2008-07-31Add gzipped logo supportMark Jackson
The README file states that CONFIG_VIDEO_BMP_GZIP behaves as follows: If this option is set, additionally to standard BMP images, gzipped BMP images can be displayed via the splashscreen support or the bmp command. However, the splashscreen function *only* supports standard BMP images. This patch adds the documented gzip support. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-07-31Fix Atmel LCD controller endianess for AVR32 processorsMark Jackson
The Atmel lcd controller is used on Atmel's AT91 (little endian) and AVR32 (big endian) platforms. As such, the controller can handle both big and little endian memory. This patch fixes the driver for the AVR32 platform. Signed-off-by: Mark Jackson <mpfj@mimc.co.uk>
2008-07-31apollon: fix build out of treeJean-Christophe PLAGNIOL-VILLARD
2008-07-31Uncompressed images loaded to their start address shall set load_end tooGuennadi Liakhovetski
Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2008-07-318260: Making the use of gd->pci_clk dependant on the CONFIG_PCIMatvejchikov Ilya
Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-07-31PPC: Add pci_clk in the global_data for CPM2 processorsMatvejchikov Ilya
This patch adds pci_clk field to the global_data structure for the processors which have CPM2 module in case the CONFIG_PCI is defined. Signed-off-by: Matvejchikov Ilya <matvejchikov@gmail.com>
2008-07-31mpc85xx: Update linker scripts for Freescale boardsKumar Gala
* Move to using absolute addressing always. Makes the scripts a bit more portable and common * Moved .bss after the end of the image. These allows us to have more room in the resulting binary image for code and data. * Removed .text object files that aren't really needed * Make sure _end is 4-byte aligned as the .bss init code expects this. (Its possible that the end of .bss isn't 4-byte aligned) Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-31Fix compile warnings in dlmallocKumar Gala
The origional code was using on odd reference to get to the first real element in av_[]. The first two elements of the array are not used for actual bins, but for house keeping. If we are more explicit about how use the first few elements we can get rid of the warnings: dlmalloc.c: In function 'malloc_extend_top': dlmalloc.c:1971: warning: dereferencing type-punned pointer will break strict-aliasing rules dlmalloc.c:1999: warning: dereferencing type-punned pointer will break strict-aliasing rules dlmalloc.c:2029: warning: dereferencing type-punned pointer will break strict-aliasing rules ... The logic of how this code came to be is: bin_at(0) = (char*)&(av_[2]) - 2*SIZE_SZ SIZE_SZ is the size of pointer, and av_ is arry of pointers so: bin_at(0) = &(av_[0]) Going from there to bin_at(0)->fd or bin_at(0)->size should be straight forward. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-31ppc4xx: Fix W7OLMG compile problems by adding missing LM75 definesStefan Roese
2008-07-31cmd_bootm.c: Fix problem with '#if (CONFIG_CMD_USB)'Stefan Roese
A recent patch used '#if (CONFIG_CMD_USB)' instead of '#if defined(CONFIG_CMD_USB)'. This patch fixes this problem and makes common/bootm.c compile again. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Markus Klotzbuecher <mk@denx.de>
2008-07-31Remove unused I2C at apollon boardKyungmin Park
There are no I2C devices on this board. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-07-31Merge branch 'master' of /home/wd/git/u-boot/custodiansWolfgang Denk
2008-07-31Merge branch 'master' of git://git.denx.de/u-boot-avr32Wolfgang Denk
2008-07-30fsl_i2c: Use timebase timer functions instead of get_timer()Kumar Gala
The current implementation of get_timer() is only really useful after we have relocated u-boot to memory. The i2c code is used before that as part of the SPD DDR setup. We actually have a bug when using the get_timer() code before relocation because the .bss hasn't been setup and thus we could be reading/writing a random location (probably in flash). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-30Merge branch 'master' of git://git.denx.de/u-boot-mipsWolfgang Denk
