2013-11-17drivers/net/npe: descend only when CONFIG_IXP4XX_NPE=yMasahiro Yamada
CONFIG_IXP4XX_NPE is defined only for CPU ixp. It is not necessary to filter by CPU ixp. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17drivers/net/fm: descend only when CONFIG_FMAN_ENET=yMasahiro Yamada
CONFIG_FMAN_ENET is defined only for CPU mpc85xx. We do not need to filter by CPU mpc85xx. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17drivers/qe: move the entry to drivers/MakefileMasahiro Yamada
2013-11-17powerpc: move mpc8xxx entry under arch/powerpc/cpu/Masahiro Yamada
2013-11-17Makefile: merge $(LIBBOARD) into $(LIBS)Masahiro Yamada
We do not need to handle $(LIBBOARD) and $(LIBS) separately. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-11-17drivers: tpm: clean up unused codeMasahiro Yamada
2013-11-17lib: descend into sub directories only when it is necessaryMasahiro Yamada
2013-11-17drivers: descend into sub directories only when it is necessaryMasahiro Yamada
- Descend into drivers/fpga/ only when CONFIG_FPGA=y - Descend into drivers/bios_emulator only when CONFIG_BIOSEMU=y Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: specifiy an explicite object name rather than $(BOARD).oMasahiro Yamada
2013-11-17Makefile: abolish COBJS, SOBJS, etc.Masahiro Yamada
The support for COBJS, COBJS-y, SOBJS, SOBJS-y, GLCOBJS, GLSOBJS from scripts/Makefile.build. Going forward we need to use Kbuild style consistently. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17board: Do not add -DCONFIG_SYS_TEXT_BASE in board config.mkMasahiro Yamada
Board config.mk do not need to add -DCONFIG_SYS_TEXT_BASE to CPPFLAGS because the top level config.mk does instead. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-15examples: remove the remainders of dead boardMasahiro Yamada
Commit 309a292e deleted OXC board, but missed to remove the standalone example specific to OXC board. eepro100_eeprom.c has been an orphan file for a long term. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-15cosmetic: README.scrapyard: Add eNET boardMasahiro Yamada
Commit 7e8c53d7 removed eNET board but missed to add eNET to README.scrapyard. This commit adds it for the record. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Graeme Russ <graeme.russ@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2013-11-15nios2: remove unnecessary header include pathMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Thomas Chou <thomas@wytron.com.tw>
2013-11-15board: cogent: include header files in a more natural wayMasahiro Yamada
2013-11-15configs: clean up unused macro CONFIG_L2_OFFMasahiro Yamada
Since commit c2dd0d455 and 45bf05854 introduced the new cache maintainance framework to ARM, CONFIG_L2_OFF has not been used at all. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-15TI:omap: Update u-boot-spl.lds for i2c multibus/multiadapter updateTom Rini
In 6789e84 we update u-boot-spl.lds for OMAP to ensure we include adapter information, as we use i2c during SPL. However, the regex used also means we included commands that may have been built. On omap5_uevm this leads to a failure as we include the command from the do_tca642x command, and fail to link. The fix is to restrict our regex to only the i2c list parts. Signed-off-by: Tom Rini <trini@ti.com>
2013-11-14Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxTom Rini
2013-11-13powerpc/85xx: fix broken cpu "clock-frequency" propertyLaurentiu TUDOR
When indexing freqProcessor[] we use the first value in the cpu's "reg" property, which on new e6500 cores IDs the threads. But freqProcessor[] should be indexed with a core index so, when fixing "the clock-frequency" cpu node property, access the freqProcessor[] with the core index derived from the "reg' property. If we don't do this, last half of the "cpu" nodes will have broken "clock-frequency" values. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Cc: York Sun <yorksun@freescale.com>
2013-11-13powerpc/t4240: fix per pci endpoint liodn offsetsLaurentiu TUDOR
Update the code that builds the pci endpoint liodn offset list so that it doesn't overlap with other liodns and doesn't generate negative offsets like: fsl,liodn-offset-list = <0 0xffffffcd 0xffffffcf 0xffffffd1 0xffffffd3 0xffffffd5 0xffffffd7 0xffffffd9 0xffffffdb>; The update consists in adding a parameter to the function that builds the list to specify the base liodn. On PCI v2.4 use the old base = 256 and, on PCI 3.0 where some of the PCIE liodns are larger than 256, use a base = 1024. The version check is based on the PCI controller's version register. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com>
