tegra2. The common ARM routine sets up the banks in the same way anyway, so we can just remove this code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Remove unneeded 'dynamic ram size' messageSimon Glass
This message is not required, since it is followed by an 'official' U-Boot message. U-Boot 2011.03-00048-gd7cb0d3 (May 11 2011 - 17:17:23) TEGRA2 Board: NVIDIA Seaboard dynamic ram_size = 1073741824 DRAM: 1 GiB becomes: TEGRA2 Board: NVIDIA Seaboard DRAM: 1 GiB This is a separate commit since it changes behavior. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Remove unused low-level Tegra2 UART codeSimon Glass
This was used by the AVP in early boot but is no longer used. Unless we plan to enable it somehow it is not needed. In any case we should try to use the ns16550 driver instead as it has the same code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Remove unneeded config optionSimon Glass
CONFIG_ENABLE_CORTEXA9 and CONFIG_SKIP_RELOCATE_UBOOT are not needed, so remove them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Remove unneeded boot codeSimon Glass
Since we have cache support built in we can remove Tegra's existing cache initialization code amd other related dead code. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Enable instruction cacheSimon Glass
Since low-level init is skipped, the instruction cache is never enabled on Tegra2. This explicitly calls this initialization as soon as the A9 is initialized. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09arm: Move CP15 init out of cpu_init_crit()Simon Glass
Some SOCs have do not start up with their 'main' CPU. The first U-Boot code may then be executed with a CPU which does not have a CP15, or not a useful one. Here we split the initialization of CP15 into a separate call, which can be performed later if required. Once the main CPU is running, you should call cpu_init_cp15() to perform this init as early as possible. Existing ARMv7 boards which define CONFIG_SKIP_LOWLEVEL_INIT should not need to change, this CP15 init is still skipped in that case. The only impact for these boards is that the cpu_init_cp15() will be available even if it is never used on these boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Simplify tegra_start() boot pathSimon Glass
The Tegra2 boot path is more complicated than it needs to be. Since we want to move to building most of U-Boot with ARMv7 and only a small part with ARMv4T (for AVP) it should be as simple as possible. This makes tegra2_start() into a simple function which either does AVP init or A9 init depending on which core is running it. Both cores now following the same init path, beginning at _start, and the special Tegra2 boot path code is no longer required. Only two files need to be built for ARMv4T, and this is handled in the Tegra2 CPU Makefile. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Add arch_cpu_init() to fire up Cortex-A9Simon Glass
We want to move away from a special Tegra2 start-up, and just use arch_cpu_init() instead. However, if we run board_init_f() from boot we need to build it for ARMv4T, since the Tegra's AVP start-up CPU does not support ARMv7. The effect of this is to do the AVP init earlier, and in arch_cpu_init(), rather that board_early_init_f(). Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Use new GPIO APIs in gpio_config_uart()Stephen Warren
... rather than open-coding the register accesses. However, gpio_request() typically stores the "label" parameter in a global data structure. This causes problems when called from gpio_config_uart(), since the code is running before relocation. To solve this, pass a NULL string to gpio_request(), and modify gpio_request() not to touch the string if it's NULL. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Add support for VentanaStephen Warren
Ventana is a board which is very similar to Seaboard. Support it by re-using board/nvidia/seaboard/seaboard.c with minor run-time conditionals. v5: Makefile: Use cmd_link_o_target, remove unused clean/distclean targets. v6: Make gpio_config_uart_seaboard() static. v7: Add MAINTAINERS entry for Ventana. Tom Warren doesn't have Ventana, so he asked me to add myself for this board. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Modify MMC driver to handle power and cd GPIOsStephen Warren