2008-07-30Adder8xx: Fix CFG_MONITOR_LENFrank Svendsbøe
Due to increased space usage, U-Boot can no longer be stored in three sectors. The current U-Boot use just over three flash sectors (197k), and U-Boot will become corrupt after saving environment variables. This patch adds another 64k to CFG_MONITOR_LEN. Signed-off-by: Frank E. Svendsbøe <frank.svendsboe@gmail.com>
2008-07-30Add OneNAND IPL related files to gitignoreKyungmin Park
2008-07-30API: Teach the storage layer about SATA and MMC options.Rafal Jaworowski
Signed-off-by: Rafal Czubak <rcz@semihalf.com> Acked-by: Rafal Jaworowski <raj@semihalf.com>
2008-07-30API: Dump contents of sector 0 in the demo application.Rafal Jaworowski
2008-07-30API: Correct storage enumeration routine, other minor fixes in API storage area.Rafal Jaworowski
2008-07-30API: Fix compilation warnings in api_examples/demo.c.Rafal Jaworowski
2008-07-30Fix more printf() format warningsJean-Christophe PLAGNIOL-VILLARD
2008-07-30Fix remaining CFG_CMD_ define, ifdef and commentsJean-Christophe PLAGNIOL-VILLARD
2008-07-30Add include for config.h in command.h.Stefano Babic
Because the cmd_tbl_s structure depends on the configuration file, it must be assured that config.h is included before the structure is evaluated by the compiler. If this is not certain, it could happen that the compiler generates structures of different size, depending on the fact if the source file includes <config.h> before or after <command.h>. The effect is that u-boot crashes when tries to relocate the command table (for ppc) or try to access to the command table for other architectures. The problem can happen on board-depending commands. All general commands under /common are unaffected, because they include already config.h before command.h. Signed-off-by: Stefano Babic <sbabic@denx.de>
2008-07-30NAND: $(obj)-qualify ecc.h in kilauea NAND boot Makefile.Scott Wood
This fixes building out-of-tree. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-30Fix warnings if compiling with IDE support.Heiko Schocher
cmd_ide.c:827: Warnung: weak declaration of `ide_outb' after first use results in unspecified behavior cmd_ide.c:839: Warnung: weak declaration of `ide_inb' after first use results in unspecified behavior Signed-off-by: Heiko Schocher <hs@denx.de>
2008-07-30Removed support for the adsvix board.Adrian Filipi
Support for the adsvix was originally provided by Applied Data Systems (ADS), inc., now EuroTech, Inc. The board never shipped aside from some sample boards. Signed-off-by: Adrian Filipi <adrian.filipi@eurotech.com>
2008-07-30ARM: set GD_FLG_RELOC for boards skipping relocation to RAMRemy Bohmer
If CONFIG_SKIP_RELOCATE_UBOOT is set the flag GD_FLG_RELOC is usually never set, because relocation to RAM is actually never done by U-boot itself. However, several pieces of code check if this flag is set at some time. So, to make sure this flag is set on boards skipping relocation, this is added to the initialisation of U-boot at a moment where it is safe to do so. Signed-off-by: Remy Bohmer <linux@bohmer.net>
2008-07-30fsl-i2c: fix writes to data segment before relocationTimur Tabi
Prevent i2c_init() in fsl_i2c.c from writing to the data segment before relocation. Commit d8c82db4 added the ability for i2c_init() to program the I2C bus speed and save the value in i2c_bus_speed[], which is a global variable. It is an error to write to the data segment before relocation, which is what i2c_init() does when it stores the bus speed in i2c_bus_speed[]. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-07-30mips: Fix baudrate divisor computation on alchemy cpusWolfgang Ocker
Use CFG_MIPS_TIMER_FREQ when computing the baudrate divisor on alchemy cpus. Signed-off-by: Wolfgang Ocker <weo@reccoware.de> Signed-off-by: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp>