2013-11-13powerpc/t4240: set pcie liodn in the correct registerLaurentiu TUDOR
The liodn for the T4240's PCIE controller is no longer set through a register in the guts register block but with one in the PCIE register block itself. Use the already existing SET_PCI_LIODN_BASE macro that puts the liodn in the correct register. Signed-off-by: Laurentiu Tudor <Laurentiu.Tudor@freescale.com> Cc: Scott Wood <scottwood@freescale.com> Cc: York Sun <yorksun@freescale.com>
2013-11-13powerpc/83xx: Define USB1 and USB2 base addr for MPC834xramneek mehresh
Define base addresse for both MPH(USB1) and DR(USB2) controllers for MPC834x socs Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1042RDB_PI board supportPriyanka Jain
T1042RDB_PI is Freescale Reference Design Board supporting the T1042 QorIQ Power Architecture™ processor. T1042 is a reduced personality of T1040 SoC without Integrated 8-port Gigabit. The board is designed with low power features targeted for Printing Image Market. T1042RDB_PI is similar to T1040RDB board with few differences like it has video interface, supports T1042 personality T1042RDB_PI board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Two on-board RGMII 10/100/1G ethernet ports. - SERDES Connections, 8 lanes supporting: — PCI — SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Video - DIU supports video at up to 1280x1024x32bpp - HDMI connector - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Device connected: EEPROM, thermal monitor, VID controller, RTC - Other IO - Two Serial ports - ProfiBus port - Four I2C ports Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com>
2013-11-13powerpc/t104xrdb: Add T1040RDB board supportPriyanka Jain
T1040RDB is Freescale Reference Design Board supporting the T1040 QorIQ Power Architecture™ processor. T1040RDB board Overview ----------------------- - Four e5500 cores, each with a private 256 KB L2 cache - 256 KB shared L3 CoreNet platform cache (CPC) - Interconnect CoreNet platform - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Data Path Acceleration Architecture (DPAA) incorporating acceleration for the following functions: - Packet parsing, classification, and distribution - Queue management for scheduling, packet sequencing, and congestion management - Cryptography Acceleration - RegEx Pattern Matching Acceleration - IEEE Std 1588 support - Hardware buffer management for buffer allocation and deallocation - Ethernet interfaces - Integrated 8-port Gigabit Ethernet switch - Four 1 Gbps Ethernet controllers - SERDES Connections, 8 lanes supporting: - PCI - SGMII - QSGMII - SATA 2.0 - DDR Controller 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and Interleaving -IFC/Local Bus - NAND flash: 1GB 8-bit NAND flash - NOR: 128MB 16-bit NOR Flash - Ethernet - Two on-board RGMII 10/100/1G ethernet ports. - PHY #0 remains powered up during deep-sleep - CPLD - Clocks - System and DDR clock (SYSCLK, “DDRCLK”) - SERDES clocks - Power Supplies - USB - Supports two USB 2.0 ports with integrated PHYs - Two type A ports with 5V@1.5A per port. - SDHC - SDHC/SDXC connector - SPI - On-board 64MB SPI flash - I2C - Devices connected: EEPROM, thermal monitor, VID controller - Other IO - Two Serial ports - ProfiBus port Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefile] Acked-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/t1040: Update defines to support T1040SoC personalitiesPriyanka Jain
T1040 Soc has four personalities: -T1040 (4 cores with L2 switch) -T1042:Reduced personality of T1040 without L2 switch -T1020:Reduced personality of T1040 with less cores(2 cores) -T1022:Reduced personality of T1040 with 2 cores and without L2 switch Update defines in arch/powerpc header files, Makefiles and in driver/net/fm/Makefile to support all T1040 personalities Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> [York Sun: fixed Makefiles] Acked-by: York Sun <yorksun@freescale.com>
2013-11-13powerpc/p1010rdb: update readme for p1010rdb-pa and p1010rdb-pbShengzhou Liu
- Remove duplicate doc/README.p1010rdb - Rename README to README.P1010RDB-PA - Add new README.P1010RDB-PB P1010RDB-PB is a variation of previous P1010RDB-PA board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
2013-11-13powerpc/t1040: enable PBL tool for T1040Prabhakar Kushwaha
