Devices that used to have a whole disk FAT filesystem but got then
partitioned will most likely still have a FAT or FAT32 signature
in the first sector as this sector does not get overwritten by
a partitioning tool (otherwise the tool would risk to kill the mbr).
The current partition search algorithm will erronously detects such
a device as a raw FAT device.
Instead of looking for the FAT or FAT32 signatures immediately we
use the same algorithm as used by the Linux kernel and first check
for a valid boot indicator flag on each of the 4 partitions.
If the value of this flag is invalid for the first entry we then
do the raw partition check.
If the flag for any higher partition is wrong we assume the device
is neiter a MBR nor PBR device.
Signed-off-by: Egbert Eich <eich@suse.com>
The number 512 appears quite a bit in the mmc code. Add a constant for this
so that it can be used here and in other parts of the code (e.g. SPL code
which loads from mmc).
Reviewed-by: Vadim Bendebury <vbendeb@google.com>
Align some comments.
include/configs/m28evk.h
Change all "#define<TAB>" sequences into "#define<SPACE>"
Add "setexpr name gsub r s [t]" and "setexpr name sub r s [t]"
commands which implement substring matching for the regular
expression <r> in the string <t>, and substitution of the string <s>.
The result is assigned to the environment variable <name>. If <t> is
not supplied, the previous value of <name> is used instead. "gsub"
performs global substitution, while "sub" will replace only the first
substring.
Both commands are closely modeled after the gawk functions with the
same names.
Examples:
- Generate broadcast address by substituting the last two numbers of
the IP address by "255.255":
=> print ipaddr
ipaddr=192.168.1.104
=> setexpr broadcast sub "(.*\\.).*\\..*" "\\1255.255" $ipaddr
broadcast=192.168.255.255
- Depending on keyboard configuration (German vs. US keyboard) a
barcode scanner may initialize the MAC address as C0:E5:4E:02:06:DC
or as C0>E5>4E>02>06>DC. Make sure we always have a correct value:
=> print ethaddr
ethaddr=C0>E5>4E>02>06>DC
=> setexpr ethaddr gsub > :
ethaddr=C0:E5:4E:02:06:DC
- Do the same, but substitute one step at a time in a loop until no
futher matches:
=> setenv ethaddr C0>E5>4E>02>06>DC
=> while setexpr ethaddr sub > :
> do
> echo -----
> done
ethaddr=C0:E5>4E>02>06>DC
ethaddr=C0:E5:4E>02>06>DC
ethaddr=C0:E5:4E:02>06>DC
ethaddr=C0:E5:4E:02:06>DC
C0:E5:4E:02:06:DC: No match
=> print ethaddr
etc.
To enable this feature, the CONFIG_REGEX option has to be defined in
the board config file.
Simplify the argument checking for the "setexpr" command. This is
done mainly to make future extensions easier.
Also improve the help message for the one argument version of the
command - this does not "load an address", but a value, which in
this context may be a plain number or a pointer dereference.
When CONFIG_REGEX is enabled, the new option "-e" becomes available
which causes regular expression matches to be used. This allows for
example things like these:
- print all MAC addresses:
=> env grep -e eth.*addr
eth1addr=00:10:ec:80:c5:15
ethaddr=00:10:ec:00:c5:15
- print all variables that have at least 2 colons in their value:
=> env grep -v -e :.*:
addip=setenv bootargs ${bootargs} ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}:${netdev}:off
panic=1
ver=U-Boot 2013.04-rc1-00289-g497746b-dirty (Mar 22 2013 - 12:50:25)
etc.
Downloaded from http://slre.sourceforge.net/
and adapted for U-Boot environment.
Used to implement regex operations on environment variables.
Code size is ~ 3.5 KiB on PPC.
To enable this code, define the CONFIG_REGEX option in your board
config file.
Note: There are more recent versions of the SLRE library available at
http://slre.googlecode.com ; unfortunately, the new code has a heavily
reorked API which makes it less usable for our purposes:
- the return code is strings, which are more difficult to process
- we don't get any information any more which sub-string of the data
was matched by the given regex
- it is much more cumbersome to work with arbitrary expressions, where
for example the number of substrings for capturing are not known at
compile time
Also, there does not seem to be any real changes or improvements of
the functionality.