2008-07-24Merge branch 'format-warnings' of git://git.denx.de/u-boot-avr32Haavard Skinnemoen
2008-07-23spi flash: Fix printf() format warningsHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-23atmel_mci: Fix printf() format warningsHaavard Skinnemoen
2008-07-23avr32: Fix printf() format warningsHaavard Skinnemoen
2008-07-23avr32: asm/io.h needs asm/types.hHaavard Skinnemoen
map_physmem() takes a phys_addr_t as parameter. This type is defined in asm/types.h, so we need to include that file. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-07-20microblaze: Fix printf() format issuesMichal Simek
2008-07-20Remove unused code from lib_arm/bootm.cGururaja Hebbar K R
Signed-off-by: Gururaja Hebbar <gururajakr@sanyo.co.in>
2008-07-20tqm85xx: Demystify 'DK: !!!' commentDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-07-2083xx/85xx/86xx: Add LTEDR local bus definitionsDetlev Zundel
2008-07-20serial_xuartlite.c: fix compiler warningsRicardo Ribalda Delgado
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@uam.es> Acked-by: Grant Likely <grant.likely@secretlab.ca>
2008-07-20POST: Add disable interrupts in some of the missing CPU POST testsStefan Roese
Some CPU POST tests did not disable the interrupts while running. This seems to be necessary to protect this self modifying code. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-20ide: Use CFG_64BIT_LBA instead of CFG_64BIT_STRTOULStefan Roese
This is needed for boards that define CFG_64BIT_STRTOUL but don't define CFG_64BIT_LBA. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-20POST PPC4xx/spr IVPR only if PPC440Niklaus Giger
The SPR IVPR register is only present (as far as I know) for processors with a PPC440 core. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com> Acked-by: Stefan Roese <sr@denx.de>
2008-07-20Merge branch 'master' of git://git.denx.de/u-boot-ppc4xxWolfgang Denk
2008-07-18ppc4xx: Enable 64bit printf format on 440/460 platformsStefan Roese
This patch defines CFG_64BIT_VSPRINTF and CFG_64BIT_STRTOUL for all 440/460 platforms. This may be needed since those platforms support 36bit physical address space. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-18ppc4xx: Fix incorrect MODTx setup for some DIMM configurationsStefan Roese
This patch fixes a problem with incorrect MODTx (On Die Termination) setup for a configuration with multiple DIMM's and multiple ranks. Without this change Katmai was unable to boot Linux with DDR2 frequency >= 533MHz and mem>=3GB. With this patch Katmai successfully boots Linux with DDR2 frequency = 640MHz and mem=4GB. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-17cfi_flash: fix flash on BE machines with CFG_WRITE_SWAPPED_DATASebastian Siewior
This got broken by commits 93c56f212c [cfi_flash: support of long cmd in U-boot.] That command needs to be in little endian format on BE machines with CFG_WRITE_SWAPPED_DATA. Without this patch, the command 0xf0 gets saved on stack as 0x00 00 00 f0 and 0x00 gets written into the cmdbuf in case portwidth = chipwidth = 8bit. Cc: Alexey Korolev <akorolev@infradead.org> Cc: Vasiliy Leonenko <vasiliy.leonenko@mail.ru> Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
2008-07-15Prepare v1.3.4-rc1: Code cleanup, update CHANGELOG, sort Makefilev1.3.4-rc1Wolfgang Denk
2008-07-15Round the serial port clock divisor value returned by calc_divisor()Hugo Villeneuve
Round the serial port clock divisor value returned by calc_divisor() Signed-off-by: Hugo Villeneuve <hugo.villeneuve@lyrtech.com> Acked-by: Gerald Van Baren <vanbaren@cideas.com>
2008-07-15Fix DHCP protocol so U-Boot does not respond too earlyRobin Getz
on the network with it's offered IP number; it should not reply until after it has received a DHCP ACK message. Also ensures that U-Boot does it's DHCPREQUEST as broadcast (per RFC 2131). Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Acked-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
