Invoking tegra124_ram_repair() before powerup_cpus() is being
invoked to avoid race-conditions if arises further.
(based on downstream: fe1c9e4d523d6727afb62f03ef9fa5c0f04e7859)
Using CPU temperature grading as a discriminator if the Wi-Fi /
Bluetooth chip is populated is no longer possible due to upcoming
SKUs. Set variant to -wifi only if a valid config block is present
and the product id mentions a SKU with Wi-Fi / Bluetooth.
Use CONFIG_TARGET_... at compile time to differentiate between
Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code
duplication by moving question about Wi-Fi / Bluetooth before
IT/non-IT decision.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Tested on Colibri iMX7 1GB aka eMMC V1.1A
The DDR validation tool (which is part of Processor Expert) allows
to evaluate leveling parameters for CR105/CR106/CR110. Several
runs have been made with Colibri VF50 and VF61 and it seems to
evaluate very similar values. Use this values by default.
Note: The newly evaluated parameters seem to require CTLUPD_AREF
to be enabled!
Note 2: The tool also evaluated 6 as a new value for PHY02/18
GATE_CFG (Coarse adjust of gate open time). However, this seems
not to work in practise.
Using the DDR Validation tool in Processor Expert uncovered two
timing inconsistencies. Since those timings are related to the
suspend mode they do not affect or change regular memory behavior.
The current value CTLUPD_AREF(0) is the reset value of the register,
so there is no need to write a value. If needed, the register can be
written using board specific CR settings.
According to the data sheet bits 10-8 are PHYDRAM_CK_EN. Fix mask
to allow setting PHYDRAM_CK_EN correctly.
The CR80 register has multiple interrupt bits, the code is supposed
to check bit 8 but instead uses a logical and. In most cases this
probably did not affect real operations since at that stage typically
none of the other bits are set.
Add support for Vybrid's UART2 (Colibri UART_B).
RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during
the SPL phase. This asserts (active low) nReset_Out from the PMIC.
Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous
versions do not use this pin, so it is safe to leave it enabled at all
times.
When using static volumes, the file size stored in the volume is
determined at runtime. Currently the ubi command prints the file
size specified on the console, which leads to a rather confusing
series of messages:
# ubi read ${fdt_addr_r} testvol
Read 0 bytes from volume testvol to 82000000
No size specified -> Using max size (179924992)
Make sure to print the actual size read in any case:
Read 179924992 bytes from volume testvol to 82000000
After a successful read of a UBI volume, the variable filesize is set
to the number of read bytes. To boot linux with a raw initramfs/initrd,
you must specify the exact size of the initramfs/initrd image in boot
command. If the initramfs/inird is read from UBI volume, $filesize is
required to access the number of read bytes.
Example:
ubi read ${loadaddr} kernelvol
ubi read ${fdtaddr} dtbvol
ubi read ${initrd_addr} initrdvol
bootz ${loadaddr} ${initrd_addr}:${filesize} ${fdt_addr}
Signed-off-by: Holger Dengler <dengler@linutronix.de>
(cherry picked from commit 985fa93e61706a78fad130b006aefa1c098145de)
[backported to 2016.11]
Use GPIO 0 of instance GPIO5 which is used as card detect on
Colibri iMX6ULL. This fixes SD card detection.
Change usb_port_owner_info to 3 in defargs to allow for USB 3.0
SuperSpeed functionality on USBO1 in host mode.
Set the ASR bit to enable auto self refresh for RAM in mode register 2.
In ASR the refresh rate is dynamically adjusted to temperature
which is more power efficient in suspend to RAM.
Signed-off-by: Sven Guggisberg <sven.guggisberg@toradex.com>
Fix toradex_modules array off by one issue potentially leading to
spurious printout during boot e.g.
Model: Toradex V1.2A,
instead of
Model: Toradex UNKNOWN MODULE V1.2A.
T20 uses different addresses for its EHCI controllers which I missed.
Fix this.
Use device tree to set MAC address of the Ethernet chip.
Use device tree to set MTD partitions of the NAND chip.
Treat the first equal sign as a key/value separation too. This makes
the script files compatible with mkenvimage input file format. It
won't support variables with equal signs anymore, but this seems not
really like a loss.
The white spaces after the zero string terminator are applied to
the following environment entry. This is not what was intended.
