Perform sync/isync as required by the architecture.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Acked-by: Jon Loeliger <jdl@freescale.com>
FILL_15BIT_555RGB macro extension for pixel swapping
by commit bed53753dd1d7e6bcbea4339be0fb7760214cc35
introduced a bug in cfb_console:
Bitmaps with odd-numbered width won't be rendered
correctly and even U-Boot crashes are observed on
some platforms while repeated rendering of such
bitmaps with "bmp display". Also if a bitmap is
rendered to an odd-numbered x starting position,
the same problem occurs. This patch is an attempt
to fix it.
If logo_plot() should ever be called with x starting
position other than zero and for pixel depths greater
than 8bpp, logo colors distortion will be observed.
This patch fixes the issue.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
- os_data_header Variable is a carry over feature
& unused. So removed all instance of this variable
- Minor Code Style Update
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
Signed-off-by: Magnus Lilja <lilja.magnus@gmail.com>
While locally preparing some U-Boot patches for ARM based OMAP3 boards, some
using OneNAND and some using NAND, we found some differences in OneNAND and
NAND command address handling.
As this might confuse users (it already confused us), we like to align OneNAND
and NAND address handling.
The issue is that cmd_onenand.c subtracts the onenand base address from the
addresses you type into the u-boot command line so, unlike nand, you can't
use addresses relative to the start of the onenand part e.g. this won't work:
onenand read 82000000 280000 400000
you have to use:
onenand read 82000000 20280000 400000
Looking at recent git, the only board currently using OneNAND is Apollon, and
for this the OneNAND base address is 0 (apollon.h)
#define CFG_ONENAND_BASE 0x00000000
so patch below won't break any existing boards and will align OneNAND and NAND
handling on boards where OneNAND base address is != 0.
Signed-off-by: Steve Sakoman <sakoman@gmail.com>
Signed-off-by: Manikandan Pillai <mani.pillai@ti.com>
Signed-off-by: Dirk Behme <dirk.behme@gmail.com>
The recent change to move the .bss outside of the image gives older
binutils (ld from eldk4.1/binutils-2.16) some headache:
ppc_85xx-ld: u-boot: Not enough room for program headers (allocated 3, need 4)
ppc_85xx-ld: final link failed: Bad value
We workaround it by being explicit about the program headers and not
assigning the .bss to a program header.
This reverts commit f5614e7926863bf0225ec860d9b319741a9c4004.
The commit was based on a misunderstanding of the (documented)
meaning of the 'autostart' environment variable. It might cause
boards to hang if 'autostart' was used, with the potential to brick
them. Go back to the documented behaviour.
common/cmd_bootm.c
common/image.c
include/image.h
- enable CFI driver where this was forgotten
- enable mtdparts support
- adjust default environment
etc.
boot_get_ramdisk() should not treat the case when a FIT image does
not contain a ramdisk as an error.
Acked-by: Michal Simek <monstr@monstr.eu>
Fix for page size of AT45DB021. Also adding bigger AT45DB081
which comes with some newer boards.
Signed-off-by: Sergey Lapin <slapin@ossfans.org>
Add sh_eth support to sh7763rdp.
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com>
When switching the TQM8xxL modules to use the CFI flash driver,
support for the second flash bank was broken because the CFI driver
did not support dynamically sized banks. This gets fixed now.
The CFI driver allowed only for static initializers in the
CFG_FLASH_BANKS_LIST definition, i. e. it did not allow to map
several flash banks contiguously if the bank sizes were not known in
advance, which kind of violates U-Boot's design philosophy.
(will be used for example by the TQM8xxL boards)
Moved static functions earlier in file so forward declarations are not needed.
Add MII commands to the UEC driver. Note that once a UEC device is selected,
any device on its MDIO bus can be addressed.
Signed-off-by: David Saada <david.saada@ecitele.com>
add support for Renesas R8A66597 usb controller.
This patch supports USB Host mode.
Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
Add support to drivers/usb/usbdcore_omap1510.c for OMAP5912 and OMAP16xx devices.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
schematic.
The Sequoia board has two UARTs in "4-pin" mode. This patch modifies the GPIO
configuration to match the schematic, and also sets the SDR0_PFC1 register to
select the corresponding mode for the UARTs.
Signed-off-by: Steven A. Falco <sfalco@harris.com>
And in the process eliminate some duplicate register defines.
Signed-off-by: Kenneth Johansson <kenneth@southpole.se>
On ADS5121 when booting linux the following errors are seen:
Unable to update property /soc5121@80000000:bus-frequency, err=FDT_ERR_NOTFOUND
Unable to update property /soc5121@80000000/ethernet@2800:local-mac-address, err=FDT_ERR_NOTFOUND
Unable to update property /soc5121@80000000/ethernet@2800:address, err=FDT_ERR_NOTFOUND
This is caused by ft_cpu_setup trying to deal with
both old and new soc node naming. This patch
fixes this by being smarter about what to
fixup.
Also do soc node fixups by compatible instead of by path.
A new board config called OF_SOC_COMPAT defined
to be "fsl,mpc5121-immr" replaces the old
OF_SOC node path that was defined to be "soc@80000000".
Old device trees still work, but the compatiblity
is conditional on CONFIG_OF_SUPPORT_OLD_DEVICE_TREES
which is on by default in include/configs/ads5121.h.
Signed-off-by: John Rigby <jrigby@freescale.com>
The current lcd_display_bitmap() function does not work properly
for the Atmel LCD controller.
2 fixes need to be done:-
(a) when setting the colour map, use the lcd_setcolreg() function
as provided by the Atmel driver
(b) the data is never actually written to the lcd framebuffer !!
Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
Implement usec2ticks() which is used by fsl_i2c.c in
lib_m68k/time.c
Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
TASREG is ColdFire platform, the include ppc4xx.h in
board/esd/common/flash.c causes conflict.
Rename OBJ to COBJ in board/platform/Makefile
Rename int mii_init(void) to void mii_init(void) for idmr
ColdFire platform
The README file states that CONFIG_VIDEO_BMP_GZIP behaves as follows:
If this option is set, additionally to standard BMP
images, gzipped BMP images can be displayed via the
splashscreen support or the bmp command.
However, the splashscreen function *only* supports standard BMP images.
This patch adds the documented gzip support.
The Atmel lcd controller is used on Atmel's AT91 (little endian) and
AVR32 (big endian) platforms.
As such, the controller can handle both big and little endian memory.
This patch fixes the driver for the AVR32 platform.
