Signed-off-by: Trent Piepho <tpiepho@freescale.com>
Add logic to the MAKEALL script to determine the number of CPU cores
on the system, and run a parallel build if there is more than one.
Usually this significantrly accelerates builds.
Allow to manually adjust the number of parallel make jobs by using
the "BUILD_NCPUS" environment variable.
Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Make should be using the bash shell by default which makes
CONFIG_SHELL unnecessary
Some Make script commands rely on bash-specific features like brace
expansion, so default to bash for the SHELL variable with a fallback
to the standard sh shell
rename devices_init () in common/jffs2.c to
jffs2_devices_init (), because there is also a
devices_init () in common/devices.c.
This patch fixes a build error for the SPARC platform. It was
introduced by commit c160a9544743e80e8889edb2275538e7764ce334.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
Signed-off-by: Gary Jennejohn <garyj@denx.de>
This implements the ICN protocol used across the backplane and is
needed by all the keymile boards.
number.
Corrected endian order printing for compact flash serial number.
Signed-off-by: Richard Retanubun <RichardRetanubun@RuggedCom.com>
Modifications to support console multiplexing. This is controlled using
CONFIG_SYS_CONSOLE_MUX in the board configuration file.
This allows a user to specify multiple console devices in the environment
with a command like this: setenv stdin serial,nc. As a result, the user can
enter text on both the serial and netconsole interfaces.
All devices - stdin, stdout and stderr - can be set in this manner.
1) common/iomux.c and include/iomux.h contain the environment setting
implementation.
2) doc/README.iomux contains a somewhat more detailed description.
3) The implementation in (1) is called from common/cmd_nvedit.c to
handle setenv and from common/console.c to handle initialization of
input/output devices at boot time.
4) common/console.c also contains the code needed to poll multiple console
devices for input and send output to all devices registered for output.
5) include/common.h includes iomux.h and common/Makefile generates iomux.o
when CONFIG_SYS_CONSOLE_MUX is set.
When running `strings` on really long strings, the stack tends to get
smashed due to printf(). Switch to puts() instead since we're only passing
the data through.
Signed-off-by: Niklaus Giger <niklaus.giger@member.fsf.org>
- fix size too small by one in sprintf
- changed old (pre 2004) device name ibmEmac to emac
- boot device may be overriden in board config
- servername may be defined in board config
- additional parameters may be defined in board config
- fixed some line wrappings
- replaced redundant MAX define by max
remove unneeded version.h from lcd.c
Use the GNU 'date' command to auto-generate a new U-Boot
timestamp on every compile.
Commit 6b59e03e0237a40a2305ea385defdfd92000978b
lcd: Let the board code show board-specific info
introduced some bugs which prevent U-Boot building
for lwmon board if CONFIG_LCD_INFO_BELOW_LOGO will
be defined in the board configuration.
Also "LCD enabled" building for TQM823L doesn't work
since this commit.
This patch fixes above-mentioned issues.
When using gdb, history files will often get generated. So ignore them.
The TftpStart() function modifies the 'BootFile'
string when 'BootFile' contains both an IP address
and filename (eg 1.2.3.4:/path/file). This causes
subsequent calls to TftpStart to incorrectly parse
the TFTP filename and server IP address to use.
For example:
=> tftp 0x100000 10.52.0.62:/home/ptyser/non_existant
Speed: 100, half duplex
Using eTSEC1 device
TFTP from server 10.52.0.62; our IP address is 10.52.253.79
^^^^^^^^^^ CORRECT
Filename '/home/ptyser/non_existant'.
^^^^^^^^^^^^^^^^^^^^^^^^^ CORRECT
Load address: 0x100000
Loading: *
TFTP error: 'File not found' (1)
Starting again
eTSEC2: No link.
Using eTSEC1 device
TFTP from server 10.52.0.33; our IP address is 10.52.253.79
^^^^^^^^^^ WRONG
Filename '10.52.0.62'.
^^^^^^^^^^ WRONG
Loading: *
Starting again
TftpStart() was modified to not modify the 'BootFile' string.
Ignore IP packets which have the "more fragments" flag bit
set. This flag indicates the IP packet is fragmented and
must be ignored by U-Boot.
These defines were pulled from the "Add simple
IP/UDP fragmentation support" patch from Frank
Haverkamp <haver@vnet.ibm.com>.