Use a default RCW of protocol 0x66. A PBI configure file which uses CPC as 256KB SRAM. It can be used by PBL tool on T1040 to build a pbl boot image. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-11-13designware_i2c: remove 10msec delay in i2c_xfer_finishAlexey Brodkin
This delay applies to any data transfer on I2C bus. For example 1kB data read with per-byte access (which happens if environment is stored in I2C EEPROM) takes more than 10 seconds. Moreover data bus driver has to care about bus state and data transfer, but not about internal states of attached devices. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> cc: Armando Visconti <armando.visconti@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Heiko Schocher <hs@denx.de> Cc: Vipin KUMAR <vipin.kumar@st.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Mischa Jonker <mjonker@synopsys.com>
2013-11-13designware_i2c: disable i2c controller during target address setupAlexey Brodkin
As it is stated in DesignWare I2C databook: writes to IC_TAR (0x4) register succeed only when IC_ENABLE[0] is set to 0. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Tom Rini <trini@ti.com> cc: Armando Visconti <armando.visconti@st.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Heiko Schocher <hs@denx.de> Cc: Vipin KUMAR <vipin.kumar@st.com> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Mischa Jonker <mjonker@synopsys.com>
2013-11-13cmd_eeprom: fix i2c_{read|write} usage if env is in I2C EEPROMAlexey Brodkin
Data "offset" is not used directly in case of I2C EEPROM. Istead it is split into "block number" and "offset within mentioned block". Which are "addr[0]" and "addr[1]" respectively. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> cc: Peter Tyser <ptyser@xes-inc.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Mischa Jonker <mjonker@synopsys.com>
2013-11-13i2c, omap1510: remove i2c driverHeiko Schocher
remove omap1510 i2c driver, as there is no board which uses it Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Tom Rini <trini@ti.com> Cc: Jian Zhang <jzhang@ti.com>
2013-11-13i2c, zynq: convert zynq i2c driver to new multibus/multiadapter frameworkHeiko Schocher
- add zync i2c driver to new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Michal Simek <michal.simek@xilinx.com>
2013-11-13i2c, omap24xx: convert driver to new mutlibus/mutliadapter frameworkHeiko Schocher
- add omap24xx driver to new multibus/multiadpater support - adapted all config files, which uses this driver Tested on the am335x based siemens boards rut, dxr2 and pxm2 posted here: http://patchwork.ozlabs.org/patch/263211/ Signed-off-by: Heiko Schocher <hs@denx.de> Tested-by: Tom Rini <trini@ti.com> Cc: Lars Poeschel <poeschel@lemonage.de> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Thomas Weber <weber@corscience.de> Cc: Tom Rix <Tom.Rix@windriver.com> Cc: Grazvydas Ignotas <notasas@gmail.com> Cc: Enric Balletbo i Serra <eballetbo@iseebcn.com> Cc: Luca Ceresoli <luca.ceresoli@comelit.it> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Ilya Yanok <yanok@emcraft.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Nishanth Menon <nm@ti.com> Cc: Pali Rohár <pali.rohar@gmail.com> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Nagendra T S <nagendra@mistralsolutions.com> Cc: Michael Jones <michael.jones@matrix-vision.de> Cc: Raphael Assenat <raph@8d.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Stefano Babic <sbabic@denx.de>
2013-11-13i2c: mxs_i2c: Squash endless loopMarek Vasut
The endless waiting for a bit to be set can cause a hang, add a timeout so we prevent such situation. A testcase for such a hang is below. The testcase assumes a device to be present at address 0x50 and a device to NOT be present at address 0x42 . Also note that the "sleep 1" induced delays are imperative for this bug to manifest . i2c read 0x42 0x0.2 0x10 0x42000000 ; sleep 1 ; \ i2c read 0x50 0x0.2 0x10 0x42000000 ; sleep 1 ; \ i2c read 0x42 0x0.2 0x10 0x42000000 The expected result of the above command is: Error reading the chip. Error reading the chip. While without this patch, we observe a hang in the last read from 0x42 precisely when waiting for this bit to be set. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Heiko Schocher <hs@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2013-11-13i2c: sh_i2c: Update to new CONFIG_SYS_I2C frameworkNobuhiro Iwamatsu
This updates to new I2C framwwork on sh_i2c. And this also updates boards(kzm9g and ecovec) that using sh_i2c. Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2013-11-12cm_t35: use scf0403 driverNikita Kiryanov
