2017-10-29checkpatch: Support wide stringsHeinrich Schuchardt
Allow prefixing typical strings with L for wide strings Patch originally by Joe Perches https://lkml.org/lkml/2017/10/17/1117 Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-29Merge git://git.denx.de/u-boot-videoTom Rini
2017-10-29exynos: video: fix typo in DisplayPort driverDongjin Kim
Signed-off-by: Dongjin Kim <tobetter@gmail.com> CC: Simon Glass <sjg@chromium.org> CC: Minkyu Kang <mk7.kang@samsung.com>
2017-10-29video/da8xx-fb: Cache-align memory allocationsNiko Mauno
Resort to malloc_cache_aligned() rather than malloc() which also removes 'CACHE: Misaligned operation at range' warnings. Signed-off-by: Niko Mauno <niko.mauno@vaisala.com>
2017-10-29efi_loader: Disable env_save() call on bootAlexander Graf
With the introduction of EFI variable support, we also wanted to persist these EFI variables. However, the way it was implemented we ended up persisting all U-Boot environment variables on every EFI boot. That could potentially lead to unexpected side effects because variables that were not supposed to be written to persisted env get written. It also means we may end up writing the environment more often than we should. For this release, let's just disable EFI variable persistence and instead implement it properly for the next one. Reported-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Fixes: ad644e7c182 ("efi_loader: efi variable support") Signed-off-by: Alexander Graf <agraf@suse.de> Acked-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-10-27Merge git://git.denx.de/u-boot-fsl-qoriqTom Rini
2017-10-27armv8: sec_firmware: Add support for loadables in FITSumit Garg
Enable support for loadables in SEC firmware FIT image. Currently support is added for single loadable image. Brief description of implementation: Add two more address pointers (loadable_h, loadable_l) as arguments to sec_firmware_init() api. Create new api: sec_firmware_checks_copy_loadable() to check if loadables node is present in SEC firmware FIT image. If present, verify loadable image and copies it to secure DDR memory. Populate address pointers with secure DDR memory addresses where loadable is copied. Example use-case could be trusted OS (tee.bin) as loadables node in SEC firmware FIT image. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: layerscape: Allocate 66 MB DDR for secure memorySumit Garg
Change DDR allocated for secure memory from 2 MB to 66 MB. This additional 64 MB secure memory is required for trusted OS running in Trusted Execution Environment using ARMv8 TrustZone. Signed-off-by: Sumit Garg <sumit.garg@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: ls1088aqds: Enable USB command on QDS for qspi-bootRan Wang
Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com> Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: ls1088ardb: Enable USB command RDB qspi-bootRan Wang
Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Signed-off-by: Amrita Kumari <amrita.kumari@nxp.com> Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27arm: layerscape: Remove CONFIG_USB_MAX_CONTROLLER_COUNTRan Wang
Because COMFIG_DM_USB has been enabled and will not use it anymore. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27usb: host: Move CONFIG_XHCI_FSL to KconfigRan Wang
use Kconfig to select xhci accordingly. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27arm64: layerscape: Move CONFIG_HAS_FSL_XHCI_USB to KconfigRan Wang
Use Kconfig to select QE-HDLC and USB pin-mux. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: ls1088aqds: Change phy mode to PHY_INTERFACE_MODE_RGMII_IDAshish Kumar
Since TX delay is now enabled only in PHY_INTERFACE_MODE_RGMII_ID PHY_INTERFACE_MODE_RGMII_TXID. These change where introduced in phy driver in commit 05b29aa0cb68 ("net: phy: realtek: fix enabling of the TX-delay for RTL8211F"). Signed-off-by: Ashish Kumar <Ashish.Kumar@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: configs: ls1012a: correct the generic timer frequencyYuantian Tang
On ls1012a soc, core clock source frequency is fixed at 100Mhz. Generic timer frequency is core clock source divided by 4, which is 25Mhz. Signed-off-by: Tang Yuantian <andy.tang@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27armv8: ls1088: Move CONFIG_ENV_IS_IN_SPI_FLASH to defconfigAshish Kumar
2017-10-27driver: fsl-mc: use calloc instead mallocPrabhakar Kushwaha
Memory allocated via malloc is not guaranteed to be zeroized. So explicitly use calloc instead of malloc. Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27AT91: remove CONFIG_PMECC_INDEX_TABLE_OFFSETMasahiro Yamada
This macro is defined, but not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-27exynos: remove CONFIG_LCD_MENU_BOARDMasahiro Yamada
This macro is defined, but not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Minkyu Kang <mk7.kang@samsung.com>
2017-10-27net: remove CONFIG_NET_MULTIMasahiro Yamada
This macro is defined, but not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: York Sun <york.sun@nxp.com>
2017-10-27mpc85xx: xpedite550x: remove CONFIG_FDT_FIXUP_PCI_IRQMasahiro Yamada
2017-10-27AM33XX: etamin: remove CONFIG_DFU_MTDMasahiro Yamada
2017-10-27MX28: remove CONFIG_DEFAULT_SPI_CSMasahiro Yamada
2017-10-27exynos: remove CONFIG_CORE_COUNTMasahiro Yamada
2017-10-27omap4: sdp4430: match the #endif comment to #ifdefMasahiro Yamada
This comment creates a wrong entry in config_whitelist.txt. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-27SOCFPGA: remove CONFIG_AUTONEG_TIMEOUTMasahiro Yamada
2017-10-27ARC: remove CONFIG_ARC_UART_BASEMasahiro Yamada
2017-10-27sh7734: remove CONFIG_553MHZ_MODEMasahiro Yamada
This macro only appears in commented-out lines. It is not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-27mpc85xx: freescale: remove CONFIG_ADDR_STREAMINGMasahiro Yamada
2017-10-27omap4: sdp4430: remove CONFIG_4430SDPMasahiro Yamada
2017-10-27IMX: novena: remove CONFIG_I2C_MXCMasahiro Yamada
This macro is defined, but not referenced by anyone. I did not touch config_whitelist.txt - the CONFIG will be dropped by the next re-sync. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher<hs@denx.de>