Remove the superfluous white spaces.
This commit fixes several issues:
- Use ${OBJCOPY} if available, fallback to system default's objcopy if not
present.
- Extend the script to accept different build directory than current one.
It is extremely handy with OE usage, where source code is separated from
build.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Tested-by: Alex Kiernan <alex.kiernan@gmail.com>
[Backported to 2016.11]
(cherry picked from commit 0778e7c50ba1904943a1d6b5194c29d1fee33334)
This allows to change U-Boots default UART by simply changing
stdout-path in the device tree.
Switch to the generic compressed Kernel image type (zImage) instead of
the U-Boot specific uImage format.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
The i.MX 6UL/ULL feature a Cortex-A7 CPU which suppor the ARM
generic timer. This change makes use of the ARM generic timer in
U-Boot.
This is crucial to make the ARM generic timers usable in Linux since
timer_init() initalizes the system counter module, which is necessary
to use the generic timers CP15 registers.
Introduce a new config symbol to select the i.MX
General Purpose Timer (GPT).
In upstream Linux the GPMI NAND node of i.MX 6UL/6ULL uses
"fsl,imx6q-gpmi-nand" as compatible string. Add both to make
sure U-Boot fixups the MTD partitions for downstream and upstream
kernels.
The pad SAI1_RX_DATA can be used as second chip select for dual-die
NAND. However, with an assembly option the pad is available as GPIO
on SODIMM 169. All current version of Colibri iMX7 modules have the
pad available as GPIO hence do not mux the pin so that it is available
as GPIO by default.
This follows a similar commit in Linux ("arm: dts: imx7: mux pad of
SODIMM 169 as GPIO")
Disabling ASPM fixes incompatibilities with some PCIe cards
It turns out that OpenSSL calls undefined instructions to detect
ARM capabilities at runtime (via SIGILL handler). This leads to
stack traces e.g. when logging in using SSH:
[ 877.464442] sshd (613): undefined instruction: pc=76ee2da8
Disable undefined instruction events since it is used as an
autodetecion mechanism.
Add DFU configuration which allows access to all MTD partitions.
Note that DFU is mostily suited for smaller image uploads e.g.
to update U-Boot but does not work well for large images such as
rootfs since DFU copies the whole image in a memory buffer first.
Let the kernel print some debug messages when a user program
crashes due to an exception.
Follow commits 59b9b3dfb and 2533000f4 which:
unified the USB PID when the config block is missing
added CONFIG_OF_LIBFDT_OVERLAY
Set the ver environment variable consistently in all modules.
Move the define form include/configs into the defconfig were
applicable and create a new minimal defconfig.
Add handling for the device tree for the Colibri iMX6ULL 512MB Wi-Fi / BT
backport commit 0c7c6fb7641646c45630235ea906200981f4fe80:
i.MX6ULL has different speed grades than i.MX6UL.
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
Clean up the print info, so that the reset cause print can display in
a new line.
Signed-off-by: Ye Li <ye.li@nxp.com>
(cherry picked from commit f84b9d512f92b66076357820b1003a1006ff619d)
Fix incorrect value for 696MHz CPU frequency on i.MX6UL.
(cherry picked from commit 0b70df1d0e888d046cec4bd030c78eb746270ec0)
With commit 84d46e7e8948 ("tools: env: allow to print U-Boot version")
the fw_env utilities need the version.h header file. Building only
the envtools in a pristine build directory will fail due to missing
header files.
Make sure the header files are a dependency of the envtools target.
Fixes: 84d46e7e8948 ("tools: env: allow to print U-Boot version")
The fw_env utility family has a default environment compiled in
which ties it quite strongly to the U-Boot source/config it has
been built with. Allow to display the U-Boot version it has been
built with using the -v/--version argument.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
(cherry picked from commit 84d46e7e8948780d7ca20c24dfc7b653b900f728)
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Rename IXORA_FAN_GPIO to FAN_EN as per schematics.
With the Colibri iMX6ULL there is a second user of the bch algorithms
to encode the FCB.
Use the more universal CONFIG_CMD_WRITEBCB_MX7 to decide if the
modifications are needed.
Remove m4boot options not available on i.MX 6ULL.
Cleanup U-Boot environment settings.
This undefs CONFIG_ISO_PARTITION.
This removes NAND torture no longer needed after bringup.
