2011-10-27cosmetic: Replace __FUNCTION__ with __func__ in part_efi.cDoug Anderson
This makes checkpatch happy. Signed-off-by: Doug Anderson <dianders@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27README: improve documentation of network related CONFIG_ settingsWolfgang Denk
Add documentation for CONFIG_GATEWAYIP and CONFIG_NETMASK; also add information which environment variables are set. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Simon Glass <sjg@chromium.org>
2011-10-27README: white-space cleanupWolfgang Denk
2011-10-27image: Fix inverted logic in architecture check.Thierry Reding
Commit 476af29 broke this check when the ifdef lists we consolidated. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Export auto_load, use it in rarpSimon Glass
The rarp code includes another instance of the auto_load logic, so call what is now net_auto_load() instead. This also fixes an incorrect call to TftpStart() which was never seen since apparently no boards enable rarp. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Change for loop to memset()Simon Glass
This is intended purely as a code size reduction. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27net: Add more #ifdefs for tftpput to reduce code sizeSimon Glass
If CONFIG_CMD_TFTPPUT is not enabled, we want minimal code size impact on the tftp code. This introduces a few more #ifdefs. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27net: Make net_transfer() a static functionSimon Glass
This should be a static function so it can be inlined. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-27net: Hide more code behind CONFIG_CMD_TFTPPUTSimon Glass
This commit reduces code size a little by making the ICMP handler only available to tftpput. This is reasonable since it is the only user at present (ping just uses the normal handler). Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-27fat: correct ATTR_VFAT checkJ. Vijayanand
ATTR_VFAT condition requires multiple bits to be set but the present condition checking in do_fat_read() & get_dentfromdir() ends up passing on even a single bit being set. Signed-off-by: J. Vijayanand <vijayanand.jayaraman@in.bosch.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
2011-10-27fs/fat/fat.c: fix warning: 'part_size' defined but not usedWolfgang Denk
Commit c30a15e "FAT: Add FAT write feature" introduced a compiler warning. Fix this. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Donggeun Kim <dg77.kim@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-10-26FAT: Add FAT write featureDonggeun Kim
In some cases, saving data in RAM as a file with FAT format is required. This patch allows the file to be written in FAT formatted partition. The usage is similar with reading a file. First, fat_register_device function is called before file_fat_write function in order to set target partition. Then, file_fat_write function is invoked with desired file name, start ram address for writing data, and file size. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2011-10-26fdt: ARM: Add fdtcontroladdr to set device tree address in environmentSimon Glass
This adds support for a new environment variable called 'fdtcontroladdr'. If defined, the hex address is used as the address of the control fdt for U-Boot. Note: I have not changed CONFIG_PRAM section as I already have an outstanding patch on that. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: ARM: Implement and verify embedded and separate device treeSimon Glass
This locates the device tree either embedded within U-Boot or attached to the end as a separate binary. When CONFIG_OF_CONTROL is defined, U-Boot requires a valid fdt. A check is provided for this early in initialisation. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: add decode helper librarySimon Glass
This library provides useful functions to drivers which want to use the fdt to control their operation. Functions are provided to: - look up and enumerate a device type (for example assigning i2c bus 0, i2c bus 1, etc.) - decode basic types from the fdt, like addresses and integers While this library is not strictly necessary, it helps to minimise the changes to a driver, in order to make it work under fdt control. Less code is required, and so the barrier to switch drivers over is lower. Additional functions to read arrays and GPIOs could be made available here also. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for a separate device tree (CONFIG_OF_SEPARATE)Simon Glass
This adds support for an FDT to be build as a separate binary file called u-boot.dtb. This can be concatenated with the U-Boot binary to provide a device tree located at run-time by U-Boot. The Makefile is modified to provide this file in u-boot-dtb.bin. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: Add support for embedded device tree (CONFIG_OF_EMBED)Simon Glass