Because of this, we deliberately stick with the older code.
Note 2: the test code (built when SLRE_TEST is defined) was modified
to allow for more extensive testing; now we can test the regexp
matching on all lines on a text file (instead of the whole data in the
file as a single block).
Add options to "env grep" command:
-n : search only the envrironment variable names
-v : search only their values
-b : search both names and values (= default)
An option "--" will stop parsing options, so to print variables that
contain the striing "- " please use:
env grep -- "- "
Or to print all environment varioables which have a '-' in their name,
use:
env grep -n -- -
Also drop hstrstr_r() which is not needed any more.
The new code is way more flexible.
The output of "env grep" is unsorted, and printing is done by a
private implementation to parse the hash table. We have all the
needed code in place in hexport_r() alsready, so let's use this
instead. Here we prepare the code for this, without any functional
changes yet.
block_read returns unsigned long, so it doesn't make sense to check for
< 0. and neither does marking the header structure as const and then
casting away the constness to load data into it.
Also cleanup some unneeded pointer casting while we're at it.
Signed-off-by: Peter Korsgaard <peter.korsgaard@barco.com>
Reviewed-by: Tom Rini <trini@ti.com>
Enable these options to use FITs on sandbox.
This allows write of files from the host filesystem in sandbox. There is
currently no concept of overwriting the file and removing its existing
contents - all writing is done on top of what is there. This means that
writing 10 bytes to the start of a 1KB file will only update those 10
bytes, not truncate the file to 10 byte slong.
If the file does not exist it is created.
Add a new method for saving that filesystems can implement. This mirrors the
existing load method.
Enhance the source command to work with sandbox, by using map_sysmem() to
convert a ulong address into a pointer.
This allows passing of entire scripts to sandbox with the -c argument,
which is useful for testing. Commands can be delimited with a newline
or semicolon.
This reverts commit 3b73459ea3421e9f8c6c8c62e1d3fe458ca5bc56.
In practice it doesn't seem like a good idea to make the the working
FDT point to the control FDT. Now that we can access the control FDT
using the 'fdt' command, there is no need for this feature. Remove it.
If we have no FDT, don't attempt to read from it. This allows sandbox to
run without an FDT if required.
By using map_sysmem() we can get the fdt command to work correctly with
sandbox.
There is an existing fdt command to deal with the working FDT. Enhance this
to support the control FDT also (CONFIG_OF_CONTROL).
This conversion is required in a number of places in U-Boot. Add a
standard function to provide this feature, so we avoid all the different
variations in the way it is coded.
At present this only checks working_fdt, but we want to check other FDTs
also. So add the FDT to check as a parameter to fdt_valid().
With sandbox it is tricky to add an FDT to the image at build time (or
later) since we build an ELF file, not a plain binary, and the address
space of the whole U-Boot is not accessible in the emulated memory map
of sandbox.
Sandbox can read files directly from the host, though, so add an option
to read an FDT from a host file on start-up.
Add generic board support for sandbox. and remove the old board init code.
Select CONFIG_SYS_GENERIC_BOARD for sandbox now that this is supported.
In many cases, pointers to memory are passed around, and these pointers
refer to U-Boot memory, not host memory. This in itself is not a
problem.
However, in a few places, we cast that pointer back to a ulong (being
a U-Boot memory address). It is possible to convert many of these cases
to avoid this. However there are data structures (e.g. struct
bootm_headers) which use pointers. We could with a lot of effort adjust
the structs and all code that uses them to use ulong instead of pointers.
This seems like an unacceptable cost, since our objective with sandbox
is to minimise the impact on U-Boot code while maximising the features
available to sandbox.
Therefore, create a map_to_sysmem() function which converts from a
pointer to a U-Boot address. This can be used sparingly when needed.
At present the generic board error can occur when configuring U-Boot, or
during distclean, but this is incorrect. The existing autoconf.mk may come
from an earlier U-Boot configuration which is about to be overwritten.