Pass the GPIO numbers for power and card detect to tegra2_mmc_init(), and modify that function to perform all required GPIO initialization. This removes the need for board files to perform these operations. Move board_mmc_getcd() into tegra2_mmc.c now that the driver knows which GPIOs to use. Update affected call-sites in seaboard.c and harmony.c. Note that this change should make all SD ports work on Harmony, since the required GPIO setup is now being performed. v4: Fix prototype of tegra2_mmc_init() in board.h to match driver change. Remove prototype of gpio_config_mmc() from board.h Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: Andy Fleming <afleming@gmail.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09tegra2: Move board_mmc_init into board filesStephen Warren
For Seaboard, this is mostly a cut/paste of board_mmc_init() and pin_mux_mmc() into seaboard.c; pin_mux_mmc() was modified to add some missing pinmux_tristate_disable calls for the GPIOs. For Harmony, those functions were modified to configure SDMMC2 (index 2) instead of SDMMC3 (index 1), since that's what is present on the board. However, harmony.c is still missing the required GPIO setup, so neither port is likely to function correctly yet. This will be fixed in the next change. v4: Include board.h to prototype tegra2_mmc_init(). Signed-off-by: Stephen Warren <swarren@nvidia.com> Tested-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-09Update pci_ids.h from current Linux sourcesGabe Black
This change copies over the pci_ids.h file from Linux verbatim, plus a few ids that had been added by hand. The last non-merge change hash in that file in the kernel repository was: 8930c8aa740b12ad69f44a35137bcc39bfa3dc41 and the kernel was at version 2.6.38. Signed-off-by: Gabe Black <gabeblack@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org> [agust@denx.de: updated to preserve used PCI IDs] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-09omap: overo: Use ubifs instead of jffs2 for nandSteve Sakoman
Signed-off-by: Steve Sakoman <steve@sakoman.com> Tested-by: Ash Charles <ash@gumstix.com>
2011-12-09omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15VAsh Charles
MMC interfaces are specified to be 3.3V compatible with an operating voltage range of 3.1V to 3.5V for SD cards. This change affects hardware using TWL4030 (TPS6595x) PMICs and should improve the reliability when communicating with marginally-spec'd MMC devices. 3.15V is the highest possible level for this chip. This patch has been tested on a Gumstix Overo board. Signed-off-by: Ash Charles <ash@gumstix.com> Tested-by: Steve Sakoman <steve@sakoman.com>
2011-12-09mpc85xx: Add board support for the eXMeritus HWW-1U-1A devicesKyle Moffett
The eXMeritus HWW-1U-1A unit is a DO-160-certified 13lb 1U chassis with 3 independent TEMPEST zones. Two independent P2020 computers may be found inside each zone. Complete hardware support is included. High-level hardware overview: * DO-160 certified for passenger aircraft (noncritical) * TEMPEST ceritified for RED/BLACK separation * 3 zones per chassis, 2 computers per zone (total of 6) * Dual-core 1.066GHz P2020 per computer * One 2GB DDR2 SO-RDIMM module per computer (upgradable to 4GB) * Removable 80GB or 160GB Intel X18-M SSD per computer * Front-accessible dual-port E1000E per computer * Front-accessible serial console per computer * Front-accessible USB port per computer * Internal Gigabit crossover within each TEMPEST zone * Internal unidirectional fiber links across TEMPEST zones * Battery-backed DS1339 I2C RTC on each CPU. Combined, each 13lb 1U chassis contains 12GB RAM, 12 cores @ 1.066GHz, 12 front-accessible Gigabit Ethernet ports and 960GB of solid-state storage with a total power consumption of ~200W. Additional notes: * SPD detection is only known to work with the DO-160-certified DIMMs * CPU reset is a little quirky due to hardware misfeature. Proper support for the hardware reset mechanism has been left for a later patch series to address. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Cc: Andy Fleming <afleming@gmail.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-09Add board_pre_console_putc to deal with early console outputSimon Glass
This patch adds support for console output before the console is inited. The main purpose of this is to deal with a very early panic() which would otherwise cause a silent hang. A new board_pre_console_putc() function is added to the board API. If provided by the board it will be called in the event of console output before the console is ready. This function should turn on all UARTs and spray the character out if it possibly can. The feature is controlled by a new CONFIG_PRE_CONSOLE_PUTC option. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Graeme Russ <graeme.russ@gmail.com>
2011-12-09common/usb_kbd.c: fix bug introduced in commit 00b7d6eWolfgang Denk
