2011-12-11USB: EHCI: Allow EHCI post-powerup configuration in board filesMarek Vasut
This patch allows USB to work on some hosts, which need additional frobing after the host was powered up via regular USB powerup sequence. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: mx51evk: add end enable USB host support on port 1Wolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: mx53loco: add end enable USB host support on port 1Wolfgang Grandegger
2011-12-11USB: MX5: Add MX5 usb post-init callbackMarek Vasut
This is useful for USB Transceivers init etc. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com>
2011-12-11USB: MX5: Abstract out mx51 USB pixmux configurationMarek Vasut
2011-12-11USB: MX5: add generic USB EHCI support for mx51 and mx53Wolfgang Grandegger
It's derived from ehci-mxc and uses the header files of the ehci-fsl interface. The callback board_ehci_hcd_init() has been introduced to allow for board-specific setup when USB is started. Signed-off-by: Wolfgang Grandegger <wg@denx.de> CC: Stefano Babic <sbabic@denx.de> CC: Remy Bohmer <linux@bohmer.net>
2011-12-11USB: MX5: add helper functions to enable USB clocksWolfgang Grandegger
Signed-off-by: Wolfgang Grandegger <wg@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Grandegger <wg@denx.de> Cc: Jason Liu <r64343@freescale.com> V2: Fix spacing in crm_regs.h
2011-12-11usb:gadget:s5p Enable the USB Gadget framework at GONILukasz Majewski
This commit enables support for USB Gadgets on the GONI reference target. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11usb:gadget:s5p USB Device Controller (UDC) implementationLukasz Majewski
This commit provides UDC driver support for Samsung's SoC family of processors. Signed-off-by: Lukasz Majewski <l.majewski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11ehci: speed up initializationVincent Palatin
According to EHCI specification v1.0, the controller should stabilize the power on a port at most 20 ms after the port power bit transition. So, we put this setting in the virtual descriptor corresponding field, (bPwrOn2PwrGood = 10 => 10 x 2ms = 20ms), this saves about 500ms at each controller initialization/enumeration. Signed-off-by: Vincent Palatin <vpalatin@chromium.org>
2011-12-11usb: add help for missing start subcommandVeli-Pekka Peltola
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11cosmetic: remove excess whitespace from usb command helpVeli-Pekka Peltola
2011-12-11usb: align usb_endpoint_descriptor to 16-bit boundaryStefan Kristiansson
The usb_endpoint_descriptor struct is 7 bytes large and is defined as an array (ep_desc[USB_MAXENDPOINTS]) in the usb_interface struct in include/usb.h This fact will result in that every odd index in that array will start at an uneven address, this in turn makes accesses to u16 wMaxPacketSize unaligned. Such accesses are illegal on the OpenRISC architecture (as well as other architectures) and will render a bus error. Setting the aligned(2) attribute on usb_endpoint_descriptor will force wMaxPacketSize to a 16-bit boundary. Signed-off-by: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
2011-12-11usbtty: init endpoints prior to startup eventsStefan Herbrechtsmeier
On some usb device controllers (pxa) the endpoint configuration must be programmed prior to enable it. Signed-off-by: Stefan Herbrechtsmeier <sherbrec@cit-ec.uni-bielefeld.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Remy Bohmer <linux@bohmer.net>
2011-12-11pxa: convert pxa27x_udc to use read and write functionsStefan Herbrechtsmeier
2011-12-11pxa: activate the first usb host port on pxa27x by defaultStefan Herbrechtsmeier
The pxa27x has 3 usb host ports. Activate all by default. Signed-off-by: Stefan Herbrechtsmeier <sherbrec@cit-ec.uni-bielefeld.de> CC: Marek Vasut <marek.vasut@gmail.com> CC: Remy Bohmer <linux@bohmer.net>
2011-12-11pxa: fix usb host register mismatchStefan Herbrechtsmeier
2011-12-11ehci-fsl: correct size of ehci caplengthWolfgang Grandegger
According to the EHCI specification the Capability Register Length has a size of 8 bits. Signed-off-by: Wolfgang Grandegger <wg@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org>
2011-12-11USB: Add usb_event_poll() to get keyboards working with EHCIMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Remy Bohmer <linux@bohmer.net>
2011-12-11USB: gadaget: add Marvell controller supportLei Wen
Signed-off-by: Lei Wen <leiwen@marvell.com>
2011-12-11USB: Fix complaints about strict aliasing in OHCI-HCDMarek Vasut
2011-12-11USB: Drop dead code from usb_kbd.cMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de>
2011-12-11USB: Rework usb_kbd.cMarek Vasut
* Support dynamic allocation of devices * Passing data via usb device privptr * Reorder functions to avoid forward declarations * Introduce generic polling mechanism to fix musb and ehci-hcd breakage due to using "extern new;" to access keyboard driver data! Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Remy Bohmer <linux@bohmer.net> Cc: Wolfgang Denk <wd@denx.de>
2011-12-11USB: Add functionality to poll the USB keyboard via control EPMarek Vasut