Use scf0403 driver to add scf0403x LCD support for cm-t35 and cm-t3730 boards. Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2013-11-12omap3_dss: define DSS_ONOFFNikita Kiryanov
Add DSS_ONOFF to polarity defines Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Anatolij Gustschin <agust@denx.de>
2013-11-12lcd: add DataImage SCF0403x LCD panel supportNikita Kiryanov
Add SPI-based driver for DataImage SCF0403852GGU04 and SCF0403526GGU20 LCD panels. Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2013-11-12spi: define SPI_XFER_ONCENikita Kiryanov
The flag combination "SPI_XFER_BEGIN | SPI_XFER_END" is a common use case of spi_xfer, and it can easily cause an already long line (spi_xfer takes 5 parameters) to go over the 80 character limit. define SPI_XFER_ONCE to be a shorter version of the above flag combination. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-12spi: omap3: add support for more word lengthsNikita Kiryanov
Current implementation only supports 8 bit word lengths, even though omap3 can handle anything between 4 and 32. Update the spi interface to support changing the SPI word length, and implement it in omap3_spi driver to support the full range of possible word lengths. This implementation is backwards compatible by defaulting to the old behavior of 8 bit word lengths. Also, it required a change to the omap3_spi non static I/O functions, but since they are not used anywhere else, no collateral changes are required. Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-12spi: omap3: remove semicolon from #defineNikita Kiryanov
Remove unnecessary semicolon from #define SPI_WAIT_TIMEOUT Cc: Tom Rini <trini@ti.com> Cc: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com> Cc: Igor Grinberg <grinberg@compulab.co.il> Cc: Gerhard Sittig <gsi@denx.de> Signed-off-by: Nikita Kiryanov <nikita@compulab.co.il>
2013-11-12video: bcm2835: respect the pitch valueAndre Heider
Depending on the firmware's video options [1] the active SDTV or HDTV mode can yield a framebuffer with noncontiguous horizontal lines, giving a messed up display, for both, u-boot and the loaded kernel. Fix this by setting lcd_line_length to the pitch value of the configured framebuffer. [1] http://elinux.org/RPiconfig#Video_mode_options Signed-off-by: Andre Heider <a.heider@gmail.com> Cc: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2013-11-12lcd: allow overriding lcd_get_size()Anatolij Gustschin
Remove the redundant lcd_line_length initialisation which sneaked in when an earlier version of the patch of commit 6d330719 has been rebased. Some lcd drivers need to setup lcd_line_length not from the panel_info parameters but by different means. Make the lcd_get_size() weak to allow setting lcd_line_length in a driver specific way. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-11-12ARM: bcm2835: add missing mbox overscan response fieldAndre Heider
Add the missing "right" field to struct bcm2835_mbox_tag_overscan. Signed-off-by: Andre Heider <a.heider@gmail.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-11-11MPC824x: remove obsolete "PN62" boardWolfgang Denk
The MPC824x processors have long reached EOL, and the PN62 board has not seen any board-specific updates for more than a decade. It is now causing build issues. Instead of wasting time on things nobody is interested in any more, we rather drop this board. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Wolfgang Grandegger <wg@grandegger.com> cc: Tom Rini <trini@ti.com>
2013-11-11time: fix gcc warnings on MIPS64Daniel Schwierzeck
Commit 8dfafdde88eb3e71d5569846396ae67a91017232 introduced new gcc warnings on MIPS64: time.c: In function 'tick_to_time': time.c:59:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:59:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' time.c: In function 'usec_to_tick': time.c:76:2: warning: comparison of distinct pointer types lacks a cast [enabled by default] time.c:76:2: warning: passing argument 1 of '__div64_32' from incompatible pointer type [enabled by default] In file included from time.c:10:0: ./u-boot-mips/include/div64.h:22:17: note: expected 'uint64_t *' but argument is of type 'long long unsigned int *' Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2013-11-11Merge branch 'master' of git://git.denx.de/u-boot-mipsTom Rini
2013-11-11malta: arch/mips/include/asm/malta.h SPDX license tagPaul Burton
This patch replaces the GPL-2.0 text with a GPL-2.0 SPDX-License-Identifier tag, and adds Imagination Technologies copyright following my recent changes. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