During the rebase of commit 00b7d6e "USB: Squash checkpatch warnings in usb_kbd.c" I missed a brace, resulting in a number of build errors. Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-09drivers/gpio/da8xx_gpio.c: Fix build warningAnatolij Gustschin
Fix: da8xx_gpio.c: In function 'gpio_toggle_value': da8xx_gpio.c:208:23: warning: variable 'bank' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-09MIPS: MAKEALL: fix lists for MIPSel and MIPS boardsDaniel Schwierzeck
Build dbau1550_el only in LIST_au1xx0_el and LIST_mips_el. Also remove obsolete lists for mips5kc. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Thomas Lange <thomas@corelatus.se>
2011-12-09drivers/usb/gadget/ep0.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: ep0.c: In function 'ep0_get_descriptor': ep0.c:187:8: warning: variable 'cp' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Remy Bohmer <linux@bohmer.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-09drivers/usb/gadget/core.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: core.c: In function 'usbd_device_event_irq': core.c:596:21: warning: variable 'state' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Remy Bohmer <linux@bohmer.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-09drivers/usb/musb/musb_udc.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: musb_udc.c: In function 'musb_peri_softconnect': musb_udc.c:166:14: warning: variable 'intrtx' set but not used [-Wunused-but-set-variable] musb_udc.c:166:6: warning: variable 'intrrx' set but not used [-Wunused-but-set-variable] musb_udc.c:165:5: warning: variable 'intrusb' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Acked-by: Remy Bohmer <linux@bohmer.net> Acked-by: Marek Vasut <marek.vasut@gmail.com>
2011-12-09drivers/usb/host/ehci-mxc.c: Fix GCC 4.6 warningAnatolij Gustschin
Fix: ehci-mxc.c: In function 'ehci_hcd_init': ehci-mxc.c:113:6: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-09Fix warnings in arch/arm/cpu/arm920t/s3c24x0/usb_ohci.cSimon Glass
Sorry if this is already fixed somewhere - I could not find it. This fixes these warnings: usb_ohci.c: In function 'submit_control_msg': usb_ohci.c:1081: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules usb_ohci.c:1081: note: initialized from here usb_ohci.c:1084: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules usb_ohci.c:1084: note: initialized from here usb_ohci.c:1087: warning: dereferencing pointer 'data_buf.76' does break strict-aliasing rules usb_ohci.c:1087: note: initialized from here Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-09USB: Squash checkpatch warnings in usb_kbd.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org> Rebased to current code. Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08ne2000: Convert to new net-multi model, fixes build of three boardsBernhard Kaindl
This fixes the build of the two sh boards shmin and r7780mp and qemu-mips which currently fail to build due to dropped pre-CONFIG_NET_MULTI code. This v2 patch minimizes the number of lines in the diff for easy review and to eliminate any possible accidential changes resulting from moving lines of code in the file. This also makes the register function very easy. Any cleanups and improvements are intentionally deferred to follow-up patches to keep this patch as simple and as easy to review as possible. A new driver register function, ne2k_register() calls the existing one-time setup part of the old init function and calls eth_register(). Changes to shmin, r7780mp and qemu-mips: - Call the new ne2k_register() from board_eth_init() of the boards. - Tested using qemu-mips board, - Tested the two renesas / sh boards r7780mp and shmin to compile again, and should work. checkpatch-clean when "--ignore VOLATILE" is added to .checkpatch.conf, and no warnings introduced in none of the three boards using this driver. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@gmx.net>
2011-12-08drivers/net/inca-ip_sw.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: inca-ip_sw.c: In function 'inca_switch_init': inca-ip_sw.c:210:6: warning: variable 'v' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-08arch/mips/lib/board.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: board.c: In function 'board_init_r': board.c:262:8: warning: unused variable 's' [-Wunused-variable] (raised for configurations without ethernet support like vct_premium_small) Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2011-12-08arch/mips/lib/board.c: make (mostly) checkpatch cleanWolfgang Denk
Fix all errors and all warnings except for "externs should be avoided" which could require more extensive changes. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