This new option allows U-Boot to embed a binary device tree into its image to allow run-time control of peripherals. This device tree is for U-Boot's own use and is not necessarily the same one as is passed to the kernel. The device tree compiler output should be placed in the $(obj) rooted tree. Since $(OBJCOPY) insists on adding the path to the generated symbol names, to ensure consistency it should be invoked from the directory where the .dtb file is located and given the input file name without the path. This commit contains my entry for the ugliest Makefile / shell interaction competition. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26fdt: ARM: Add device tree control of U-Boot (CONFIG_OF_CONTROL)Simon Glass
This adds a device tree pointer to the global data. It can be set by board code. A later commit will add support for making a device tree binary blob available to U-Boot for run-time configuration. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: add tftpput commandSimon Glass
This adds the tftpput command to U-Boot. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: implement tftp logicSimon Glass
This adds logic to tftp.c to implement the tftp 'put' command, and updates the README. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26tftpput: add save_addr and save_size global variablesSimon Glass
We need something akin to load_addr to handle saving data. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Support selecting get/put for tftpSimon Glass
TftpStart should support starting either a get or a put. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Factor out start, restart and next block functionsSimon Glass
This code is required for tftpput, so move it into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: move common code into separate functionsSimon Glass
We want to show block markers on completion of get and put, so move this common code into separate functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Rename TFTP to TFTPGETSimon Glass
This is a better name for this protocol. Also remove the typedef to keep checkpatch happy, and move zeroing of NetBootFileXferSize a little earlier since TFTPPUT will need to change this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Add support for receiving ICMP packetsSimon Glass
ICMP packets can tell you when there is no server at the other end. It is useful for tftp to figure this out, so that a quick error can be displayed, rather than pointlessly retrying. This adds an ICMP packet handler to the net interface. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26net: tftpput: Move ICMP code into its own functionSimon Glass
NetReceive() is a very long function with a lot of indent. Before adding code to the ICMP bit, split it out. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26Add setenv_ulong() and setenv_addr()Simon Glass
It seems we put numbers and addresses into environment variables a lot. We should have some functions to do this. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26Move simple_itoa to vsprintfSimon Glass
This function is generally useful and shouldn't hide away in hush. It has been moved as is. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-26altera_tse: Fix return of eth_device's recv() callbackJoachim Foerster
It seems to be good practice to return the number of received bytes in the eth_device's recv() callback, here: tse_eth_rx(). Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-26altera_tse: m88e1111s: Honor device flags regarding PHY interface modeJoachim Foerster
Note: This is kind of guess work. The current code is preserved for all RGMII related modes. It is different for flags=0 (GMII) and flags=5 (SGMII). The last case, SGMII, is successfully tested on Altera's Terasic DE4. Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-26altera_tse: Add support for dedicated descriptor memoryJoachim Foerster
2011-10-26altera_tse: Fix SGDMA reset triggeringJoachim Foerster
The SW_RESET needs to be set instead of being masked out! Signed-off-by: Joachim Foerster <joachim.foerster@missinglinkelectronics.com>
2011-10-26altera_tse: Clear SGDMA's RUN bit in async transfer, like in sync caseJoachim Foerster
2011-10-25part_efi: dcache: allocate cacheline aligned buffersAnton staaf
Currently part_efi.c allocates buffers for the gpt_header, the legacy_mbr, and the pte (partition table entry) that may be incorrectly aligned for DMA operations. This patch uses ALLOC_CACHE_ALIGN_BUFFER for the stack allocated buffers and memalign to replace the malloc of the pte. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25mmc: dcache: allocate cache aligned buffers for ext_csdAnton staaf
Currently the mmc_change_freq and mmc_startup functions allocates buffers on the stack that are passed down to the MMC device driver. These buffers could be unaligned to the L1 dcache line size. This causes problems when using DMA and with caches enabled. This patch correctly cache alignes the buffers used for reading the ext_csd data from an MMC device. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2011-10-25ext2: Cache line aligned partial sector bounce bufferAnton staaf
