Davinci: Table driven pinmux configuration
Add code to allow pinmux_config tables to be grouped and configured
as a single resource. This removes multiple calls to the pinmux
configuration code from board_init and allows pinmuxes to be
individually configured and added by data manipulation only.
All related #ifdefs can the be removed from board_init code and
since the compiler optimises away statics, #ifdefs can be reduced in
the data definitions as well.
Signed-off-by: Nick Thompson <nick.thompson@gefanuc.com>
A number of config files define the V_PROMPT macro for the
command-line prompt, only to immediately use that macro to define
CONFIG_SYS_PROMPT, making V_PROMPT entirely superfluous.
These regulators are not needed to start the kernel and only
cause "incomplete constraints" warnings from kernel, so don't
turn them on to save power.
Signed-off-by: Grazvydas Ignotas <notasas@gmail.com>
Not all boards have both LEDs hooked, so enabling both on
boards with single LED will just waste power. Make it
possible to choose LEDs by adding argument to
twl4030_led_init().
Using this turn on only LEDB for pandora, leave both LEDs
on for all other boards, as it was before this patch.
Prototype for gunzip/zunzip was only in lib_generic/gunzip.c and thus
repeated in every file using it. This patch moves the prototypes to
common.h and removes all prototypes distributed anywhere else.
Signed-off-by: Wolfgang Wegner <w.wegner@astro-kom.de>
This patch implements write support to usb device with raw partition.
It will be useful for filesystem write support to usb device from
u-boot in future.
Tested with writing kernel image to raw usb disk & booting with usb
read command into ram.
[Note: run usb part to get info about start sector & number of
sectors on a partition for usb write operation.]
Signed-off-by: Mahavir Jain <mjain@marvell.com>
Added USB host and device config for host (MSC, Keyboard) and
device (ACM) functionalities.
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
OMAP3EVM uses ISP1504 phy and so twl4030 related init is not required.
Submitted-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
Signed-off-by: Tom Rix <Tom.Rix@windriver.com>
The preferred serial output comes from the debug board.
When the debug board is disconnected, fall back on using
usbtty from the usb connector on the Zoom2 board.
This shows up as /dev/ttyACM0 in a linux host.
Zoom2 needs to use these declarations and the include directory is a
better place from them than in the middle of the driver directory.
It did not make sense to create a new file for just a couple of
lines so they were appended to the serial.h
The primary console of beagle is the serial header.
A secondary console is to use the usbtty. The user can set this
manually by doing
setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty
saveenv
usbtty will be usable by accessing the /dev/ttyACM0 on a linux host.
The primary console of zoom1 is the serial out from the jumpers
accessed by removing the back panel.
manually by doing
saveenv
This change adds the usb device support for musb.
Omap3 platform support added at the same level as davinci.
The interface for usbtty to use the musb device support was added.
Verified on omap3 beagle, zoom1 and zoom2.
The twl4030 provides a PHY device for connecting a link device,
like musb, to physical connection.
This change adds the twl4030 usb registers and functions for
initializing the PHY as required by omap3.
When developing usb device features, it is useful to print out
common usb structures.
The header files usb.h and usbdescriptors.h have the same nameed
structure definitions for
usb_config_descriptor
usb_interface_descriptor
usb_endpoint_descriptor
usb_device_descriptor
usb_string_descriptor
These are out right duplicates in usb.h
This one has extra unused elements
unsigned char bRefresh
unsigned char bSynchAddress;
These in usb.h have extra elements at the end of the usb 2.0
specified descriptor and are used.
The change is to consolidate the definition of the descriptors
to usbdescriptors.h. The dublicates in usb.h are removed.
The extra element structure will have their name shorted by
removing the '_descriptor' suffix.
So
usb_config_descriptor -> usb_config
usb_interface_descriptor -> usb_interface
For these, the common descriptor elements are accessed now
by an element 'desc'.
As an example
- if (iface->bInterfaceClass != USB_CLASS_HUB)
+ if (iface->desc.bInterfaceClass != USB_CLASS_HUB)
This has been compile tested on MAKEALL arm, ppc and mips.
Get tag directories from the $(__LIB) and also generate tag for .S files.
Signed-off-by: Li Yang <leoli@freescale.com>
make -C drivers/bios_emulator/
make[2]: Entering directory
`drivers/bios_emulator'
In file included from atibios.c:49:
biosemui.h:47:21: error: biosemu.h: No such file or directory
x86emu/decode.c:40:28: error: x86emu/x86emui.h: No such file or directory
Due to lack of proper CPPFLAGS being passed to .depend generation rule
The gd->cpu pointer is set to an address located in flash when the
probecpu() function is called while U-Boot is executing from flash.
This pointer needs to be updated to point to an address in RAM after
relocation has occurred otherwise Linux may not be able to boot due to
"fdt board" crashing if flash has been erased or changed.
This bug was introduced in commit
a0e2066f392782730f0398095e583c87812d97f2.
Reported-by: Ed Swarthout <Ed.Swarthout@freescale.com>
Tested-by: Kumar Gala <galak@kernel.crashing.org>
Tested on MPC8527DS.
Tested by: Ed Swarthout <Ed.Swarthout@freescale.com>
A previous Commit converted the LAN91C96 Ethernet driver to using the
CONFIG_NET_MULTI API, but did not include full board support. This patch
finishes the job.
Neither the MVBLUE nor its underlying architecture implement the
do_irqinfo() function which is required when CONFIG_CMD_IRQ is defined.
