Add defconfig file to use plugin code.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Correct boot device macro according to kconfig entry
in common/Kconfig
Add plugin code for mx6ullevk.
Define CONFIG_USE_IMXIMG_PLUGIN in defconfig file to use plugin code.
If CONFIG_USE_IMXIMG_PLUGIN is selected, plugin.bin will be
generated under board/$(BOARDDIR)/.
Introduce USE_IMXIMG_PLUGIN Kconfig
Add mx7_plugin.S which calls boot rom setup function, generate the second ivt,
and jump back to boot rom.
Signed-off-by: Ye Li <ye.li@nxp.com>
Add mx6_plugin.S which calls boot rom setup function, generate the second ivt,
Signed-off-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Acked-by: Utkarsh Gupta <utkarsh.gupta@nxp.com>
Add plugin support for imximage.
Define CONFIG_USE_IMXIMG_PLUGIN in defconfig to enable using plugin.
Cc: Eric Nelson <eric@nelint.com>
Cc: Ye Li <ye.li@nxp.com>
Add a README to explain the steps for booting mx6sabresd in different ways:
1. Booting via Normal U-Boot (u-boot.imx)
2. Booting via SPL (SPL and u-boot.img)
3. Booting via Falcon mode (SPL launches the kernel directly)
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
Allow i.MX6Q Sabre SD to load the kernel and dtb via SPL in Falcon mode.
Based on the Falcon mode code for MX6 Gateworks Ventana board.
Declaring a CSF section makes the imximage tool increase the size of
data to be loaded by the BootROM and also adds a pointer to that CSF
section in the IVT header to the BootROM can check the signature.
Signed-off-by: Gary Bisson <gary.bisson@boundarydevices.com>
Selecting the proper options to enable the build of the HAB tools.
Note, this support is disabled by default, one will have to select
the SECURE_BOOT configuration through menuconfig to enable it.
See doc/README.mxc_hab for more details.
Also remove duplicate options from board config headers.
Cc: Stefan Agner <stefan.agner@toradex.com>
This commit "2bb014820c49a63902103bac710bc86b5772e843"
do some clean up to use the code in lib/time.c.
But usec2ticks is still being used by security related job ring code.
Bring back the function to avoid build break when CONFIG_FSL_CAAM
is defined.
The computation logic has been changed, using 64-bit variable
to ease the process, making it work on older (MX5) platforms.
Signed-off-by: Peng Fan <van.freenix@gmail.com>
Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
So the option can easily be selected through menuconfig.
Move FDT_FIXUP_PARTITIONS to Kconfig and cleanup existing
uses.
Move SYS_OS_BASE to Kconfig and cleanup existing
uses.
[trini: Also migrate a4m2k]
Move SPL_OS_BOOT to Kconfig and cleanup existing
uses.
We can only run this command if the sleep command is enabled and that
depends on CONFIG_CMD_MISC
Jon Master reports that QEMU refuses to load a U-Boot image built
with CONFIG_ARMV7_NONSEC, but without CONFIG_ARMV7_PSCI since
commit 5a3aae68c74e ("ARM: armv7: guard memory reserve for PSCI
with #ifdef CONFIG_ARMV7_PSCI").
It looks like only PSCI that needs the Secure stack, so move
the #ifdef to guard the whole of .secure_stack allocation in order
not to create the empty section.
Reported-by: Jon Masters <jcm@redhat.com>
Link: http://patchwork.ozlabs.org/patch/664025/
The fdt_path_offset() function is not inlined in upstream libfdt. Adjust
U-Boot's version to match.
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
This includes small changes to the following functions, from upstream
commit 6d1832c:
- fdt_get_max_phandle() (upstream commit 84e0e134)
- fdt_node_check_compatible (upstream commit 53bf130b)
- fdt_setprop_inplace_namelen_partial() to remove useless brackets and
use idx instead of index
- _fdt_resize_property() to use idx instead of index
- _fdt_splice() (upstream commit d4c7c25c)
It also includes various typo fixes in libfdt.h
Using pointer arithmetic to generate a pointer outside a known object is,
technically, undefined behaviour in C. Unfortunately, we were using that
in fdt_offset_ptr() to detect overflows.
To fix this we need to do our bounds / overflow checking on the offsets
before constructing pointers from them.
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Sometimes devicetree nodes and or properties are added out of the u-boot
console, maybe through some script or manual interaction.
The devicetree as loaded or embedded is quite small, so the devicetree
has to be resized to take up those new nodes/properties.