This patch tries to ensure that phy interrupt pin
won't be asserted after booting. We experienced
following issues with current 88E1121R phy init:
Marvell 88E1121R phy can be hardware-configured
to share MDC/MDIO and interrupt pins for both ports
P0 and P1 (e.g. as configured on socrates board).
Port 0 interrupt pin will be shared by both ports
in such configuration. After booting Linux and
configuring eth0 interface, port 0 phy interrupts
are enabled. After rebooting without proper eth0
interface shutdown port 0 phy interrupts remain
enabled so any change on port 0 (link status, etc.)
cause assertion of the interrupt. Now booting Linux
and configuring eth1 interface will cause permanent
phy interrupt storm as the registered phy 1 interrupt
handler doesn't acknowledge phy 0 interrupts. This
of course should be fixed in Linux driver too.
Acked-by: Andy Fleming <afleming@freescale.com>
When CONFIG_SYS_HUSH_PARSER is defined network download
commands with 1 argument in the format 'tftp "/path/file"'
do not work as expected. The hush command parser strips
the quotes from "/path/file" which causes the network
commands to interpret "/path/file" as an address
instead of the intended filename.
The previous check for a leading quote in netboot_common()
was replaced with a check which ensures only valid
numbers are treated as addresses.
This code contains some non-ascii characters in comment lines and code.
Most editors do not display those characters properly and editing those
files results always in diffs at these places which are usually not required
to be changed at all. This is error prone.
So, remove those weird characters and replace them by normal C-style
equivalents for which the proper defines were already in the header.
Signed-off-by: Remy Bohmer <linux@bohmer.net>
The default DDR freq is 400MHz or 800M data rate,
the old settings is pure wrong for the default case.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Moved up the initialization of GD so C code like set_tlb() can use
gd->flags to determine if we've relocated or not in the future.
If the virtual address for CCSRBAR is the same after relocation but
the physical address is changing we'd end up having two TLB entries with
the same VA. Instead we new us the new CCSRBAR virt address + 4k as a
temp virt address to access the old CCSRBAR to relocate it.
The BR_PHYS_ADDR macro is useful on all machines that have local bus
which is pretty much all 83xx/85xx/86xx chips.
Additionally most 85xx & 86xx will need it if they want to support
36-bit physical addresses.
Add define used to determine if PCI1 interface is in PCI or PCIX mode.
Convert users of the old PORDEVSR_PCI constant to use MPC85xx_PORDEVSR_PCI1
Signed-off-by: Andy Fleming <afleming@freescale.com>
The current code will cause the creation of a 4GB window
starting at 0 if we have more than 4GB of RAM installed,
which overlaps with PCI_MEM space and causes pci_bus_to_phys()
to return erroneous information. Limit the size to 4GB - 1;
which causes the code to create one 2GB and one 1GB window
instead.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
Removed while(1) hang if memctl_intlv_ctl is set wrong.
Remove embedded tabs from strings.
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
since commit be0bd8234b9777ecd63c4c686f72af070d886517
tlb entry for socrates DDR SDRAM will be reconfigured
by setup_ddr_tlbs() from initdram() causing an
inconsistency with previously configured DDR SDRAM tlb
entry from tlb_table:
socrates>l2cam 7 9
IDX PID EPN SIZE V TS RPN U0-U3 WIMGE UUUSSS
7 : 00 00000000 256MB V 0 -> 0_00000000 0000 -I-G- ---RWX
8 : 00 00000000 256MB V 0 -> 0_00000000 0000 ----- ---RWX
9 : 00 10000000 256MB V 0 -> 0_10000000 0000 ----- ---RWX
This patch makes the presence of the DDR SDRAM tlb entry in
the tlb_table dependent on CONFIG_SPD_EEPROM to avoid this
inconsistency.
All mpc8548-based boards should implement the suggested workaround
to CPU 2 errata. Without the workaround, its possible for the
8548's core to hang while executing a msync or mbar 0 instruction
and a snoopable transaction from an I/O master tagged to make
quick forward progress is present.
we need TLB entry for DDR at !SPD case.
The DDR controller of 8548/8544/8568/8572/8536 processors
have the ECC data init feature, and the new DDR code is
using the feature, and we don't need the way with DMA to
init memory any more.
This patch fix the problem that only the [NB_DATAFLASH_AREA - 1] dataflash
partition can be defined to use the area to the end of dataflash size.
Now it is possible to have only one dataflash partition from 0 to the end
of of dataflash size.
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