2017-10-27i2c: fti2c010: remove unused/unmaintained driverMasahiro Yamada
CONFIG_SYS_I2C_FTI2C010 is not enabled by anyone. Commit 2852709676c8 ("dm: i2c: Add a note to I2C drivers which need conversion") prompted to convert this driver to DM before June 2017, but not converted yet. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher <hs@denx.de>
2017-10-27i2c: adi_i2c: remove left-over Blackfin I2C driverMasahiro Yamada
This driver was used by Blackfin boards, but Blackfin support is gone. There is no user of this driver. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Heiko Schocher <hs@denx.de>
2017-10-27Merge git://git.denx.de/u-boot-x86Tom Rini
2017-10-27sunxi: video: add LCD support to DE2 driverVasily Khoruzhick
Extend DE2 driver with LCD support. Tested on Pinebook which is based on A64 and has ANX6345 eDP bridge with eDP panel connected to it. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> [agust: rebased v5 on u-boot-video/master] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-10-27sunxi: video: split out PLL configuration codeVasily Khoruzhick
It will be reused in new DM LCD driver. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2017-10-27x86: acpi: Put sleepstates.asl to the common placeBin Meng
The supported sleep states are generic on Intel processors. Move the ASL definition to the common place. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: fsp: graphics: Add some notes about the graphics info hobBin Meng
On some platforms (eg: Braswell), the FSP will not produce the graphics info HOB unless you plug some cables to the display interface (eg: HDMI) on the board. Add such notes in the FSP video driver. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: braswell: cherryhill: Update dts for SPI lock downBin Meng
Intel Braswell FSP requires SPI controller settings to be locked down, let's do this in the chrryhill.dts and remove previous Kconfig option. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27spi: ich: Lock down controller settings if requiredBin Meng
Some Intel FSP (like Braswell) does SPI lock-down during the call to fsp_notify(INIT_PHASE_BOOT). But before SPI lock-down is done, it's bootloader's responsibility to configure the SPI controller's opcode registers properly otherwise SPI controller driver doesn't know how to communicate with the SPI flash device. Rather than passively doing the opcode configuration, let's add a simple DTS property "intel,spi-lock-down" and let the driver call the opcode configuration function if required by such FSP. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27Revert "x86: fsp: Configure SPI opcode registers before SPI is locked down"Bin Meng
This reverts commit 1e6ebee667da47fd3a87839a239a7574c66f5659. It's not appropriate to call the Intel SPI driver specific stuff in the FSP codes. We may add a simple DTS property "intel,spi-lock-down" and let the Intel SPI driver call these stuff instead. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-27x86: Fix ACPI resume dependency to MRC cacheBin Meng
In an S3 resume path, MRC cache is mandatory. Enforce the dependency in the Kconfig. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27env: x86: braswell: Set ENV_IS_IN_SPI_FLASH as defaultBin Meng
Imply does not work for a Kconfig choice. Update ENV_IS_IN_SPI_FLASH to be the default one for Intel Braswell. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: braswell: Fix unexpected crash during Linux kernel bootBin Meng
It was observed that when booting Linux kernel on Intel Cherry Hill board, unexpected crash happens quite randomly. Sometimes kernel just oops, while sometimes kernel throws MCE errors and hangs: mce: [Hardware Error]: Machine check events logged mce: [Hardware Error]: CPU 0: Machine Check: 0 Bank 4: c400000000010151 mce: [Hardware Error]: TSC 0 ADDR 130f3f2c0 mce: [Hardware Error]: PROCESSOR 0:406c3 TIME 1508160686 SOCKET 0 APIC 0 microcode 363 This looks like a hardware error per mcelog. After debugging, it seems turning off turbo mode on the processor does not expose this behavior, although U-Boot runs OK with turbo mode on. Suspect it is related to an errata of Braswell processor. To fix this, remove the Braswell cpu driver which does the turbo mode configuration, and switch to use the generic cpu-x86 driver. Also there is a configuration option in the FSP that turns on the turbo mode and that has been turned off too. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-10-27x86: galileo: Fix boot failureBin Meng
With latest codes on mainstream master, Intel Galileo board does not boot unfortunately. Git biset leads to b383d6c0 "bootstage: Convert to use malloc()". Disable bootstage support to make it boot again. The root cause needs to be investigated however. Fixes: b383d6c0 ("bootstage: Convert to use malloc()") Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-10-26Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2017-10-26video: add anx6345 DM driverVasily Khoruzhick
This is a eDP bridge similar to ANX9804, it allows to connect eDP panels to the chips that can output only parallel signal Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> [agust: fixed most checkpatch errors/warnings] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-10-26video: anx9804: split out registers definitions into a separate headerVasily Khoruzhick
This header will be used in anx6345 driver Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> [agust: moved header to drivers/video] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-10-26dm: video: bridge: add operation to read EDIDVasily Khoruzhick
Add an operation to read EDID, since bridge may have ability to read EDID from the panel that is connected to it, for example LCD<->eDP bridge. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
2017-10-26sunxi: setup simplefb for Allwinner DE2Icenowy Zheng
As the support of EFI boot on Allwinner H3 is broken, we still need to use simplefb to pass the framebuffer to Linux. Add code to setup simplefb for Allwinner DE2 driver. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