In original the devicetree was only extended by effective
4 * add_mem_rsv.
With this commit we can add an argument to the "fdt resize" command,
which takes the extrasize to be added.
Signed-off-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
Signed-off-by: Hannes Schmelzer <oe5hpm@oevsv.at>
eth-uclass.c expects DM-capable Ethernet adapters to implement ops->
read_rom_hwaddr(), or for some other mechanism to set pdata->enetaddr, or
for the user to set environment variable $usbethaddr. Without any of
these, it will refuse to initialize the device since no valid MAC address
is known. Implement this function for the smsc95xx driver.
With this feature implemented, there is no point smsc95xx_init_common()
re-reading the MAC address from ROM, so ifdef out this code when DM_ETH
is enabled.
This allows (at least) the built-in Ethernet on the NVIDIA Harmony board
to operate again.
Fixes: 0990fcb77219 ("net: smsc95xx: Add driver-model support")
Add a NFS download test, based on TFTP test.
Tested on i.MX6 SabreLite board.
Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr>
Cc: Stephen Warren <swarren@wwwdotorg.org>
After any operation that downloads a file (e.g., pxe get, or dhcp), the
buffer containing the downloaded data is flushed. This is unnecessary
and annoying. Unnecessary, because
the network driver should already have fliushed the cache for the DMAed area,
and annoying because it generates a cache misalignment message.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
Acked-by: Heiko Schocher <hs@denx.de>
The call to flush cache on the transmit buffer was misplaced (for very
short packets) and asked to flush less than a cacheline.
Move the flush cache call to after a short packet has been padded
to minimum length (so the padding is flushed too), and round the size
up to a cacheline.
If mac-address is changed using "setenv ethaddr ...." command the new
mac-adress also must be written into the responsible ethernet driver.
Signed-off-by: Chris Packham <judge.packham@gmail.com>
On some boards these switches are wired directly into a SERDES
interface on another Ethernet MAC. Add the ability to specify
these kinds of boards using CONFIG_MV88E61XX_FIXED_PORTS which defines
a bit mask of these fixed ports.
The Marvell Link Street mv88e60xx is a series of FastEthernet switch
chips, some of which also support Gigabit ports. It is similar to the
mv88e61xx series which support Gigabit on all ports.
The main difference is the number of ports. Which affects the
PORT_COUNT define and the size of the mask passed to
mv88e61xx_port_set_vlan().
Other than that it's just a matter of adding the appropriate chip
IDs.
Cc: Joshua Scott <joshua.scott@alliedtelesis.co.nz>
Ethernet ports might be used in the kernel even if CPSW driver
is disabled at u-boot. So always set ethaddr and eth1addr
environment variable from efuse.
Retain usbnet_devaddr as it is required for SPL USB eth boot.
Signed-off-by: Roger Quadros <rogerq@ti.com>
Both ethernet ports can be used as CPSW ethernet (RMII mode)
or PRU ethernet (MII mode) by setting the jumper near the port.
Read the jumper value and set the pinmux, external mux and
PHY clock accordingly.
As jumper line is overridden by PHY RX_DV pin immediately
after bootstrap (power-up/reset), we have to use GPIO edge
detection to capture the jumper line status.
As u-boot doesn't provide any infrastructure for GPIO edge
detection, we directly access the GPIO registers.
source selection
cpsw driver supports only selection of phy mode in control module
but control module has more setting like RGMII ID mode selection,
RMII clock source selection. So ported to cpsw-phy-sel driver
from kernel to u-boot.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
In AM335x GP EVM, Atheros 8031 phy is used, enable the driver as
AM335x SoC RGMII delay mode has to be enabled in phy as mentioned
in the silicon errata Advisory 1.0.10
In the current driver implementation, config() callback is common
for AR8035 and AR8031 phy. In config() callback, driver tries to
configure MMD Access Control Register and MMD Access Address Data
Register unconditionally for both phy versions which leads to
auto negotiation failure in AM335x EVMsk second port which uses
AR8031 Giga bit RGMII phy. Fixing this by adding separate config
for AR8031 phy.
Reviewed-by: Sekhar Nori <nsekhar@ti.com>
This adds support for internal delay on RX and TX on RGMII interface for the
AR8035 phy.
This is basically the same Linux driver do. Tested on a Zynq Zturn board (for
which u-boot support in is my tree; first patch waiting ML approval)
Signed-off-by: Andrea Merello <andrea.merello@gmail.com>
include/configs/ls1021aqds.h
include/configs/ls1021atwr.h
