Signed-off-by: Tim Chick <tim.chick@mediatek.com>
PIC32 internal flash devices are parallel NOR flash divided into
number of banks to allow erase-programming in one while fetch and
execution continues on other. As the flash banks are memory mapped
stored code can be executed directly from flash (XIP), also there
is additional hardware logic to prefetch and cache contents to
improve execution performance. These flash can also be used to
store user data (like environment).
Flash erase and programming are handled by on-chip NVM controller.
Driver implemented driver model but MTD is not really support.
Signed-off-by: Purna Chandra Mandal <purna.mandal@microchip.com>
Microchip PIC32 has internal parallel flash (non-CFI compliant).
These flash devices do not support any identifier command so no
standard IDs. Added unique IDs to seperate these flash devices
from others supported by U-Boot.
This patch add board-level code and base DT for AP143.
Signed-off-by: Wills Wang <wills.wang@live.com>
[updated defconfig, enabled CONFIG_USE_PRIVATE_LIBGCC=y]
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This patch add board-level code and base DT for AP121.
This patch add a compatible spi driver for ath79 series SOC.
Reviewed-by: Thomas Chou <thomas@wytron.com.tw>
Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
This patch add support for ar933x serial.
This is a simple pinctrl driver, it just support uart and spi pin-mux now.
[fixed typo in commit subject line]
This patch enable work for qca953x SOC.
This patch enable work for ar933x SOC.
This patch add some common code for QCA/Atheros ath79 SOCs such as
DDR tuning, chip reset and CPU detection.
Signed-off-by: Stanislav Galabov <sgalabov@gmail.com>
Specifically tested on MIPS under QEMU (works with all combination of bit-ness and endian-ness)
QEMU so that IDE transfers work properly
for both 32-bit and 64-bit targets
Add a simple test which checks that a sandbox-emulated SD card can be used
correctly. This tests plumbing through the MMC stack's block-device
implementaion.
Enable building the MMC code for sandbox. This increases build
coverage for sandbox.
Add an emulation of an SD card to sandbox, allowing MMC to be used in tests.
The emulation is very simple, supporting only card detection and reading
test data.
Add support for enabling CONFIG_BLK with MMC. This involves changing a
few functions to use struct udevice and adding a MMC block device driver.
Binding an MMC device when CONFIG_BLK is enabled requires that a block
device be bound as a child of the MMC device. Add a function to do this.
The mmc_create() method will be used only when DM_BLK is disabled.
Add an unbind method also.
Implement the functions in mmc_legacy.c for driver-model block devices, so
that MMC can use driver model for these. This allows CONFIG_BLK to be enabled
with DM_MMC.
This driver will require generic MMC and block-device support in a future
commit. To avoid test errors, make this change now.
Instead of looking up the MMC device by number, just pass it in. This makes
it possible to use this function with driver model.
Return -EINVAL instead of -1 in this function, to provide a more meaningful
error.
At present the MMC subsystem maintains its own list of MMC devices. This
cannot work with driver model, which needs to maintain this itself. Move the
list code into a separate 'legacy' file. The core MMC code remains, and will
be shared with the driver-model implementation.
Update the existing drivers to set up this new pointer. This will be required
by the MMC uclass.
This member should be explained, since it is not obvious why it is needed.
Add a comment.
This is not needed since we can use the functions provided by the legacy
block device support.
Drop use of the table in part.c for this feature.
The block device uclass does not currently support selecting a particular
hardware partition but this is needed for MMC. Add it so that the blk API
can support MMC properly.
Avoid calling directly into the MMC code - use the new API call instead.
Bring this in for SPL so that we can use generic code for loading from
block devices.
The MMC block device is contained within struct mmc. But with driver model
this will not be the case. Add a function to obtain the block device. We
can later implement this for CONFIG_BLK.
Implement this method so that hardware partitions will work correctly with
MMC.
This function is defined after it is used. In preparation for making it
static, move it up a little. Also drop the printf() which should not appear
in a driver.
Mark the device name as allocated so that it will be freed correctly when the
device is unbound.
Some devices have a name that is stored in allocated memory. At present
there is no mechanism to free this memory when the device is unbound.
Add a device flag to track whether a name is allocated and a function to
add the flag. Free the memory when the device is unbound.
Due to code ordering the block devices are not numbered sequentially. Fix
this.
Enable building the systemace code for sandbox. This increases build
Add support for CONFIG_BLK to the systemace driver.
Move the systemace_get_dev() function below systemace_read() so that we can
avoid a forward declaration.
Add a function that automatically builds the device name given the parent
and a supplied string. Most callers will want to do this, so putting this
functionality in one place makes more sense.
Allow a devnum parameter of -1 to indicate that the device number should be
alocated automatically. The next highest available device number for that
interface type is used.
Enable building the SATA code for sandbox. This increases build coverage
for sandbox.
Add driver-model block-device support to the SATA implementation. This is
just a dummy implementation for now, since the SATA low-level API uses
numbered devices and that doesn't fit with driver model.
Enable building the SCSI code for sandbox. This increases build coverage
for sandbox.
Add driver-model block-device support to the SCSI implementation.