Currently, if a device read request is done that does not begin or end on a sector boundary a stack allocated bounce buffer is used to perform the read, and then just the part of the sector that is needed is copied into the users buffer. This stack allocation can mean that the bounce buffer will not be aligned to the dcache line size. This is a problem when caches are enabled because unaligned cache invalidates are not safe. This patch uses ALLOC_CACHE_ALIGN_BUFFER to create a stack allocated cache line size aligned bounce buffer. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Dave Liu <r63238@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Change-Id: I32e1594d90ef039137bb219b0f7ced55768744ff Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25mmc: dcache: allocate cache aligned buffer for scr and switch_statusAnton staaf
Currently the sd_change_freq function allocates two buffers on the stack that it passes down to the MMC device driver. These buffers could be unaligned to the L1 dcache line size. This causes problems when using DMA and with caches enabled. This patch correctly cache alignes the buffers used for reading the scr register and switch status values from an MMC device. Change-Id: Ifa8414f572ef907681bd2d5ff3950285a215357d Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25tegra: define CONFIG_SYS_CACHELINE_SIZE for tegraAnton staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Tom Warren <twarren.nvidia@gmail.com> Cc: Simon Glass <sjg@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Change-Id: I5c4bcfc0bfe59158ff249fe3be6640eec6d3cc76 Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-25cache: add ALLOC_CACHE_ALIGN_BUFFER macroAnton staaf
This macro is used to allocate cache line size aligned stack buffers for use with DMA hardware. Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Aneesh V <aneesh@ti.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Wolfgang Denk <wd@denx.de>
2011-10-24Revert "km_arm: enable POST for these boards"Wolfgang Denk
This reverts commit a2da616311151ecfab8b8fcc510686fc3c0c9a21. THis was applied by accident - a more recent version of this change was already present, see commit 9400f8f 2011-10-05 22:03:11 +0200 km_arm: enable POST for these boards Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-10-24arm: Correct build error introduced by getenv_ulong() patchSimon Glass
Commit dc8bbea removed a local variable that is used in most ARM boards. Since we want to avoid an 'unused variable' warning with later compilers, and the #ifdef logic of whether this variable is required is bit painful, this declares the variable local to the block of code that needs it. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-24powerpc: Correct build warning introduced by getenv_ulong() patchSimon Glass
Commit 1272592 introduced a warning since the variable 's' is no longer always used, depending on the CONFIG options. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23mkimage: adding support for Davinci AIS imageStefano Babic
Some Davinci processors supports the Application Image Script (AIS) boot process. The patch adds the generation of the AIS image inside the mkimage tool to make possible to generate a bootable U-boot without external tools (TI Davinci AIS Generator). Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Wolfgang Denk <wd@denx.de>
2011-10-23net: xilinx_enet: drop unused !NET_MULTI driverMike Frysinger
This driver doesn't support the NET_MULTI framework, and I can't find any boards/configs/files that reference this subdir, so punt it all. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23net: sc589: drop unused !NET_MULTI driverMike Frysinger
No boards appear to use this driver, and it doesn't support NET_MULTI, so punt the old driver. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23net: s3c4510b_eth: drop unused !NET_MULTI driverMike Frysinger
2011-10-23net: ns9750: drop !NET_MULTI driverMike Frysinger
Only one board uses this driver (ns9750dev), but the board doesn't seem to have an entry to actually build it in the Makefile/boards.cfg, so just delete net support from its board config. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23net: enc28j60_lpc2292: drop unused !NET_MULTI driverMike Frysinger
Everyone seems to have converted to the new enc28j60 driver, so drop this older one which isn't used and doesn't support NET_MULTI. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23powerpc/lib/board.c: Call run_post(POST_ROM) before relocatingBernhard Kaindl
The call to run_post(POST_ROM) which can run the POST memory test is currently called too late when gd has already been copied to DRAM. This results in failure to boot Linux after a POST_ROM memory test tested all RAM while gd was already relocated to DRAM due to gd being overwritten by the POST_ROM memory test. Support this by moving the call to run_post(POST_ROM) to run earlier, before U-Boot has started to move data to DRAM (from late board_init_f to early board_init_f) where DRAM is initialized, but not used yet. This allows that an POST memory test can test the whole DRAM, including the area where the board info struct is located. Signed-off-by: Bernhard Kaindl <bernhard.kaindl@thalesgroup.com> Cc: Pieter Voorthuijsen <pieter.voorthuijsen@prodrive.nl>