Make the error conditional so that it will only be triggered when we are
actually building U-Boot.
This avoids a problem where the system is being reconfigured to remove
CONFIG_SYS_GENERIC_BOARD on an architecture that does not support it.
Currently this will print an error and require the manual removal of
include/autoconf.mk.
Devices in CONFIG_SYS_POST_I2C_IGNORES list may be absent
and the rule is not to report I2C POST failure for devices
in this list. Currently this doesn't work since probing for
these devices isn't done and thus they are not marked as
successfully probed. Ignore optional devices when checking
for devices that didn't respond.
Watchdog can be used on Microblaze, PPC and Zynq hw designs.
Fix microblaze soft reset function and disable
all cpu features. Especially disable caches because
IRQs were off by disable_interrupts().
Reported-by: John Williams <john.williams@xilinx.com>
Setup environment and enable netconsole.
Remove CONFIG_SYS_RESET_ADDRESS macro.
It was there from historical point of view
when soft reset was just jump to u-boot text start
(not used right now).
This is a MIME GnuPG-signed message. If you see this text, it means that
your E-mail or Usenet software does not support MIME signed messages.
The Internet standard for MIME PGP messages, RFC 2015, was published in 1996.
To open this message correctly you will need to install E-mail or Usenet
software that supports modern Internet standards.
Easier for using with patman.
Sometimes it might make sense to verify the written data to NOR flash.
This patch adds this feature. To enable this verify-after-write, you
need to define CONFIG_FLASH_VERIFY in your board config header.
Please note that this option is useless in nearly all cases,
since such flash programming errors usually are detected earlier
while unprotecting/erasing/programming. Please only enable
this option if you really know what you are doing.
This patch adds the fast booting LWMON5 derivat "lcd4_lwmon5".
Its a stripped down version of the full blown lwmon5 support,
without ECC, USB, POST and some other stuff. It used the newly
introduced SPL infrastrucure for SPL from NOR flash booting
on the PPC4xx.
By setting the environment variable "boot_os" to "yes", Linux
will be started from the SPL version. If not, the "normal"
U-Boot will be started.
This new make target "u-boot-img-spl-at-end.bin" consists of the
the real, full-blown U-Boot image and the U-Boot SPL binary
directly attached to it. The full-blown U-Boot image has the
mkimage header included, with its load-address and entry-point.
This will be used by the upcoming lwmon5 PPC440EPx derivate board
port.
This patch adds SPL booting support (NOR flash) for the
PPC4xx platforms.
This SPL booting (Falcon mode) will be used by the upcoming
lcd4_lwmon5 board port (lwmon5 variant).
With 'mtest' no longer a default command, we will have unused defines
which should be removed for the v2013.10 release.
As per doc/feature-removal-schedule.txt, remove CONFIG_CMD_MEMTEST from
default list of commands.
When crc32 is handled by the hash library, it requires the data to be in
big-endian format, since it reads it byte-wise. Thus at present the 'crc32'
command reports incorrect data. For example, previously we might see:
Peach # crc32 40000000 100
CRC32 for 40000000 ... 400000ff ==> 0d968558
but instead with the hash library we see:
CRC32 for 40000000 ... 400000ff ==> 5885960d
Correct this.
The git config parameter log.decorate is quite useful when working with git.
Patman, however can not handle the decorated output when parsing the commit.
To prevent this use the '--no-decorate' switch for git-log.
Quick manual fixup to merge the USB boot related defines and TPM related
defines.
include/configs/exynos5250-dt.h
When building host utilities, we include libfdt.h from the host, not from
U-Boot. This in turn brings in libfdt_env.h from the host, which can mess
up the types and cause a build failure, depending on the host environment.
To fix this, force inclusion of U-Boot's libfdt_env.h so that the types
are correct.
Another way to fix this is to use -nostdinc and -idirafter to ensure that
system includes are included after U-Boot ones. Unfortunately this means
that U-Boot's errno.h gets included instead of the system one. This in
turn requires a hack to errno.h to redirect things, so all in all the
solution in this patch is probably cleaner.