This allows the keyboard to avoid requests via Interrupt Endpoint altogether and run all requests via Control Endpoint. This uses the Get_Report request. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Remy Bohmer <linux@bohmer.net> Rebased on current code. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2011-12-11arm: add __aeabi_unwind_cpp_pr1() function to avoid linker complaintsWolfgang Grandegger
With the ELDK 5.1 (beta) "armv7a" toolchain I'm get the following build failure: $ ./MAKEALL mx51evk ... /opt/eldk-5.1/armv7a/sysroots/arm-linux-gnueabi/usr/lib/arm-linux- gnueabi/4.6.1/libgcc.a(bpabi.o):(.ARM.exidx+0x0): undefined reference to `__aeabi_unwind_cpp_pr1' make: *** [u-boot] Error 1 This patch fixes the issue similar to commit d442b6e7ad6a86e2fd0e6297291fe8872ff26fc6 but I don't know if it's general enough or if it does harm when using other toolchains. Signed-off-by: Wolfgang Grandegger <wg@denx.de>
2011-12-11post: fix compile issue for post tests on kirkwoodHolger Brunck
commit f31a911fe (arm, post: add missing post_time_ms for arm) enables get_ticks and get_tbclk for all arm based boards, but kirkwood has currently no implementation for this. So undefine this for kirkwood boards. Signed-off-by: Holger Brunck <holger.brunck@keymile.com> cc: Heiko Schocher <hs@denx.de> cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-12-10sandbox: fix compiling of cpu/os.cAndreas Bießmann
U-boot itself generally builds with -nostdinc. This is because the bootloader needs to be completely standalone. In the sandbox arch though, we need a little bit of code to glue the u-boot world to the host operating system, and we need to be able to access the host libc's headers in order to do so. Currently, we're using -I/usr/include to workaround the global -nostdinc, but that doesn't work for everyone and for all headers. Instead, let's filter out -nostdinc when building the os.c code. Without this patch, some distros hit errors such as: ---8<--- In file included from /usr/include/fcntl.h:27:0, from os.c:22: /usr/include/features.h:323:26: fatal error: bits/predefs.h: No such file or directory --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add timer simulationMatthias Weisser
Making sleep command work Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10sandbox: Add improved RAM simulationMatthias Weisser
Using mmap to allocate memory from the OS for RAM simulation we can use u-boot own malloc implementation. Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Matthias Weisser <weisserm@arcor.de> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-12-10post/post.c: Use lldiv for 64-bit divisionsChristian Riesch
Signed-off-by: Christian Riesch <christian.riesch@omicron.at> Cc: Tom Rini <trini@ti.com> Cc: Heiko Schocher <hs@denx.de> Cc: Wolfgang Denk <wd@denx.de>
2011-12-10arm, davinci: Use lldiv for the 64-bit divisions in timer.cChristian Riesch
2011-12-10ARM: convert "omap730p2" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Dave Peverley <dpeverley@mpc-data.co.uk> Acked-by: Tom Rini <trini@ti.com>
2011-12-10board/ti/omap730p2/flash.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: flash.c: In function 'flash_get_offsets': flash.c:122:10: warning: variable 'pOrgDef' set but not used [-Wunused-but-set-variable] flash.c: In function 'flash_erase': flash.c:263:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:439:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Dave Peverley <dpeverley@mpc-data.co.uk> Acked-by: Tom Rini <trini@ti.com>
2011-12-10ARM: convert "omap16xx" boards to boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kshitij Gupta <kshitij@ti.com> Acked-by: Tom Rini <trini@ti.com>
2011-12-10board/ti/omap1610inn/flash.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: flash.c: In function 'flash_get_offsets': flash.c:139:10: warning: variable 'pOrgDef' set but not used [-Wunused-but-set-variable] flash.c: In function 'flash_erase': flash.c:280:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] flash.c: In function 'write_data': flash.c:456:6: warning: variable 'flag' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Tom Rini <trini@ti.com>
2011-12-10board/LaCie/edminiv2/edminiv2.c: Fix build warningWolfgang Denk
Fix: edminiv2.c: In function 'reset_phy': edminiv2.c:98:2: warning: implicit declaration of function 'mv_phy_88e1116_init' [-Wimplicit-function-declaration] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Acked-by: Simon Guinot <simon.guinot@sequanux.org>
2011-12-10ARM: convert "apollon" board to use boards.cfgWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net>
2011-12-10board/apollon/sys_info.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: sys_info.c: In function 'display_board_info': sys_info.c:260:16: warning: variable 'db_s' set but not used [-Wunused-but-set-variable] Also fix resulting warnings: sys_info.c:251:7: warning: unused variable 'db_ip' [-Wunused-variable] sys_info.c:250:7: warning: unused variable 'db_men' [-Wunused-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-12-10board/apollon/apollon.c: Fix GCc 4.6 build warnings.Wolfgang Denk
Fix: apollon.c: In function 'dram_init': apollon.c:188:29: warning: variable 'cpu' set but not used [-Wunused-but-set-variable] apollon.c:188:20: warning: variable 'rev' set but not used [-Wunused-but-set-variable] apollon.c:187:26: warning: variable 'size1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Kyungmin Park <kyungmin.park@samsung.com>