This change fixes the following MVBLUE compiler error:
-> ./MAKEALL MVBLUE
Configuring for MVBLUE board...
common/libcommon.a(cmd_irq.o):(.u_boot_cmd+0x24): undefined reference to `do_irqinfo'
make: *** [u-boot] Error 1
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
The support for this was silently dropped by a configuration
split during the merge of the imx27lite board support in commit
864aa034f3a0e10ce710e8bbda171df3cab59414 (cmd_mtdparts: Move to common
handling of FLASH devices via MTD layer).
Signed-off-by: Detlev Zundel <dzu@denx.de>
commit 60f61e6d7655400bb785a2ef637581679941f6d1 breaks compile with gcc by introducing __func__
instead of constant string "func" in the macro call but missed to change the macro.
Signed-off-by: Thomas Weber <weber@corscience.de>
fec_init() will only allocate fec->base_ptr if it is non-NULL. But
the cleanup routine on error will free the pointer without setting
it to NULL. This means that a later call to fec_init() would result
in using an invalid pointer.
Signed-off-by: John Ogness <john.ogness@linutronix.de>
This chip is equipped for example on the esd PMC-ETH2-GB board. So let's
add it to the list of supported chips to the e1000 driver.
Signed-off-by: Reinhard Arlt <reinhard.arlt@esd.eu>
Signed-off-by: Remy Bohmer <linux@bohmer.net>
This modification is NOT tested on any of the
platforms modified as I dont have them. please
help by testing+building+fixing
Signed-off-by: Nishanth Menon <nm@ti.com>
Enable the NET MULTI option and remove build warning
Tested: SDP3430
Make the lan91c96 driver capable of CONFIG_NET_MULTI
to be clean for the new arch, add a a lil detect function
Most of the formatting change was done to keep checkpatch
silent, but a few functions and #if 0ed code which
does not make sense for NET_MULTI have been removed
Now, use the lan91c96_initialize() function to init the driver
Currently, the last block of NAND devices can't be accessed. This patch
fixes this issue by correcting the boundary checking (off-by-one error).
Cc: Scott Wood <scottwood@freescale.com>
Commit c7190f02 (retain POR values of non-configured ACR, SPCR, SCCR,
and LCRR bitfields) moved the LCRR assignment to after relocation
to RAM because of the potential problem with changing the local bus
clock while executing from flash.
This change unfortunately adversely affects the boot time, as running
all code up to cpu_init_r can cause significant slowdown.
E.G. on a 8347 board a bootup time increase of ~600ms has been observed:
0.020 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz
0.168 RS: 232
0.172 I2C: ready
0.176 DRAM: 64 MB
1.236 FLASH: 32 MB
Versus:
0.016 CPU: e300c1, MPC8347_PBGA_EA, Rev: 3.0 at 400 MHz, CSB: 266.667 MHz
0.092 RS: 232
0.092 I2C: ready
0.096 DRAM: 64 MB
0.644 FLASH: 32 MB
So far no boards have needed the late LCRR setup, so simply revert it
for now - If it is needed at a later time, those boards can either do
their own final LCRR setup in board code (E.G. in board_early_init_r),
or we can introduce a CONFIG_SYS_LCRR_LATE config option to only do
the setup in cpu_init_r.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
We are using generic implementation of ffs. This should
be part of Simon's commit 0413cfecea350000eab5e591a0965c3e3ee0ff00
Here is warning message which this patch removes.
In file included from /tmp/u-boot-microblaze/include/common.h:38,
from cmd_mtdparts.c:87:
/tmp/u-boot-microblaze/include/linux/bitops.h:123:1: warning: "ffs" redefined
In file included from /tmp/u-boot-microblaze/include/linux/bitops.h:110,
/tmp/u-boot-microblaze/include/asm/bitops.h:269:1:
warning: this is the location of the previous definition
A typo caused the stack and malloc regions to overlap, which prevented
mem_malloc_init() from returning. This commit makes the memory layout match
the example described in include/configs/microblaze-generic.h
Signed-off-by: Graeme Smecher <graeme.smecher@mail.mcgill.ca>
Previously MAKEALL would always return a value of 0, even if 1 or more
boards did not compile. This change causes MAKEALL to return 0 if all
boards were able to build, otherwise 1.
This change also requires changing the script interpreter from sh to
bash to support bash's PIPESTATUS variable.
Recent commits 1a99de2cb4d08eb3bf9fb3f60a9d533150de8c0e and
6a590c5f5fd12cdd27f3153522acfac3854590e7 both fixed the same bug in the
same manner. Unfortunately git was "smart" enough to merge both changes
which resulted in some duplicate code.
Reordered code and comment a bit.
commit bd3784df94bfeca43fbf34094df9cb1bd3ecca3b deleted some unused
code in do_i2c_mw(), but missed to also remove the respective
commment. This patch fixes this.
add the following commands for the manroland boards:
CONFIG_CMDLINE_EDITING
CONFIG_COMMAND_HISTORY
CONFIG_AUTO_COMPLETE
lib_generic/zlib.c
This patch introduces a weak default function for post_hotkey_pressed(),
returning 0, for boards without hotkey support. The long-running tests
won't be started on those boards. This default function was implemented
in many board directories. By implementing this weak default we can
remove all those duplicate versions.
Boards with hotkey support, can override this weak default function
by defining one in their board specific code.
To update the real memory size in the memory node on the
uc101 and mucmc52 boards call fdt_fixup_memory() in
ft_board_setup().
Depending on offset, flash size and the number of bad blocks,
get_len_incl_bad may return a too small value which may lead to:
1) If there are no bad blocks, nand_{read,write}_skip_bad chooses the
bad block aware read/write code. This may hurt performance, but does
not have any adverse effects.
2) If there are bad blocks, the nand_{read,write}_skip_bad may choose
the bad block unaware read/write code (if len_incl_bad == *length)
which leads to corrupted data.
Signed-off-by: Daniel Hobi <daniel.hobi@schmid-telecom.ch>
