This updated defconfig following boards:
- Alt
- Gose
- Koelsh
- Lager
- Porter
- Silk
- Stout
- Blanche
This commit fixes HDMI output for BLANCHE board
Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com>
BLANCHE is development board based on R-Car V2H SoC (R8A7792)
This commit supports the following periherals:
- SCIF, Ethernet, QSPI, MMC
Building w/ GCC v5.2, the SD card access is broken due to invalid data
in the response command reconstructed at the end of
sh_sdhci_get_response().
Add a memory barrier between the two main steps of this function to
ensure the resp[] table content is consistent before bits reordering.
This fix has been tested Ok on Porter board rev1.0 using v2016.03
release.
Signed-off-by: Yannick Gicquel <yannick.gicquel@iot.bzh>
Salvator-x is an entry level development board based on
R-Car H3 SoC (R8A7795). This commit supports SCIF only.
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
Renesas R8A7795 is CPU with Cortex-a57.
This supports the basic register definition and GPIO and
framework of PFC.
This adds supporting R-Car Generation 3 (Gen3) as Renesas ARM64 SoC.
To common use of rcar-gen2-common directory in the R-Car SoCs, and change from
rcar-gen2-common to rcar-common.
This creates Kconfig of R-Car 32bit for Kconfig of R-Car 64bit (Gen3).
This can be used in the same way as other R-CAR serial setting.
Add MAINTAINERS entry.
Move form arch/arm/include/asm/arch-rmobile/ to arch/arm/mach-rmobile/include/mach/.
Move from arch/arm/cpu/armv7/rmobile/ to arch/arm/mach-rmobile/.
As printf calls may be executed quite early, we should avoid using any
BSS stored variables, since some boards put BSS in DRAM, which may not
have been initialised yet.
Explicitly mark those "static global" variables as belonging to the
.data section, to keep tiny-printf clear of any BSS usage.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Some CONFIG_ variables were recently renamed, but test/py wasn't updated
to match. This causes some tests to be skipped. Fix test/py so the tests
are run.
Fixes: 11636258981a ("Rename reset to sysreset")
Fixes: f1f9d4fac527 ("hush: complete renaming CONFIG_SYS_HUSH_PARSER to CONFIG_HUSH_PARSER")
MMC core expects (now) valid mmc->dev pointer.
During conversion in commit cffe5d86 not every driver was updated.
This patch fixes crash while accessing MMC on
boards using Qualcomm SDHCI controller.
Signed-off-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Commit 9262367 moves USB errata workaround into a C file. This
causes compiling error for kmcoge4 and kmlion1. To enable the
errata workaround, define CONFIG_USB_EHCI_FSL in common header.
Signed-off-by: York Sun <york.sun@nxp.com>
Cc: Ed Swarthout <Ed.Swarthout@nxp.com>
Cc: Sriram Dash <sriram.dash@nxp.com>
Fixes: 92623672f9d3 ("fsl: usb: make errata function common for PPC and ARM")
Return value of rtl_send_common propogates unmodified all the way
up to eth_send and further to API consumer if CONFIG_API is enabled.
Previously rtl_send_common returned number of bytes sent on success
which was erroneouly detected as error condition by API consumers
that checked for operation success by comparing return value with 0.
Switch rtl_send_common to use common convention: return 0 on success
and negative value for failure.
Cc: Stephen Warren <swarren@nvidia.com>
Signed-off-by: Oleksandr Tymoshenko <gonzo@bluezbox.com>
This patch fixes incorrect RPC packet layout caused by
'long' type size difference on 64 and 32-bit architectures.
Signed-off-by: Ralf Hubert <r.hubert@technisat.de>
This patch adds support for aquantia AQR106/107 PHY.
Signed-off-by: Mingkai Hu <mingkai.hu@nxp.com>
Signed-off-by: Gong Qianyu <Qianyu.Gong@nxp.com>
Commit 90b7fc924adf "net: designware: support phy reset device-tree
bindings" made DW GMAC driver dependent on DM_GPIO by unconditional
usage of purely DM_GPIO stuff like:
* dm_gpio_XXX()
* gpio_request_by_name()
But since that driver as of today might be easily used without
DM_GPIO (that's the case for Synopsys AXS10x boards) we're
shielding all DM_GPIO things by ifdefs.
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Sonic Zhang <sonic.zhang@analog.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
We want people using errnos for errors instead of -1, so make it easy
by always including the definition of all the errnos.
We have driver-model drivers for some of these now, so drop them.
Signed-off-by: Tom Warren <twarren@nvidia.com>
This seems to give the best performance, so let's use it always.
We have standard drivers for panels and backlights which can do most of the
work for us. Move the tegra20 LCD driver over to use those instead of custom
code.