2011-12-10boards.cfg: sort listWolfgang Denk
2011-12-10fs/yaffs2/yaffs_guts.c: Fix GCC 4.6 compile warning (and bug)Wolfgang Denk
Fix: yaffs_guts.c: In function 'yaffs_GarbageCollectBlock': yaffs_guts.c:2761:6: warning: variable 'retVal' set but not used [-Wunused-but-set-variable] Here GCC actually detected a bug. The code was always returning OK instead of the previously set retrun code. Fix that. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: William Juul <wiljuul@cisco.com> Cc: Scott Wood <scottwood@freescale.com> Acked-by: William Juul <wiljuul@cisco.com>
2011-12-10drivers/net/at91_emac.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: at91_emac.c: In function 'at91emac_phy_init': at91_emac.c:244:20: warning: variable 'duplex' set but not used [-Wunused-but-set-variable] at91_emac.c:244:13: warning: variable 'speed' set but not used [-Wunused-but-set-variable] Use new debug_cond() to fix these warnings. In the result, anumber of inconsistent printf() formats are detected: at91_emac.c: In function 'at91emac_read': at91_emac.c:147:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c: In function 'at91emac_write': at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 2 has type 'struct at91_emac_t *' [-Wformat] at91_emac.c:157:2: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'short unsigned int *' [-Wformat] at91_emac.c: In function 'at91emac_recv': at91_emac.c:451:3: warning: format '%d' expects argument of type 'int', but argument 2 has type 'long unsigned int' [-Wformat] at91_emac.c:451:3: warning: format '%x' expects argument of type 'unsigned int', but argument 4 has type 'long unsigned int' [-Wformat] Fix these, too. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jens Scharsig <js_at_ng@scharsoft.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-12-10drivers/net/ne2000_base.c: Fix GCC 4.6 build warningsWolfgang Denk
Fix: ne2000_base.c: In function 'dp83902a_send': ne2000_base.c:282:7: warning: variable 'tmp' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_RxEvent': ne2000_base.c:376:5: warning: variable 'rsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_TxEvent': ne2000_base.c:513:5: warning: variable 'tsr' set but not used [-Wunused-but-set-variable] ne2000_base.c: In function 'dp83902a_ClearCounters': ne2000_base.c:550:17: warning: variable 'cnt3' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:11: warning: variable 'cnt2' set but not used [-Wunused-but-set-variable] ne2000_base.c:550:5: warning: variable 'cnt1' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
* 'master' of git://git.denx.de/u-boot-arm: M28: Cleanup memsize.o OOT build i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28 M28: Fix typo M28: Document that units has to be set to sectors on SD bootcard i.mx: i.mx6q: add the initial support for i.mx6q ARM2 board i.mx: mxc_gpio: add the i.mx6q support i.mx: add the initial support for freescale i.MX6Q processor i.mx: introduce the armv7/imx-common folder S5PC2XX: Rename S5pc2XX to exynos tegra2: Don't use board pointer before it is set up tegra2: Remove unneeded 'dynamic ram size' message tegra2: Remove unused low-level Tegra2 UART code tegra2: Remove unneeded config option tegra2: Remove unneeded boot code tegra2: Enable instruction cache arm: Move CP15 init out of cpu_init_crit() tegra2: Simplify tegra_start() boot path tegra2: Add arch_cpu_init() to fire up Cortex-A9 tegra2: Use new GPIO APIs in gpio_config_uart() tegra2: Add support for Ventana tegra2: Modify MMC driver to handle power and cd GPIOs tegra2: Move board_mmc_init into board files
2011-12-10Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-stagingWolfgang Denk
* 'agust@denx.de' of git://git.denx.de/u-boot-staging: Update pci_ids.h from current Linux sources omap: overo: Use ubifs instead of jffs2 for nand omap: TWL4030 Bump VMMC1 interface voltage from 3V to 3.15V
2011-12-10Merge branch 'master' of git://git.denx.de/u-boot-mpc85xxWolfgang Denk
* 'master' of git://git.denx.de/u-boot-mpc85xx: mpc85xx: Add board support for the eXMeritus HWW-1U-1A devices
2011-12-09M28: Cleanup memsize.o OOT buildMarek Vasut
The current way memsize.c is built just made a symlink into the directory with SPL and then compiled it like any other file there. This was bad as that broke the out-of-tree build. The new way introduced in this patch uses the standard spl/Makefile methods (CONFIG_SPL_LIBCOMMON_SUPPORT / CONFIG_SPL_LIBGENERIC_SUPPORT) to let files in common/ be built. Because common/Makefile says memsize.c is always built (SPL and non-SPL build), this fixes our issue with memsize.c out-of-tree build. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09i.MX28: Move SPL to arch/arm/cpu/arm926ejs/mx28Marek Vasut
This moves SPL to common location so it can be reused by multiple boards. Also, this commit adjusts M28 SoM to avoid breakage due to the move. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Detlev Zundel <dzu@denx.de> Cc: Stefano Babic <sbabic@denx.de>
2011-12-09M28: Fix typoMarek Vasut
2011-12-09M28: Document that units has to be set to sectors on SD bootcardMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Wolfgang Denk <wd@denx.de>