This patch includes device tree changes for the nvidia boards. I have only
been able to test seaboard. If this patch is applied, these boards will
also need to be synced with the kernel, and updated to use display-timings:
- colibri
- medcom-wide
- paz00
- tec
Sync everything except the display panel, which will come in a future patch.
One USB port is left disabled since we don't want to support it in U-Boot.
The pmic framework uses errno_str() and this requires board that use it to
enable CONFIG_ERRNO_STR to avoid a build error. Update the header to provide
a NULL error message when CONFIG_ERRNO_STR is not defined, and fix the build
error.
This will show as "(null)" when U-Boot prints it.
Bring in a copyright for this file from cmd/pmic.c since this file was
submitted by the same author at around the same time. Also fix the missing
header guard.
On recent SoCs, tegra_pcie_phy_enable() isn't called; but instead
tegra_pcie_enable_controller() calls tegra_xusb_phy_enable(). However,
part of tegra_pcie_phy_enable() needs to happen in all cases. Move that
code to tegra_pcie_port_enable() instead.
For reference, NVIDIA's downstream Linux kernel performs this operation
in tegra_pcie_enable_rp_features(), which is called immediately after
tegra_pcie_port_enable(). Since that function doesn't exist in the U-Boot
driver, we'll just add it to the tail of tegra_pcie_port_enable() instead.
The value that should be programmed into the PADS_REFCLK register varies
per SoC. Fix the Tegra PCIe driver to program the correct values. Future
SoCs will require different values in cfg0/1, so the two values are stored
separately in the per-SoC data structures.
For reference, the values are all documented in NV bug 1771116 comment 20.
The Tegra210 value doesn't match the current TRM, but I've filed a bug to
get the TRM fixed. Earlier TRMs don't document the value this register
should contain, but the ASIC team has validated all these values, except
for the Tegra20 value which is simply left unchanged in this patch.
Waiting 30 seconds for the hpd to go high seems a bit much, especially
on headless boots. Lowering the timeout to 300ms.
Sending as RFC because frankly i don't know what a sensible timeout is
here, but 30 seconds is clearly not it :)
Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Dropped RFC tag:
The errata command is useless in SPL, so don't build it. This fixes
multiple build failures on PowerPC.
Cc: York Sun <york.sun@nxp.com>
The old dm "usb info" implementation has several issues:
1) NULL pointer deref when a bus has no children
2) Not showing usb devices on busses without an emulated root-hub (otg host)
3) Attempting to show devices on inactive busses
4) "usb info" Would cause some hosts to get re-probed something which only
"usb reset" should do
TL;DR: proper iterating over usb bus root devs is hard, use the helper
for it.
Reported-by: Bernhard Nortmann <bernhard.nortmann@web.de>
Iterating over usb-root devs and doing something for all of them is
a bit tricky with dm, factor out the proven usb_show_tree() for this
into a helper function.
Currently on attempt to use global_data.h in an assembly file following
will happen:
-------------------->8-----------------
./arch/arc/include/asm/global_data.h: Assembler messages:
./arch/arc/include/asm/global_data.h:11: Error: bad instruction 'struct arch_global_data{'
./arch/arc/include/asm/global_data.h:12: Error: junk at end of line, first unrecognized character is `}'
scripts/Makefile.build:316: recipe for target 'arch/arc/lib/start.o' failed
In this change we disable struct arch_global_data in ASM which fixes
the issue above.
Newer ARC toolchains don't support "-marchs" option any longer.
Instead "-mcpu=archs" should be used. What's also important older
toiolchains that support ARC HS cores will also happily accept
"-mcpu=archs" so that's a very safe move.
The Parrot Board is an evaluation board with an Allwinner R16 (assumed
to be close to an Allwinner A33), 4GB of eMMC, 512MB of RAM, USB host
and OTG, a WiFi/Bluetooth combo chip, a micro SD Card reader, 2
controllable buttons, an LVDS port with separated backlight and
capacitive touch panel ports, an audio/microphone jack, a camera CSI
port, 2 sets of 22 GPIOs and an accelerometer.
The DTS file is identical to the one submitted to the upstream kernel.
Signed-off-by: Quentin Schulz <quentin.schulz@free-electrons.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Commit b19236fd1 ("sunxi: Increase SPL header size to 64 bytes to avoid
code corruption") Added defines for MMC0 and SPI as boot identification.
After verifying on an OLinuXino Lime2 with NAND and eMMC, the expected
values have been confirmed and added to spl.h
Signed-off-by: Olliver Schinagl <oliver@schinagl.nl>
The switch to simple_printf was causing the SPL dram info to show as:
DRAM: u MiB
This fixes this by switching from %lu to %d for printing the DRAM size.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
